The gpio mode of pin is configured when setting
direction and hence this call is no more required.
Change-Id: Ic36636535be7be9b799b9f6bf0c56aac89675e63
Add configurability support for i2s parameters accross all board.
ARM: tegra: board: add i2s params
files.
Signed-off-by: Ankit Gupta <ankitgupta@nvidia.com>
Change-Id: If58788b5126280b7e1dc8c66e9c96d0e71229b5e
Reviewed-on: http://git-master/r/111476
(cherry-picked from commit cac52867b0a0cad3b3c5bf46f08b0b94d0be2e02)
ARM: tegra: include: add configurability support for i2s params.
Add several variables for i2s configuration in platform data
structure.
Change-Id: Iea3930f308954471f170513234c2c02a8559ef98
Reviewed-on: http://git-master/r/111473
(cherry picked from commit 35e749770f6046fc82860f1152db2f5f579b9508)
Reviewed-on: http://git-master/r/118071
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Based on the kernel command line argument, this change will register the
UARTD for the tegra_uart driver, instead of the serial8250. Hence we can
put the harmony for the UART automation test.
Bug 991545
Change-Id: I5e637c73f4ce352fb615453121d14e2874e51a53
Signed-off-by: Ramalingam C <ramalingamc@nvidia.com>
Reviewed-on: http://git-master/r/106755
Reviewed-by: Mursalin Akon <makon@nvidia.com>
GVS: Gerrit_Virtual_Submit
Modify USB structures of platform data. Based on the new
platform data structures modifying the initialization in
board files.
Bug 887361
Change-Id: Ie6347a078c9a596a4debe21a353e127ddde35220
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/103597
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
fix typo in pre-power wifi code
Bug 956238
Change-Id: Iee794da508d39131e3166bba71b1c46c60d19a3b
Signed-off-by: Mursalin Akon <makon@nvidia.com>
Reviewed-on: http://git-master/r/96821
Reviewed-by: Allen Martin <amartin@nvidia.com>
power up WiFi chip, if Kconfig option
TEGRA_PREPOWER_WIFI is turned on.
Bug 956238
Change-Id: I26ef92fee30f8d18a47c3968b9b01b97e52a9382
Reviewed-on: http://git-master/r/90671
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Opt into the tps6586x registering the pm_power_off handler instead of
doing it ourselves.
Change-Id: I7859530c0c88de860c617a1a185f9cf6e8f046c5
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-on: http://git-master/r/83602
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Register tegra avp platform device from harmony board file.
Bug 932463
Change-Id: I83294a4f402ee0f16433998b9f756240c1ed07d4
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/79482
Reviewed-by: Shashank Sharma <shashanks@nvidia.com>
SOC Soundcard WM8903 Driver Needs tegra_i2s_device2 and bluetooth_dit_device
for different DIGITAL AUDIO INTERFACES(DAIs).
bug 921806
Change-Id: I3b81553d17de4321741d039af6d4d7506fbed8e6
Signed-off-by: Shashank Sharma(shashanks@nvidia.com)
Reviewed-on: http://git-master/r/73010
Enabled HDMI support for harmony.
Bug: 911662
Change-Id: I50d513dc0705fb64fc3946c1518b60b885d6194e
Reviewed-on: http://git-master/r/72611
Reviewed-by: Simone Willett <swillett@nvidia.com>
On Harmony during PNP of UART console, spurious interrupts are triggered
continuously. Hence kernel/irq/spurious.c will disable the interrupt.
To avoid the trigger of spurious interrupts, this patch disables the
modem status interrupts.
Bug: 909044
Change-Id: I00529ed16503d2c29f377e558b90f2c379e8b624
Reviewed-on: http://git-master/r/72751
implement pm_power_off with tps6586x's power off routine.
Change-Id: I20b818816982bad97daae1d8961aade4b6a0e6c4
Signed-off-by: Bill Huang <bilhuang@nvidia.com>
Reviewed-on: http://git-master/r/71139
enable suspend for harmony and set suspend mode to lp0
bug 911107
Change-Id: I59d412ab991fa86fedac12f0981bf93e26f8810a
Reviewed-on: http://git-master/r/70270
bug 911107
Change-Id: Iaf463f44d56942b181ae48b5b8e464e5b9164687
Reviewed-on: http://git-master/r/70965
enable power button for waking up harmony
bug 911107
Change-Id: Id69204a904cafa4186cbac201830ac6d1e5a81b1
Reviewed-on: http://git-master/r/70274
enable backlight and pwm device for harmony
bug 911107
Change-Id: Ib77d759f3248590a4a8d5b609068a3be97015b29
Reviewed-on: http://git-master/r/70286
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Enabling PCIE support in cardhu board.
