path: root/arch/arm/mm/copypage-v3.c
2009-10-05ARM: Pass VMA to copy_user_highpage() implementationsRussell King
Our copy_user_highpage() implementations may require cache maintainence. Ensure that implementations have all necessary details to perform this maintainence. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-12[ARM] 5421/1: ftrace: fix crash due to tracing of __naked functionsUwe Kleine-König
This is a fix for the following crash observed in 2.6.29-rc3: http://lkml.org/lkml/2009/1/29/150 On ARM it doesn't make sense to trace a naked function because then mcount is called without stack and frame pointer being set up and there is no chance to restore the lr register to the value before mcount was called. Reported-by: Matthias Kaehlcke <matthias@kaehlcke.net> Tested-by: Matthias Kaehlcke <matthias@kaehlcke.net> Cc: Abhishek Sagar <sagar.abhishek@gmail.com> Cc: Steven Rostedt <rostedt@home.goodmis.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] fix a couple clear_user_highpage assembly constraintsNicolas Pitre
In all cases the kaddr is assigned an input register even though it is modified in the assembly code. Let's assign a new variable to the modified value and mark those inline asm with volatile otherwise they get optimized away because the output variable is otherwise not used. Also fix a few conversion errors in copypage-feroceon.c and copypage-v4mc.c. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-27[ARM] clearpage: provide our own clear_user_highpage()Russell King
For similar reasons as copy_user_page(), we want to avoid the additional kmap_atomic if it's unnecessary. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-27[ARM] copypage: provide our own copy_user_highpage()Russell King
We used to override the copy_user_page() function. However, this is not only inefficient, it also causes additional complexity for highmem support, since we convert from a struct page to a kernel direct mapped address and back to a struct page again. Moreover, with highmem support, we end up pointlessly setting up kmap entries for pages which we're going to remap. So, push the kmapping down into the copypage implementation files where it's required. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-27[ARM] copypage: convert assembly files to CRussell King
