Added kernel timer to track grading interval. Check timer expiration
flag in grading callback instead of reading and checking time directly.
It reduced some CPU cycles within each callback invocation.
Bug 1343366
Change-Id: I6ba901e34b737cae760ead944ee344722d2eb47c
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/400717
(cherry picked from commit 228c7221be7d39724f739b3dc563ce4c9722dc99)
Reviewed-on: http://git-master/r/407058
(cherry picked from commit f5ce03476dcc33950082a9a88be27d793a629a04)
Reviewed-on: http://git-master/r/410539
GVS: Gerrit_Virtual_Submit
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Change-Id: I52f134c896bab6a91556e2c2078e82ff4cab6d45
Reviewed-on: http://git-master/r/398600
(cherry picked from commit e2243720d0f3754a4ef772bec0ff3e9fcec62972)
Reviewed-on: http://git-master/r/403800
Bug 1343366
Change-Id: Ieedc742803f15947e1ab1f2d06436e0cb53b0440
Reviewed-on: http://git-master/r/388163
Added SiMon grading watch-dog timer for each domain. It is running
while domain grade is above zero. If WDT expires domain grade is reset
to default zero.
Since it is possible to modify grade concurrently by grading and WDT
callbacks, added domain grade lock to serialize grade updates in both
callbacks as well as in debugfs grade write operation.
Bug 1343366
Change-Id: Id907878c478b5ac581905a04a600c37505721dae
Reviewed-on: http://git-master/r/387442
Bug 1343366
Change-Id: I6ab3e31ec13097862cf29654d0bfe27cfc25c326
Reviewed-on: http://git-master/r/384702
Clamped DFLL voltage limits at minimum during CPU SiMon grading, so
that voltage would not fluctuate during grading for sure (with previous
approach - grade after frequency request is low enough to saturate DFLL
at minimum - there was still a possibility for fluctuation).
Bug 1343366
Change-Id: I390f67e3b1bb38e648965f4dc8159a57270eebcd
Reviewed-on: http://git-master/r/384700
Restarted SiMon grading every time grade is changed via debugfs.
Bug 1343366
Change-Id: Ic466dee600fb4270fb969dc50f49c96b7ac3b1ae
Reviewed-on: http://git-master/r/384124
Added minimum grading temperature to SiMon grader description.
Updated grading callbacks accordingly. Set minimum temperature to 20C
for now.
Renamed grading rate and voltage limits, to make it clear that these
are maximum limits (unlike temperature minimum limit).
Bug 1343366
Change-Id: Ifbd65b0f4bfda1a046351252ae2904f2e2922a04
Reviewed-on: http://git-master/r/384123
Updated SiMon grading policy so that lowering high (non-zero) grade
back to zero automatically stops grading completely.
Bug 1343366
Change-Id: I1d94b071eba7bfdd4371958d018a702bf58b8cb5
Reviewed-on: http://git-master/r/382336
Added voltage settling time to SiMon grader description, and delay
grading respectively.
Bug 1343366
Change-Id: I0eb476cea75a51d015f9dd0c3686e2f52f31a8cb
Reviewed-on: http://git-master/r/382334
- Combined platform/chip specific SiMon grader data into
tegra_simon_grader_desc structure
- Defined tegra_simon_add_grader() interface for grader driver to pass
grader description to SiMon core
- Renamed ..._grade_update functions to ..._grade_notify to properly
reflect the actual operation
- Modified SiMon domain debugfs to send debug grade notification even
when no grader description is added
- On Tegra12 added fake GPU and CPU graders that always report safe
low grade
Bug 1343366
Change-Id: I51a9bea159a7931d35e7b57b867132b1d6fb289e
Reviewed-on: http://git-master/r/382292
Bypass thermal zone lock when calling get temperature interface from
SiMon callback to avoid ABBA dead-lock (thermal zone lock also covers
cooling device update that locks CPU/GPU clock rate interfaces that
are calling SiMon grading callbacks).
Bug 1343366
Change-Id: I319d26dde1a79752f43f217b40279231152646c9
Reviewed-on: http://git-master/r/367477
Simplified initial GPU SiMon grader registration with vdd_gpu regulator
by using DVFS rail interface (instead of creating/destroying temporary
regulator consumer).
Bug 1343366
Change-Id: I9e0c50c697856eefbde08bf5c2f07b37477f8c31
Reviewed-on: http://git-master/r/360765
Limited SiMon grading support to Tegra12 platforms, for now.
Bug 1343366
Change-Id: I78b3a6084a14e3f6a57bdb78cbfe47d7e5b8c271
Reviewed-on: http://git-master/r/355379
Added SiMon CPU grading callback to CPU rate post-change notification
chain. This guarantees constant frequency during grading. Grading is
executed when running on G-CPU, with DFLL as clock source, at rate low
enough for DFLL to saturate at minimum voltage at any temperature. It
is still possible that DFLL Vmin changes during grading because of
temperature fluctuation. In that case grading results are discarded.
First grading after boot can be executed anytime the conditions above
are met, next grading is always separated by the grading interval
from the last successful grading.
Bug 1343366
Change-Id: Id1caa346c957afb95d2006132fff9ad7bbf54586
Reviewed-on: http://git-master/r/349283
Added SiMon GPU grading callback to vdd_gpu post-change notification
chain. This guarantees constant voltage during grading. First grading
after boot can be executed anytime when GPU voltage is below specified
threshold, next grading is always separated by the grading interval
from the last successful grading. Current setting for threshold (0.85V)
and interval (about 8 weeks) are placeholders and subject to change.
Bug 1343366
Change-Id: Id774ee1f3f60071d1ad732901cdd80dd6604dae8
Reviewed-on: http://git-master/r/347825
Defined tegra SiMon grading device data structure. Moved SiMon domain
grade notification to work function. Re-factored SiMon debugfs entries,
accordingly.
Bug 1343366
Change-Id: Id12f4b7252051701081a9f2a0b1f638c178f4a71
Reviewed-on: http://git-master/r/347824
Defined tegra Silicon Monitor (SiMon) domains: CPU, GPU, core. Added
SiMon domain grade notification chain, and debugfs entries.
Bug 1343366
Change-Id: Ieff7ca57af48e5a5a2224fd6800bcccabf8eef5e
Reviewed-on: http://git-master/r/338521
Reviewed-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
