Please refer to "Documentation/printk-formats.txt".
Change-Id: I3b14a2dfbe98edce0c09fcef6d5609299c59e64a
Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com>
Reviewed-on: http://git-master/r/394698
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Tested-by: Krishna Reddy <vdumpa@nvidia.com>
The end address shouldn't overwrap the next start address.
Change-Id: I48f95f43b79b9e678908a2a6f0562347d671fcad
Reviewed-on: http://git-master/r/394697
Fix incorrect phys address printed in trace message in
arm_coherent_iommu_unmap_page(). iommu_iova_to_phys() is
called after unmap iova in arm_coherent_iommu_unmap_page().
This causes invalid phys address printed in trace message.
Change-Id: I94acbfc9ef6f25c765ed3057b474596c8f12c6dc
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/391952
GVS: Gerrit_Virtual_Submit
Reviewed-by: Alex Waterman <alexw@nvidia.com>
Add missing trace print in arm_iommu_unmap_page.
Change-Id: I77914350aadccb0688b02658185e26652d4fdf2b
Reviewed-on: http://git-master/r/391951
Change-Id: Id97ea4af04323f4a4c18597a4dba0423c3061a27
Reviewed-on: http://git-master/r/391950
A helper function to check if a device is iommuable or not.
Bug 1490400
Change-Id: I65b803e57ad19e32214df8fde054a4f68535a74b
Reviewed-on: http://git-master/r/390156
Reviewed-by: Sri Krishna Chowdary <schowdary@nvidia.com>
Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
commit 10c8562f932d89c030083e15f9279971ed637136 upstream.
GFP_ATOMIC is not a single gfp flag, but a macro which expands to the other
flags and LACK of __GFP_WAIT flag. To check if caller wanted to perform an
atomic allocation, the code must test __GFP_WAIT flag presence. This patch
fixes the issue introduced in v3.6-rc5
slab allocator doens't acceppt DMA32, HIGHMEM gfp flags, and the
passed gfp param is for a buffer usage, not for meta data, page porter
array. Drop DMA32, HIGHMEM for meta data allocation.
Bug 1414172
Bug 1427490
Change-Id: Ie894c110ada185aed04d5fc41a46fa1de4bd9670
Reviewed-on: http://git-master/r/346947
There's a case that a client wants to avoid highmem explicitly. For
example some PM code lets firmware access to pages during
suspend/resume when IOMMU is off. This allows a client to specify a
type of pages{GPF_DMA,GFP_DMA32} to not contradicting to
GFP_HIGHMEM. This would be valid if AArch64 selects ZONE_DMA(32).
Bug 1414172
Change-Id: I3c97262f9388094dae12a350420a3d184d1e7144
Reviewed-on: http://git-master/r/343645
The data size varis depending on LPAE, 32 or 64. Modified to support
both without any build warnings.
Change-Id: Iacb8cbbffdab9f7148a62315e011c9a3a74d9030
Reviewed-on: http://git-master/r/339861
This new attribute can handle allocation & release of
memory of exact sizes by making call to attr version
of dma_alloc_from_coherent/dma_release_from_coherent
bug 1380639
Change-Id: I2af8c8131ff552ae5e0ac3a628139318b3395a73
Signed-off-by: Vandana Salve <vsalve@nvidia.com>
Reviewed-on: http://git-master/r/334000
Reviewed-by: Hiroshi Doyu <hdoyu@nvidia.com>
Tested-by: Hiroshi Doyu <hdoyu@nvidia.com>
Fix undefined reference to debug_dma_platformdata
Bug 1373902
Change-Id: I77544b64f84e8e43a9bfb873f6b2af375d341f0d
Reviewed-on: http://git-master/r/278134
Log the map/unmap/alloc/free calls. This ftrace is enabled by default.
Bug 1173494
Change-Id: I01fe24e570346413644368a6bff1578814f05f5a
Signed-off-by: Konsta Holtta <kholtta@nvidia.com>
Reviewed-on: http://git-master/r/268383
Export via debugfs the debug-dma infrastructure's data about allocated
mappings, and architecture specific information about possible mappings.
