This reverts commit 55f0f45a45263ba26bd473f50f867d29dd836e46.
Bug 967887
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Change-Id: I036e0bd4e391a17dec8fa0fe86da7eb6b98d503a
Reviewed-on: http://git-master/r/96795
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
This reverts commit 46d9f14943770c24603ef7cdfd8eb2dbcd3c1248.
Bug 967887
Change-Id: Iee732d8137043240902201d7783d2c3fede98fbe
Reviewed-on: http://git-master/r/96794
Only use the preallocated page table during the resume, not while
suspending. This avoids the overhead of having to switch unnecessarily
to the resume page table in the suspend path.
Change-Id: Ib71c9b60b0ec39749aadc6f592549d213e6a852e
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-on: http://git-master/r/85725
Preallocate a page table and setup an identity mapping for the MMU
enable code. This means we don't have to "borrow" a page table to
do this, avoiding complexities with L2 cache coherency.
Change-Id: I625d3622359e961e4f358171e9a82b51bcecf9c2
Reviewed-on: http://git-master/r/85671
For streaming-style operations (e.g., software rendering of graphics
surfaces shared with non-coherent DMA devices), the cost of performing
L2 cache maintenance can exceed the benefit of having the larger cache
(this is particularly true for OUTER_CACHE configurations like the ARM
PL2x0).
This change uses the currently-unused mapping 5 (TEX[0]=1, C=0, B=1)
in the tex remapping tables as an inner-writeback-write-allocate, outer
non-cacheable memory type, so that this mapping will be available to
clients which will benefit from the reduced L2 maintenance.
Change-Id: Iaec3314a304eab2215100d991b1e880b676ac906
Signed-off-by: Gary King <gking@nvidia.com>
arch/arm/include/asm/pgtable.h
arch/arm/mm/proc-v7.S
Commit 66a625a (ARM: mm: proc-macros: Add generic proc/cache/tlb struct
definition macros) introduced build errors when PM_SLEEP is not enabled.
The per-CPU do_suspend/do_resume functions are defined via the
preprocessor to constant 0. However, the macros which use these were
converted to assembly, resulting in undefined references to these
functions. Fix that by moving the ! ifdef section into proc-macros.S
and deleting it from all effected proc-*.S files.
Acked-by: Dave Martin <dave.martin@linaro.org>
Without this patch, xscale_80200_A0_A1 is missing the
icache_flush_all entry, which would result in the wrong functions
being called at run-time.
This patch re-uses xscale_icache_flush_all for
xscale_80200_A0_A1_cache_fns.
Signed-off-by: Dave Martin <dave.martin@linaro.org>
gas used to accept (and ignore?) .size directives which referred to
undefined symbols, as this does. In binutils 2.21 these are treated
as fatal errors.
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
CONFIG_PM is now set whenever we support either runtime PM in addition
to suspend and hibernate. This causes build errors when runtime PM is
enabled on a platform, but the CPU does not have the appropriate support
for suspend.
So, switch this code to use CONFIG_PM_SLEEP rather than CONFIG_PM to
allow runtime PM to be enabled without causing build errors.
This adds core support for saving and restoring CPU coprocessor
registers for suspend/resume support. This contains support for suspend
with ARM920, ARM926, SA11x0, PXA25x, PXA27x, PXA3xx, V6 and V7 CPUs.
Tested on Assabet and Tegra 2.
Tested-by: Colin Cross <ccross@android.com>
Tested-by: Kukjin Kim <kgene.kim@samsung.com>
Commit 81d11955bf0 ("ARM: 6405/1: Handle __flush_icache_all for
CONFIG_SMP_ON_UP") added a new function to struct cpu_cache_fns:
flush_icache_all(). It also implemented this for v6 and v7 but not
for v5 and backwards. Without the function pointer in place, we
will be calling wrong cache functions.
