This reverts commit 55f0f45a45263ba26bd473f50f867d29dd836e46.
Bug 967887
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Change-Id: I036e0bd4e391a17dec8fa0fe86da7eb6b98d503a
Reviewed-on: http://git-master/r/96795
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
This reverts commit 46d9f14943770c24603ef7cdfd8eb2dbcd3c1248.
Bug 967887
Change-Id: Iee732d8137043240902201d7783d2c3fede98fbe
Reviewed-on: http://git-master/r/96794
Only use the preallocated page table during the resume, not while
suspending. This avoids the overhead of having to switch unnecessarily
to the resume page table in the suspend path.
Change-Id: Ib71c9b60b0ec39749aadc6f592549d213e6a852e
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-on: http://git-master/r/85725
Preallocate a page table and setup an identity mapping for the MMU
enable code. This means we don't have to "borrow" a page table to
do this, avoiding complexities with L2 cache coherency.
Change-Id: I625d3622359e961e4f358171e9a82b51bcecf9c2
Reviewed-on: http://git-master/r/85671
r1 stores the v:p offset from the CPU invariant resume code, and is
expected to be preserved by the CPU specific code. Overwriting it is
not a good idea.
We've managed to get away with it on sa1100 platforms because most
happen to have PHYS_OFFSET == PAGE_OFFSET, but that may not be the
case depending on kernel configuration. So fix this latent bug.
This fixes xsc3 as well which was saving and restoring this register
independently.
arch/arm/kernel/entry-armv.S
Commit 66a625a (ARM: mm: proc-macros: Add generic proc/cache/tlb struct
definition macros) introduced build errors when PM_SLEEP is not enabled.
The per-CPU do_suspend/do_resume functions are defined via the
preprocessor to constant 0. However, the macros which use these were
converted to assembly, resulting in undefined references to these
functions. Fix that by moving the ! ifdef section into proc-macros.S
and deleting it from all effected proc-*.S files.
Acked-by: Dave Martin <dave.martin@linaro.org>
Signed-off-by: Dave Martin <dave.martin@linaro.org>
cpu_proc_init() does processor specific initialization, which we do
at boot time. We have been omitting to do this on resume, which
causes some of this initialization to be skipped. We've also been
skipping this on SMP initialization too.
Ensure that cpu_proc_init() is always called appropriately by
moving it into cpu_init(), and move cpu_init() to a more appropriate
point in the boot initialization.
Tested-by: Kevin Hilman <khilman@ti.com>
Acked-by: Jean Pihet <j-pihet@ti.com>
CONFIG_PM is now set whenever we support either runtime PM in addition
to suspend and hibernate. This causes build errors when runtime PM is
enabled on a platform, but the CPU does not have the appropriate support
for suspend.
So, switch this code to use CONFIG_PM_SLEEP rather than CONFIG_PM to
allow runtime PM to be enabled without causing build errors.
This adds core support for saving and restoring CPU coprocessor
registers for suspend/resume support. This contains support for suspend
with ARM920, ARM926, SA11x0, PXA25x, PXA27x, PXA3xx, V6 and V7 CPUs.
Tested on Assabet and Tegra 2.
Tested-by: Colin Cross <ccross@android.com>
Tested-by: Kukjin Kim <kgene.kim@samsung.com>
__lookup_processor_type
When hotplug CPU is enabled, we need to keep the list of supported CPUs,
their setup functions, and __lookup_processor_type in place so that we
can find and initialize secondary CPUs. Move these into the __CPUINIT
section.
All implementations of cpu_proc_fin() start by disabling interrupts
and then flush caches. Rather than have every processors proc_fin()
implementation do this, move it out into generic code - and move the
cache flush past setup_mm_for_reboot() (so it can benefit from having
caches still enabled.)
This allows cpu_proc_fin() to become independent of the L1/L2 cache
types, and eventually move the L2 cache flushing into the L2 support
code.
