Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
commit bae0ca2bc550d1ec6a118fb8f2696f18c4da3d8e upstream.
During __v{6,7}_setup, we invalidate the TLBs since we are about to
enable the MMU on return to head.S. Unfortunately, without a subsequent
dsb instruction, the invalidation is not guaranteed to have completed by
the time we write to the sctlr, potentially exposing us to junk/stale
translations cached in the TLB.
This patch reworks the init functions so that the dsb used to ensure
completion of cache/predictor maintenance is also used to ensure
completion of the TLB invalidation.
Reported-by: Albin Tonnerre <Albin.Tonnerre@arm.com>
- Replace compile time flag with runtime selection.
- Same kernel should work in secure and non secure mode
bug 1411345
Change-Id: I7b20121623aa432eaefe00f47115908595590f16
Signed-off-by: Nitin Sehgal <nsehgal@nvidia.com>
Reviewed-on: http://git-master/r/362897
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
The Cortx A15 r3 adds additional regional clock gating to save power.
This is enabled by setting bit 31 of ACTLR2. So, enable it at boot time
and after power-gating
Bug 1332608
Change-Id: Id9be4ebe0b8e2c546a20fc8db9215d21b508f5ba
Signed-off-by: Alex Van Brunt <avanbrunt@nvidia.com>
Reviewed-on: http://git-master/r/253139
Reviewed-by: Bo Yan <byan@nvidia.com>
Reviewed-by: Dan Hansen <dhansen@nvidia.com>
GVS: Gerrit_Virtual_Submit
Save and restore event counter selections and counter
values over power gating.
Change-Id: If9b467781e94cb08b8cf8a980fff00eb5af71250
Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com>
Reviewed-on: http://git-master/r/192646
This new config would only be enabled when we enable a secure os
implementation. This config would be generic and we can reuse it
if/when we change the secure os vendor.
Change-Id: I94a0a365d4dc834fafa1137a0c0d9adf1b394c51
Signed-off-by: James Zhao <jamesz@nvidia.com>
Reviewed-on: http://git-master/r/211756
Reviewed-by: Chris Johnson <cwj@nvidia.com>
extended period may not work correctly
This workaround is for ARM errata 799270 which is applicable to
Cortex-A15 up to revision R2P4. The workaround is to read from
a device register and create a data dependency between this read
and the modification of ACTLR.
Change-Id: I26813f17a8a9c6a90446ddeb943ef318e3c69770
Signed-off-by: Bo Yan <byan@nvidia.com>
Reviewed-on: http://git-master/r/212770
(cherry picked from commit 2340401e2dec7228bcc5d9074c310d0146454736)
Reviewed-on: http://git-master/r/213135
Reviewed-by: Simone Willett <swillett@nvidia.com>
Bug 1234168
Change-Id: I61d968955972f129a1be8fdccbdcdf01041d8043
Reviewed-on: http://git-master/r/199718
Tested-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
Reviewed-by: Seshendra Gadagottu <sgadagottu@nvidia.com>
This is not required since cache is invalidated by HW in the reset
sequence. Bootloader is supposed to do the same before it hands
over control to kernel.
Change-Id: I0991de3ba1015a32f2c49a0333fd0b17a51a4f31
Reviewed-on: http://git-master/r/197028
(cherry picked from commit 9c49ffd08d6da03caa820711db83f561d9333aee)
Reviewed-on: http://git-master/r/200854
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Disable A15's L2 prefetch throttle mechanism to improve performance.
bug 1212902
Change-Id: I03a27518b26da3cbf1e7aad96ff2d67187a1ebf6
Reviewed-on: http://git-master/r/188788
Reviewed-by: Hyung Taek Ryoo <hryoo@nvidia.com>
Do an external device read to start L2 clock, then change
SMP bit in ACTLR. The ACTLR change needs to be done immediately
after the device read is done since there are only 256 clock cycles
maximum available before the L2 clock can be gated again.
bug 1208654
bug 1195192
Change-Id: Ide1c0476d629cbea07f585013ed3b7e79a67c86e
Reviewed-on: http://git-master/r/187521
Reviewed-by: Bobby Meeker <bmeeker@nvidia.com>
Cortex-A15 flush L2 cache after reset, there is no need to do this
in software, if L2 is already invalidated in bootloader and
cache is disabled. For secondary startup, there is no reason to
flush L2 as well.
