The mach-nomadik machine did not compile properly due to bad
ux500-specific functions being called. Introduce new state
variables to fix this up.
Reported-by: Axel Lin <axel.lin@gmail.com>
Cc: Alessandro Rubini <rubini@unipv.it>
Cc: Prafulla Wadaskar <prafulla.wadaskar@st.com>
Signed-off-by: Rickard Andersson <rickard.andersson@stericsson.com>
Reviewed-by: Martin Persson <martin.persson@stericsson.com>
[Split off from larger patch]
Enable wakeups by default for any GPIO interrupts and in the suspend/resume
path narrow this down to only the the real wakeup interrupts. This approach is
based on the assumption that cpuidle ApSleep will be entered more often than
system suspend.
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
[Fixup for genirq changes to struct irq_data on 2.6.38]
Setting pinmux alternative C for a GPIO pin is actually not
so easy since it ivolves setting value "1" in two registers,
and since the combined result will take effect for intermediate
values (01 or 10) this will cause glitches while you wrote one
register but have not yet written the other.
This patch implements a series of kludges including an optional
machine-specific callback to avoid glitches when changing pin
mux mode to alternative C.
When GPIOs wake up the system from sleep mode, the normal GPIO interrupt
handler does not hit and the normal interrupt status register does not
contain the status. Instead the secondary GPIO handler does, and the
interrupt status needs to be retrieved from the wakeup status saved by
the suspend/resume code.
[Added constant 32-pin assignment in platform data]
The SLPM register enables/disables wakeup detection on DB8500v2.
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
On the U8500 platform there are four GPIO blocks, each with a 4K address
space, including the peripheral identification. However, each of these
blocks have a varying number of banks, each of which have 32 GPIOs and
an interrupt line.
The current nomadik-gpio driver implementation can handle each of these
sub-banks easily with one instance each, but cannot as-is be hooked up
to them because it is an AMBA driver and it expects to see a peripheral
with the appropriate peripheral ids but having only one bank and only
one interrupt.
Solve this by converting the driver to a platform driver.
Acked-by: Alessandro Rubini <rubini@unipv.it>
Move the Nomadik GPIO driver to plat-nomadik so that it can also be used
on the Ux500 platform.
The mach-nomadik include/mach/gpio.h is replaced by one that includes
the one now in plat-nomadik, so that code doesn't need to include the
one in plat specifically, and can instead use <linux/gpio.h> as usual.
