Pull ARM changes from Russell King:
- Perf updates from Will Deacon:
- Support for Qualcomm Krait processors (run perf on your phone!)
- Support for Cortex-A12 (run perf stat on your FPGA!)
- Support for perf_sample_event_took, allowing us to automatically decrease
the sample rate if we can't handle the PMU interrupts quickly enough
(run perf record on your FPGA!).
- Basic uprobes support from David Long:
This patch series adds basic uprobes support to ARM. It is based on
patches developed earlier by Rabin Vincent. That approach of adding
hooks into the kprobes instruction parsing code was not well received.
This approach separates the ARM instruction parsing code in kprobes out
into a separate set of functions which can be used by both kprobes and
uprobes. Both kprobes and uprobes then provide their own semantic action
tables to process the results of the parsing.
- ARMv7M (microcontroller) updates from Uwe Kleine-König
- OMAP DMA updates (recently added Vinod's Ack even though they've been
sitting in linux-next for a few months) to reduce the reliance of
omap-dma on the code in arch/arm.
- SA11x0 changes from Dmitry Eremin-Solenikov and Alexander Shiyan
- Support for Cortex-A12 CPU
- Align support for ARMv6 with ARMv7 so they can cooperate better in a
single zImage.
- Addition of first AT_HWCAP2 feature bits for ARMv8 crypto support.
- Removal of IRQ_DISABLED from various ARM files
- Improved efficiency of virt_to_page() for single zImage
- Patch from Ulf Hansson to permit runtime PM callbacks to be available for
AMBA devices for suspend/resume as well.
- Finally kill asm/system.h on ARM.
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (89 commits)
dmaengine: omap-dma: more consolidation of CCR register setup
dmaengine: omap-dma: move IRQ handling to omap-dma
dmaengine: omap-dma: move register read/writes into omap-dma.c
ARM: omap: dma: get rid of 'p' allocation and clean up
ARM: omap: move dma channel allocation into plat-omap code
ARM: omap: dma: get rid of errata global
ARM: omap: clean up DMA register accesses
ARM: omap: remove almost-const variables
ARM: omap: remove references to disable_irq_lch
dmaengine: omap-dma: cleanup errata 3.3 handling
dmaengine: omap-dma: provide register read/write functions
dmaengine: omap-dma: use cached CCR value when enabling DMA
dmaengine: omap-dma: move barrier to omap_dma_start_desc()
dmaengine: omap-dma: move clnk_ctrl setting to preparation functions
dmaengine: omap-dma: improve efficiency loading C.SA/C.EI/C.FI registers
dmaengine: omap-dma: consolidate clearing channel status register
dmaengine: omap-dma: move CCR buffering disable errata out of the fast path
dmaengine: omap-dma: provide register definitions
dmaengine: omap-dma: consolidate setup of CCR
dmaengine: omap-dma: consolidate setup of CSDP
The 'order' parameter for IOMMU-aware dma-mapping implementation was
introduced mainly as a hack to reduce size of the bitmap used for
tracking IO virtual address space. Since now it is possible to dynamically
resize the bitmap, this hack is not needed and can be removed without any
impact on the client devices. This way the parameters for
arm_iommu_create_mapping() becomes much easier to understand. 'size'
parameter now means the maximum supported IO address space size.
The code will allocate (resize) bitmap in chunks, ensuring that a single
chunk is not larger than a single memory page to avoid unreliable
allocations of size larger than PAGE_SIZE in atomic context.
Instead of using just one bitmap to keep track of IO virtual addresses
(handed out for IOMMU use) introduce an array of bitmaps. This allows
us to extend existing mappings when running out of iova space in the
initial mapping etc.
If there is not enough space in the mapping to service an IO virtual
address allocation request, __alloc_iova() tries to extend the mapping
-- by allocating another bitmap -- and makes another allocation
attempt using the freshly allocated bitmap.
This allows arm iommu drivers to start with a decent initial size when
an dma_iommu_mapping is created and still to avoid running out of IO
virtual addresses for the mapping.