This change assumes the setup code is always entered as the result
of CPU reset.
Change-Id: I6d58f8b4a638b70acfb35b97c87a09266aceef41
Reviewed-on: http://git-master/r/170563
Reviewed-by: Mrutyunjay Sawant <msawant@nvidia.com>
Tested-by: Mrutyunjay Sawant <msawant@nvidia.com>
at least two processors might deadlock processor
Under very rare circumstances, full cache line writes
from (at least) 2 processors on cache lines in hazard with
other requests may cause arbitration issues in the SCU,
leading to processor deadlock. This erratum can be
worked around by setting bit[21] of the undocumented
Diagnostic Control Register to 1.
Change-Id: I83f919ead5ef4f90f50fa3f38f2cc31ab6bfc31e
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/170582
Change-Id: I2433e53175e79d558d76a7c37b10de9175d7b1b0
Reviewed-on: http://git-master/r/167385
Change-Id: If966ee69f1d5e4314f79685238ecff3c44eadac0
Reviewed-on: http://git-master/r/167879
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
This is cortex-a15 specific
bug 1178938
Change-Id: Id695d89dbe1411d277f2c1296c74586ca9c1584e
Reviewed-on: http://git-master/r/164168
The work around for ARM erratum 752520 was applied for all revisions
upto r2p8. But this erratum is present only on r2p0 to r2p8 versions
while T20 has r1p1 revision. Making this change to enable the WAR
only for revisions from r2p0 to r2p8.
Bug 853428
Bug 1045637
Reviewed-on: http://git-master/r/43962
(cherry picked from commit 57a0028d94c7ad71acab0c9ee29f5472e46c55bf)
Reviewed-on: http://git-master/r/44540
(cherry picked from commit d7f06b0a1b247f2a1444b3b78bc7dc8b21a5b7dd)
Reviewed-on: http://git-master/r/161949
(cherry picked from commit f84777eadee307e605f3accdfbf7114917e5a51c)
Change-Id: Id3ab36cb757d45ab9bddfa5b08c0643a00765bb2
Signed-off-by: Vishal Annapurve <vannapurve@nvidia.com>
Signed-off-by: Vishal Singh <vissingh@nvidia.com>
Reviewed-on: http://git-master/r/165948
Reviewed-by: Sumeet Gupta <sumeetg@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Specifically, this change saves and restores registers controlling
user space access of ARM performance monitoring unit registers and
for PMU interrupt enables.
Change-Id: Iac88df17112e2ef2ccf53674c3fa3a74d2d4221f
Reviewed-on: http://git-master/r/162149
Bug 885613
Change-Id: I283f0ed737951e16fbf1cd9b0d0e1f2bc568bf49
Signed-off-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-on: http://git-master/r/88856
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Rebase-Id: Rd8b2eb11fc71ec2c55f18403b56de1227ead113f
Rebase-Id: R940fad74c7e91ef3d1d3d589a48064ccb7335541
Add CONFIG_TRUSTED_FOUNDATIONS build option and calls to issue
SMCs to the TL secure monitor (used when needing to update state
not writable by non-secure code).
Make security/tf_driver an optional part of the build, which is
part of the TL framework to interact with secure services.
Bug 883391
Change-Id: I9c6c14ff457fb3a0c612d558fe731a17c2480750
Signed-off-by: Chris Johnson <cwj@nvidia.com>
Reviewed-on: http://git-master/r/65616
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R57977499bb6b372ac4faa360e442e8733265e9f3
Under some rare circumstances, an uncacheable load multiple
instruction (LDRD, LDM, VLDM, VLD1, VLD2, VLD3, VLD4) can cause
a processor deadlock.
