This patch proposes to remove the IRQF_DISABLED flag from OMAP code
It's a NOOP since 2.6.35, and will be removed one day.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Fix to return a negative error code from the error handling
case instead of 0, as done elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Given p = pdev->dev.platform_data; and
d = p->dma_attr;
the freeing of either one of these by the driver
seems just plain wrong.
Get rid of them in the .probe failure path as well as the
.remove.
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Init dma_chan_link_map[lch] *after* its memset to 0.
Signed-off-by: R Sricharan <r.sricharan@ti.com>
Once a free channel is found, the check for dev_id == 0 does
not make any sense. Get rid of it.
'omap_dma_reserve_channels' when used is suppose to be from command.
so, it alreay has value before 1st call of omap_system_dma_probe.
and it will never be changed again during running (not from ioctl).
but 'dma_lch_count' is zero before 1st call of omap_system_dma_probe.
so it will be failed for omap_dma_reserve_channels, when 1st call.
so, need use 'd->lch_count' instead of 'dma_lch_count' for judging.
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Based on earlier discussions[1] we attempted to find a suitable
location for the omap DMA header in commit 2b6c4e73 (ARM: OMAP:
DMA: Move plat/dma.h to plat-omap/dma-omap.h) until the conversion
to dmaengine is complete.
Unfortunately that was before I was able to try to test compile
of the ARM multiplatform builds for omap2+, and the end result
was not very good.
So I'm creating yet another all over the place patch to cut the
last dependency for building omap2+ for ARM multiplatform. After
this, we have finally removed the driver dependencies to the
arch/arm code, except for few drivers that are being worked on.
The other option was to make the <plat-omap/dma-omap.h> path
to work, but we'd have to add some new header directory to for
multiplatform builds.
Or we would have to manually include arch/arm/plat-omap/include
again from arch/arm/Makefile for omap2+.
Neither of these alternatives sound appealing as they will
likely lead addition of various other headers exposed to the
drivers, which we want to avoid for the multiplatform kernels.
Since we already have a minimal include/linux/omap-dma.h,
let's just use that instead and add a note to it to not
use the custom omap DMA functions any longer where possible.
Note that converting omap DMA to dmaengine depends on
dmaengine supporting automatically incrementing the FIFO
address at the device end, and converting all the remaining
legacy drivers. So it's going to be few more merge windows.
[1] https://patchwork.kernel.org/patch/1519591/#
cc: Russell King <linux@arm.linux.org.uk>
cc: Kevin Hilman <khilman@ti.com>
cc: "Benoît Cousson" <b-cousson@ti.com>
cc: Herbert Xu <herbert@gondor.apana.org.au>
cc: "David S. Miller" <davem@davemloft.net>
cc: Vinod Koul <vinod.koul@intel.com>
cc: Dan Williams <djbw@fb.com>
cc: Mauro Carvalho Chehab <mchehab@infradead.org>
cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
cc: David Woodhouse <dwmw2@infradead.org>
cc: Kyungmin Park <kyungmin.park@samsung.com>
cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
cc: Hans Verkuil <hans.verkuil@cisco.com>
cc: Vaibhav Hiremath <hvaibhav@ti.com>
cc: Lokesh Vutla <lokeshvutla@ti.com>
cc: Rusty Russell <rusty@rustcorp.com.au>
cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
cc: Afzal Mohammed <afzal@ti.com>
cc: linux-crypto@vger.kernel.org
cc: linux-media@vger.kernel.org
cc: linux-mtd@lists.infradead.org
cc: linux-usb@vger.kernel.org
cc: linux-fbdev@vger.kernel.org
Acked-by: Felipe Balbi <balbi@ti.com>
This code will be eventually in drivers, and for the
code in the drivers we don't want to have any cpu_is_omap
usage. Those macros should be private to arch/arm/mach-omap1
and arch/arm/mach-omap2.
To fix this, let's move the define for dma_omap2plus()
to dma-omap.h, and use the existing dma_attr passed in
the platform_data as the revision registers are what they
are.
Note that we can now also remove the relative includes
introduced by the recent clean-up patches.