Signed-off-by: Andreas Herrmann <andreas.herrmann@calxeda.com>
[mszyprow: removed extensions parameter to arm_iommu_create_mapping()
function, which will be modified in the next patch anyway, also some
debug messages about extending bitmap]
The Coherant DMA allocator allocates pages of high order then splits
them up into smaller pages.
This splitting logic would run into problems if the allocator was
given compound pages. Thus the Coherant DMA allocator was originally
incompatible with compound pages existing and, by extension, huge
pages. A compile #error was put in place whenever huge pages were
enabled.
Compatibility with compound pages has since been introduced by the
following commit (which merely excludes GFP_COMP pages from being
requested by the coherant DMA allocator):
ea2e705 ARM: 7172/1: dma: Drop GFP_COMP for DMA memory allocations
When huge page support was introduced to ARM, the compile #error in
dma-mapping.c was replaced by a #warning when it should have been
removed instead.
This patch removes the compile #warning in dma-mapping.c when huge
pages are enabled.
Signed-off-by: Steve Capper <steve.capper@linaro.org>
GFP_ATOMIC is not a single gfp flag, but a macro which expands to the other
flags and LACK of __GFP_WAIT flag. To check if caller wanted to perform an
atomic allocation, the code must test __GFP_WAIT flag presence. This patch
fixes the issue introduced in v3.6-rc5
CC: stable@vger.kernel.org
for-next
The CMA region was being marked executable:
0xdc04e000-0xdc050000 8K RW x MEM/CACHED/WBRA
0xdc060000-0xdc100000 640K RW x MEM/CACHED/WBRA
0xdc4f5000-0xdc500000 44K RW x MEM/CACHED/WBRA
0xdcce9000-0xe0000000 52316K RW x MEM/CACHED/WBRA
This is mainly due to the badly worded MT_MEMORY_DMA_READY symbol, but
there are also a few other places in dma-mapping which should be
corrected to use the right constant. Fix all these places:
0xdc04e000-0xdc050000 8K RW NX MEM/CACHED/WBRA
0xdc060000-0xdc100000 640K RW NX MEM/CACHED/WBRA
0xdc280000-0xdc300000 512K RW NX MEM/CACHED/WBRA
0xdc6fc000-0xe0000000 58384K RW NX MEM/CACHED/WBRA
Peter reports that OMAP audio broke with the recent fix for these
checks, caused by OMAP audio using a 64-bit DMA mask. We should
allow 64-bit DMA masks even with 32-bit dma_addr_t if we can be sure
the amount of RAM we have won't allow the 32-bit dma_addr_t to
overflow. Unfortunately, the checks to detect overflow were not
correct.
Tested-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Some buses have negative offsets, which causes the DMA mask checks to
falsely fail. Fix this by using the actual amount of memory fitted in
the system.
Pull ARM updates from Russell King:
"Included in this series are:
1. BE8 (modern big endian) changes for ARM from Ben Dooks
2. big.Little support from Nicolas Pitre and Dave Martin
3. support for LPAE systems with all system memory above 4GB
4. Perf updates from Will Deacon
5. Additional prefetching and other performance improvements from Will.
6. Neon-optimised AES implementation fro Ard.
7. A number of smaller fixes scattered around the place.
There is a rather horrid merge conflict in tools/perf - I was never
notified of the conflict because it originally occurred between Will's
tree and other stuff. Consequently I have a resolution which Will
forwarded me, which I'll forward on immediately after sending this
mail.
The other notable thing is I'm expecting some build breakage in the
crypto stuff on ARM only with Ard's AES patches. These were merged
into a stable git branch which others had already pulled, so there's
little I can do about this. The problem is caused because these
patches have a dependency on some code in the crypto git tree - I
tried requesting a branch I can pull to resolve these, and all I got
each time from the crypto people was "we'll revert our patches then"
which would only make things worse since I still don't have the
dependent patches. I've no idea what's going on there or how to
resolve that, and since I can't split these patches from the rest of
this pull request, I'm rather stuck with pushing this as-is or
reverting Ard's patches.
Since it should "come out in the wash" I've left them in - the only
build problems they seem to cause at the moment are with randconfigs,
and since it's a new feature anyway. However, if by -rc1 the
dependencies aren't in, I think it'd be best to revert Ard's patches"
I resolved the perf conflict roughly as per the patch sent by Russell,
but there may be some differences. Any errors are likely mine. Let's
see how the crypto issues work out..
