path: root/arch/arm/mach-w90x900/include
2013-12-20ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, tooUwe Kleine-König
While <mach/timex.h> isn't used for multi-platform builds since long it still is for "normal" builds. As the previous patches fix all sites to not make use of this per-platform file, it can go now for good also for platforms that are not (yet) converted to multi-platform. While at it there are no users of CLOCK_TICK_RATE any more, so also drop the dummy #define. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2013-10-01ARM: w90x900: delete <mach/gpio.h>Linus Walleij
The local <mach/gpio.h> file on the w90x900 is completely unused and the platform does not define NEED_MACH_GPIO_H. Cc: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-21Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC cleanups from Arnd Bergmann: "A large number of cleanups, all over the platforms. This is dominated largely by the Samsung platforms (s3c, s5p, exynos) and a few of the others moving code out of arch/arm into more appropriate subsystems. The clocksource and irqchip drivers are now abstracted to the point where platforms that are already cleaned up do not need to even specify the driver they use, it can all get configured from the device tree as we do for normal device drivers. The clocksource changes basically touch every single platform in the process. We further clean up the use of platform specific header files here, with the goal of turning more of the platforms over to being "multiplatform" enabled, which implies that they cannot expose their headers to architecture independent code any more. It is expected that no functional changes are part of the cleanup. The overall reduction in total code lines is mostly the result of removing broken and obsolete code." * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits) ARM: mvebu: correct gated clock documentation ARM: kirkwood: add missing include for nsa310 ARM: exynos: move exynos4210-combiner to drivers/irqchip mfd: db8500-prcmu: update resource passing drivers/db8500-cpufreq: delete dangling include ARM: at91: remove NEOCORE 926 board sunxi: Cleanup the reset code and add meaningful registers defines ARM: S3C24XX: header mach/regs-mem.h local ARM: S3C24XX: header mach/regs-power.h local ARM: S3C24XX: header mach/regs-s3c2412-mem.h local ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/ ARM: S3C24XX: transform s3c2443 subirqs into new structure ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs ARM: S3C24XX: move s3c2443 irq code to irq.c ARM: S3C24XX: transform s3c2416 irqs into new structure ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs ARM: S3C24XX: move s3c2416 irq init to common irq code ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property ARM: S3C24XX: Move irq syscore-ops to irq-pm clocksource: always define CLOCKSOURCE_OF_DECLARE ...
2013-02-14ARM: w90x900: fix legacy assembly syntaxArnd Bergmann
New ARM binutils don't allow extraneous whitespace inside of brackets, which causes this error on all mach-w90x900 defconfigs: arch/arm/kernel/entry-armv.S: Assembler messages: arch/arm/kernel/entry-armv.S:214: Error: ARM register expected -- `ldr r0,[ r6,#(0x10C)]' arch/arm/kernel/entry-armv.S:214: Error: ARM register expected -- `ldr r0,[ r6,#(0x110)]' arch/arm/kernel/entry-armv.S:430: Error: ARM register expected -- `ldr r0,[ r6,#(0x10C)]' arch/arm/kernel/entry-armv.S:430: Error: ARM register expected -- `ldr r0,[ r6,#(0x110)]' This removes the whitespace in order to build the kernel again. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Wan ZongShun <mcuos.com@gmail.com>
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2012-09-14ARM: w90x900: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the w90x900 include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: "Ben Dooks (embedded platforms)" <ben-linux@fluff.org> Cc: "Wolfram Sang (embedded platforms)" <w.sang@pengutronix.de> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-03-06ARM: remove bunch of now unused mach/io.h filesRob Herring
Now that many platforms don't need mach/io.h, remove the unused ones. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org>
2012-02-22Merge branch 'entry-macro-cleanup' of git://sources.calxeda.com/kernel/linux ↵Russell King
into for-armsoc
2012-02-21ARM: remove disable_fiq and arch_ret_to_user macrosRob Herring
Now that most platforms don't need disable_fiq and arch_ret_to_user macros, we can remove the empty macros or empty entry-macro.S files. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Ryan Mallon <rmallon@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2012-01-20ARM: big removal of now unused arch_idle()Nicolas Pitre
When this is the only content remaining in mach/system.h then the whole file is removed. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-and-tested-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-20ARM: mach-w90x900: properly disable CPU idle callNicolas Pitre
Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org>
2012-01-05Merge branch 'restart' into for-linusRussell King
Conflicts: arch/arm/mach-exynos/cpu.c The changes to arch/arm/mach-exynos/cpu.c were moved to mach-exynos/common.c.
