bug 865816
Adapted from x86 change_page_attr() implementation
Change-Id: I398c9d460b841484de4fcfcac10ffffdf49a4a5a
Reviewed-on: http://git-master/r/56769
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Tested-by: Krishna Reddy <vdumpa@nvidia.com>
Rebase-Id: Rddeccf358c948ba84af52316f084814ae53dca5e
Cortex-A9 has PIPT D-cache which do not require clean the cache
on creating page table.
Original-Change-Id: I42d528be83ea8def96045c7e575c7b3ed95f5980
Reviewed-on: http://git-master/r/40505
Reviewed-by: Heechul Yun <hyun@nvidia.com>
Tested-by: Heechul Yun <hyun@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R214ce4b138abb18e1cfe79465087c39ead248d72
Add pud_offset() et.al. between the pgd and pmd code in preparation of
using pgtable-nopud.h rather than 4level-fixup.h.
This incorporates a fix from Jamie Iles <jamie@jamieiles.com> for
uaccess_with_memcpy.c.
pte alloc routines must wait for split_huge_page if the pmd is not present
and not null (i.e. pmd_trans_splitting). The additional branches are
optimized away at compile time by pmd_trans_splitting if the config option
is off. However we must pass the vma down in order to know the anon_vma
lock to wait for.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
FIRST_USER_PGD_NR is now unnecessary, as this has been replaced by
FIRST_USER_ADDRESS except in the architecture code. Fix up the last
usage of FIRST_USER_PGD_NR, and remove the definition.
Remove knowledge of the 2-level wrapping in pgd_free(), and use the
pXd_none_or_clear_bad() macros when checking the entries.
These old names are just aliases for pgd_alloc/pgd_free. Just use the
new names.
Since we no longer need to provide KM_type, the whole pte_*map_nested()
API is now redundant, remove it.
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
As suggested by Andrew Morton, remove memzero() - it's not supported
on other architectures so use of it is a potential build breaking bug.
Since the compiler optimizes memset(x,0,n) to __memzero() perfectly
well, we don't miss out on the underlying benefits of memzero().
Since 2f569af (CONFIG_HIGHPTE vs. sub-page page tables.) pte_free() calls
pte_lock_deinit() and dec_zone_page_state(). So free_pgd_slow must not call
the latter two when calling the first.
Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com>
(with Martin Schwidefsky <schwidefsky@de.ibm.com>)
The pgd/pud/pmd/pte page table allocation functions get a mm_struct pointer as
first argument. The free functions do not get the mm_struct argument. This
is 1) asymmetrical and 2) to do mm related page table allocations the mm
argument is needed on the free function as well.
[kamalesh@linux.vnet.ibm.com: i386 fix]
[akpm@linux-foundation.org: coding-syle fixes]
Cc: <linux-arch@vger.kernel.org>
Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
L_PTE_ASID is not really required to be stored in every PTE, since we
can identify it via the address passed to set_pte_at(). So, create
set_pte_ext() which takes the address of the PTE to set, the Linux
PTE value, and the additional CPU PTE bits which aren't encoded in
the Linux PTE value.
mm-armv.c now only contains the pgd allocation/freeing code, so
rename it to have a more sensible filename.
