Added DFLL tune settings for new speedo ranges below 2180,
and 2180... 2336.
Bug 1442659
Change-Id: I8259d2e3de3ed5ca9b5a622700755711d82511f0
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/429137
Reviewed-by: Krishna Sitaraman <ksitaraman@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Karan Jhavar <kjhavar@nvidia.com>
Bug 1442659
Change-Id: Ie0f64869aa79cfd57ab31ca4096800bfb4e797a4
Reviewed-on: http://git-master/r/429136
update SoC therm caps table and vmax trips table
bug 1442659
Change-Id: I26cc83fd9f6fe2a2f806eed254e2d70ce00ff254
Signed-off-by: Ishwarya Balaji Gururajan <igururajan@nvidia.com>
Reviewed-on: http://git-master/r/427836
Reviewed-by: Harshada Kale <hkale@nvidia.com>
Tested-by: Harshada Kale <hkale@nvidia.com>
Added GPU Vmin -20mV offset for high SiMon grade on Tegra13 platforms.
Constructed the respective GPU DVFS table with offsets applied, and
SiMon notifier to switch between tables w/wo offset. Since no SiMon
grading is available only original DVFS table with no offset is used
for now.
Bug 1511506
Change-Id: I959ed2142e478b9693a5bc425ef2165b43210bab
Reviewed-on: http://git-master/r/425035
Reviewed-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Tested-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Specified DFLL tuning mask to toggle settings based on SiMon grade.
Changed defaults used before SiMon grade is determined after boot to
slower settings.
Bug 1511506
Change-Id: Ibcf25c418fe0fa10af0778599a701f11a9f90719
Reviewed-on: http://git-master/r/424908
Added CPU Vmin -20mV offset for high SiMon grade on Tegra13 platforms.
Since no SiMon grading is available this offset is not actually applied.
Bug 1511506
Change-Id: Ia7fa83db6a6ee003c0e1211c8a7fb9ac89630487
Reviewed-on: http://git-master/r/424907
Update temperature dependent vmin for A01 cpu table version p4v4
Bug 1458402
Change-Id: I4a2200eda67278b6d2e3f2696f25c4779169e162
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/401361
(cherry picked from commit a25df4eef43bb682d70b2897ce8e2a6f5bdd9b61)
Reviewed-on: http://git-master/r/421552
Update freq for DSI to 402M and sor to 162M
at 800mV. Update SoC dvfs revision to p4v1l.
Bug 1442659
Change-Id: I2f488d5d5bd2c0be577d4947f9f36d0c4a810596
Reviewed-on: http://git-master/r/415053
Reviewed-by: Riham Haidar <rhaidar@nvidia.com>
Tested-by: Riham Haidar <rhaidar@nvidia.com>
- Changed Tune1 parameter according to recent characterization results
- Made Tune0 selection forward looking: applied current settings to
possible future speedo ids (if any is introduced).
- Updated CPU DVFS version to p4v12.
Bug 1442659
Change-Id: I3430fc43a3ff045fd6fbcbfddbe5feda4671a727
Reviewed-on: http://git-master/r/419772
update sbus, host1x, mselect and sor0 clocks in
SoC dvfs table to version p4v10
Bug 1442659
Change-Id: Ifa0127c9750d89a88af3e41a94d67bebf528286b
Reviewed-on: http://git-master/r/413420
Reviewed-by: Mandar Padmawar <mpadmawar@nvidia.com>
Tested-by: Mandar Padmawar <mpadmawar@nvidia.com>
updat SoC dvfs table for c2/c3 bus and their clients
Bug 1442659
Change-Id: I6897a82acc4cdbf26324e6e4fd3819b61b5c1a0e
Reviewed-on: http://git-master/r/413458
update SoC dvfs tables for I/O peripherals
Bug 1442659
Change-Id: I9f96b131aa13b033b5db1941b7ffe04b0a5e9096
Reviewed-on: http://git-master/r/413411
update max freq to 918MHz and speedo_id to 2
for sku_fuse 0x83
Bug 1442659
Change-Id: Ie7c94baeb5769c8a271f94ba2442fd00183aad99
Reviewed-on: http://git-master/r/410384
Update max freq to 852Mhz for speedo_id 1
Bug 1442659
Change-Id: Ie4a08691963996e6ed7d988948cc9bd2d85614a0
Reviewed-on: http://git-master/r/409702
Bug 1492902
Bug 1442659
Change-Id: Id9e6114fa05e38d21f59fd34e1804abdb456f193
Reviewed-on: http://git-master/r/402658
Added CVB coefficients to account CPU Vmin dependency on speedo and
temperature. Implemented CVB equations to calculate Vmin thermal
profile.