Fixes bug: 637871
Reviewed-on: http://git-master/r/34474
(cherry picked from commit bde3e58d998b6e76934152219b8803327cea2fad)
Change-Id: I18c548b458ad3d17ec07d2ec5b16fd83897b44b1
Signed-off-by: Krishna Kishore <kthota@nvidia.com>
Reviewed-on: http://git-master/r/62072
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
The SDIO WiFi module requires power from external PMU and 1.2V regulator.
The module gets powered on if - (1) all power sources are enabled, and
(2) power (down) and reset (down) pins are enabled as per spec.
To enable mmc/SDIO driver to detect the WiFi hardware, the WiFi chip has
to be powered-up before mmc driver does probing. So, steps should be as
following: (1) required regulators are on, (2) power/reset of WiFi are
enabled, (3) mmc does probing. Later time, when WiFi driver module is
loaded and registers with SDIO, the SDIO driver knows which H/W the driver
has to be associated with.
Bug: 908534
Change-Id: I6510bced5fa9b8b3314c00180f2694903b23145c
Reviewed-on: http://git-master/r/#change,47808,patchset=2
Signed-off-by: Preetham Chandru <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/67121
Rebase-Id: Rbc628711479b187a90437bea94776066c7a58b54
This is necessary to use the Tegra accelerated device drivers.
Signed-off-by: Robert Morell <rmorell@nvidia.com>
Change-Id: I6c6f10f35654793b4fb713f4ac854f72640a5fef
Reviewed-on: http://git-master/r/58253
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: Rab19f5b8a98914619ff3d43f5a7eeeed0114f86a
This change includes the keymapping details for chicony keyboard and registers
the platform_device called "tegra-kbc" with all board resources corresponding
to KBC.
Change-Id: I4222914f09520b60882a447fc149fd1c352be037
Reviewed-on: http://git-master/r/57233
Rebase-Id: Rb233d2e2065fa590a6e776eb81ba205efc45442b
Registered USB3 host as harmony platform device.
Bug: 879944
Change-Id: I02e03c0978472972504d405dbbdc6f4e483fe2a3
Reviewed-on: http://git-master/r/56264
Rebase-Id: R126da51ba56a2c52d7f39a30a93e1a9c829beb8c
Added 4K page support.
Added 16-bit support
Added sys interfaces for various operations.
Added support for un-aligned page read.
Added setting timing values based on vendor-id/device-id.
Moved support for setting clock to platform from the driver.
Fixed OOB-Read/Write issues.
Original-Change-Id: Idf920c1cb0352dcda0282fa399d6c1f57a20736c
Reviewed-on: http://git-master/r/42347
Tested-by: Bhavesh Parekh <bparekh@nvidia.com>
Reviewed-by: Sandeep Trasi <strasi@nvidia.com>
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Rebase-Id: Refa8b8aa651f824a27513bfe663c57237dde2beb
The ALSA driver now configures most audio clocks as desired, so the board
has no need to manually configure them first.
Rebase-Id: R3face8d7c3a6f6e2486c86100f13387a8f43a52e
Without this, I see a huge number of SD timeouts when the root fs is on
an SD card in SD controller 4.
Change-Id: Iaa6dd74889a082a3f48cc571487d4680684715e3
Rebase-Id: R47ff3f22021a1c990b1bc43a40f40ee72e4f01b7
Tegra SDHCI devices were being registered through both harmony_devices[]
and board-harmony-sdhci.c. The latter is mostly duplicate code, so just
use the simpler logic already in board-harmony.c, and which is upstream.
Change-Id: Ib8c4e612541cbc299335f9770a463fccb384b9ce
Rebase-Id: R789721008a0cfb2c8faa03ee59c2b56f2c075c3e
board-harmony.c's I2C platform data was structured for the upstream driver,
but this branch contains the downstream driver. Fix the platform data to
match; pull it in from the chromeos-2.6.38 branch.
