Some nommu systems have RAM at address 0. When vectors are not located
there, the very beginning of memory remains available for dynamic
allocations. The memblock allocator explicitly skips the first page
but the standard page allocator does not, and while it correctly returns
a non-null struct page pointer for that page, page_address() gives 0
which gets confused with NULL (out of memory) by callers despite having
plenty of free memory left.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- add framework for supporting PCIe devices in Endpoint mode (Kishon
Vijay Abraham I)
- use non-postable PCI config space mappings when possible (Lorenzo
Pieralisi)
- clean up and unify mmap of PCI BARs (David Woodhouse)
- export and unify Function Level Reset support (Christoph Hellwig)
- avoid FLR for Intel 82579 NICs (Sasha Neftin)
- add pci_request_irq() and pci_free_irq() helpers (Christoph Hellwig)
- short-circuit config access failures for disconnected devices (Keith
Busch)
- remove D3 sleep delay when possible (Adrian Hunter)
- freeze PME scan before suspending devices (Lukas Wunner)
- stop disabling MSI/MSI-X in pci_device_shutdown() (Prarit Bhargava)
- disable boot interrupt quirk for ASUS M2N-LR (Stefan Assmann)
- add arch-specific alignment control to improve device passthrough by
avoiding multiple BARs in a page (Yongji Xie)
- add sysfs sriov_drivers_autoprobe to control VF driver binding
(Bodong Wang)
- allow slots below PCI-to-PCIe "reverse bridges" (Bjorn Helgaas)
- fix crashes when unbinding host controllers that don't support
removal (Brian Norris)
- add driver for MicroSemi Switchtec management interface (Logan
Gunthorpe)
- add driver for Faraday Technology FTPCI100 host bridge (Linus
Walleij)
- add i.MX7D support (Andrey Smirnov)
- use generic MSI support for Aardvark (Thomas Petazzoni)
- make Rockchip driver modular (Brian Norris)
- advertise 128-byte Read Completion Boundary support for Rockchip
(Shawn Lin)
- advertise PCI_EXP_LNKSTA_SLC for Rockchip root port (Shawn Lin)
- convert atomic_t to refcount_t in HV driver (Elena Reshetova)
- add CPU IRQ affinity in HV driver (K. Y. Srinivasan)
- fix PCI bus removal in HV driver (Long Li)
- add support for ThunderX2 DMA alias topology (Jayachandran C)
- add ThunderX pass2.x 2nd node MCFG quirk (Tomasz Nowicki)
- add ITE 8893 bridge DMA alias quirk (Jarod Wilson)
- restrict Cavium ACS quirk only to CN81xx/CN83xx/CN88xx devices
(Manish Jaggi)
* tag 'pci-v4.12-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (146 commits)
PCI: Don't allow unbinding host controllers that aren't prepared
ARM: DRA7: clockdomain: Change the CLKTRCTRL of CM_PCIE_CLKSTCTRL to SW_WKUP
MAINTAINERS: Add PCI Endpoint maintainer
Documentation: PCI: Add userguide for PCI endpoint test function
tools: PCI: Add sample test script to invoke pcitest
tools: PCI: Add a userspace tool to test PCI endpoint
Documentation: misc-devices: Add Documentation for pci-endpoint-test driver
misc: Add host side PCI driver for PCI test function device
PCI: Add device IDs for DRA74x and DRA72x
dt-bindings: PCI: dra7xx: Add DT bindings to enable unaligned access
PCI: dwc: dra7xx: Workaround for errata id i870
dt-bindings: PCI: dra7xx: Add DT bindings for PCI dra7xx EP mode
PCI: dwc: dra7xx: Add EP mode support
PCI: dwc: dra7xx: Facilitate wrapper and MSI interrupts to be enabled independently
dt-bindings: PCI: Add DT bindings for PCI designware EP mode
PCI: dwc: designware: Add EP mode support
Documentation: PCI: Add binding documentation for pci-test endpoint function
ixgbe: Use pcie_flr() instead of duplicating it
IB/hfi1: Use pcie_flr() instead of duplicating it
PCI: imx6: Fix spelling mistake: "contol" -> "control"
The PCI bus specification (rev 3.0, 3.2.5 "Transaction Ordering and
Posting") defines rules for PCI configuration space transactions ordering
and posting, that state that configuration writes have to be non-posted
transactions.
Current ioremap interface on ARM provides mapping functions that provide
"bufferable" writes transactions (ie ioremap uses MT_DEVICE memory type)
aka posted writes, so PCI host controller drivers have no arch interface to
remap PCI configuration space with memory attributes that comply with the
PCI specifications for configuration space.
