path: root/arch/arm/mm/proc-arm1020e.S
2011-07-07ARM: mm: proc-arm1020e: Use the new processor struct macrosDave Martin
Signed-off-by: Dave Martin <dave.martin@linaro.org>
2011-02-22ARM: pm: add generic CPU suspend/resume supportRussell King
This adds core support for saving and restoring CPU coprocessor registers for suspend/resume support. This contains support for suspend with ARM920, ARM926, SA11x0, PXA25x, PXA27x, PXA3xx, V6 and V7 CPUs. Tested on Assabet and Tegra 2. Tested-by: Colin Cross <ccross@android.com> Tested-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-28ARM: 6466/1: implement flush_icache_all for the rest of the CPUsMika Westerberg
Commit 81d11955bf0 ("ARM: 6405/1: Handle __flush_icache_all for CONFIG_SMP_ON_UP") added a new function to struct cpu_cache_fns: flush_icache_all(). It also implemented this for v6 and v7 but not for v5 and backwards. Without the function pointer in place, we will be calling wrong cache functions. For example with ep93xx we get following: Unable to handle kernel paging request at virtual address ee070f38 pgd = c0004000 [ee070f38] *pgd=00000000 Internal error: Oops: 80000005 [#1] PREEMPT last sysfs file: Modules linked in: CPU: 0 Not tainted (2.6.36+ #1) PC is at 0xee070f38 LR is at __dma_alloc+0x11c/0x2d0 pc : [<ee070f38>] lr : [<c0032c8c>] psr: 60000013 sp : c581bde0 ip : 00000000 fp : c0472000 r10: c0472000 r9 : 000000d0 r8 : 00020000 r7 : 0001ffff r6 : 00000000 r5 : c0472400 r4 : c5980000 r3 : c03ab7e0 r2 : 00000000 r1 : c59a0000 r0 : c5980000 Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: c000717f Table: c0004000 DAC: 00000017 Process swapper (pid: 1, stack limit = 0xc581a270) [<c0032c8c>] (__dma_alloc+0x11c/0x2d0) [<c0032e5c>] (dma_alloc_writecombine+0x1c/0x24) [<c0204148>] (ep93xx_pcm_preallocate_dma_buffer+0x44/0x60) [<c02041c0>] (ep93xx_pcm_new+0x5c/0x88) [<c01ff188>] (snd_soc_instantiate_cards+0x8a8/0xbc0) [<c01ff59c>] (soc_probe+0xfc/0x134) [<c01adafc>] (platform_drv_probe+0x18/0x1c) [<c01acca4>] (driver_probe_device+0xb0/0x16c) [<c01ac284>] (bus_for_each_drv+0x48/0x84) [<c01ace90>] (device_attach+0x50/0x68) [<c01ac0f8>] (bus_probe_device+0x24/0x44) [<c01aad7c>] (device_add+0x2fc/0x44c) [<c01adfa8>] (platform_device_add+0x104/0x15c) [<c0015eb8>] (simone_init+0x60/0x94) [<c0021410>] (do_one_initcall+0xd0/0x1a4) __dma_alloc() calls (inlined) __dma_alloc_buffer() which ends up calling dmac_flush_range(). Now since the entries in the arm920_cache_fns are shifted by one, we jump into address 0xee070f38 which is actually next instruction after the arm920_cache_fns structure. So implement flush_icache_all() for the rest of the supported CPUs using a generic 'invalidate I cache' instruction. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-08ARM: hotplug cpu: Keep processor information, startup code & ↵Russell King
__lookup_processor_type When hotplug CPU is enabled, we need to keep the list of supported CPUs, their setup functions, and __lookup_processor_type in place so that we can find and initialize secondary CPUs. Move these into the __CPUINIT section. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: Factor out common code from cpu_proc_fin()Russell King
All implementations of cpu_proc_fin() start by disabling interrupts and then flush caches. Rather than have every processors proc_fin() implementation do this, move it out into generic code - and move the cache flush past setup_mm_for_reboot() (so it can benefit from having caches still enabled.) This allows cpu_proc_fin() to become independent of the L1/L2 cache types, and eventually move the L2 cache flushing into the L2 support code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-15ARM: dma-mapping: remove dmac_clean_range and dmac_inv_rangeRussell King
These are now unused, and so can be removed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Tested-By: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-02-15ARM: dma-mapping: provide per-cpu type map/unmap functionsRussell King
2009-12-14ARM: add size argument to __cpuc_flush_dcache_pageRussell King
... and rename the function since it no longer operates on just pages. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-02ARM: 5727/1: Pass IFSR register to do_PrefetchAbort()Kirill A. Shutemov
Instruction fault status register, IFSR, was introduced on ARMv6 to provide status information about the last insturction fault. It needed for proper prefetch abort handling. Now we have three prefetch abort model: * legacy - for CPUs before ARMv6. They doesn't provide neither IFSR nor IFAR. We simulate IFSR with section translation fault status for them to generalize code; * ARMv6 - provides IFSR, but not IFAR; * ARMv7 - provides both IFSR and IFAR. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-01[ARM] Don't include asm/elf.h in asm codeRussell King
asm code really wants asm/hwcap.h, so include that instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-01[ARM] Convert set_pte_ext implementions to macrosRussell King
There are actually only four separate implementations of set_pte_ext. Use assembler macros to insert code for these into the proc-*.S files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-24[ARM] fix 48d7927bdf071d05cf5d15b816cf06b0937cb84fCatalin Marinas
The proc-*.S files have the _prefetch_abort pointer placed at the end of the processor structure but the cpu-multi32.h defines it in the second position. The patch also fixes the support for XSC3 and the MMU-less CPUs (740, 7tdmi, 940, 946 and 9tdmi). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-18Add a prefetch abort handlerPaul Brook