Bug 1173494
Change-Id: I6c64364dad69f83fd301a89938fe184dde33806a
Reviewed-on: http://git-master/r/268384
This new attribute can control to append gap pages or not on each
allocation via DMA attribute. The same needs to be done with freeing
too.
Bug 1303110
Bug 1173494
Change-Id: I6a038fbfb3e960d740fdc9aa752e2b88313af4b0
Reviewed-on: http://git-master/r/275022
Needed along with the common IOVA API chagne to pass DMA attribute.
Bug 1303110
Bug 1173494
Change-Id: Ia12984bbaf2486b0c1031feae983967e011270f2
Reviewed-on: http://git-master/r/275019
The variable "iova_gap_pages" is global in this file so that assigning
iova_gap_phys for its physical adress could be a bit easier to read
instead of converting via page_to_phys() at everytime.
Bug 1303110
Bug 1173494
Change-Id: Ifb8c5154fd5cc07d76e678fbf0ca84cb5c919f72
Reviewed-on: http://git-master/r/275017
Use correct name, "iova_gap_page". This pages are not only for
prefetcher but also guarding between IOVA allocations so that we call
this guard pages, which can include a prefetch page and/or a guard
page not to confuse.
Bug 1303110
Bug 1173494
Change-Id: Ie46cc8e33e2fdd520931d05f087a075af52c1a81
Reviewed-on: http://git-master/r/275016
Inconsistent type for set_dma_ops()
Change-Id: I78ebecaa335cafe627dc673cf54590d3354a7dc8
Reviewed-on: http://git-master/r/273536
Reviewed-by: Vandana Salve <vsalve@nvidia.com>
At IOVA area allocation, its end address check isn't enough strict in
the case of __alloc_iova_at().
Bug 1353121
Bug 1343762
Change-Id: Iebb1b100313ff70c23bbf262dddddfde1a52727b
Reviewed-on: http://git-master/r/265018
Make iommu_ops available before iommu_attach_devce()
Bug 1297607
Change-Id: I41f6f8c71e7056f67f8245bbcddd1cd6f3ecf5bf
Reviewed-on: http://git-master/r/264253
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Pass DMA attribute as IOMMU property, which can be proccessed in the
backend implementation of IOMMU. For example, DMA_ATTR_READ_ONLY can
be translated into each IOMMU H/W implementaion.
Bug 1309863
Change-Id: I0921ec35a4e056ea45a79acbea3e3b58a5a13a66
Reviewed-on: http://git-master/r/260009
Require also the prefetch page to map in pg_iommu_map*(): return error
if either it or the requested buffer fail to map.
Bug 1303110
Bug 1338469
Change-Id: I57f59207fb547390d87a24d7c4c7faec23a61768
Reviewed-on: http://git-master/r/256163
(cherry picked from commit b6fe2c18b9528a112943a054866a452f1fff3425)
Reviewed-on: http://git-master/r/259519
add support for prefetch and gap pages to be part of iova allocations
and mapping.
prefetch pages are necessary to avoid smmu faults, which are the result
of hw engines speculatively fetching beyond the iova mapped area.
gap pages are to separate the iova allcoations in order catch iova
access violations.
Bug 1303110
Bug 1265246
Bug 1215880
Bug 1327616
Change-Id: Ieacc0cd0a82e7f93746b453dafcec6a1766088a6
Reviewed-on: http://git-master/r/246693
(cherry picked from commit 889be8cbffa184c38f31542546d1f1ffbe8d8502)
Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com>
Reviewed-on: http://git-master/r/264780
Use iommu_map_sg() in dma_map_sg() for perf instead of calling
iommu_map() repeatedly.
Bug 1304956
Bug 1327616
Change-Id: Ib5941f719fdf822a166fbbb0dc3fad22e2767e21
Reviewed-on: http://git-master/r/253307
(cherry picked from commit 1765eb73dd6f668e8f9fde99230af8fcba0bd906)
Reviewed-on: http://git-master/r/264779
Add the version we can specify which IOVA to allocate.