Implement an ARM specific pci_remap_cfgspace() interface that allows to map
PCI config memory regions with MT_UNCACHED memory type (ie strongly ordered
- non-posted writes), providing a remap function that complies with PCI
specifications for config space transactions.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: Russell King <linux@armlinux.org.uk>
Greg upon trying to boot no-MMU Kernel on ARM926EJ reported boot
failure. He root caused it to ID_PFR1 access introduced by the
commit mentioned in the fixes tag below.
All CP15 processors need not have processor feature registers, only
for architectures defined by CPUID scheme would have it. Hence check
for it before accessing processor feature register, ID_PFR1.
Fixes: f8300a0b5de0 ("ARM: 8647/2: nommu: dynamic exception base address setting")
Reported-by: Greg Ungerer <gerg@uclinux.org>
Signed-off-by: afzal mohammed <afzal.mohd.ma@gmail.com>
Tested-by: Greg Ungerer <gerg@uclinux.org>
No-MMU dynamic exception base address configuration on CP15
processors. In the case of low vectors, decision based on whether
security extensions are enabled & whether remap vectors to RAM
CONFIG option is selected.
For no-MMU without CP15, current default value of 0x0 is retained.
Tested-by: Vladimir Murzin <vladimir.murzin@arm.com>
The logic for sanity_check_meminfo has become difficult to
follow. Clean up the code so it's more obvious what the code
is actually trying to do. Additionally, meminfo is now removed
so rename the function to better describe its purpose.
Tested-by: Magnus Lilja <lilja.magnus@gmail.com>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
Signed-off-by: Laura Abbott <labbott@redhat.com>
Pull ARM updates from Russell King:
"Changes included in this pull request:
- revert pxa2xx-flash back to using ioremap_cached() and switch
memremap() to use arch_memremap_wb()
- remove pci=firmware command line argument handling
- remove unnecessary arm_dma_set_mask() implementation, the generic
implementation will do for ARM
- removal of the ARM kallsyms "hack" to work around mode switching
veneers and vectors located below PAGE_OFFSET
- tidy up build system output a little
- add L2 cache power management DT bindings
- remove duplicated local_irq_disable() in reboot paths
- handle AMBA primecell devices better at registration time with PM
domains (needed for Samsung SoCs)
- ARM specific preparation to support Keystone II kexec"
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm:
ARM: 8567/1: cache-uniphier: activate ways for secondary CPUs
ARM: 8570/2: Documentation: devicetree: Add PL310 PM bindings
ARM: 8569/1: pl2x0: Add OF control of cache power management
ARM: 8568/1: reboot: remove duplicated local_irq_disable()
ARM: 8566/1: drivers: amba: properly handle devices with power domains
ARM: provide arm_has_idmap_alias() helper
ARM: kexec: remove 512MB restriction on kexec crashdump
ARM: provide improved virt_to_idmap() functionality
ARM: kexec: fix crashkernel= handling
ARM: 8557/1: specify install, zinstall, and uinstall as PHONY targets
ARM: 8562/1: suppress "include/generated/mach-types.h is up to date."
ARM: 8553/1: kallsyms: remove --page-offset command line option
ARM: 8552/1: kallsyms: remove special lower address limit for CONFIG_ARM
ARM: 8555/1: kallsyms: ignore ARM mode switching veneers
ARM: 8548/1: dma-mapping: remove arm_dma_set_mask()
ARM: 8554/1: kernel: pci: remove pci=firmware command line parameter handling
ARM: memremap: implement arch_memremap_wb()
memremap: add arch specific hook for MEMREMAP_WB mappings
mtd: pxa2xx-flash: switch back from memremap to ioremap_cached
ARM: reintroduce ioremap_cached() for creating cached I/O mappings
Commit 19accfd3 (ARM: move vector stubs) moved the vector stubs in an
additional page above the base vector one. This change wasn't taken into
account by the nommu memreserve.
This patch ensures that the kernel won't overwrite any vector stub on
nommu.
[changed the MPU side too]
Signed-off-by: Jean-Philippe Brucker <jean-philippe.brucker@arm.com>
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
Commit 1c2f87c (ARM: 8025/1: Get rid of meminfo) broke the support for
MPU on ARMv7-R. This patch adapts the code inside CONFIG_ARM_MPU to use
memblocks appropriately.
MPU initialisation only uses the first memory region, and removes all
subsequent ones. Because looping over all regions that need removal is
inefficient, and memblock_remove already handles memory ranges, we can
flatten the 'for_each_memblock' part.
The generic memremap() falls back to using ioremap_cache() to create
MEMREMAP_WB mappings if the requested region is not already covered
by the linear mapping, unless the architecture provides an implementation
of arch_memremap_wb().