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
We want to remove plat/cpu.h. To do this, let's first split
it to private soc.h to mach-omap1 and mach-omap2. We have to
keep plat/cpu.h around until the remaining drivers are fixed,
so let's include the local soc.h in plat/cpu.h and for drivers
still including plat/cpu.h.
Once the drivers are fixed not to include plat/cpu.h, we
can remove the file.
This is needed for the ARM common zImage support.
[tony@atomide.com: updated to not print a warning]
We cannot keep this in plat as it causes problems
with the ARM single zImage support.
Cc: Felipe Balbi <balbi@ti.com>
Cc: linux-pcmcia@lists.infradead.org
Move plat/dma.h to plat-omap/dma-omap.h as part of single
zImage work
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into cleanup-makefile-sparse
smatch and string-wrapping cleanups for the OMAP subarch code.
These changes fix some of the more meaningful warnings that smatch
returns for the OMAP subarch code, and unwraps strings that are
wrapped at the 80-column boundary, to conform with the current
practice.
Basic build, boot, and PM logs are available here:
http://www.pwsan.com/omap/testlogs/warnings_a_cleanup_3.7/20120912025927/
As the plat and mach includes need to disappear for single zImage work,
we need to remove plat/hardware.h.
Do this by splitting plat/hardware.h into omap1 and omap2+ specific files.
The old plat/hardware.h already has omap1 only defines, so it gets moved
to mach/hardware.h for omap1. For omap2+, we use the local soc.h
that for now just includes the related SoC headers to keep this patch more
readable.
Note that the local soc.h still includes plat/cpu.h that can be dealt
with in later patches. Let's also include plat/serial.h from common.h for
all the board-*.c files. This allows making the include files local later
on without patching these files again.
Note that only minimal changes are done in this patch for the
drivers/watchdog/omap_wdt.c driver to keep things compiling. Further
patches are needed to eventually remove cpu_is_omap usage in the drivers.
Also only minimal changes are done to sound/soc/omap/* to remove the
unneeded includes and to define OMAP44XX_MCPDM_L3_BASE locally so there's
no need to include omap44xx.h.
While at it, also sort some of the includes in the standard way.
Cc: linux-watchdog@vger.kernel.org
Cc: alsa-devel@alsa-project.org
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
Cc: Liam Girdwood <lrg@ti.com>
Acked-by: Wim Van Sebroeck <wim@iguana.be>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Find and unwrap wrapped strings in the style:
pr_debug("clockdomain: hardware cannot set/clear wake up of "
"%s when %s wakes up\n", clkdm1->name, clkdm2->name);
Keeping these strings contiguous seems to be the current Linux kernel
policy.
The offending lines were found with the following command:
pcregrep -rnM '"\s*$\s*"' arch/arm/*omap*
While here, some messages have been clarified, some pr_warning(
... calls have been converted to pr_warn( ..., and some printk(KERN_*
... have been converted to pr_*.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Use omap_disable_channel_irq() function instead of directly accessing CICR
register in various functions.
The omap_disable_chanel_irq() function now clears pending interrupts
and disables interrupt on channel.
Functions omap2_enable_irq_lch()/omap2_disable_irq_lch() clear interrupt
status register.
Signed-off-by: Oleg Matcovschi <oleg.matcovschi@ti.com>
Tested-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
[tony@atomide.com: updated comments to clarify CICR access]
Pull arm-soc cleanups (part 2) from Olof Johansson:
"More cleanups, continuing an earlier set with omap and samsung
specific cleanups. These could not go into the first set because they
have dependencies on various other series that in turn depend on the
first cleanups."
Fixed up conflicts in arch/arm/plat-omap/counter_32k.c due to commit
bd0493eaaf5c: "move read_{boot,persistent}_clock to the architecture
level" that changed how the persistent clocks were handled. And trivial
conflicts in arch/arm/mach-omap1/common.h due to just independent
changes close to each other.
* tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (35 commits)
ARM: SAMSUNG: merge plat-s5p into plat-samsung
ARM: SAMSUNG: move options for common s5p into plat-samsung/Kconfig
ARM: SAMSUNG: move setup code for s5p mfc and mipiphy into plat-samsung
ARM: SAMSUNG: move platform device for s5p uart into plat-samsung
ARM: SAMSUNG: move hr timer for common s5p into plat-samsung
ARM: SAMSUNG: move pm part for common s5p into plat-samsung
ARM: SAMSUNG: move interrupt part for common s5p into plat-samsung
ARM: SAMSUNG: move clock part for common s5p into plat-samsung
ARM: S3C24XX: Use common macro to define resources on dev-uart.c
ARM: S3C24XX: move common clock init into common.c
ARM: S3C24XX: move common power-management code to mach-s3c24xx
ARM: S3C24XX: move plat-s3c24xx/dev-uart.c into common.c
ARM: S3C24XX: move plat-s3c24xx/cpu.c
ARM: OMAP2+: Kconfig: convert SOC_OMAPAM33XX to SOC_AM33XX
ARM: OMAP2+: Kconfig: convert SOC_OMAPTI81XX to SOC_TI81XX
GPMC: add ECC control definitions
ARM: OMAP2+: dmtimer: remove redundant sysconfig context restore
ARM: OMAP: AM35xx: convert 3517 detection/flags to AM35xx
ARM: OMAP: AM35xx: remove redunant cpu_is checks for AM3505
ARM: OMAP1: Pass dma request lines in platform data to MMC driver
Linux 3.4-rc6
Resolve conflict where an u5500 file had a bugfix go in, but was
deleted in the branch staged for next merge window.
git://gitorious.org/omap-sw-develoment/linux-omap-dev into cleanup-soc
cpu_class_is_omap2() contains all OMAP2+ devices. So update the DMA code
cpu checks accordingly so that there is no need to patch
the file for any future OMAP2+ devices.
In long run, all these attributes should come from hwmod dev_attr based
on DMA IP version.
Using coherent DMA memory with the OMAP DMA engine results in
unpredictable behaviour due to memory ordering issues; as things stand,
there is no guarantee that data written to coherent DMA memory will be
visible to the DMA hardware.
This is because the OMAP dma_write() accessor contains no barriers,
necessary on ARMv6 and above. The effect of this can be seen in comments
in the OMAP serial driver, which incorrectly talks about cache flushing
for the coherent DMA stuff.
Rather than adding barriers to the accessors, add it in the DMA support
code just before we enable DMA, and just after we disable DMA. This
avoids having barriers for every DMA register access.
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
gcc can apparently handle stack-allocated arrays that use a dynamic
variable as the array maximum. Rather than using a mutable quantity,
simply use a constant maximum possible size. To me, code clarity is
improved; and it also avoids the following sparse warnings:
arch/arm/plat-omap/dma.c:886:40: error: bad constant expression
arch/arm/plat-omap/dma.c:892:17: error: cannot size expression
arch/arm/plat-omap/dma.c:970:40: error: bad constant expression
arch/arm/plat-omap/dma.c:972:17: error: cannot size expression
Also drop some dead code from the OMAP1 LCD DMA code:
arch/arm/mach-omap1/lcd_dma.c:80:6: warning: symbol 'omap_set_lcd_dma_src_port' was not declared. Should it be static?
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Disintegrate asm/system.h for ARM.
cc: linux-arm-kernel@lists.infradead.org
Pull "ARM: global cleanups" from Arnd Bergmann:
"Quite a bit of code gets removed, and some stuff moved around, mostly
the old samsung s3c24xx stuff. There should be no functional changes
in this series otherwise. Some cleanups have dependencies on other
arm-soc branches and will be sent in the second round.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fixed up trivial conflicts mainly due to #include's being changes on
both sides.
