This reverts commit 55f0f45a45263ba26bd473f50f867d29dd836e46.
Bug 967887
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Change-Id: I036e0bd4e391a17dec8fa0fe86da7eb6b98d503a
Reviewed-on: http://git-master/r/96795
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
This reverts commit 46d9f14943770c24603ef7cdfd8eb2dbcd3c1248.
Bug 967887
Change-Id: Iee732d8137043240902201d7783d2c3fede98fbe
Reviewed-on: http://git-master/r/96794
This reverts commit 16e0bb8c46656b1d902d422e0065c746af161a1c.
Bug 967887
Change-Id: Ifa115c4030c48cbd0b629cf02899ca8c6f25d314
Reviewed-on: http://git-master/r/96792
There is no need to save and restore the context ID register on ARMv6
and ARMv7 with a temporary page table as we write the context ID
register when we switch back to the real page tables for the thread.
Moreover, the temporary page tables do not contain any non-global
mappings, so the context ID value should not be used. To be safe,
initialize the register to a reserved context ID value.
Change-Id: I7de05e736dde5bc1b8ab682a8660eaaba52104cf
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-on: http://git-master/r/85727
Only use the preallocated page table during the resume, not while
suspending. This avoids the overhead of having to switch unnecessarily
to the resume page table in the suspend path.
Change-Id: Ib71c9b60b0ec39749aadc6f592549d213e6a852e
Reviewed-on: http://git-master/r/85725
Preallocate a page table and setup an identity mapping for the MMU
enable code. This means we don't have to "borrow" a page table to
do this, avoiding complexities with L2 cache coherency.
Change-Id: I625d3622359e961e4f358171e9a82b51bcecf9c2
Reviewed-on: http://git-master/r/85671
enabled
This patch is a workaround for the 364296 ARM1136 r0p2 erratum (possible
cache data corruption with hit-under-miss enabled). It sets the
undocumented bit 31 in the auxiliary control register and the FI bit in
the control register, thus disabling hit-under-miss without putting the
processor into full low interrupt latency mode.
Tested-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Commit 66a625a (ARM: mm: proc-macros: Add generic proc/cache/tlb struct
definition macros) introduced build errors when PM_SLEEP is not enabled.
The per-CPU do_suspend/do_resume functions are defined via the
preprocessor to constant 0. However, the macros which use these were
converted to assembly, resulting in undefined references to these
functions. Fix that by moving the ! ifdef section into proc-macros.S
and deleting it from all effected proc-*.S files.
Acked-by: Dave Martin <dave.martin@linaro.org>
This patch adds simple definitions of cpu_reset for ARMv6 and ARMv7
cores, which disable the MMU via the SCTLR.
Signed-off-by: Dave Martin <dave.martin@linaro.org>
This patch makes TTBR1 point to swapper_pg_dir so that global, kernel
mappings can be used exclusively on v6 and v7 cores where they are
needed.
The Marvell PJ4 is ARMv7 capable, so we don't support it in
ARMv6 mode anymore.
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
Acked-by: Saeed Bishara <saeed.bishara@gmail.com>
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6 into fixes
CONFIG_PM is now set whenever we support either runtime PM in addition
to suspend and hibernate. This causes build errors when runtime PM is
enabled on a platform, but the CPU does not have the appropriate support
for suspend.
So, switch this code to use CONFIG_PM_SLEEP rather than CONFIG_PM to
allow runtime PM to be enabled without causing build errors.
This adds core support for saving and restoring CPU coprocessor
registers for suspend/resume support. This contains support for suspend
with ARM920, ARM926, SA11x0, PXA25x, PXA27x, PXA3xx, V6 and V7 CPUs.
Tested on Assabet and Tegra 2.
Tested-by: Colin Cross <ccross@android.com>
Tested-by: Kukjin Kim <kgene.kim@samsung.com>
arch/arm/kernel/head-common.S
__lookup_processor_type
When hotplug CPU is enabled, we need to keep the list of supported CPUs,
their setup functions, and __lookup_processor_type in place so that we
can find and initialize secondary CPUs. Move these into the __CPUINIT
section.
UP systems do not implement all the instructions that SMP systems have,
so in order to boot a SMP kernel on a UP system, we need to rewrite
parts of the kernel.
Do this using an 'alternatives' scheme, where the kernel code and data
is modified prior to initialization to replace the SMP instructions,
thereby rendering the problematical code ineffectual. We use the linker
to generate a list of 32-bit word locations and their replacement values,
and run through these replacements when we detect a UP system.
All implementations of cpu_proc_fin() start by disabling interrupts
and then flush caches. Rather than have every processors proc_fin()
implementation do this, move it out into generic code - and move the
cache flush past setup_mm_for_reboot() (so it can benefit from having
caches still enabled.)
This allows cpu_proc_fin() to become independent of the L1/L2 cache
types, and eventually move the L2 cache flushing into the L2 support
code.
The TLS register is only available on ARM1136 r1p0 and later.
Set HWCAP_TLS flags if hardware TLS is available and test for
it if CONFIG_CPU_32v6K is not set for V6.
Note that we set the TLS instruction in __kuser_get_tls
dynamically as suggested by Jamie Lokier <jamie@shareable.org>.
Also the __switch_to code is optimized out in most cases as
suggested by Nicolas Pitre <nico@fluxnic.net>.
Reviewed-by: Nicolas Pitre <nicolas.pitre@linaro.org>
and V7 comments
The comments in cacheflush.h should follow what's in
struct cpu_cache_fns. The comments for V6 and V7 are
unnecessary.