Bug 1492902
Bug 1442659
Change-Id: Ib039df6807880d1714550bd6b770d2c4e46e8ac0
Reviewed-on: http://git-master/r/402657
On Tegra13 A02 silicon set CPU DFLL tuning parameters as a function
of chip speed.
Bug 1492902
Bug 1442659
Change-Id: I03a5a419c60ffa86a360c58222b93279f25e3145
Reviewed-on: http://git-master/r/402656
Keep the voltage dependency for A01 and A02 and remove for later
revisions.
Change-Id: If354f1bf2ddb5cca8d8db2b7d9a72ebe9f2f6d6b
Signed-off-by: Krishna Sitaraman <ksitaraman@nvidia.com>
Signed-off-by: Hridya <hvalsaraju@nvidia.com>
Reviewed-on: http://git-master/r/401094
update gpu dvfs tables to version p4v4
Bug 1442659
Change-Id: Ibbb10fc17ea5a3663759df85d9e657b29b1587dc
Reviewed-on: http://git-master/r/397260
Tested-by: Thomas Cherry <tcherry@nvidia.com>
soc dvfs version p4v7
Bug 1497005
Bug 1442659
Change-Id: I357db8a0c0417214a1a749cb1160ef5154a0933c
Reviewed-on: http://git-master/r/396661
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Chao Xu <cxu@nvidia.com>
Bug 1442659
Change-Id: I79941c7ca11344ec924663f5f1d24e08c44afb02
Reviewed-on: http://git-master/r/383443
Reviewed-by: Alexander Van Brunt <avanbrunt@nvidia.com>
Tested-by: Alexander Van Brunt <avanbrunt@nvidia.com>
Bug 1442659
Change-Id: I4d04b30bb278468abadeddf605798e2cd7fb29a1
Reviewed-on: http://git-master/r/382228
Reviewed-by: Seema Khowala <seemaj@nvidia.com>
Update max pll_m rate to 1200MHz to support
1200MHz emc freq for loki
Bug 1452529
Change-Id: I8fcfe4ffd9bb423d78888911882ce474a4d9988d
Signed-off-by: Ray Poudrier <rapoudrier@nvidia.com>
(cherry picked from commit b8a928a34bc216e7fac36c983c13df2507ce3d6a)
Reviewed-on: http://git-master/r/370215
Signed-off-by: siddardha naraharisetti <siddardhan@nvidia.com>
Reviewed-on: http://git-master/r/379628
Reviewed-by: David Dastous St Hilaire <ddastoussthi@nvidia.com>
Tested-by: David Dastous St Hilaire <ddastoussthi@nvidia.com>
Reviewed-by: Tao Xie <txie@nvidia.com>
When calculating VDD_CORE floor imposed by VDD_CPU took into account
that in dfll-mode VDD_CPU rail will be at/above current thermal floor
however low is voltage specified in DVFS table for target frequency.
Set margin above thermal floor to 30mV. Lower dependency constraint at
VDD_CPU level 900mV from 870mV to 830mV (this limit was statically set
higher than necessary because 900mV is a cold floor, and thermal floor
slack was not accounted in resolution algorithm until this commit).