Since ioremap_cache() is not appropriate on ARM to map memory with the
same attributes used for the linear mapping, implement arch_memremap_wb()
which does exactly that. Also, relax the WARN() check to allow MT_MEMORY_RW
mappings of pfn_valid() pages.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
The original ARM-only ioremap flavor 'ioremap_cached' has been renamed
to 'ioremap_cache' to align with other architectures, and subsequently
abused in generic code to map things like firmware tables in memory.
For that reason, there is currently an effort underway to deprecate
ioremap_cache, whose semantics are poorly defined, and which is typed
with an __iomem annotation that is inappropriate for mappings of ordinary
memory.
However, original users of ioremap_cached() used it in a context where
the I/O connotation is appropriate, and replacing those instances with
memremap() does not make sense. So let's revive ioremap_cached(), so
that we can change back those original users before we drop ioremap_cache
entirely in favor of memremap.
Convert the ioremap*() preprocessor macros to real functions, moving
them out of line. This allows us to kill off __arm_ioremap(), and
__arm_iounmap() helpers, and remove __arm_ioremap_pfn_caller() from
global view.
Eliminate the needless nommu version of this function, and get rid of
the proc_info_list structure argument - we no longer need this in order
to fix up the page table entries.
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
Tested-by: Murali Karicheri <m-karicheri2@ti.com>
Commit 1c2f87c (ARM: 8025/1: Get rid of meminfo) changed find_limits
to use memblock_get_current_limit for calculating the max_low pfn.
nommu targets never actually set a limit on memblock though which
means memblock_get_current_limit will just return the default
value. Set the memblock_limit to be the end of DDR to make sure
bounds are calculated correctly.
memblock is now fully integrated into the kernel and is the prefered
method for tracking memory. Rather than reinvent the wheel with
meminfo, migrate to using memblock directly instead of meminfo as
an intermediate.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Tested-by: Leif Lindholm <leif.lindholm@linaro.org>
The 0-day kernel build robot found this new warning:
arch/arm/mm/nommu.c:303:17: warning: 'struct proc_info_list' declared inside parameter list [enabled by default]
arch/arm/mm/nommu.c:303:17: warning: its scope is only this definition or declaration, which is probably not what you want [enabled by default]
Fix it by including the appropriate header.
No-MMU configurations currenty fail to build because they are missing
the early_paging_init() symbol.
Acked-by: Olof Johansson <olof@lixom.net>
Signed-off-by: Thierry Reding <treding@nvidia.com>
struct machine_desc records are defined everywhere as a 'const'
structure, but unfortuantely it loses its const-ness through the use of
linker magic - the symbols which surround the section are not declared
const so it becomes possible not to use 'const' for pointers to these
const structures.
Let's fix this oversight - all pointers to these structures should be
marked const too.
arch/arm/Makefile
arch/arm/include/asm/glue-proc.h
Commit 1bc3974 (ARM: 7755/1: handle user space mapped pages in
flush_kernel_dcache_page) moved the implementation of
flush_kernel_dcache_page() into mm/flush.c but did not implement it
on noMMU ARM.
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
Acked-by: Kevin Hilman <khilman@linaro.org>
Cc: <stable@vger.kernel.org> # 3.2+: 1bc3974: ARM: 7755/1
Much like with the MMU, MPU initialisation is performed in two stages; the
first in the pre-C world and the 'real' initialisation during arch setup.
This patch wires in previously added MPU initialisation functions so that
the whole of memory is mapped with the appropriate region properties for
'normal' RAM (the appropriate properties depend on whether the system is
SMP).
Stub initialisation functions are added for the case that there MPU support
is not configured in to the kernel.
Signed-off-by: Jonathan Austin <jonathan.austin@arm.com>
Reviewed-by: Will Deacon <will.deacon@arm.com>
CC: Hyok S. Choi <hyok.choi@samsung.com>
This patch adds new functions for probing and initialising the ARMv7
PMSA-compliant MPU.
These use the pre-defined and reserved MPU_PROBE_REGION for establishing
properties of the MPU, which is necessary because certain probe operations
require modifying region properties and reading back the results.
This patch also introduces a minimal sanity_check_meminfo_mpu function, that
ensures that the memory set-up passed to the kernel can be used in conjunction
with the MPU. The base address of a region must be aligned to the region size,
otherwise behavior is unpredictable and region sizes can only be specified as a
power-of-two. To simplify the satisfaction of these requirements this
implementation currently enforces that all memory is contiguous from
PHYS_OFFSET, merging banks that are contiguous but passed in separately.
The functions are added in this patch but wired in to the boot process later
in the series.
Several of the ioremap functions use unsigned long in places
resulting in truncation if physical addresses greater than
4G are passed in. Change the types of the functions and the
callers accordingly.