2012-01-05ARM: restart: remove the now empty arch_reset()Russell King
Remove the now empty arch_reset() from all the mach/system.h includes, and remove its callsite. Remove arm_machine_restart() as this function no longer does anything useful. For samsung platforms, remove the include of mach/system-reset.h and plat/system-reset.h from their respective mach/system.h headers as these just define their arch_reset functions. As a result, the s3c2410 and plat-samsung system-reset.h files are no longer referenced, so remove these files entirely. Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-01-05ARM: restart: w90x900: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-01-05Merge branch 'restart-cleanup' into restartRussell King
Conflicts: arch/arm/kernel/setup.c
2011-12-05Merge branch 'vmalloc' of git://git.linaro.org/people/nico/linux into ↵Russell King
devel-stable
2011-12-05Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/will/linux into devel-stable Conflicts: arch/arm/common/gic.c arch/arm/plat-omap/include/plat/common.h
2011-11-26ARM: big removal of now unused vmalloc.h filesNicolas Pitre
2011-11-21ARM: restart: only perform setup for restart when soft-restartingRussell King
We only need to set the system up for a soft-restart if we're going to be doing a soft-restart. Provide a new function (soft_restart()) which does the setup and final call for this, and make platforms use it. Eliminate the call to setup_restart() from the default handler. This means that platforms arch_reset() function is no longer called with the page tables prepared for a soft-restart, and caches will still be enabled. Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Krzysztof Ha■asa <khc@pm.waw.pl> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-12ARM: 7158/1: add new MFP implement for NUC900wanzongshun
This patch is to add new MFP implement in mfp.c,since nuc900 mmc driver needs this function support. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-28Merge branch 'devel-stable' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits) ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET ARM: gic, local timers: use the request_percpu_irq() interface ARM: gic: consolidate PPI handling ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H ARM: mach-s5p64x0: remove mach/memory.h ARM: mach-s3c64xx: remove mach/memory.h ARM: plat-mxc: remove mach/memory.h ARM: mach-prima2: remove mach/memory.h ARM: mach-zynq: remove mach/memory.h ARM: mach-bcmring: remove mach/memory.h ARM: mach-davinci: remove mach/memory.h ARM: mach-pxa: remove mach/memory.h ARM: mach-ixp4xx: remove mach/memory.h ARM: mach-h720x: remove mach/memory.h ARM: mach-vt8500: remove mach/memory.h ARM: mach-s5pc100: remove mach/memory.h ARM: mach-tegra: remove mach/memory.h ARM: plat-tcc: remove mach/memory.h ARM: mach-mmp: remove mach/memory.h ARM: mach-cns3xxx: remove mach/memory.h ... Fix up mostly pretty trivial conflicts in: - arch/arm/Kconfig - arch/arm/include/asm/localtimer.h - arch/arm/kernel/Makefile - arch/arm/mach-shmobile/board-ap4evb.c - arch/arm/mach-u300/core.c - arch/arm/mm/dma-mapping.c - arch/arm/mm/proc-v7.S - arch/arm/plat-omap/Kconfig largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP -> CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
2011-10-13ARM: mach-w90x900: remove mach/memory.hNicolas Pitre
2011-08-12ARM: gpio: make trivial GPIOLIB implementation the defaultRussell King
Rather than marking the mach/gpio.h header files which want to use the trivial GPIOLIB implementation, mark those which do not want to use it instead. This means that by default, you get the trivial implementation and only have to do something extra if you need to. This should encourage the use of the trivial default implementation. As an additional bonus, several gpio.h header files become empty. Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-12ARM: gpio: consolidate gpio_to_irqRussell King
Many of the gpio_to_irq implementations use the gpiolib version of this function. Provide the standard gpiolib gpio_to_irq() for everyone, but allow platforms to override it if they wish. Add the neccessary overrides for those platforms which do not use the standard definition. Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-12ARM: gpio: consolidate trivial gpiolib implementationsRussell King
Consolidate 24 trivial gpiolib implementions out of mach/gpio.h into asm/gpio.h. This is basically the include of asm-generic/gpio.h and the definition of gpio_get_value, gpio_set_value, and gpio_cansleep as described in Documentation/gpio.txt Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: David Brown <davidb@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Tested-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-19ARM: Consolidate the clkdev header filesKyungmin Park
Now most of ARM machines has the alsmot same __clk_get/put() macro So place it at the arch/arm/include/asm/clkdev.h and remove the reduntant header files But some machines don't have the same form as above. It can use the machince specific clkdev file by HAVE_MACH_CLKDEV config Now there are only 3 caese. 1) define the clk structure with clkdev macro => Need to move clk structure to proper header file arch/arm/mach-versatile/include/mach/clkdev.h arch/arm/mach-realview/include/mach/clkdev.h arch/arm/mach-vexpress/include/mach/clkdev.h arch/arm/mach-integrator/include/mach/clkdev.h 2) export the __clk_get/put function at clock.c arch/arm/mach-shmobile/include/mach/clkdev.h 3) demuxing the clk source arch/arm/mach-u300/include/mach/clkdev.h Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-05-07ARM: zImage: remove the static qualifier from global data variablesNicolas Pitre