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (110 commits)
ARM: 7868/1: arm/arm64: remove atomic_clear_mask() in "include/asm/atomic.h"
ARM: 7867/1: include: asm: use 'int' instead of 'unsigned long' for 'oldval' in atomic_cmpxchg().
ARM: 7866/1: include: asm: use 'long long' instead of 'u64' within atomic.h
ARM: 7871/1: amba: Extend number of IRQS
ARM: 7887/1: Don't smp_cross_call() on UP devices in arch_irq_work_raise()
ARM: 7872/1: Support arch_irq_work_raise() via self IPIs
ARM: 7880/1: Clear the IT state independent of the Thumb-2 mode
ARM: 7878/1: nommu: Implement dummy early_paging_init()
ARM: 7876/1: clear Thumb-2 IT state on exception handling
ARM: 7874/2: bL_switcher: Remove cpu_hotplug_driver_{lock,unlock}()
ARM: footbridge: fix build warnings for netwinder
ARM: 7873/1: vfp: clear vfp_current_hw_state for dying cpu
ARM: fix misplaced arch_virt_to_idmap()
ARM: 7848/1: mcpm: Implement cpu_kill() to synchronise on powerdown
ARM: 7847/1: mcpm: Factor out logical-to-physical CPU translation
ARM: 7869/1: remove unused XSCALE_PMU Kconfig param
ARM: 7864/1: Handle 64-bit memory in case of 32-bit phys_addr_t
ARM: 7863/1: Let arm_add_memory() always use 64-bit arguments
ARM: 7862/1: pcpu: replace __get_cpu_var_uses
ARM: 7861/1: cacheflush: consolidate single-CPU ARMv7 cache disabling code
Pull DMA mask updates from Russell King:
"This series cleans up the handling of DMA masks in a lot of drivers,
fixing some bugs as we go.
Some of the more serious errors include:
- drivers which only set their coherent DMA mask if the attempt to
set the streaming mask fails.
- drivers which test for a NULL dma mask pointer, and then set the
dma mask pointer to a location in their module .data section -
which will cause problems if the module is reloaded.
To counter these, I have introduced two helper functions:
- dma_set_mask_and_coherent() takes care of setting both the
streaming and coherent masks at the same time, with the correct
error handling as specified by the API.
- dma_coerce_mask_and_coherent() which resolves the problem of
drivers forcefully setting DMA masks. This is more a marker for
future work to further clean these locations up - the code which
creates the devices really should be initialising these, but to fix
that in one go along with this change could potentially be very
disruptive.
The last thing this series does is prise away some of Linux's addition
to "DMA addresses are physical addresses and RAM always starts at
zero". We have ARM LPAE systems where all system memory is above 4GB
physical, hence having DMA masks interpreted by (eg) the block layers
as describing physical addresses in the range 0..DMAMASK fails on
these platforms. Santosh Shilimkar addresses this in this series; the
patches were copied to the appropriate people multiple times but were
ignored.
Fixing this also gets rid of some ARM weirdness in the setup of the
max*pfn variables, and brings ARM into line with every other Linux
architecture as far as those go"
* 'for-linus-dma-masks' of git://git.linaro.org/people/rmk/linux-arm: (52 commits)
ARM: 7805/1: mm: change max*pfn to include the physical offset of memory
ARM: 7797/1: mmc: Use dma_max_pfn(dev) helper for bounce_limit calculations
ARM: 7796/1: scsi: Use dma_max_pfn(dev) helper for bounce_limit calculations
ARM: 7795/1: mm: dma-mapping: Add dma_max_pfn(dev) helper function
ARM: 7794/1: block: Rename parameter dma_mask to max_addr for blk_queue_bounce_limit()
ARM: DMA-API: better handing of DMA masks for coherent allocations
ARM: 7857/1: dma: imx-sdma: setup dma mask
DMA-API: firmware/google/gsmi.c: avoid direct access to DMA masks
DMA-API: dcdbas: update DMA mask handing
DMA-API: dma: edma.c: no need to explicitly initialize DMA masks
DMA-API: usb: musb: use platform_device_register_full() to avoid directly messing with dma masks
DMA-API: crypto: remove last references to 'static struct device *dev'
DMA-API: crypto: fix ixp4xx crypto platform device support
DMA-API: others: use dma_set_coherent_mask()
DMA-API: staging: use dma_set_coherent_mask()
DMA-API: usb: use new dma_coerce_mask_and_coherent()
DMA-API: usb: use dma_set_coherent_mask()
DMA-API: parport: parport_pc.c: use dma_coerce_mask_and_coherent()
DMA-API: net: octeon: use dma_coerce_mask_and_coherent()
DMA-API: net: nxp/lpc_eth: use dma_coerce_mask_and_coherent()
We need to start treating DMA masks as something which is specific to
the bus that the device resides on, otherwise we're going to hit all
sorts of nasty issues with LPAE and 32-bit DMA controllers in >32-bit
systems, where memory is offset from PFN 0.