Bug 1309498
Bug 1327616
Change-Id: I434171b09e40f888190b696b567d25777c69bb45
Reviewed-on: http://git-master/r/247938
(cherry picked from commit 063bf38038fa11b2ba0b7af64a2151b74dee8516)
Reviewed-on: http://git-master/r/250834
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Tested-by: Dan Willemsen <dwillemsen@nvidia.com>
This is necessary for iova_alloc_at(). On high order allocation, the
lower bit of base was ignored, and it returns incorrect IOVA address.
bug 1274699
bug 1254010
bug 1226176
bug 999937
Change-Id: I0be96b97c8036f8a5bc1c35a1c85e04593021a2b
Reviewed-on: http://git-master/r/228729
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Add new API dma_ops->map_pages() for performance
bug 1254010
bug 1226176
bug 999937
Change-Id: Ib8bbcad53024225173be765358af03d0961f8af0
Reviewed-on: http://git-master/r/225673
This patch adds DMA_ATTR_SKIP_CPU_SYNC attribute to the DMA-mapping
subsystem.
This is the counter part of map_page_at() which just maps the
pre-allocate iova to a page. With this attribute, unmap_page() unmap
the link between iova and a page, leaving iova allocated.
bug 1235233
Change-Id: Id5535b73e0ca212a045dd0b0ff57de8432e7cf13
Reviewed-on: http://git-master/r/204468
Add dev_dbg() to trance IOMMU atomic allocation,
__iommu_{alloc,free}_atomic().
Usage:
echo -n 'func __iommu_alloc_atomic +p' > /sys/kernel/debug/dynamic_debug/control
echo -n 'func __iommu_free_atomic +p' > /sys/kernel/debug/dynamic_debug/control
Change-Id: Ibe322c2d009652eb6b07fd988ff1fff97268e207
Reviewed-on: http://git-master/r/197752
pfn_valid() should be done in a caller function if *needed*. map/unmap
care about address mapping only but should not care about if the
address is a valid page or not. This allows to unmap out of kernel
control address by dma mapping API, for exmaple ones mapped by
dma_map_linear(-ENXIO)
bug 1222494
Change-Id: I4d59e4078edf3c8876da8f4492bd0c306b693815
Reviewed-on: http://git-master/r/194630
iova_alloc_at() sets -ENXIO at *iova for out-of-range, and -EINVAL for
the rest failure cases. We need to differenciate out-of-range to know
if 'da' reservation fails because of overwrapping or out-of-range.
Bug 1182882
Bug 1024594
Change-Id: If0441c0521ef74c8792a8f0562a821ca76dbbc34
Reviewed-on: http://git-master/r/169327
Reviewed-by: Simone Willett <swillett@nvidia.com>
Rebase-Id: R6abb22d807d44a6a1e876116c58ab0e58c441e65
To allocate IOVA area at specified address
Rebase-Id: R6070776b91e090e2a3dd342743e8e07edd63b747
There are some cases that IOVA allocation and mapping have to be done
seperately, especially for perf optimization reasons. This patch
allows client modules to {alloc,free} IOVA space without backing up
actual pages for that area.
Rebase-Id: Rfe3d8edc2bdec9e69f90a76d8229974208b6bdf5
->iova>_get_free_total() returns the sum of available free areas.
->iova>_get_free_max() returns the largest available free area size.
Change-Id: I817ff46bea799a809e2e6b163b2e86cb737cf077
Rebase-Id: R9fa69019291e268816b8b316c98e4f39d8555ea3
Skip cache maint for invalid page but warn it.
Change-Id: I780587d132fd9440767046877c0724939897889f
Rebase-Id: Rb3610fd43422fbce269431146defbc6eb7272de8
dma_alloc_coherent wants to split pages after allocation in order to
reduce the memory footprint. This does not work well with GFP_COMP
pages, so drop this flag before allocation.
This patch is ported from arch/avr32
(commit 3611553ef985ef7c5863c8a94641738addd04cff).