For example with ep93xx we get following:
Unable to handle kernel paging request at virtual address ee070f38
pgd = c0004000
[ee070f38] *pgd=00000000
Internal error: Oops: 80000005 [#1] PREEMPT
last sysfs file:
Modules linked in:
CPU: 0 Not tainted (2.6.36+ #1)
PC is at 0xee070f38
LR is at __dma_alloc+0x11c/0x2d0
pc : [<ee070f38>] lr : [<c0032c8c>] psr: 60000013
sp : c581bde0 ip : 00000000 fp : c0472000
r10: c0472000 r9 : 000000d0 r8 : 00020000
r7 : 0001ffff r6 : 00000000 r5 : c0472400 r4 : c5980000
r3 : c03ab7e0 r2 : 00000000 r1 : c59a0000 r0 : c5980000
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: c000717f Table: c0004000 DAC: 00000017
Process swapper (pid: 1, stack limit = 0xc581a270)
[<c0032c8c>] (__dma_alloc+0x11c/0x2d0)
[<c0032e5c>] (dma_alloc_writecombine+0x1c/0x24)
[<c0204148>] (ep93xx_pcm_preallocate_dma_buffer+0x44/0x60)
[<c02041c0>] (ep93xx_pcm_new+0x5c/0x88)
[<c01ff188>] (snd_soc_instantiate_cards+0x8a8/0xbc0)
[<c01ff59c>] (soc_probe+0xfc/0x134)
[<c01adafc>] (platform_drv_probe+0x18/0x1c)
[<c01acca4>] (driver_probe_device+0xb0/0x16c)
[<c01ac284>] (bus_for_each_drv+0x48/0x84)
[<c01ace90>] (device_attach+0x50/0x68)
[<c01ac0f8>] (bus_probe_device+0x24/0x44)
[<c01aad7c>] (device_add+0x2fc/0x44c)
[<c01adfa8>] (platform_device_add+0x104/0x15c)
[<c0015eb8>] (simone_init+0x60/0x94)
[<c0021410>] (do_one_initcall+0xd0/0x1a4)
__dma_alloc() calls (inlined) __dma_alloc_buffer() which ends up
calling dmac_flush_range(). Now since the entries in the
arm920_cache_fns are shifted by one, we jump into address 0xee070f38
which is actually next instruction after the arm920_cache_fns
structure.
So implement flush_icache_all() for the rest of the supported CPUs
using a generic 'invalidate I cache' instruction.
Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi>
__lookup_processor_type
When hotplug CPU is enabled, we need to keep the list of supported CPUs,
their setup functions, and __lookup_processor_type in place so that we
can find and initialize secondary CPUs. Move these into the __CPUINIT
section.
All implementations of cpu_proc_fin() start by disabling interrupts
and then flush caches. Rather than have every processors proc_fin()
implementation do this, move it out into generic code - and move the
cache flush past setup_mm_for_reboot() (so it can benefit from having
caches still enabled.)
This allows cpu_proc_fin() to become independent of the L1/L2 cache
types, and eventually move the L2 cache flushing into the L2 support
code.
These are now unused, and so can be removed.
Tested-By: Santosh Shilimkar <santosh.shilimkar@ti.com>
... and rename the function since it no longer operates on just
pages.
Instruction fault status register, IFSR, was introduced on ARMv6 to
provide status information about the last insturction fault. It
needed for proper prefetch abort handling.
Now we have three prefetch abort model:
* legacy - for CPUs before ARMv6. They doesn't provide neither
IFSR nor IFAR. We simulate IFSR with section translation fault
status for them to generalize code;
* ARMv6 - provides IFSR, but not IFAR;
* ARMv7 - provides both IFSR and IFAR.
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Due to problems at cam.org, my nico@cam.org email address is no longer
valid. FRom now on, nico@fluxnic.net should be used instead.
Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
asm code really wants asm/hwcap.h, so include that instead.
As of the previous commit, MT_DEVICE_IXP2000 encodes to the same
PTE bit encoding as MT_DEVICE, so it's now redundant. Convert
MT_DEVICE_IXP2000 to use MT_DEVICE instead, and remove its aliases.
Use 'shared device' mappings for devices, and use the standard
bit combinations for Xscale3.
There are actually only four separate implementations of set_pte_ext.
Use assembler macros to insert code for these into the proc-*.S files.
The proc-*.S files have the _prefetch_abort pointer placed at the end
of the processor structure but the cpu-multi32.h defines it in the
second position. The patch also fixes the support for XSC3 and the
MMU-less CPUs (740, 7tdmi, 940, 946 and 9tdmi).
This patch adds a prefetch abort handler similar to the data abort one
and renames the latter for consistency. Initial implementation by Paul
Brook with some renaming by Catalin Marinas.
Signed-off-by: Paul Brook <paul@codesourcery.com>
Some bootloaders are disabling write buffer coalescing. Enable it back
under linux.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
Add Intel KIXRP435 Reference Platform based on IXP43x processor.
Fixed after review : access to cp15 removed in identification functions,
used access to global processor_id instead
Signed-off-by: Vladimir Barinov <vbarinov@ru.mvista.com>
Signed-off-by: Ruslan Sushko <rsushko@ru.mvista.com>
cosmetic fix so iop333 is not reported as ixp46x
iop333 cpuid = 0x69054210
L_PTE_ASID is not really required to be stored in every PTE, since we
can identify it via the address passed to set_pte_at(). So, create
set_pte_ext() which takes the address of the PTE to set, the Linux
PTE value, and the additional CPU PTE bits which aren't encoded in
the Linux PTE value.
XScale cores either have a DSP coprocessor (which contains a single
40 bit accumulator register), or an iWMMXt coprocessor (which contains
eight 64 bit registers.)
Because of the small amount of state in the DSP coprocessor, access to
the DSP coprocessor (CP0) is always enabled, and DSP context switching
is done unconditionally on every task switch. Access to the iWMMXt
coprocessor (CP0/CP1) is enabled only when an iWMMXt instruction is
first issued, and iWMMXt context switching is done lazily.