In order to start doing this, we convert the DMA mask to a PFN using
the device specific dma_to_pfn() macro. This is the reverse of the
pfn_to_dma() macro which is used to get the DMA address for the device.
This gives us a PFN mask, which we can then check against the PFN
limit of the DMA zone.
DMA mapping permissions were being derived from pgprot_kernel directly
without using PAGE_KERNEL. This causes them to be marked with executable
permission, which is not what we want. Fix this.
... otherwise it is impossible for the low level iommu driver to
figure out which pte flags should be used.
In __map_sg_chunk we can derive the flags from dma_data_direction.
In __iommu_create_mapping we should treat the memory like
DMA_BIDIRECTIONAL and pass both IOMMU_READ and IOMMU_WRITE to
iommu_map.
__iommu_create_mapping is used during dma_alloc_coherent (via
arm_iommu_alloc_attrs). AFAIK dma_alloc_coherent is responsible for
allocation _and_ mapping. I think this implies that access to the
mapped pages should be allowed.
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Acked-by: Will Deacon <will.deacon@arm.com>
"This set includes adding support for Neon acceleration of RAID6 XOR
code from Ard Biesheuvel, cache flushing and barrier updates from Will
Deacon, and a cleanup to the ARM debug code which reduces the amount
of code by about 500 lines.
A few other cleanups, such as constifying the machine descriptors
which already shouldn't be written to, cleaning up the printing of the
L2 cache size"
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (55 commits)
ARM: 7826/1: debug: support debug ll on hisilicon soc
ARM: 7830/1: delay: don't bother reporting bogomips in /proc/cpuinfo
ARM: 7829/1: Add ".text.unlikely" and ".text.hot" to arm unwind tables
ARM: 7828/1: ARMv7-M: implement restart routine common to all v7-M machines
ARM: 7827/1: highbank: fix debug uart virtual address for LPAE
ARM: 7823/1: errata: workaround Cortex-A15 erratum 773022
ARM: 7806/1: allow DEBUG_UNCOMPRESS for Tegra
ARM: 7793/1: debug: use generic option for ep93xx PL10x debug port
ARM: debug: move SPEAr debug to generic PL01x code
ARM: debug: move davinci debug to generic 8250 code
ARM: debug: move keystone debug to generic 8250 code
ARM: debug: remove DEBUG_ROCKCHIP_UART
ARM: debug: provide generic option choices for 8250 and PL01x ports
ARM: debug: move PL01X debug include into arch/arm/include/debug/
ARM: debug: provide PL01x debug uart phys/virt address configuration options
ARM: debug: add support for word accesses to debug/8250.S
ARM: debug: move 8250 debug include into arch/arm/include/debug/
ARM: debug: provide 8250 debug uart phys/virt address configuration options
ARM: debug: provide 8250 debug uart register shift configuration option
ARM: debug: provide 8250 debug uart flow control configuration option
mm/Kconfig
CMA DMA split and ZSWAP introduction were conflicting, fix up manually.
