path: root/arch/arm/mm/proc-arm946.S
2010-10-28ARM: 6466/1: implement flush_icache_all for the rest of the CPUsMika Westerberg
Commit 81d11955bf0 ("ARM: 6405/1: Handle __flush_icache_all for CONFIG_SMP_ON_UP") added a new function to struct cpu_cache_fns: flush_icache_all(). It also implemented this for v6 and v7 but not for v5 and backwards. Without the function pointer in place, we will be calling wrong cache functions. For example with ep93xx we get following: Unable to handle kernel paging request at virtual address ee070f38 pgd = c0004000 [ee070f38] *pgd=00000000 Internal error: Oops: 80000005 [#1] PREEMPT last sysfs file: Modules linked in: CPU: 0 Not tainted (2.6.36+ #1) PC is at 0xee070f38 LR is at __dma_alloc+0x11c/0x2d0 pc : [<ee070f38>] lr : [<c0032c8c>] psr: 60000013 sp : c581bde0 ip : 00000000 fp : c0472000 r10: c0472000 r9 : 000000d0 r8 : 00020000 r7 : 0001ffff r6 : 00000000 r5 : c0472400 r4 : c5980000 r3 : c03ab7e0 r2 : 00000000 r1 : c59a0000 r0 : c5980000 Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: c000717f Table: c0004000 DAC: 00000017 Process swapper (pid: 1, stack limit = 0xc581a270) [<c0032c8c>] (__dma_alloc+0x11c/0x2d0) [<c0032e5c>] (dma_alloc_writecombine+0x1c/0x24) [<c0204148>] (ep93xx_pcm_preallocate_dma_buffer+0x44/0x60) [<c02041c0>] (ep93xx_pcm_new+0x5c/0x88) [<c01ff188>] (snd_soc_instantiate_cards+0x8a8/0xbc0) [<c01ff59c>] (soc_probe+0xfc/0x134) [<c01adafc>] (platform_drv_probe+0x18/0x1c) [<c01acca4>] (driver_probe_device+0xb0/0x16c) [<c01ac284>] (bus_for_each_drv+0x48/0x84) [<c01ace90>] (device_attach+0x50/0x68) [<c01ac0f8>] (bus_probe_device+0x24/0x44) [<c01aad7c>] (device_add+0x2fc/0x44c) [<c01adfa8>] (platform_device_add+0x104/0x15c) [<c0015eb8>] (simone_init+0x60/0x94) [<c0021410>] (do_one_initcall+0xd0/0x1a4) __dma_alloc() calls (inlined) __dma_alloc_buffer() which ends up calling dmac_flush_range(). Now since the entries in the arm920_cache_fns are shifted by one, we jump into address 0xee070f38 which is actually next instruction after the arm920_cache_fns structure. So implement flush_icache_all() for the rest of the supported CPUs using a generic 'invalidate I cache' instruction. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-08ARM: hotplug cpu: Keep processor information, startup code & ↵Russell King
__lookup_processor_type When hotplug CPU is enabled, we need to keep the list of supported CPUs, their setup functions, and __lookup_processor_type in place so that we can find and initialize secondary CPUs. Move these into the __CPUINIT section. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: Factor out common code from cpu_proc_fin()Russell King
All implementations of cpu_proc_fin() start by disabling interrupts and then flush caches. Rather than have every processors proc_fin() implementation do this, move it out into generic code - and move the cache flush past setup_mm_for_reboot() (so it can benefit from having caches still enabled.) This allows cpu_proc_fin() to become independent of the L1/L2 cache types, and eventually move the L2 cache flushing into the L2 support code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-15ARM: dma-mapping: remove dmac_clean_range and dmac_inv_rangeRussell King
These are now unused, and so can be removed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Tested-By: Santosh Shilimkar <santosh.shilimkar@ti.com>
2010-02-15ARM: dma-mapping: provide per-cpu type map/unmap functionsRussell King
2009-12-14ARM: add size argument to __cpuc_flush_dcache_pageRussell King
... and rename the function since it no longer operates on just pages. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-02ARM: 5727/1: Pass IFSR register to do_PrefetchAbort()Kirill A. Shutemov
Instruction fault status register, IFSR, was introduced on ARMv6 to provide status information about the last insturction fault. It needed for proper prefetch abort handling. Now we have three prefetch abort model: * legacy - for CPUs before ARMv6. They doesn't provide neither IFSR nor IFAR. We simulate IFSR with section translation fault status for them to generalize code; * ARMv6 - provides IFSR, but not IFAR; * ARMv7 - provides both IFSR and IFAR. Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-01[ARM] Don't include asm/elf.h in asm codeRussell King
asm code really wants asm/hwcap.h, so include that instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-12[ARM] add proc-macros.S include to proc-arm940 and proc-arm946Russell King
... otherwise these fail to build. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-17[ARM] 5034/1: fix arm{925,926,940,946} dma_flush_range() in WT modeLennert Buytenhek
The CPU's dma_flush_range() operation needs to clean+invalidate the given memory area if the cache is in writeback mode, or do just the invalidate part if the cache is in writethrough mode, but the current proc-arm{925,926,940,946} (incorrectly) do a cache clean in the latter case. This patch fixes that. Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-24[ARM] fix 48d7927bdf071d05cf5d15b816cf06b0937cb84fCatalin Marinas
The proc-*.S files have the _prefetch_abort pointer placed at the end of the processor structure but the cpu-multi32.h defines it in the second position. The patch also fixes the support for XSC3 and the MMU-less CPUs (740, 7tdmi, 940, 946 and 9tdmi). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Include asm/elf.h instead of asm/procinfo.hRussell King
These files want to provide/access ELF hwcap information, so should be including asm/elf.h rather than asm/procinfo.h Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-28[ARM] nommu: abort handler fixup for !CPU_CP15_MMU cores.Hyok S. Choi
There is no FSR/FAR register on no-CP15 or MPU cores. This patch adds a dummy abort handler which returns zero for the base restored Data Abort model !CPU_CP15_MMU cores. The abort-lv4t.S is still used with the fix-up for the base updated Data Abort model cores. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] nommu: add ARM946E-S core supportHyok S. Choi
This patch adds ARM946E-S core support which has typically 8KB I&D cache. It has a MPU and supports ARMv5TE instruction set. Because the ARM946E-S core can be synthesizable with various cache size, CONFIG_CPU_DCACHE_SIZE is defined for vendor specific configurations. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