This patch adds a prefetch abort handler similar to the data abort one and renames the latter for consistency. Initial implementation by Paul Brook with some renaming by Catalin Marinas. Signed-off-by: Paul Brook <paul@codesourcery.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2006-12-13[ARM] Unuse another Linux PTE bitRussell King
L_PTE_ASID is not really required to be stored in every PTE, since we can identify it via the address passed to set_pte_at(). So, create set_pte_ext() which takes the address of the PTE to set, the Linux PTE value, and the additional CPU PTE bits which aren't encoded in the Linux PTE value. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Include asm/elf.h instead of asm/procinfo.hRussell King
These files want to provide/access ELF hwcap information, so should be including asm/elf.h rather than asm/procinfo.h Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-03[ARM] More missing proc-macros.S includesRussell King
2006-07-02Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (44 commits) [ARM] 3541/2: workaround for PXA27x erratum E7 [ARM] nommu: provide a way for correct control register value selection [ARM] 3705/1: add supersection support to ioremap() [ARM] 3707/1: iwmmxt: use the generic thread notifier infrastructure [ARM] 3706/2: ep93xx: add cirrus logic edb9315a support [ARM] 3704/1: format IOP Kconfig with tabs, create more consistency [ARM] 3703/1: Add help description for ARCH_EP80219 [ARM] 3678/1: MMC: Make OMAP MMC work [ARM] 3677/1: OMAP: Update H2 defconfig [ARM] 3676/1: ARM: OMAP: Fix dmtimers and timer32k to compile on OMAP1 [ARM] Add section support to ioremap [ARM] Fix sa11x0 SDRAM selection [ARM] Set bit 4 on section mappings correctly depending on CPU [ARM] 3666/1: TRIZEPS4 [1/5] core ARM: OMAP: Multiplexing for 24xx GPMC wait pin monitoring ARM: OMAP: Fix SRAM to use MT_MEMORY instead of MT_DEVICE ARM: OMAP: Update dmtimers ARM: OMAP: Make clock variables static ARM: OMAP: Fix GPMC compilation when DEBUG is defined ARM: OMAP: Mux updates for external DMA and GPIO ...
2006-07-01Merge nommu branchRussell King
2006-06-29[ARM] Set bit 4 on section mappings correctly depending on CPURussell King
On some CPUs, bit 4 of section mappings means "update the cache when written to". On others, this bit is required to be one, and others it's required to be zero. Finally, on ARMv6 and above, setting it turns on "no execute" and prevents speculative prefetches. With all these combinations, no one value fits all CPUs, so we have to pick a value depending on the CPU type, and the area we're mapping. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-29[ARM] nommu: provide a way for correct control register value selectionRussell King
Most MMU-based CPUs have a restriction on the setting of the data cache enable and mmu enable bits in the control register, whereby if the data cache is enabled, the MMU must also be enabled. Enabling the data cache without the MMU is an invalid combination. However, there are CPUs where the data cache can be enabled without the MMU. In order to allow these CPUs to take advantage of that, provide a method whereby each proc-*.S file defines the control regsiter value for use with nommu (with the MMU disabled.) Later on, when we add support for enabling the MMU on these devices, we can adjust the "crval" macro to also enable the data cache for nommu. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-29[ARM] Remove yucky ifdefs to print "id(wb)BRR" suffix on CPU nameRussell King
The "id(wb)BRR" suffix reports which CPU debugging options were (or were not) selected at kernel build time. Rather than have every proc-*.S file implement this, report the control register value, from which this information can be deduced. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-28[ARM] nommu: Initial uCLinux support for MMU-based CPUsHyok S. Choi
In noMMU mode, various of functions which are defined in mm/proc-*.S is not valid or needed to be avoided. i.g. switch_mm is not needed, just returns and this makes the I & D caches are valid which shows great improvement of performance including task switching and IPC. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-25Merge nommu treeRussell King
Fix merge conflict in arch/arm/mm/proc-xscale.S Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Remove unnecessary asm/hardware.h includesRussell King
asm/hardware.h is not required for the majority of processor support files, ioremap support, mm initialisation, acorn IO support, nor the debug code (which picks up its machine specific includes via debug-macros.S) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] nommu: Move hardware page table definitions to pgtable-hwdef.hRussell King
Move the hardware PMD and PTE page table definitions from pgtable.h into pgtable-hwdef.h, and include pgtable-hwdef.h as necessary. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-20[ARM] 2926/1: .proc.info - postfix section with .init for `make buildcheck`Ben Dooks
Patch from Ben Dooks The `make buildcheck` is erroneously reporting that the .proc.info list is referencing items in the .init section as it is not itself postfixed with .init Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-09kbuild: arm - use generic asm-offsets.h supportSam Ravnborg
Delete obsoleted stuff from arch Makefile and rename constants.h to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-06-30[PATCH] ARM: 2779/1: Fix the V bit setting for the ARM1020x CPUsCatalin Marinas
Patch from Catalin Marinas This patch fixes the V bit setting for the ARM1020x processors. At reset, this bit is automatically set to the value of the HIVECSINIT input signal which just happened to be 1 but it is not mandatory. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