The kernel TLB range invalidation functions already contain dsb
instructions before and after the maintenance, so there is no need to
introduce additional barriers.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Add prerequisite patch for CMA RMA allocation patches
git://git.linaro.org/people/mszyprowski/linux-dma-mapping
Pull ARM DMA mapping updates from Marek Szyprowski:
"This contains important bugfixes and an update for IOMMU integration
support for ARM architecture"
* 'for-v3.11' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping:
ARM: dma: Drop __GFP_COMP for iommu dma memory allocations
ARM: DMA-mapping: mark all !DMA_TO_DEVICE pages in unmapping as clean
ARM: dma-mapping: NULLify dev->archdata.mapping pointer on detach
ARM: dma-mapping: convert DMA direction into IOMMU protection attributes
ARM: dma-mapping: Get pages if the cpu_addr is out of atomic_pool
We want to use CMA for allocating hash page table and real mode area for
PPC64. Hence move DMA contiguous related changes into a seperate config
so that ppc64 can enable CMA without requiring DMA contiguous.
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Acked-by: Paul Mackerras <paulus@samba.org>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
[removed defconfig changes]
arch/arm/Makefile
arch/arm/include/asm/glue-proc.h
__iommu_alloc_buffer wants to split pages after allocation in order to
reduce the memory footprint. This does not work well with __GFP_COMP
pages, so drop this flag before allocation
One failure example is snd_malloc_dev_pages call dma_alloc_coherent with
__GFP_COMP.
Signed-off-by: Richard Zhao <rizhao@nvidia.com>
It is common for one sg to include many pages, so mark all these
pages as clean to avoid unnecessary flushing on them in
set_pte_at() or update_mmu_cache().
The patch might improve loading performance of applciation code a bit.
On the below test code to read file(~1GByte size) from usb mass storage
disk to buffer created with mmap(PROT_READ | PROT_EXEC) on
Pandaboard, average ~1% improvement can be observed with the patch on
10 times test.
unsigned int sum = 0;
static unsigned long tv_diff(struct timeval *tv1, struct timeval *tv2)
return (tv2->tv_sec - tv1->tv_sec) * 1000000 +
(tv2->tv_usec - tv1->tv_usec);
int main(int argc, char *argv[])
char *mbuffer;
int fd;
int i;
unsigned long page_size, size;
struct stat stat;
struct timeval t1, t2;
page_size = getpagesize();
fd = open(argv[1], O_RDONLY);
assert(fd >= 0);
fstat(fd, &stat);
size = stat.st_size;
printf("%s: file %s, file size %lu, page size %lu\n", argv[0],
read_filename, size, page_size);
gettimeofday(&t1, NULL);
mbuffer = mmap(NULL, size, PROT_READ | PROT_EXEC, MAP_SHARED, fd, 0);
for (i = 0 ; i < size ; i += page_size)
sum += mbuffer[i];
munmap(mbuffer, page_size);
gettimeofday(&t2, NULL);
printf("\tread mmaped time: %luus\n", tv_diff(&t1, &t2));
close(fd);
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Signed-off-by: Ming Lei <ming.lei@canonical.com>
The current code only clobbers a local variable, so the device is left
with a stale mapping pointer.
Cc: Hiroshi Doyu <hdoyu@nvidia.com>
Acked-by: Hiroshi Doyu <hdoyu@nvidia.com>
IOMMU mappings take a prot parameter, identifying the protection bits
to enforce on the newly created mapping (READ or WRITE). The ARM
dma-mapping framework currently just passes 0 as the prot argument,
resulting in faulting mappings.
This patch infers the protection attributes based on the direction of
the DMA transfer.
In __iommu_get_pages(), the cpu_addr is checked wheather in
atomic_pool range or not. So if the cpu_addr is in atomic_pool
range, it does not need to check twice.
Signed-off-by: YoungJun Cho <yj44.cho@samsung.com>
This patch adds support for hugetlbfs based on the x86 implementation.
It allows mapping of 2MB sections (see Documentation/vm/hugetlbpage.txt
for usage). The 64K pages configuration is not supported (section size
is 512MB in this case).
[steve.capper@linaro.org: symbolic constants replace numbers in places.
Split up into multiple files, to simplify future non-LPAE support,
removed huge_pmd_share code, as this is very rarely executed,
Added PROT_NONE support].
