Fix the build break when PM_SLEEP is not select that was
introduced by the restructuring of the reset handler code
for Trusted Foundations support.
Change-Id: I039d84f9244be52dd0a6a3b50d78d7189acb2ea8
Reviewed-on: http://git-master/r/68753
Tested-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Chris Johnson <cwj@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Add CONFIG_TRUSTED_FOUNDATIONS build option and calls to issue
SMCs to the TL secure monitor (used when needing to update state
not writable by non-secure code).
Make security/tf_driver an optional part of the build, which is
part of the TL framework to interact with secure services.
Bug 883391
Change-Id: I9c6c14ff457fb3a0c612d558fe731a17c2480750
Signed-off-by: Chris Johnson <cwj@nvidia.com>
Reviewed-on: http://git-master/r/65616
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Bug 862502
Change-Id: If70e54fb32ce14d5f13dde1d7fb4c1f1499a6722
Reviewed-on: http://git-master/r/47398
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Tested-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Ra77a54e6930692bca628a97bf1de10a30408cdef
- Add a single unified handler for all CPU resets that is copied to
IRAM.
- Add state information to direct the flow of execution through the
reset handler based on the reason a CPU was reset.
- Write the EVP CPU reset vector only once per cold/warm boot session.
- Prevent modification of the EVP CPU reset vector in Tegra3.
Bug 786290
Bug 790458
Change-Id: Ica6707f3514986ee914e73a2d9766a4e06ce2d29
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
DW: Split into logical changes
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R7b9859a83717e76c3c083bdde724bd5fef9ce089