Also, modify any affected calls to i2c_register_board_info for the bus
numbering changes.
Change-Id: Ie1586455a2f5d46e497dcf594f7a83c4b70eda60
Rebase-Id: R6ebe439ccf53a5a0a0f0a3d826bade8bfa75a2bb
tegra_i2c_device* were listed in harmony_devices[], and manually registered
by harmony_i2c_init after platform data was initialized. Thus, they were
registered twice, and the first time was before platform data was
initialized. Remove the entries in harmony_devices[] so solve this.
Change-Id: Ibd699a68f1ae7eb22743a7fc8ae5c06a26a10f29
Rebase-Id: R8e17caacfb75958c51775efc7141024fb1ef415a
Change-Id: I6b39d27144a71a952f534b9066173be5a25ff049
Change-Id: I69082a1a2c1e5430fb8f9a186088aa45ec8a9715
Originally fixed by Will Deacon.
Change-Id: I2319d269f645766597100f91b2086fde4535c0fd
Signed-off-by: Colin Cross <ccross@google.com>
Change-Id: I1b456bb5634a75ae1dba2f5bd64ad71b8abdfc53
Signed-off-by: Gary King <gking@nvidia.com>
update harmony and ventana to use the common UDC definition, rather
than using the current duplicated definitions
Change-Id: I2e3aca674ab35305a0c516bd22e044382280d05e
register GART, pda_power, and OTG devices
Change-Id: I6dec5f765494cdc96f3395cf32fd962c87bf70b7
use the partition information provided on the kernel command line rather
than a fixed table that is subject to change.
Change-Id: I650f634bf49b8658debb75535e94f2a497ef3432
Signed-off-by: Colin Cross <ccross@android.com>
Change-Id: Ic14e8db00f2272de2f4ee4013bb3ab5c1951e7fe
Signed-off-by: Erik Gilling <konkers@android.com>
Every board file includes the same platform data definition
for the i2c-tegra driver's bus speed. Move the platform data
into devices.c, and remove it from all the board files.
Tested-by: Konstantin Sinyuk <kostyas@compulab.co.il>
Acked-by: Olof Johansson <olof@lixom.net>
Seaboard derivate Kaen has a GPIO to mute the headphone output. Add a field
to tegra_wm8903_platform_data so the board files can pass the GPIO number
for that to the ASoC machine driver.
Also, initialize this new field to a "not present" value for Harmony.
Soon, this machine driver will be updated to handle a number of Tegra boards
using the WM8903 codec. Rename the platform device in advance to reflect this.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
The audio driver will soon support more than just the Tegra Harmony board.
Rename the platform data header file and data type to reflect this.
Initialize the PMIC voltage regulators and provide the supply map for
PCI-e clock supply. The rest of the supplies should be added together
with the drivers that use them.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
CC: Mark Brown <broonie@opensource.wolfsonmicro.com>
This is the final patch to enable audio support on Harmony. It additionally
relies on the latest ASoC branch being merged in, which provides the header
defining the gpio_base field in the WM8903 platform data.
This patch is the portion of the audio-related setup that relies additionally
on the latest Tegra I2C driver being merged.
* Define platform data for WM8903 audio codec
* Register WM8903 as an I2C device
Register the base i2c busses on harmony. Devices coming at a later date,
but this allows for hand-probing of some of them at least.
This change includes everything required to enable audio on Harmony, except
those parts which rely on code not currently in Tegra's for-next branch, i.e.
except those parts which rely on merges of the Tegra I2C driver or latest
ASoC subsystem.
* Define GPIO names for audio-related GPIOs
* Set up platform data and platform device for ASoC machine driver
* Register audio-related platform devices
* Initialize audio-related clocks
* Correctly configure pinmux and GPIO enables for audio-related pins
This ensures they're kept in sync between platform_data definitions and
the GPIO table initialization.
Add the 3 sdhci devices that are available on Harmony as
platform devices. Two go to slots (one 4-lane, one 8-lane),
and one goes to onboard wifi.
Acked-by: Colin Cross <ccross@android.com>
Remove dead atag handling code for nvidia-specific tags.