Reviewed-by: Will Deacon <will.deacon@arm.com>
10 times test.
return (tv2->tv_sec - tv1->tv_sec) * 1000000 + (tv2->tv_usec - tv1->tv_usec);
char *mbuffer;
int fd;
int i;
struct stat stat;
assert(fd >= 0);
fstat(fd, &stat);
printf("%s: file %s, file size %lu, page size %lun", argv[0],
sum += mbuffer[i];
printf("tread mmaped time: %luusn", tv_diff(&t1, &t2));
close(fd);
'smp-hotplug' into for-linus
In kmap_atomic(), kmap_high_get() is invoked for checking already
mapped area. In __flush_dcache_page() and dma_cache_maint_page(),
we explicitly call kmap_high_get() before kmap_atomic()
when cache_is_vipt(), so kmap_high_get() can be invoked twice.
This is useless operation, so remove one.
v2: change cache_is_vipt() to cache_is_vipt_nonaliasing() in order to
be self-documented
Acked-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Atomic pool should always be allocated from DMA zone if such zone is
available in the system to avoid issues caused by limited dma mask of
any of the devices used for making an atomic allocation.
Reported-by: Krzysztof Halasa <khc@pm.waw.pl>
Cc: Stable <stable@vger.kernel.org> [v3.6+]
This patch removes page_address() usage in IOMMU-aware dma-mapping
implementation and replaced it with direct use of the cpu virtual address
provided by the caller. page_address() returned incorrect address for
pages remapped in atomic pool, what caused memory leak.
Reported-by: Hiroshi Doyu <hdoyu@nvidia.com>
Tested-by: Hiroshi Doyu <hdoyu@nvidia.com>
Alignment order for a dma iommu buffer is set by buffer size. For
large buffer, it is a waste of iommu address space. So configurable
parameter to limit maximum alignment order can reduce the waste.
Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com>
Signed-off-by: Kyungmin.park <kyungmin.park@samsung.com>
IOMMU can provide access to any memory page, so there is no point in
limiting the allocated pages only to lowmem, once other parts of
dma-mapping subsystem correctly supports himem pages.
This patch adds missing pieces to correctly support memory pages served
from CMA regions placed in high memory zones. Please note that the default
global CMA area is still put into lowmem and is limited by optional
architecture specific DMA zone. One can however put device specific CMA
regions in high memory zone to reduce lowmem usage.
This patch adds EXPORT_SYMBOL_GPL calls to the three arm iommu
functions - arm_iommu_create_mapping, arm_iommu_free_mapping
and arm_iommu_attach_device. These three functions are arm specific
wrapper functions for creating/freeing/using an iommu mapping and
they are called by various drivers. If any of these drivers need
to be built as dynamic modules, these functions need to be exported.
Changelog v2: using EXPORT_SYMBOL_GPL as suggested by Marek.
Signed-off-by: Prathyush K <prathyush.k@samsung.com>
[m.szyprowski: extended with recently introduced
EXPORT_SYMBOL_GPL(arm_iommu_detach_device)]
A counter part of arm_iommu_attach_device().
Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com>
struct dma_map_ops iommu_ops doesn't have ->set_dma_mask, which causes
crash when dma_set_mask() is called from some driver.
