Tegra3 platform may boot with one of the predefined fixed PLLP
(peripheral PLL) output rates: 216MHz, 408MHz, or 204MHz. This
commit implements auto-detection of PLLP rate, and debug uart
configuration during kernel uncompressing.
Bug 928260
Change-Id: I435c228691191434a10847fdbccef048a8d507c7
Reviewed-on: http://git-master/r/75848
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/77293
On Tegra3 fixed PLLP output frequency has been set to 408MHz
(instead of 216MHz). Respectively changed:
- Tegra3 broads setting for UART, and audio clocks
- Tegra3 common clock setting for PLLP output dividers, SDMMC,
and system buses
- Tegra3 CPU backup configuration to guarantee safe backup at
any voltage
Bug 829081
Original-Change-Id: Ied0c75204ccb2e4a428f0b8a124f0f3e053aa386
Reviewed-on: http://git-master/r/34813
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: Rb9a445970ed83922394a24a732372c5541d8ef47
Original-Change-Id: I2ffeaf6f8dfeb279b40ca6f69f6c9157401a746a
Rebase-Id: Rd8ebde470ad475b826857413018a2da8e1fdea25
Bug 764354
Original-Change-Id: I8a390eb4dae87dceacb97461f23d13554868b046
Reviewed-on: http://git-master/r/12228
Tested-by: Scott Williams <scwilliams@nvidia.com>
Original-Change-Id: I8e6b8303898796419fb5a759cd16edff9aeac081
Rebase-Id: R2866240384c6c24f46bd7ef54bc3dc9140d9e96b
This reverts commit a8ba61048eb502231d9cd7cd20f4223941c9510f.
UART enable request should be handled by bootloader.
bug 775099
Original-Change-Id: Ide7edf12daba80f831918e6e2d6e253667cf4820
Reviewed-on: http://git-master/r/21330
Tested-by: Peter Zu <pzu@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Rebase-Id: Raa0209404bdf47bda56c8a6de7c59f0a4761e687
Signed-off-by: Colin Cross <ccross@android.com>
v2: Fixes from Mike Rapoport
- remove unused header files (mach/dma.h and mach/nand.h)
- remove tegra 1 references from Makefile.boot
v2: fixes from Russell King
- remove mach/io.h include from mach/iomap.h
- fix whitespace in Kconfig
v2: from Colin Cross
- fix invalid immediate in debug-macro.S
v3:
- allow selection of multiple boards
Signed-off-by: Erik Gilling <konkers@android.com>