Cc: Krzysztof Halasa <khc@pm.waw.pl>
Cc: Stephen Boyd <sboyd@codeaurora.org>
This patch adds the base support for the ARMv7-M
architecture. It consists of the corresponding arch/arm/mm/ files and
various #ifdef's around the kernel. Exception handling is implemented by
a subsequent patch.
[ukleinek: squash in some changes originating from commit
b5717ba (Cortex-M3: Add support for the Microcontroller Prototyping System)
from the v2.6.33-arm1 patch stack, port to post 3.6, drop zImage
support, drop reorganisation of pt_regs, assert CONFIG_CPU_V7M doesn't
leak into installed headers and a few cosmetic changes]
Reviewed-by: Jonathan Austin <jonathan.austin@arm.com>
Tested-by: Jonathan Austin <jonathan.austin@arm.com>
Commit 94e5a85b ("ARM: earlier initialization of vectors page") made it
the responsibility of paging_init to initialise the vectors page.
This patch adds a call to early_trap_init for the !CONFIG_MMU case,
placing the vectors at CONFIG_VECTORS_BASE.
Cc: Jonathan Austin <jonathan.austin@arm.com>
With commit 4fe7ef3a081 (ARM: provide runtime hook for ioremap/iounmap),
compiles with !CONFIG_MMU were broken. Rename nommu __iounmap to
__arm_iounmap and add arch_ioremap_caller and arch_iounmap. Its
not expected that these need to be overriden for !CONFIG_MMU, so setting
the function ptrs has no effect in this case.
devel-stable
Some upcoming changes must know the VMALLOC_START value, which is based
on high_memory, before bootmem_init() is called.
The best location to set it is in sanity_check_meminfo() where the needed
computation is already done, and in the non MMU case it is trivial to do
now that the meminfo array is already sorted at that point.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
setup_mm_for_reboot() doesn't make use of its argument, so remove it.
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Ensure that the meminfo array is sanity checked before we pass the
memory to memblock. This helps to ensure that memblock and meminfo
agree on the dimensions of memory, especially when more memory is
passed than the kernel can deal with.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Move the platform specific bootmem memory reservations out of
arch/arm/mm/mmu.c into their respective platform files.
Everything should now be using sparsemem rather than discontigmem, so
remove the code supporting discontigmem from ARM.
Commit 7959722 introduced calls to copy_(to|from)_user_page() from
access_process_vm() in mm/nommu.c. The copy_to_user_page() was not
implemented on noMMU ARM.
Commit 31aa8fd6 introduced the __arm_ioremap_caller() function but the
nommu.c version did not have the _caller suffix.
This allows the procfs vmallocinfo file to show who created the ioremap
regions. Note: __builtin_return_address(0) doesn't do what's expected
if its used in an inline function, so we leave __arm_ioremap callers
in such places alone.
... and rename the function since it no longer operates on just
pages.
This is needed for the struct meminfo definition.
Update to use the asm/sections.h header rather than declaring these
symbols ourselves. Change __data_start to _data to conform with the
naming found within asm/sections.h.
Currently there are two instances of struct meminfo: one in
kernel/setup.c marked __initdata, and another in mm/init.c with
permanent storage. Let's keep only the later to directly populate
the permanent version from arm_add_memory().
Also move common validation tests between the MMU and non-MMU cases
into arm_add_memory() to remove some duplication. Protection against
overflowing the membank array is also moved in there in order to cover
the kernel cmdline parsing path as well.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
The newly introduced sanity_check_meminfo() function should be
used to collect all validation of the meminfo array, which we
have in bootmem_init(). Move it there.
... some of which are now in linux/*.h headers.
This patchset adds a flags variable to reserve_bootmem() and uses the
BOOTMEM_EXCLUSIVE flag in crashkernel reservation code to detect collisions
between crashkernel area and already used memory.
This patch:
Change the reserve_bootmem() function to accept a new flag BOOTMEM_EXCLUSIVE.
If that flag is set, the function returns with -EBUSY if the memory already
has been reserved in the past. This is to avoid conflicts.
Because that code runs before SMP initialisation, there's no race condition
inside reserve_bootmem_core().
[akpm@linux-foundation.org: fix powerpc build]
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: <linux-arch@vger.kernel.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
__ioremap() took a set of page table flags (specifically the cacheable
and bufferable bits) to control the mapping type. However, with
the advent of ARMv6, this is far too limited.
Replace the page table flags with a memory type index, so that the
desired attributes can be selected from the mem_type table.
Finally, to prevent silent miscompilation due to the differing
arguments, rename the __ioremap() and __ioremap_pfn() functions.
Fix warnings and errors in arch/arm/mm for nommu build.
Remove commented out function prototype in pgtable-nommu.h
Add an empty setup_mm_for_reboot() function for nommu machines.
Move the MMU specific code from init.c into mmu.c, and add nommu
fixups to nommu.c