Realview fails to boot with this warning:
BUG: spinlock lockup suspected on CPU#0, init/1
lock: 0xcf8bde10, .magic: dead4ead, .owner: init/1, .owner_cpu: 0
Backtrace:
[<c00185d8>] (dump_backtrace+0x0/0x10c) from [<c03294e8>] (dump_stack+0x18/0x1c) r6:cf8bde10 r5:cf83d1c0 r4:cf8bde10 r3:cf83d1c0
[<c03294d0>] (dump_stack+0x0/0x1c) from [<c018926c>] (spin_dump+0x84/0x98)
[<c01891e8>] (spin_dump+0x0/0x98) from [<c0189460>] (do_raw_spin_lock+0x100/0x198)
[<c0189360>] (do_raw_spin_lock+0x0/0x198) from [<c032cbac>] (_raw_spin_lock+0x3c/0x44)
[<c032cb70>] (_raw_spin_lock+0x0/0x44) from [<c01c9224>] (pl011_console_write+0xe8/0x11c)
[<c01c913c>] (pl011_console_write+0x0/0x11c) from [<c002aea8>] (call_console_drivers.clone.7+0xdc/0x104)
[<c002adcc>] (call_console_drivers.clone.7+0x0/0x104) from [<c002b320>] (console_unlock+0x2e8/0x454)
[<c002b038>] (console_unlock+0x0/0x454) from [<c002b8b4>] (vprintk_emit+0x2d8/0x594)
[<c002b5dc>] (vprintk_emit+0x0/0x594) from [<c0329718>] (printk+0x3c/0x44)
[<c03296dc>] (printk+0x0/0x44) from [<c002929c>] (warn_slowpath_common+0x28/0x6c)
[<c0029274>] (warn_slowpath_common+0x0/0x6c) from [<c0029304>] (warn_slowpath_null+0x24/0x2c)
[<c00292e0>] (warn_slowpath_null+0x0/0x2c) from [<c0070ab0>] (lockdep_trace_alloc+0xd8/0xf0)
[<c00709d8>] (lockdep_trace_alloc+0x0/0xf0) from [<c00c0850>] (kmem_cache_alloc+0x24/0x11c)
[<c00c082c>] (kmem_cache_alloc+0x0/0x11c) from [<c00bb044>] (__get_vm_area_node.clone.24+0x7c/0x16c)
[<c00bafc8>] (__get_vm_area_node.clone.24+0x0/0x16c) from [<c00bb7b8>] (get_vm_area_caller+0x48/0x54)
[<c00bb770>] (get_vm_area_caller+0x0/0x54) from [<c0020064>] (__alloc_remap_buffer.clone.15+0x38/0xb8)
[<c002002c>] (__alloc_remap_buffer.clone.15+0x0/0xb8) from [<c0020244>] (__dma_alloc+0x160/0x2c8)
[<c00200e4>] (__dma_alloc+0x0/0x2c8) from [<c00204d8>] (arm_dma_alloc+0x88/0xa0)[<c0020450>] (arm_dma_alloc+0x0/0xa0) from [<c00beb00>] (dma_pool_alloc+0xcc/0x1a8)
[<c00bea34>] (dma_pool_alloc+0x0/0x1a8) from [<c01a9d14>] (pl08x_fill_llis_for_desc+0x28/0x568)
[<c01a9cec>] (pl08x_fill_llis_for_desc+0x0/0x568) from [<c01aab8c>] (pl08x_prep_slave_sg+0x258/0x3b0)
[<c01aa934>] (pl08x_prep_slave_sg+0x0/0x3b0) from [<c01c9f74>] (pl011_dma_tx_refill+0x140/0x288)
[<c01c9e34>] (pl011_dma_tx_refill+0x0/0x288) from [<c01ca748>] (pl011_start_tx+0xe4/0x120)
[<c01ca664>] (pl011_start_tx+0x0/0x120) from [<c01c54a4>] (__uart_start+0x48/0x4c)
[<c01c545c>] (__uart_start+0x0/0x4c) from [<c01c632c>] (uart_start+0x2c/0x3c)
[<c01c6300>] (uart_start+0x0/0x3c) from [<c01c795c>] (uart_write+0xcc/0xf4)
[<c01c7890>] (uart_write+0x0/0xf4) from [<c01b0384>] (n_tty_write+0x1c0/0x3e4)
[<c01b01c4>] (n_tty_write+0x0/0x3e4) from [<c01acfe8>] (tty_write+0x144/0x240)
[<c01acea4>] (tty_write+0x0/0x240) from [<c01ad17c>] (redirected_tty_write+0x98/0xac)
[<c01ad0e4>] (redirected_tty_write+0x0/0xac) from [<c00c371c>] (vfs_write+0xbc/0x150)
[<c00c3660>] (vfs_write+0x0/0x150) from [<c00c39c0>] (sys_write+0x4c/0x78)
[<c00c3974>] (sys_write+0x0/0x78) from [<c0014460>] (ret_fast_syscall+0x0/0x3c)
This happens because the DMA allocation code is not respecting atomic
allocations correctly.
GFP flags should not be tested for GFP_ATOMIC to determine if an
atomic allocation is being requested. GFP_ATOMIC is not a flag but
a value. The GFP bitmask flags are all prefixed with __GFP_.