/tmp/ccJ3ssZW.s: Assembler messages:
/tmp/ccJ3ssZW.s:1952: Error: can't resolve `.text' {.text section} - `.LFB1077'
This is caused because:
.section .data
.section .text
.section .text
.previous
does not return us to the .text section, but the .data section; this
makes use of .previous dangerous if the ordering of previous sections
is not known.
Fix up the other users of .previous; .pushsection and .popsection are
a safer pairing to use than .section and .previous.
Instruction fault status register, IFSR, was introduced on ARMv6 to
provide status information about the last insturction fault. It
needed for proper prefetch abort handling.
Now we have three prefetch abort model:
* legacy - for CPUs before ARMv6. They doesn't provide neither
IFSR nor IFAR. We simulate IFSR with section translation fault
status for them to generalize code;
* ARMv6 - provides IFSR, but not IFAR;
* ARMv7 - provides both IFSR and IFAR.
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
asm code really wants asm/hwcap.h, so include that instead.
There are actually only four separate implementations of set_pte_ext.
Use assembler macros to insert code for these into the proc-*.S files.
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
The proc-*.S files have the _prefetch_abort pointer placed at the end
of the processor structure but the cpu-multi32.h defines it in the
second position. The patch also fixes the support for XSC3 and the
MMU-less CPUs (740, 7tdmi, 940, 946 and 9tdmi).
This patch adds a prefetch abort handler similar to the data abort one
and renames the latter for consistency. Initial implementation by Paul
Brook with some renaming by Catalin Marinas.
Signed-off-by: Paul Brook <paul@codesourcery.com>
L_PTE_ASID is not really required to be stored in every PTE, since we
can identify it via the address passed to set_pte_at(). So, create
set_pte_ext() which takes the address of the PTE to set, the Linux
PTE value, and the additional CPU PTE bits which aren't encoded in
the Linux PTE value.
These files want to provide/access ELF hwcap information, so should
be including asm/elf.h rather than asm/procinfo.h
For several proc-<cputype>.S files the include of proc-macros.S is
missing. Make it compile and work again.
On some CPUs, bit 4 of section mappings means "update the
cache when written to". On others, this bit is required to
be one, and others it's required to be zero. Finally, on
ARMv6 and above, setting it turns on "no execute" and prevents
speculative prefetches.
With all these combinations, no one value fits all CPUs, so we
have to pick a value depending on the CPU type, and the area
we're mapping.
Most MMU-based CPUs have a restriction on the setting of the data cache
enable and mmu enable bits in the control register, whereby if the data
cache is enabled, the MMU must also be enabled. Enabling the data
cache without the MMU is an invalid combination.
However, there are CPUs where the data cache can be enabled without the
MMU.
In order to allow these CPUs to take advantage of that, provide a
method whereby each proc-*.S file defines the control regsiter value
for use with nommu (with the MMU disabled.) Later on, when we add
support for enabling the MMU on these devices, we can adjust the
"crval" macro to also enable the data cache for nommu.
In noMMU mode, various of functions which are defined in mm/proc-*.S
is not valid or needed to be avoided. i.g. switch_mm is not needed,
just returns and this makes the I & D caches are valid which shows
great improvement of performance including task switching and IPC.
Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com>
We had two implementations for flushing the cache, which meant StrongARM
caches weren't being correctly flushed. Fix this by always using the
v4wb_flush_kern_cache_all method, rather than duplicating it.
Move the hardware PMD and PTE page table definitions from pgtable.h
into pgtable-hwdef.h, and include pgtable-hwdef.h as necessary.
Patch from Ben Dooks
The `make buildcheck` is erroneously reporting that the .proc.info
list is referencing items in the .init section as it is not itself
postfixed with .init
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Delete obsoleted stuff from arch Makefile and rename
constants.h to asm-offsets.h
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
infrastructure for it.
Let it rip!