Change-Id: Ibd79aa8182dce37d0be9892f2310735e1123618a
Reviewed-on: http://git-master/r/95914
Rebase-Id: R87f0be6dfa8d8ac812cb46deb8c4466f622e580c
Implement the complete debug arch v7 save/restore sequence
as required by the ARM Architectural Reference Manual.
Change-Id: Ia346a87b16e759ae5dbbbd02e77eda1e6d6deb82
Reviewed-on: http://git-master/r/87865
Rebase-Id: R961728bfc7e7e0e28c963ee8009fb047e79e8649
Change-Id: I5a5a26c6fc0a169a004307e07de1223c107e4df7
Reviewed-on: http://git-master/r/86158
Tested-by: Gerrit_Virtual_Submit
Rebase-Id: Rf3af25a6871f92887c3e83d0eb1b1ceb64895485
requests may create a system deadlock.
Under rare circumstances, PLDs may interfere with a Cacheable page table walk,
creating a processor deadlock. The erratum can only happen when the Data Cache
and MMU are enabled, with the TLB descriptors marked as L1 cacheable,
so that Page Table Walks are performed as cache linefills.
This workaround sets a bit in the diagnostic register of the Cortex-A9,
causing PLD operations treated as NOP.
(cherry-picked from b501cafea7328bc578f67e3e846ab9d25b7ec1b0)
Change-Id: Ic4039b83de43530bae7ce705162441bea74e1e98
Reviewed-on: http://git-master/r/54095
Tested-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: Ra35e48e21c1d62b6480a9d67d1413dd5d0df3f53
Change-Id: I48bd9ddf9f0a65b1754560bae261d0b3faa69e06
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Rebase-Id: Rbbd2387b98c81919b3a8bf9782828c8b4ef33f45
Change-Id: I7d0efeb53e41722f92f9373785045ccc61e56adf
Rebase-Id: R6ab8cf0cfe2930330b49d3fccee65d8366ef909d
Enable dynamic high level clock gating for Cortex-A9 CPUs, as
described in 2.3.3 "Dynamic high level clock gating" of the
Cortex-A9 TRM. This may cut the clock of the integer core,
system control block, and Data Engine in certain conditions.
Add ARM errata 720791 to avoid corrupting the Jazelle
instruction stream on earlier Cortex-A9 revisions.
Original-Change-Id: I48e51d907e593f26982ea91b0a811553f68e3c86
Signed-off-by: Todd Poynor <toddpoynor@google.com>
Rebase-Id: R7ae4d4825e9171bca2471fe776ecf363e75b9ca6
commit bf3f0f332f76a85ff3a0b393aaded5a8533769c0 upstream.
Commit ae8a8b9553bd ("ARM: 7691/1: mm: kill unused TLB_CAN_READ_FROM_L1_CACHE
and use ALT_SMP instead") added early function returns for page table
cache flushing operations on ARMv7 SMP CPUs.
Unfortunately, when targetting Thumb-2, these `mov pc, lr' sequences
assemble to 2 bytes which can lead to corruption of the instruction
stream after code patching.
This patch fixes the alternates to use wide (32-bit) instructions for
Thumb-2, therefore ensuring that the patching code works correctly.
This commit fixes the regression on Armada 370 (the kernal hang during
boot) introduced by the commit: "ARM: 7691/1: mm: kill unused
TLB_CAN_READ_FROM_L1_CACHE and use ALT_SMP instead".
When coming out of either a Wait for Interrupt (WFI) or a Wait for
Event (WFE) IDLE states, a specific timing sensitivity exists between
the retiring WFI/WFE instructions and the newly issued subsequent
instructions. This sensitivity can result in a CPU hang scenario. The
workaround is to insert either a Data Synchronization Barrier (DSB) or
Data Memory Barrier (DMB) command immediately after the WFI/WFE
instruction.
This commit was based on the work of Lior Amsalem, but heavily
modified to apply the errata fix dynamically according to the
processor type thanks to the suggestions of Russell King and Nicolas
Pitre.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Reviewed-by: Will Deacon <will.deacon@arm.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Willy Tarreau <w@1wt.eu>
Cc: <stable@vger.kernel.org>
This commit fixes the ID and mask for the PJ4B which was too
restrictive and didn't match the CPU of the Armada 370 SoC.
