Add inline wrappers for device_prep_slave_sg() and device_prep_dma_cyclic()
interfaces to hide new parameter from current users of affected interfaces.
Convert current users to use new wrappers instead of direct calls.
Suggested by Russell King [https://lkml.org/lkml/2012/2/3/269].
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
cherry-picked from mainline commit
16052827d98fbc13c31ebad560af4bd53e2b4dd5
Change-Id: I929a49556539621a0546829e88b3caa498c94be2
Reviewed-on: http://git-master/r/94463
Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually).
To prevent mm.h inclusion via other channels also extract "enum dma_data_direction"
definition into separate header. This tiny piece is what gluing netdevice.h with mm.h
via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h".
Removal of mm.h from scatterlist.h was tried and was found not feasible
on most archs, so the link was cutoff earlier.
Hope people are OK with tiny include file.
Note, that mm_types.h is still dragged in, but it is a separate story.
The mach-nomadik machine did not compile properly due to bad
ux500-specific functions being called. Introduce new state
variables to fix this up.
Reported-by: Axel Lin <axel.lin@gmail.com>
Cc: Alessandro Rubini <rubini@unipv.it>
Cc: Prafulla Wadaskar <prafulla.wadaskar@st.com>
Signed-off-by: Rickard Andersson <rickard.andersson@stericsson.com>
Reviewed-by: Martin Persson <martin.persson@stericsson.com>
[Split off from larger patch]
This moves the Nomadik GPIO driver out of arch/arm/plat-nomadik
and into the desired location indicated by the subsystem
maintainer.
[grant.likely: squashed with kconfig fixup]
The I2C speed enumerators in the i2c-nomadik header file were in
the wrong order.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Add option to have different i2c timeout delay for different i2c buses
specified in platform data. Default to the old value unless specified.
Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com>
Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
arch/arm/Kconfig
arch/arm/mach-ns9xxx/include/mach/uncompress.h
Convert SP804, MXC, Nomadik and Orion 32-bit down-counting clocksources
to generic mmio clocksource infrastructure.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Acked-by: Nicolas Pitre <nico@fluxnic.net>
This patch updates the Nomadik gpio chained IRQ handler to use the
chained IRQ enter/exit functions in order to function correctly on
primary controllers with different methods of flow control.
Cc: Rabin Vincent <rabin@rab.in>
Cc: Grant Likely <grant.likely@secretlab.ca>
Use irq_set_chip_and_handler() instead. Converted with coccinelle.
Convert to the new function names. Automated with coccinelle.
Store the enabled mask in the local state, so there is no need to
fiddle in the irq descriptor.
gpiolib plus two gpio implementations in arm fiddle in the guts of
irq_desc in a racy and buggy way. Remove the stuff. I already told the
gpio folks that we can provide that information in a proper way if
necessary.
LKML-Reference: <20110324212508.931638262@linutronix.de>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (66 commits)
avr32: at32ap700x: fix typo in DMA master configuration
dmaengine/dmatest: Pass timeout via module params
dma: let IMX_DMA depend on IMX_HAVE_DMA_V1 instead of an explicit list of SoCs
fsldma: make halt behave nicely on all supported controllers
fsldma: reduce locking during descriptor cleanup
fsldma: support async_tx dependencies and automatic unmapping
fsldma: fix controller lockups
fsldma: minor codingstyle and consistency fixes
fsldma: improve link descriptor debugging
fsldma: use channel name in printk output
fsldma: move related helper functions near each other
dmatest: fix automatic buffer unmap type
drivers, pch_dma: Fix warning when CONFIG_PM=n.
dmaengine/dw_dmac fix: use readl & writel instead of __raw_readl & __raw_writel
avr32: at32ap700x: Specify DMA Flow Controller, Src and Dst msize
dw_dmac: Setting Default Burst length for transfers as 16.
dw_dmac: Allow src/dst msize & flow controller to be configured at runtime
dw_dmac: Changing type of src_master and dest_master to u8.
dw_dmac: Pass Channel Priority from platform_data
dw_dmac: Pass Channel Allocation Order from platform_data
Enable wakeups by default for any GPIO interrupts and in the suspend/resume
path narrow this down to only the the real wakeup interrupts. This approach is
based on the assumption that cpuidle ApSleep will be entered more often than
system suspend.