Bug 1461646
Change-Id: I11e00e7077496150e86f5ef56efede40febba1e9
Reviewed-on: http://git-master/r/379284
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Change-Id: I9ad911ea2fc438b6863e785bd9a390f2ea639c79
Reviewed-on: http://git-master/r/373097
Update temperature dependent vmin for cpu table version p4v4
Change-Id: If20feaf65847e9682f9d92f6ad2100afd7d541a3
Reviewed-on: http://git-master/r/377956
Tested-by: Chao Xu <cxu@nvidia.com>
First soc dvfs post silicon table update. Version p4_v3
Change-Id: I2850ad3806cf89eb1357946b42280de0e7f8918c
Reviewed-on: http://git-master/r/375067
Add PLLX based table for A01 and
CLDVFS based table for A02
Change-Id: Ibbec5b5d0dc9b43f6e4447791675a7226c732419
Reviewed-on: http://git-master/r/375803
Bug 1461646
Change-Id: I84e9d3f5a2cc17451f32c682a1fcd10680a7c838
Reviewed-on: http://git-master/r/369112
Adding first post silicion gpu dvfs table (version p4_v3)
Bug 1442659
Change-Id: I3bf09c4134a3bb3afe5de4a49c3ecf11993025b5
Reviewed-on: http://git-master/r/375029
Add the A02 CPU DVFS table. Right now the A01 and A02 CPU DVFS tables
are identical except for the speedo_id. In the future the A02 CPU DVFS
table will be updated.
Bug 1455768
Change-Id: Ia7461e5aa09501413ef9cc0b8c979d5a6b78d472
Signed-off-by: Adeel Raza <araza@nvidia.com>
Reviewed-on: http://git-master/r/369014
Update sbus to operate at 1.0V or higher forcing vdd_core
to operate atleast at 1.0v
Change-Id: I0dd488fbe9f5683e79d0f16ff56a41221758c24c
Reviewed-on: http://git-master/r/356803
Reviewed-on: http://git-master/r/361715
Tested-by: Shashank Garg <sgarg@nvidia.com>
Update cpu cl-dvfs parameters with first post silicon dvfs table
Change-Id: I9cfc7afb4933d837e109d35d1569c7277c0e4235
Reviewed-on: http://git-master/r/355734
Reviewed-on: http://git-master/r/361712
As per recommendation from silicon validation team
Change-Id: I5f9ed90db05b7056cc5a3c9dc73df9ac00f4ed8c
Reviewed-on: http://git-master/r/360031
Reviewed-on: http://git-master/r/361709
Tested-by: Seema Khowala <seemaj@nvidia.com>
Change-Id: I959bbed9d926f7b5861610f1df1e5d3a53f2511f
Reviewed-on: http://git-master/r/355245
Reviewed-on: http://git-master/r/361684
Change-Id: Ic91fcb02474b4bfb28bcf943d5a2726cbdd760c7
Reviewed-on: http://git-master/r/355258
Reviewed-on: http://git-master/r/361682
Increase voltage for all PLLX entries by 100mV to fix boot issue
on slow and fast boards.
Change-Id: I35e3770eb5a6799f668a83247256072386da8c98
Reviewed-on: http://git-master/r/353432
Change-Id: I228ba5cc4f67c5ad4dac6b3810da454296930b6d
Reviewed-on: http://git-master/r/350004
gpu safe table has 50mV margin over T124 production SW setting.
Frequency limit was removed.
Bug 1394146
Bug 1426244
Change-Id: Id0eae3bd99efe38cc2a417217c45c6138e9e1795
Reviewed-on: http://git-master/r/347665
Adding safe cvb table for cpu with 20% margin.
Remove any limits on max cpu voltage.
Bug 1394146
Change-Id: Ic293bd51d08a502999b2f9eec51c67b19fff3f47
Reviewed-on: http://git-master/r/347173
Creating dvfs and speedo files separately for T132 and
reducing the max gpu speed to 252Mhz
Bug 1426244
Change-Id: Ie274b134d7704ff02560cb1658d4d1814a8487be
Reviewed-on: http://git-master/r/346662
Reviewed-by: Adeel Raza <araza@nvidia.com>