'smp-hotplug' into for-linus
pj4b cpus are LPAE capable so enable them on LPAE compilations
Signed-off-by: Lior Amsalem <alior@marvell.com>
Tested-by: Franklin <flin@marvell.com>
Many ARMv7 cores have hardware page table walkers that can read the L1
cache. This is discoverable from the ID_MMFR3 register, although this
can be expensive to access from the low-level set_pte functions and is a
pain to cache, particularly with multi-cluster systems.
A useful observation is that the multi-processing extensions for ARMv7
require coherent table walks, meaning that we can make use of ALT_SMP
patching in proc-v7-* to patch away the cache flush safely for these
cores.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Some early versions of the Krait CPU design incorrectly indicate
that they only support the UDIV and SDIV instructions in Thumb
mode when they actually support them in ARM and Thumb mode. It
seems that these CPUs follow the DDI0406B ARM ARM which has two
possible values for the divide instructions field, instead of the
DDI0406C document which has three possible values.
Work around this problem by checking the MIDR against Krait CPUs
with this faulty ISAR0 register and force the hwcaps to indicate
support in both modes.
[sboyd: Rewrote commit text to reflect real reasoning now that
we autodetect udiv/sdiv]
Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
The ISAR0 register indicates support for the SDIV and UDIV
instructions in both the Thumb and ARM instruction set. Read the
register to detect the supported instructions and update the
elf_hwcap mask as appropriate. This is better than adding more
and more cpuid checks in proc-v7.S for each new cpu variant that
supports these instructions.
Cc: Stepan Moskovchenko <stepanm@codeaurora.org>
If CONFIG_ARCH_MULTIPLATFORM & CONFIG_ARCH_MVEBU are both enabled,
__v7_pj4b_setup is added between __v7_ca9mp_setup and __v7_setup.
But there's no jump instruction added. If the chip is Cortex A5/A9,
it goes through __v7_pj4b_setup also. It results in system hang.
Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org>
In order to support secure and non-secure platforms in multi-platform
kernels, errata work-arounds that access secure only registers need to
be disabled. Make all the errata options that fit in this category
depend on !CONFIG_ARCH_MULTIPLATFORM.
This will effectively remove the errata options as platforms are
converted over to multi-platform.
Pull ARM SoC updates for Marvell mvebu/kirkwood from Olof Johansson:
"This is a branch with updates for Marvell's mvebu/kirkwood platforms.
They came in late-ish, and were heavily interdependent such that it
didn't make sense to split them up across the cross-platform topic
branches. So here they are (for the second release in a row) in a
branch on their own."
* tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (88 commits)
arm: l2x0: add aurora related properties to OF binding
arm: mvebu: add Aurora L2 Cache Controller to the DT
arm: mvebu: add L2 cache support
dma: mv_xor: fix error handling path
dma: mv_xor: fix error checking of irq_of_parse_and_map()
dma: mv_xor: use request_irq() instead of devm_request_irq()
dma: mv_xor: clear the window override control registers
arm: mvebu: fix address decoding armada_cfg_base() function
ARM: mvebu: update defconfig with I2C and RTC support
ARM: mvebu: Add SATA support for OpenBlocks AX3-4
ARM: mvebu: Add support for the RTC in OpenBlocks AX3-4
ARM: mvebu: Add support for I2C on OpenBlocks AX3-4
ARM: mvebu: Add support for I2C controllers in Armada 370/XP
arm: mvebu: Add hardware I/O Coherency support
arm: plat-orion: Add coherency attribute when setup mbus target
arm: dma mapping: Export a dma ops function arm_dma_set_mask
arm: mvebu: Add SMP support for Armada XP
arm: mm: Add support for PJ4B cpu and init routines
arm: mvebu: Add IPI support via doorbells
arm: mvebu: Add initial support for power managmement service unit
PJ4B is an implementation of the ARMv7 (such as the Cortex A9 for
example) released by Marvell. This CPU is currently found in
Armada 370 and Armada XP SoCs. This patch provides a support for the
specific initialization of this CPU.