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
[Fixup for genirq changes to struct irq_data on 2.6.38]
The compiler warns that [rf]wimsc may be used uninitialized in
this function - the warning is actually false since the uses are
in identical if()-clauses, but it can't hurt very much to read
out the values to be modified early anyway and rid the warning.
Cc: Rabin Vincent <rabin.vincent@stericsson.com>
The NOMADIK_GPIO_PM config option is disabled by default, not user visible,
and never selected by any other option: the code is therefore unused. The
GPIO registers need not be saved and restored since their values are
preserved when vAPE (on DB8500) is powered down.
Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com>
This patch fixes a bug when setting SLPM register for DB8500.
When calling__nmk_gpio_set_slpm(...) offset to GPIO is now used
instead of the GPIO number itself.
Signed-off-by: Rikard Olsson <rikard.p.olsson@stericsson.com>
Setting pinmux alternative C for a GPIO pin is actually not
so easy since it ivolves setting value "1" in two registers,
and since the combined result will take effect for intermediate
values (01 or 10) this will cause glitches while you wrote one
register but have not yet written the other.
This patch implements a series of kludges including an optional
machine-specific callback to avoid glitches when changing pin
mux mode to alternative C.
Coverity found that we were checking an unsigned variable for
>= zero. Type it correctly so that the check works as intended.
Suspend/resume didn't take care of pull-up and pull-down
settings and writing back the DAT register at resume can
change pull up/down settings, depending on pin input value.
Output values are now also restored.
Signed-off-by: Jonas Aaberg <jonas.aberg@stericsson.com>
When GPIOs wake up the system from sleep mode, the normal GPIO interrupt
handler does not hit and the normal interrupt status register does not
contain the status. Instead the secondary GPIO handler does, and the
interrupt status needs to be retrieved from the wakeup status saved by
the suspend/resume code.
[Added constant 32-pin assignment in platform data]
The dmaengine framework has the API for this now.
Acked-by: Per Forlin <per.forlin@stericsson.com>
Acked-by: Jonas Aaberg <jonas.aberg@stericsson.com>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
DB8500v2's DMA40 (revision 3) allows setting event lines as high priority and
real time.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (63 commits)
ARM: PL08x: cleanup comments
Update CONFIG_MD_RAID6_PQ to CONFIG_RAID6_PQ in drivers/dma/iop-adma.c
ARM: PL08x: fix a warning
Fix dmaengine_submit() return type
dmaengine: at_hdmac: fix race while monitoring channel status
dmaengine: at_hdmac: flags located in first descriptor
dmaengine: at_hdmac: use subsys_initcall instead of module_init
dmaengine: at_hdmac: no need set ACK in new descriptor
dmaengine: at_hdmac: trivial add precision to unmapping comment
dmaengine: at_hdmac: use dma_address to program DMA hardware
pch_dma: support new device ML7213 IOH
ARM: PL08x: prevent dma_set_runtime_config() reconfiguring memcpy channels
ARM: PL08x: allow dma_set_runtime_config() to return errors
ARM: PL08x: fix locking between prepare function and submit function
ARM: PL08x: introduce 'phychan_hold' to hold on to physical channels
ARM: PL08x: put txd's on the pending list in pl08x_tx_submit()
ARM: PL08x: rename 'desc_list' as 'pend_list'
ARM: PL08x: implement unmapping of memcpy buffers
ARM: PL08x: store prep_* flags in async_tx structure
ARM: PL08x: shrink srcbus/dstbus in txd structure
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
Acked-by: Rabin Vincent <rabin.vincent@stericsson.com>
arch/arm/mach-pxa/clock.c
arch/arm/mach-pxa/clock.h
The maximum transfer size of the stedma40 is (64k-1) x data-width.
If the transfer size of one element exceeds this limit
the job is split up and sent as linked transfer.
Signed-off-by: Per Forlin <per.forlin@linaro.org>
Convert nomadik platforms to use the new sched_clock() infrastructure
for extending 32bit counters to full 64-bit nanoseconds.
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
ftrace requires sched_clock() to be notrace. Ensure that all
implementations are so marked. Also make sure that they include
linux/sched.h
Also ensure OMAP clocksource read functions are marked notrace as
they're used for sched_clock() too.