... to be the same as proc-v6
Signed-off-by: Saeed Bishara <saeed@marvell.com>
Signed-off-by: Nicolas Pitre <nico@marvell.com>
The Marvell Dove (88AP510) is a high-performance, highly integrated,
low power SoC with high-end ARM-compatible processor (known as PJ4),
graphics processing unit, high-definition video decoding acceleration
hardware, and a broad range of peripherals.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
Mapping the same memory using two different attributes (memory
type, shareability, cacheability) is unpredictable. During boot,
we encounter a situation when we're updating the kernel's page
tables which can lead to dirty cache lines existing in the cache
which are subsequently missed. This causes stack corruption,
and therefore a crash.
Therefore, ensure that the shared and cacheability settings
matches the configuration that will be used later; this together
with the restriction in early_cachepolicy() ensures that we won't
create a mismatch during boot.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Instruction fault status register, IFSR, was introduced on ARMv6 to
provide status information about the last insturction fault. It
needed for proper prefetch abort handling.
Now we have three prefetch abort model:
* legacy - for CPUs before ARMv6. They doesn't provide neither
IFSR nor IFAR. We simulate IFSR with section translation fault
status for them to generalize code;
* ARMv6 - provides IFSR, but not IFAR;
* ARMv7 - provides both IFSR and IFAR.
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Starting with ARMv6, the CPUs support the BE-8 variant of big-endian
(byte-invariant). This patch adds the core support:
- setting of the BE-8 mode via the CPSR.E register for both kernel and
user threads
- big-endian page table walking
- REV used to rotate instructions read from memory during fault
processing as they are still little-endian format
- Kconfig and Makefile support for BE-8. The --be8 option must be passed
to the final linking stage to convert the instructions to
little-endian
arm is placing some code in the .text.init section, but it does not
reference that section in its linker scripts.
This change moves this code from the .text.init section to the
.init.text section, which is presumably where it belongs.
Signed-off-by: Tim Abbott <tabbott@mit.edu>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Since WFI may cause the processor to enter a low-power mode, data may
still be in the write buffer. This patch adds a DSB (or DWB) to the
cpu_(v6|v7)_do_idle functions before the WFI.
asm code really wants asm/hwcap.h, so include that instead.
There are actually only four separate implementations of set_pte_ext.
Use assembler macros to insert code for these into the proc-*.S files.
The proc-*.S files have the _prefetch_abort pointer placed at the end
of the processor structure but the cpu-multi32.h defines it in the
second position. The patch also fixes the support for XSC3 and the
MMU-less CPUs (740, 7tdmi, 940, 946 and 9tdmi).
This patch moves the SCU initialisation from __v6_setup to the
smp_prepare_cpus() function as it relies on platform-specific
settings. Changes to get_core_count() are mainly for allowing cleaner
code with the upcoming PB11MPCore patches.
This patch adds a prefetch abort handler similar to the data abort one
and renames the latter for consistency. Initial implementation by Paul
Brook with some renaming by Catalin Marinas.
Signed-off-by: Paul Brook <paul@codesourcery.com>
The kernel originally supported revB only. This patch enables revC by
default and adds a config option for building the kernel for the revB
platform. Since the SCU base address was hard-coded in the proc-v6.S
file (and only valid for RealView/EB revB), this patch also adds a
more generic support for defining the SCU information.
Other platforms other than SMP may have an outer cache. For these, we
also need to mark the page table walks outer cacheable. Since marking
the walks always outer cacheable apparantly has no side effects, we
might as well always mark them so.
However, we continue to only mark PTWs shared if we have SMP enabled.
L_PTE_ASID is not really required to be stored in every PTE, since we
can identify it via the address passed to set_pte_at(). So, create
set_pte_ext() which takes the address of the PTE to set, the Linux
PTE value, and the additional CPU PTE bits which aren't encoded in
the Linux PTE value.
Don't set HWCAP_VFP in the processor support file; not only does it
depend on the processor features, but it also depends on the support
code being present. Therefore, only set it if the support code
detects that we have a VFP coprocessor attached.
Also, move the VFP handling of the coprocessor access register into
the VFP support code.
These files want to provide/access ELF hwcap information, so should
be including asm/elf.h rather than asm/procinfo.h
On some CPUs, bit 4 of section mappings means "update the
cache when written to". On others, this bit is required to
be one, and others it's required to be zero. Finally, on
ARMv6 and above, setting it turns on "no execute" and prevents
speculative prefetches.
With all these combinations, no one value fits all CPUs, so we
have to pick a value depending on the CPU type, and the area
we're mapping.
Most MMU-based CPUs have a restriction on the setting of the data cache
enable and mmu enable bits in the control register, whereby if the data
cache is enabled, the MMU must also be enabled. Enabling the data
cache without the MMU is an invalid combination.
However, there are CPUs where the data cache can be enabled without the
MMU.
In order to allow these CPUs to take advantage of that, provide a
method whereby each proc-*.S file defines the control regsiter value
for use with nommu (with the MMU disabled.) Later on, when we add
support for enabling the MMU on these devices, we can adjust the
"crval" macro to also enable the data cache for nommu.
In noMMU mode, various of functions which are defined in mm/proc-*.S
is not valid or needed to be avoided. i.g. switch_mm is not needed,
just returns and this makes the I & D caches are valid which shows
great improvement of performance including task switching and IPC.
Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com>
proc-v6 contains some compatibility to be able to use the V6
"cps" instruction. However, the kernel makes use of this
instruction elsewhere extensively, so there's no point keeping
this compatibility anymore.
Mark page table walks with outer-cacheable attribute, and enable no-execute
in page tables.
Move the hardware PMD and PTE page table definitions from pgtable.h
into pgtable-hwdef.h, and include pgtable-hwdef.h as necessary.
Add SMP support for the MPcore tile fitted to the Realview ARM
platform.