Signed-off-by: Yehuda Yitschak <yehuday@marvell.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Because mov pc,<Rn> never switches instruction set when executed in
Thumb code, Thumb-2 kernels will silently execute the target code
after cpu_reset as Thumb code, even if the passed code pointer
denotes ARM (bit 0 clear).
This patch uses bx instead, ensuring the correct instruction set
for the target code.
Thumb code in the kernel is not supported prior to ARMv7, so other
CPUs are not affected.
Signed-off-by: Dave Martin <dave.martin@linaro.org>
The ARMv7 processor setup function __v7_setup() cleans and invalidates the
CPU cache before enabling MMU to start the CPU with a clean CPU local cache.
But on ARMv7 architectures like Cortex-[A15/A8], this code will end
up flushing the L2 caches(up to level of Coherency) which is undesirable
and expensive. The setup functions are used in the CPU hotplug scenario too
and hence flushing all cache levels should be avoided.
This patch replaces the cache flushing call with the newly introduced
v7 dcache LoUIS API where only cache levels up to LoUIS are cleaned and
invalidated when a processors executes __v7_setup which is the expected
behavior.
For processors like A9 and A5 where the L2 cache is an outer one the
behavior should be unchanged.
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Currently when ThumbEE is not enabled (!CONFIG_ARM_THUMBEE) the ThumbEE
register states are not saved/restored at context switch. The default state
of the ThumbEE Ctrl register (TEECR) allows userspace accesses to the
ThumbEE Base Handler register (TEEHBR). This can cause unexpected behaviour
when people use ThumbEE on !CONFIG_ARM_THUMBEE kernels, as well as allowing
covert communication - eg between userspace tasks running inside chroot
jails.
This patch sets up TEECR in order to prevent user-space access to TEEHBR
when !CONFIG_ARM_THUMBEE. In this case, tasks are sent SIGILL if they try to
access TEEHBR.
Cc: stable@vger.kernel.org
Signed-off-by: Jonathan Austin <jonathan.austin@arm.com>
Erratum #743622 affects all r2 variants of the Cortex-A9 processor, so
ensure that the workaround is applied regardless of the revision.
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
On v7, we use the same cache maintenance instructions for data lines
as for unified lines. This was not the case for v6, where HARVARD_CACHE
was defined to indicate the L1 cache topology.
This patch removes the erroneous compile-time check for HARVARD_CACHE in
proc-v7.S, ensuring that we perform I-side invalidation at boot.
Reported-and-Acked-by: Shawn Guo <shawn.guo@linaro.org>
Cc: stable <stable@vger.kernel.org>
Acked-by: Catalin Marinas <Catalin.Marinas@arm.com>
The merging of commits 1b6ba46b ("ARM: LPAE: MMU setup for the 3-level
page table format") and b4244738 ("ARM: 7202/1: Add Cortex-A7 proc info")
during the merge window ended up putting the Cortex-A7 proc_info into a
code block guarded by !CONFIG_ARM_LPAE. This makes Cortex-A7 platforms
unbootable when LPAE is enabled.
This patch moves the proc_info structure for Cortex-A7 outside of the
guarded block.
Cc: Pawel Moll <pawel.moll@arm.com>
arch/arm/kernel/setup.c
arch/arm/mach-shmobile/board-kota2.c
Activation conditions for a workaround should not be encoded in the
workaround's direct dependencies if this makes otherwise reasonable
configuration choices impossible.
This patches uses the SMP/UP patching facilities instead to compile
out the workaround if the configuration means that it is definitely
not needed.
This means that configs for buggy silicon can simply select
ARM_ERRATA_751472, without preventing a UP kernel from being built
or duplicatiing knowledge about when to activate the workaround.
This seems the correct way to do things, because the erratum is a
property of the silicon, irrespective of what the kernel config
happens to be.
This patch adds processor info for ARM Ltd. Cortex-A7.
A7 is architecturally identical to A15 so it shares the
same SMP initialization code and hwcaps.
Tested-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