CONFIG_IWMMXT is supposed to mean 'the cpu we will be running on will
have iWMMXt support', but boards are supposed to select this config
symbol by hand, and at least one pxa27x board doesn't get this right,
so on that board, proc-xscale.S will incorrectly assume that we have a
DSP coprocessor, enable CP0 on boot, and we will then only save the
first iWMMXt register (wR0) on context switches, which is Bad.
This patch redefines CONFIG_IWMMXT as 'the cpu we will be running on
might have iWMMXt support, and we will enable iWMMXt context switching
if it does.' This means that with this patch, running a CONFIG_IWMMXT=n
kernel on an iWMMXt-capable CPU will no longer potentially corrupt iWMMXt
state over context switches, and running a CONFIG_IWMMXT=y kernel on a
non-iWMMXt capable CPU will still do DSP context save/restore.
These changes should make iWMMXt work on PXA3xx, and as a side effect,
enable proper acc0 save/restore on non-iWMMXt capable xsc3 cores such
as IOP13xx and IXP23xx (which will not have CONFIG_CPU_XSCALE defined),
as well as setting and using HWCAP_IWMMXT properly.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Acked-by: Dan Williams <dan.j.williams@intel.com>
These files want to provide/access ELF hwcap information, so should
be including asm/elf.h rather than asm/procinfo.h
ARM patch 3756/1 added HWCAP_IWMMXT. This patch adds support
for broadcasting that info via /proc/cpuinfo and sets it for
the CPU features of the PXA270.
I've booted 19rc3 on a pxa270 and confirmed that the /proc/cpuinfo
shows "iwmmxt" in the Features.
Signed-off-by: Nicolas Pitre <nico@cam.org>
On stepping A0/A1 of the 80200, invalidating D-cache by line doesn't
clear the dirty bits, which means that if we invalidate a dirty line,
the dirty data can still be written back to memory later on.
To work around this, dma_inv_range() on these two processors is
implemented as dma_flush_range() (i.e. do a clean D-cache line before
doing the invalidate D-cache line.) For this, we currently have a
processor ID check in xscale_dma_inv_range(), but a better solution
is to add a separate cache_fns and proc_info for A0/A1 80200.
Patch from Dan Williams
commit a6a38a66224c7c578cfed2f584b440c81af0c3ae changed the iop321 id to a value that does not work with all platforms. Change the mask to permit bit 11. Tested on an iq80321 600Mhz CRB.
Patch from Lennert Buytenhek
The IOP 80219 xscale CPU is a stripped down version of the IOP32x.
But the fact that the 80219 and IOP32x are very similar doesn't mean
that they need to share a cpu table entry. It's also somewhat confusing
for the end user to see the 80219 reported as an IOP32x, so this patch
splits the IOP32x cpu table entry to make a separate entry for the
80219.
Patch from Nicolas Pitre
According to the Intel PXA27x Processor Family Specification
Update document (doc.nr. 280071-009) erratum E7, some care must be taken
to locate the disabling and re-enabling of the MMU to the beginning of a
cache line to avoid problems in some circumstances.
Credits to Simon Vogl <simon.vogl@researchstudios.at> for bringing this
up.
On some CPUs, bit 4 of section mappings means "update the
cache when written to". On others, this bit is required to
be one, and others it's required to be zero. Finally, on
ARMv6 and above, setting it turns on "no execute" and prevents
speculative prefetches.
With all these combinations, no one value fits all CPUs, so we
have to pick a value depending on the CPU type, and the area
we're mapping.
Most MMU-based CPUs have a restriction on the setting of the data cache
enable and mmu enable bits in the control register, whereby if the data
cache is enabled, the MMU must also be enabled. Enabling the data
cache without the MMU is an invalid combination.
However, there are CPUs where the data cache can be enabled without the
MMU.
In order to allow these CPUs to take advantage of that, provide a
method whereby each proc-*.S file defines the control regsiter value
for use with nommu (with the MMU disabled.) Later on, when we add
support for enabling the MMU on these devices, we can adjust the
"crval" macro to also enable the data cache for nommu.
Fix merge conflict in arch/arm/mm/proc-xscale.S
asm/hardware.h is not required for the majority of processor support
files, ioremap support, mm initialisation, acorn IO support, nor
the debug code (which picks up its machine specific includes via
debug-macros.S)
Move the hardware PMD and PTE page table definitions from pgtable.h
into pgtable-hwdef.h, and include pgtable-hwdef.h as necessary.
The mini I-cache issue is valid only for kernel space since debuggers
would not fly if they used user space addresses for their stubs.
Patch from Ben Dooks
The `make buildcheck` is erroneously reporting that the .proc.info
list is referencing items in the .init section as it is not itself
postfixed with .init
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Patch from Deepak Saxena
The XScale locking code is not something that has been validated
on 2.6 and needs to be replaced with a more generic API to use
with other ARMs that support locking features.
Signed-off-by: Deepak Saxena <dsaxena@plexity.net>
infrastructure for it.
Let it rip!