The rest of the kernel tests for __GFP_WAIT not being set to indicate
an atomic allocation. We need to do the same.
Subhash Jadavani reported this partial backtrace:
Now consider this call stack from MMC block driver (this is on the ARMv7
based board):
[<c001b50c>] (v7_dma_inv_range+0x30/0x48) from [<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c)
[<c0017b8c>] (dma_cache_maint_page+0x1c4/0x24c) from [<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c)
[<c0017c28>] (___dma_page_cpu_to_dev+0x14/0x1c) from [<c0017ff8>] (dma_map_sg+0x3c/0x114)
This is caused by incrementing the struct page pointer, and running off
the end of the sparsemem page array. Fix this by incrementing by pfn
instead, and convert the pfn to a struct page.
Cc: <stable@vger.kernel.org>
Suggested-by: James Bottomley <JBottomley@Parallels.com>
Tested-by: Subhash Jadavani <subhashj@codeaurora.org>
Pull DRM updates from Dave Airlie:
"This is the one and only next pull for 3.8, we had a regression we
found last week, so I was waiting for that to resolve itself, and I
ended up with some Intel fixes on top as well.
Highlights:
- new driver: nvidia tegra 20/30/hdmi support
- radeon: add support for previously unused DMA engines, more HDMI
regs, eviction speeds ups and fixes
- i915: HSW support enable, agp removal on GEN6, seqno wrapping
- exynos: IPP subsystem support (image post proc), HDMI
- nouveau: display class reworking, nv20->40 z compression
- ttm: start of locking fixes, rcu usage for lookups,
- core: documentation updates, docbook integration, monotonic clock
usage, move from connector to object properties"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (590 commits)
drm/exynos: add gsc ipp driver
drm/exynos: add rotator ipp driver
drm/exynos: add fimc ipp driver
drm/exynos: add iommu support for ipp
drm/exynos: add ipp subsystem
drm/exynos: support device tree for fimd
radeon: fix regression with eviction since evict caching changes
drm/radeon: add more pedantic checks in the CP DMA checker
drm/radeon: bump version for CS ioctl support for async DMA
drm/radeon: enable the async DMA rings in the CS ioctl
drm/radeon: add VM CS parser support for async DMA on cayman/TN/SI
drm/radeon/kms: add evergreen/cayman CS parser for async DMA (v2)
drm/radeon/kms: add 6xx/7xx CS parser for async DMA (v2)
drm/radeon: fix htile buffer size computation for command stream checker
drm/radeon: fix fence locking in the pageflip callback
drm/radeon: make indirect register access concurrency-safe
drm/radeon: add W|RREG32_IDX for MM_INDEX|DATA based mmio accesss
drm/exynos: support extended screen coordinate of fimd
drm/exynos: fix x, y coordinates for right bottom pixel
drm/exynos: fix fb offset calculation for plane
This patch adds support for DMA_ATTR_FORCE_CONTIGUOUS attribute for
dma_alloc_attrs() in IOMMU-aware implementation. For allocating physically
contiguous buffers Contiguous Memory Allocator is used.
Expose another DMA operations function: arm_dma_set_mask. This
function will be added to a custom DMA ops for Armada 370/XP.
Depending of its configuration Armada 370/XP can be set as a "nearly"
coherent architecture. In this case the DMA ops is made of:
- specific functions for this architecture
- already exposed arm DMA related functions
- the arm_dma_set_mask which was not exposed yet.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
Fix build warning in __dma_alloc() as below:
arch/arm/mm/dma-mapping.c: In function '__dma_alloc':
arch/arm/mm/dma-mapping.c:653:29: warning: 'page' may be used uninitialized in this function [-Wuninitialized]
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Remove arch_is_coherent() from iommu dma ops and implement separate
coherent ops functions.
arch_is_coherent is problematic as it is a global symbol. This
doesn't work for multi-platform kernels or platforms which can support
per device coherent DMA.
This adds arm_coherent_dma_ops to be used for devices which connected
coherently (i.e. to the ACP port on Cortex-A9 or A15). The arm_dma_ops
are modified at boot when arch_is_coherent is true.
