cleanup of unwanted fuse related data as
a part of migration of fuse driver
Bug 1380004
Change-Id: I78ff9f6b1d3a27ae0ba0369ad9692c40e9e24bfd
Signed-off-by: Shardar Shariff Md <smohammed@nvidia.com>
Reviewed-on: http://git-master/r/310037
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Change-Id: I13f3ff891510d2c868f609d507149b32183d34c5
Disable the the remainder of the silicon only features at
run time instead of the Kconfig file. This change covers
THERMAL_THROTTLE, EDP_LIMITS and DYNAMIC_PWRDET.
Change HZ to 100 for all pre-si configs, not just FPGA. We
cannot change this field at run time. A faster tick doesn't
help sim or Qt CPUs go faster.
This change is a part of the effort to enable runtime
platform detection and reduce compile-time conditionals.
Bug 1333554
Change-Id: I24a865bf192347e487c743fdae3a3369e3ba89d1
Signed-off-by: Jeff Smith <jsmith@nvidia.com>
Signed-off-by: Chetan Kumar N G <chetankumarn@nvidia.com>
Reviewed-on: http://git-master/r/264034
Reviewed-by: Alexander Van Brunt <avanbrunt@nvidia.com>
T12x powerdetect cell list populated
bug 1317298
Change-Id: Ie104f6df035467536ca40bee60d290cdca743ef3
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/246143
Reviewed-by: Daniel Solomon <daniels@nvidia.com>
Tested-by: Daniel Solomon <daniels@nvidia.com>
Reviewed-by: Mitch Luban <mluban@nvidia.com>
T14x specific power detect cells only must be used. The
implementation needs all supported power detect cells
specific to chip. If extra entries are declared for a
chip the initialization fails.
bug 1231612
bug 1236429
bug 1231668
Change-Id: Iffe8271c77f1b382972f29f20dc0a4094b270490
Reviewed-on: http://git-master/r/242233
(cherry picked from commit 11d6341368449513f9ba56ab868cf05ff0002300)
Reviewed-on: http://git-master/r/247140
- Power detect hv regulator entry added for dalmore and pluto
- mem_comp no iopower entry removed from T114 power detect table as
software cannot turn these off
Reviewed-on: http://git-master/r/133285
(cherry picked from commit bab3fda7e504e302db5cfbddc131b48c84a3c4f8)
Change-Id: Ifea4329cf4035d67b1f77897659abfe48b948678
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/143065
Reviewed-by: Simone Willett <swillett@nvidia.com>
Rebase-Id: R8d60adba573dda42c2e71c04e4d5b93996d49057
T11x powerdetect table updated
Change-Id: I19ba11015ae80b6c715d35b78e8743b2a6ed8da1
Reviewed-on: http://git-master/r/131474
Rebase-Id: R1aec12a178c3f5e5b9d8755b18dd32e8e26d2d28
Power detect and no io power chart updated for T11x
bug 1039236
Change-Id: Id669d994cc6ec140c53f4c0a5adeb9473fea7126
Reviewed-on: http://git-master/r/128207
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Rebase-Id: Ref529ca2f7fe39c5706b5ef764e5ff265a06a7ae
Rebase-Id: R940fad74c7e91ef3d1d3d589a48064ccb7335541
Regulator notifier event chain may be called with several events OR'd
together, e.g. in drivers/regulator/core.c:
_notifier_call_chain(rdev, REGULATOR_EVENT_FORCE_DISABLE |
REGULATOR_EVENT_DISABLE,
Bug 913417
Change-Id: Ifba9860c1ee59c2fe2a4ee3c901e983912e07139
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Reviewed-on: http://git-master/r/69725
Rebase-Id: Rb83003f89e371b359616e000f3cef249554bb999
Change-Id: I31f2717327a627ad83e4cc2f083b71fd68fb1465
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/50221
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Rcaef7248cf06aa01c40b8e5eae13e3a20ed097d3
Modified dynamic IO pad configuration control to support SoC package
dependencies: set into "no-io-power state" IO pads that are not bonded
out on the particular package. Updated IO power detect table to account
for differences in Tegra2 and Tegra3 architecture.
Bug 853132
Original-Change-Id: I5f0aedfa784173cc37251ccf4e1dfb4d919db96e
Reviewed-on: http://git-master/r/42785
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Karan Jhavar <kjhavar@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Tested-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Rebase-Id: R46208845c32e25340de6b1cebfb6b617c6c7ce4d
Tegra IO pads are automatically re-configured when IO power level is
changed. Current code keeps auto-detection cells in default, active
state all the time. This change will allow turning off cells when IO
power is stable, and activate them only during power transitions.
In addition IO pads will be set into "no-io-power" state after the
respective regulator is disabled, and re-configured back for regular
operations before regulator is re-enabled.
Dynamic IO pad control introduced in this commit is still disabled
by default on all tegra platforms.
Bug 853132
Original-Change-Id: Ifc7bbe2ac34929c14f8f8e9feaa4290b78fe6cf6
Reviewed-on: http://git-master/r/42263
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R8b7c7863c1580816a2f3b28bdb3c228a97a18736