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Will Deacon <will.deacon@arm.com>
Tested-by: Mikael Pettersson <mikpe@it.uu.se>
Tested-by: Eric Miao <eric.y.miao@gmail.com>
Tested-by: Olof Johansson <olof@lixom.net>
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new
interfaces were added which simplify (and optimize) the selection of the
divisor shift/mult constants. Switch over to using this new interface.
Platforms may choose not to provide an additional name for the GPIO
block.
In the nomadik GPIO pin configuration, allow the sleep mode direction
and pull configurations to differ from the ones for the normal state.
PIN_SLPM_PULL_*, PIN_SLPM_INPUT, PIN_SLPM_OUTPUT* macros are provided
for this.
Since the hardware does not allow seperate configurations for sleep mode
and normal mode, this is implemented by having software remux the
configurations as necessary.
Reviewed-by: Srinidhi KASAGAR <srinidhi.kasagar@stericsson.com>
Signed-off-by: Mian Yousaf Kaukab <mian.yousaf.kaukab@stericsson.com>
The current implementation of sched_clock() for the Nomadik
family is based on the clock source that will wrap around without
any compensation. Currently on the Ux500 after 1030 seconds.
Utilize cnt32_to_63 to expand the sched_clock() counter to 63
bits and introduce a keepwarm() timer to assure that sched clock
and this cnt32_to_63 is called atleast once every half period.
When I print out the actual wrap-around time, and using
a year (3600*24*365 seconds) as minumum wrap limit I get an
actual wrap-around of:
sched_clock: using 55 bits @ 8333125 Hz wrap in 416 days
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (48 commits)
DMAENGINE: move COH901318 to arch_initcall
dma: imx-dma: fix signedness bug
dma/timberdale: simplify conditional
ste_dma40: remove channel_type
ste_dma40: remove enum for endianess
ste_dma40: remove TIM_FOR_LINK option
ste_dma40: move mode_opt to separate config
ste_dma40: move channel mode to a separate field
ste_dma40: move priority to separate field
ste_dma40: add variable to indicate valid dma_cfg
async_tx: make async_tx channel switching opt-in
move async raid6 test to lib/Kconfig.debug
dmaengine: Add Freescale i.MX1/21/27 DMA driver
intel_mid_dma: change the slave interface
intel_mid_dma: fix the WARN_ONs
intel_mid_dma: Add sg list support to DMA driver
intel_mid_dma: Allow DMAC2 to share interrupt
intel_mid_dma: Allow IRQ sharing
intel_mid_dma: Add runtime PM support
DMAENGINE: define a dummy filter function for ste_dma40
Signed-off-by: Zimny Lech <napohybelskurwysynom2010@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (75 commits)
Input: wacom - specify Cinitq supported tools
Input: ab8500-ponkey - fix IRQ freeing in error path
Input: adp5588-keys - use more obvious i2c_device_id name string
Input: ad7877 - switch to using threaded IRQ
Input: ad7877 - use attribute group to control visibility of attributes
Input: serio - add support for PS2Mult multiplexer protocol
Input: wacom - properly enable runtime PM
Input: ad7877 - filter events where pressure is beyond the maximum
Input: ad7877 - implement EV_KEY:BTN_TOUCH reporting
Input: ad7877 - implement specified chip select behavior
Input: hp680_ts_input - use cancel_delayed_work_sync()
Input: mousedev - correct lockdep annotation
Input: ads7846 - switch to using threaded IRQ
Input: serio - support multiple child devices per single parent
Input: synaptics - simplify pass-through port handling
Input: add ROHM BU21013 touch panel controller support
Input: omap4-keypad - wake-up on events & long presses
Input: omap4-keypad - fix interrupt line configuration
Input: omap4-keypad - SYSCONFIG register configuration
Input: omap4-keypad - use platform device helpers
It has been replaced with separate fields.
A bool will suffice. The default is little endian.
This does not seem to be implemented.
Defaults are "basic mode" for physical channels, and "logical source
logical destination" for logical channels.
And keep it logical by default.
And keep it low priority by default.
'st-ux' and 'unwind' into devel