Change-Id: I67eb2b15807c36c6a3ade95ee35bf5856d8e0e11
Rebase-Id: Rf13a569ebe836d341cf4d9287ff4b4711dde85cc
'smp-hotplug' into for-linus
In kmap_atomic(), kmap_high_get() is invoked for checking already
mapped area. In __flush_dcache_page() and dma_cache_maint_page(),
we explicitly call kmap_high_get() before kmap_atomic()
when cache_is_vipt(), so kmap_high_get() can be invoked twice.
This is useless operation, so remove one.
v2: change cache_is_vipt() to cache_is_vipt_nonaliasing() in order to
be self-documented
Acked-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Atomic pool should always be allocated from DMA zone if such zone is
available in the system to avoid issues caused by limited dma mask of
any of the devices used for making an atomic allocation.
Reported-by: Krzysztof Halasa <khc@pm.waw.pl>
Cc: Stable <stable@vger.kernel.org> [v3.6+]
This patch removes page_address() usage in IOMMU-aware dma-mapping
implementation and replaced it with direct use of the cpu virtual address
provided by the caller. page_address() returned incorrect address for
pages remapped in atomic pool, what caused memory leak.
Reported-by: Hiroshi Doyu <hdoyu@nvidia.com>
Alignment order for a dma iommu buffer is set by buffer size. For
large buffer, it is a waste of iommu address space. So configurable
parameter to limit maximum alignment order can reduce the waste.
Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com>
Signed-off-by: Kyungmin.park <kyungmin.park@samsung.com>
IOMMU can provide access to any memory page, so there is no point in
limiting the allocated pages only to lowmem, once other parts of
dma-mapping subsystem correctly supports himem pages.
This patch adds missing pieces to correctly support memory pages served
from CMA regions placed in high memory zones. Please note that the default
global CMA area is still put into lowmem and is limited by optional
architecture specific DMA zone. One can however put device specific CMA
regions in high memory zone to reduce lowmem usage.
Acked-by: Michal Nazarewicz <mina86@mina86.com>
This patch adds EXPORT_SYMBOL_GPL calls to the three arm iommu
functions - arm_iommu_create_mapping, arm_iommu_free_mapping
and arm_iommu_attach_device. These three functions are arm specific
wrapper functions for creating/freeing/using an iommu mapping and
they are called by various drivers. If any of these drivers need
to be built as dynamic modules, these functions need to be exported.
Changelog v2: using EXPORT_SYMBOL_GPL as suggested by Marek.
Signed-off-by: Prathyush K <prathyush.k@samsung.com>
[m.szyprowski: extended with recently introduced
EXPORT_SYMBOL_GPL(arm_iommu_detach_device)]
A counter part of arm_iommu_attach_device().
struct dma_map_ops iommu_ops doesn't have ->set_dma_mask, which causes
crash when dma_set_mask() is called from some driver.
Realview fails to boot with this warning:
BUG: spinlock lockup suspected on CPU#0, init/1
lock: 0xcf8bde10, .magic: dead4ead, .owner: init/1, .owner_cpu: 0
Backtrace:
[<c00185d8>] (dump_backtrace+0x0/0x10c) from [<c03294e8>] (dump_stack+0x18/0x1c) r6:cf8bde10 r5:cf83d1c0 r4:cf8bde10 r3:cf83d1c0