To be able to relocate the .bss section at run time independently from the rest of the code, we must make sure that no GOTOFF relocations are used with .bss symbols. This usually means that no global variables can be marked static unless they're also const. Let's remove the static qualifier from current offenders, or turn them into const variables when possible. Next commit will ensure the build fails if one of those is reintroduced due to otherwise enforced coding standards for the kernel. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Tony Lindgren <tony@atomide.com>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-08-11i2c/nuc900: add i2c driver support for nuc900Wan ZongShun
This patch is to add i2c driver support for nuc900. Signed-off-by: Wan ZongShun <mcuos.com@gmail.org> Reviewed-by: Marek Vasut <marek.vasut@gmail.com> Reviewed-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2010-07-29ARM: 6274/1: add global control registers definition header file for nuc900wanzongshun
add global control registers definition header file for nuc900 Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-24ARM: 6141/1: Add audio support part in arch/arm/mach-w90x900wanzongshun
Add audio support part in arch/arm/mach-w90x900 Signed-off-by: Wan ZongShun<mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-12NUC900 LCD Controller DriverWang Qiang
An LCD controller driver for nuc900s. The Linux LOGO is just fine and the FB-Test application was ok, too. Signed-off-by: Wang Qiang <rurality.linux@gmail.com> Cc: Wang Zongshun <mcuos.com@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-15ARM: 5928/1: Change type of VMALLOC_END to unsigned long.Fenkart/Bostandzhyan
Makes it consistent with VMALLOC_START Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-01-05ARM: 5864/1: Implement arch_reset() in NUC900Li Jie
Implement arch_reset(), reboot from shell become possible. Signed-off-by: lijie <eltshanli@gmail.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-22ARM: 5855/1: putc support for nuc900wanzongshun
putc support for nuc900 Signed-off-by: lijie <eltshanli@gmail.com> Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-13ARM: NUC900: Add spi driver support for nuc900Wan ZongShun
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-09-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (52 commits) Input: bcm5974 - silence uninitialized variables warnings Input: wistron_btns - add keymap for AOpen 1557 Input: psmouse - use boolean type Input: i8042 - use platform_driver_probe Input: i8042 - use boolean type where it makes sense Input: i8042 - try disabling and re-enabling AUX port at close Input: pxa27x_keypad - allow modifying keymap from userspace Input: sunkbd - fix formatting Input: i8042 - bypass AUX IRQ delivery test on laptops Input: wacom_w8001 - simplify querying logic Input: atkbd - allow setting force-release bitmap via sysfs Input: w90p910_keypad - move a dereference below a NULL test Input: add twl4030_keypad driver Input: matrix-keypad - add function to build device keymap Input: tosakbd - fix cleaning up KEY_STROBEs after error Input: joydev - validate axis/button maps before clobbering current ones Input: xpad - add USB ID for the drumkit controller from Rock Band Input: w90p910_keypad - rename driver name to match platform Input: add new driver for Sentelic Finger Sensing Pad Input: psmouse - allow defining read-only attributes ...
2009-08-09Input: w90p910_keypad - adjust to use definitions from matrix_keypad.hDmitry Torokhov
Also have the driver send MSC_SCAN events as most keyboards do to aid in updating keymap from userspace. Tested-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-08-09Input: add keypad driver for w90p910Wan ZongShun
Add keypad driver for the 4x4 keypad on an evaluation board based on w90p910. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Reviewed-by: Trilok Soni <soni.trilok@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2009-08-01ARM: 5634/1: Add static setting cpu frequence for w90p910 platformwanzongshun
Add static setting cpu frequence for w90p910 platform. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-06-11[ARM] 5549/1: Add clock api for w90p910 platform.wanzongshun
Add clock api for w90p910 platform. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-06-11[ARM] 5548/1: Add gpio api for w90p910 platformwanzongshun
Add gpio api for w90p910 platform. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-07[ARM] 5499/1: Add Usb register controller header file dfinewanzongshun
Add Usb register controller header file dfine. w90p910 usb ip is standard,but some mutifunction controll pin must be special define in w90p910 Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-07[ARM] 5498/1: w90p910 Clock register controller header file dfinewanzongshun
Add Clock register controller header file dfine. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-07[ARM] 5494/1: Add w90p910 irq number definewanzongshun
Add irq number define for driver will be submitted. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-07[ARM] 5493/1: Add w90p910 IC interface controller regester mapwanzongshun
Add w90p910 IC other interface controller regester map for driver will be submitted. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-19[ARM] pass reboot command line to arch_reset()Russell King
OMAP wishes to pass state to the boot loader upon reboot in order to instruct it whether to wait for USB-based reflashing or not. There is already a facility to do this via the reboot() syscall, except we ignore the string passed to machine_restart(). This patch fixes things to pass this string to arch_reset(). This means that we keep the reboot mode limited to telling the kernel _how_ to perform the reboot which should be independent of what we request the boot loader to do. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-03[ARM] 5338/1: Add Nuvoton W90P910 Platform supportwanzongshun
Add Nuvoton W90X900 ARM9 plat support to linux arm tree, Now, this patch include only W90P910 EVB of W90P910 CPU, Its driver is nothing. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
