disable the usb1 vbus gpio in kernel and not depend on bootloader
to disable the vbus initially.
Currently, the kernel enables and disables the vbus when
the otg is configured to host mode, but when the system boots
with no cable connected the kernel relies on the bootloader
to turn the vbus off.
This CL removes that dependency.
Bug 1047048
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/#change,141970
(cherry picked from commit c3461995dd156968d766ec05879fd1097221ceb8)
Change-Id: I96c1f4b97a2cafdfd498b591647200d26298a43b
Reviewed-on: http://git-master/r/142839
Reviewed-by: Kiran Adduri <kadduri@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Bug 925547
Change-Id: I81f87cef3a9767d9bd60b72e33a23620392ab5fc
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/89736
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Bug 925547
Change-Id: Id4aaec9a847034ff16022123993433c9ce4754c3
Reviewed-on: http://git-master/r/76997
Reviewed-by: Simone Willett <swillett@nvidia.com>
Bug 825602
Change-Id: I32b09ec561e9be41660a64e6b2dda31b9cf5604d
Signed-off-by: Johnny Qiu <joqiu@nvidia.com>
Reviewed-on: http://git-master/r/83296
-move sensors defines to board header file.
-add defines for pca954x i2c mux instead of using direct i2c
bus number.
-cleanup board-ventana.h.
Bug 925547
Change-Id: I76a42b66f3a3fa0adbc8c06b2edb9fd006c7ae44
Reviewed-on: http://git-master/r/75689
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Bug 825602
Bug 834422
Bug 843573
Change-Id: I50ded8cafb228b216f4e3a899f50336c8450698b
Reviewed-on: http://git-master/r/66084
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
-Separate ac detection from battery driver
Bug 877456
Change-Id: I411ca707c58422075bdb27105bafc86a8de4e63e
Reviewed-on: http://git-master/r/54636
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R34bd7290f4c20c55bba8730b48fabe3fe0f566e1
Bug 868608
Bug 862023
Change-Id: I0f902098fc9cabd9d8c4962cf73c758df99a3199
Reviewed-on: http://git-master/r/49459
Tested-by: Sumit Bhattacharya <sumitb@nvidia.com>
Rebase-Id: Rea8335719e3f20cdb645d22c19da3d61d52d4eaf
Enabling power down when device suspends for USB1 and USB3.
Also added the platform data structure which is used
when USB suspends.
Bug 770041
Original-Change-Id: I8bbe3ee90451a4a193c832bd384558747fe25036
Reviewed-on: http://git-master/r/20030
Rebase-Id: R4e63ff13e831b3a278b4f195e0ff67097f87630b
Original-Change-Id: I58ad22bd0a78e705ba6d4941352c397c3cb2bd43
Reviewed-on: http://git-master/r/18539
Reviewed-by: Nathan Lord <nlord@nvidia.com>
Tested-by: Nathan Lord <nlord@nvidia.com>
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Reviewed-by: Pritesh Raithatha <praithatha@nvidia.com>
Rebase-Id: R9f25d092f95ad26da0bc564c6b412075db0040df
Added memory table for ventana
Enabled emc tables used for emc voltage scaling
Original-Change-Id: I2c46faf1eeea90b7f4097c4128dbec5d08888d13
Reviewed-on: http://git-master/r/14245
Reviewed-by: Amit Kamath <akamath@nvidia.com>
Tested-by: Amit Kamath <akamath@nvidia.com>
Rebase-Id: Rd26dd6d70024e8d38c5225113de5d526807d1a53
the gpios external to the chip are getting used in different
files and are not located in a cental location. there is a chance
people would step onto each other's gpios.
Original-Change-Id: I1ddf5b880c34105e4e11604c186be41e3cd9e5bc
Reviewed-on: http://git-master/r/14218
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Rebase-Id: R49969d0cc361d1cf85d48bc033a0d88832dc10a9
This code is off by default.
By default Ventana's buttons are GPIO pins.
But it is possible to connect it to kbc controller
(simple hardware rework needed).
This code might be used as a reference code for using kbc driver.
Original-Change-Id: Iaad4b8ca4b1bf6da1674e282f3bfb86349927fbd
Reviewed-on: http://git-master/r/9801
Tested-by: Victor Ryabukhin <vryabukhin@nvidia.com>
Rebase-Id: Rec5eaab861c97d7b363b796db96b8eb181d38782
Bug 749251
Original-Change-Id: I95db2d0327f4425de40e64b4ea70c0c76f908ab9
Reviewed-on: http://git-master/r/12465
Rebase-Id: R93eae47b9e270c19d4cc1adf164330ceb114b0c5
For Ventana board registering i2c board info for akm8975
compass on i2c bus4.
Original-Change-Id: Ie5a293699e69a9c94d89bb419db26ca81e5c4a91
Reviewed-on: http://git-master/r/7974
Rebase-Id: R10647df6bb1889c2a80cb4fc1d86dc48914bd624
register the tegradc0, tegradc1, grhost, pwm-backlight and carveout
devices
Change-Id: Ia61c0632470e571cc57279dc3b197ccd1fca80f0
Signed-off-by: Gary King <gking@nvidia.com>
register I2C controllers, regulator consumers and the panjit
touchscreen platform_device
Change-Id: Ife13c0d86084f26c734dea2c358f8c4fd3e27a8e