[<c03294d0>] (dump_stack+0x0/0x1c) from [<c018926c>] (spin_dump+0x84/0x98)
[<c01891e8>] (spin_dump+0x0/0x98) from [<c0189460>] (do_raw_spin_lock+0x100/0x198)
[<c0189360>] (do_raw_spin_lock+0x0/0x198) from [<c032cbac>] (_raw_spin_lock+0x3c/0x44)
[<c032cb70>] (_raw_spin_lock+0x0/0x44) from [<c01c9224>] (pl011_console_write+0xe8/0x11c)
[<c01c913c>] (pl011_console_write+0x0/0x11c) from [<c002aea8>] (call_console_drivers.clone.7+0xdc/0x104)
[<c002adcc>] (call_console_drivers.clone.7+0x0/0x104) from [<c002b320>] (console_unlock+0x2e8/0x454)
[<c002b038>] (console_unlock+0x0/0x454) from [<c002b8b4>] (vprintk_emit+0x2d8/0x594)
[<c002b5dc>] (vprintk_emit+0x0/0x594) from [<c0329718>] (printk+0x3c/0x44)
[<c03296dc>] (printk+0x0/0x44) from [<c002929c>] (warn_slowpath_common+0x28/0x6c)
[<c0029274>] (warn_slowpath_common+0x0/0x6c) from [<c0029304>] (warn_slowpath_null+0x24/0x2c)
[<c00292e0>] (warn_slowpath_null+0x0/0x2c) from [<c0070ab0>] (lockdep_trace_alloc+0xd8/0xf0)
[<c00709d8>] (lockdep_trace_alloc+0x0/0xf0) from [<c00c0850>] (kmem_cache_alloc+0x24/0x11c)
[<c00c082c>] (kmem_cache_alloc+0x0/0x11c) from [<c00bb044>] (__get_vm_area_node.clone.24+0x7c/0x16c)
[<c00bafc8>] (__get_vm_area_node.clone.24+0x0/0x16c) from [<c00bb7b8>] (get_vm_area_caller+0x48/0x54)
[<c00bb770>] (get_vm_area_caller+0x0/0x54) from [<c0020064>] (__alloc_remap_buffer.clone.15+0x38/0xb8)
[<c002002c>] (__alloc_remap_buffer.clone.15+0x0/0xb8) from [<c0020244>] (__dma_alloc+0x160/0x2c8)
[<c00200e4>] (__dma_alloc+0x0/0x2c8) from [<c00204d8>] (arm_dma_alloc+0x88/0xa0)[<c0020450>] (arm_dma_alloc+0x0/0xa0) from [<c00beb00>] (dma_pool_alloc+0xcc/0x1a8)
[<c00bea34>] (dma_pool_alloc+0x0/0x1a8) from [<c01a9d14>] (pl08x_fill_llis_for_desc+0x28/0x568)
[<c01a9cec>] (pl08x_fill_llis_for_desc+0x0/0x568) from [<c01aab8c>] (pl08x_prep_slave_sg+0x258/0x3b0)
[<c01aa934>] (pl08x_prep_slave_sg+0x0/0x3b0) from [<c01c9f74>] (pl011_dma_tx_refill+0x140/0x288)
[<c01c9e34>] (pl011_dma_tx_refill+0x0/0x288) from [<c01ca748>] (pl011_start_tx+0xe4/0x120)
[<c01ca664>] (pl011_start_tx+0x0/0x120) from [<c01c54a4>] (__uart_start+0x48/0x4c)
[<c01c545c>] (__uart_start+0x0/0x4c) from [<c01c632c>] (uart_start+0x2c/0x3c)
[<c01c6300>] (uart_start+0x0/0x3c) from [<c01c795c>] (uart_write+0xcc/0xf4)
[<c01c7890>] (uart_write+0x0/0xf4) from [<c01b0384>] (n_tty_write+0x1c0/0x3e4)
[<c01b01c4>] (n_tty_write+0x0/0x3e4) from [<c01acfe8>] (tty_write+0x144/0x240)
[<c01acea4>] (tty_write+0x0/0x240) from [<c01ad17c>] (redirected_tty_write+0x98/0xac)
[<c01ad0e4>] (redirected_tty_write+0x0/0xac) from [<c00c371c>] (vfs_write+0xbc/0x150)
[<c00c3660>] (vfs_write+0x0/0x150) from [<c00c39c0>] (sys_write+0x4c/0x78)
[<c00c3974>] (sys_write+0x0/0x78) from [<c0014460>] (ret_fast_syscall+0x0/0x3c)
This happens because the DMA allocation code is not respecting atomic
allocations correctly.
GFP flags should not be tested for GFP_ATOMIC to determine if an
atomic allocation is being requested. GFP_ATOMIC is not a flag but
a value. The GFP bitmask flags are all prefixed with __GFP_.
The rest of the kernel tests for __GFP_WAIT not being set to indicate
an atomic allocation. We need to do the same.