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (121 commits)
ep93xx: Remove unnecessary includes of ep93xx-regs.h
ep93xx: Move EP93XX_SYSCON defines to SoC private header
ep93xx: Move crunch code to mach-ep93xx directory
ep93xx: Make syscon access functions private to SoC
ep93xx: Configure GPIO ports in core code
ep93xx: Move peripheral defines to local SoC header
ep93xx: Convert the watchdog driver into a platform device.
ep93xx: Use ioremap for backlight driver
ep93xx: Move GPIO defines to gpio-ep93xx.h
ep93xx: Don't use system controller defines in audio drivers
ep93xx: Move PHYS_BASE defines to local SoC header file
ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver
ARM: EXYNOS: add clock registers for exynos4x12-cpufreq
PM / devfreq: update the name of EXYNOS clock registers that were omitted
ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock
ARM: EXYNOS: use static declaration on regarding clock
ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs
ARM: OMAP2+: Fix build error after merge
ARM: S3C24XX: remove call to s3c24xx_setup_clocks
This is needed to minimize io.h so the SoC specific io.h
for ARMs can removed.
Note that minimal driver changes for DSS and RNG are needed to
include cpu.h for SoC detection macros.
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Otherwise we get:
`omap_system_dma_remove' referenced in section `.data' of arch/arm/plat-omap/built-in.o:
defined in discarded section `.devexit.text' of arch/arm/plat-omap/built-in.o
If the DMA destination position has been asked before the
first actual data transfer has been done, the CDAC
register still contains 0 (it is initialized to 0 at
omsp_dma_start).
If CDAC == 0, return the programmed start address.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Reviewed-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
If the DMA source position has been asked before the
first actual data transfer has been done, the CSAC
register does not contain valid information.
We can identify this situation by checking the CDAC
register:
CDAC != 0 indicates that the DMA transfer on the channel has
been started already.
When CDAC == 0 we can not trust the CSAC value since it has
not been updated, and can contain random number.
Return the start address in case the DMA has not jet started.
Note: The CDAC register has been initialized to 0 at dma_start
time.
Eliminates the following sparse warning:
arch/arm/plat-omap/dma.c:137:5: warning: symbol 'omap_dma_in_1510_mode' was not declared. Should it be static?
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
When clearing the DMA channel, clear all status bits.
When handling a DMA interrupt, clear only the interrupt
status bits that have been read and are passed to the
channel's interrupt handler, not every status bit.
Signed-off-by: Adrian Hunter <adrian.hunter@nokia.com>
Acked-by: G, Manjunath Kondaiah <manjugk@ti.com>
Convert DMA library into DMA platform driver and make use of
platform data provided by hwmod data base for OMAP2+ onwards.
For OMAP1 processors, the DMA driver in mach-omap uses resource
structures for getting platform data.
Thanks to Tony Lindgren <tony@atomide.com> for fixing various
omap1 issues and testing the same on OSK5912 board.
Signed-off-by: G, Manjunath Kondaiah <manjugk@ti.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
Implement errata handling to use flags instead of cpu_is_* and
cpu_class_* in the code.
The errata flags are initialized at init time and during runtime we are
using the errata variable (via the IS_DMA_ERRATA macro) to execute the
required errata workaround.
Reused errata handling patch from: Peter Ujfalusi
<peter.ujfalusi@nokia.com>
https://patchwork.kernel.org/patch/231191/
Changes to above patch:
1. Changes are done for converting all the existing errata work arounds
to use this feature.
2. Detailed description for each errata is added.
3. Fixed bug in SET_DMA_ERRATA macro
4. Bit shifting in macro definitions are replaced with BIT() macro
Prepare DMA library to get converted into DMA driver using platform
device model and hwmod infrastucture(for omap2+, resource structures
for omap1)
The low level read/write macros are replaced with static inline
functions and register offsets are handled through static register
offset tables mapped through enumeration constants.
These low level read/write functions along with static register offset
tables will be moved to respective mach-omap dma files in the later
patches of this series.
There are no functionality changes with these changes except change in
logic for handling 16bit registers of OMAP1.
Make some functions static to get rid of the following sparse warnings:
arch/arm/mach-omap1/mcbsp.c:177:12: warning: symbol 'omap1_mcbsp_init' was not declared. Should it be static?
arch/arm/mach-omap1/mux.c:346:22: warning: symbol 'omap1_cfg_reg' was not declared. Should it be static?
arch/arm/plat-omap/dma.c:177:5: warning: symbol 'omap_dma_in_1510_mode' was not declared. Should it be static?
arch/arm/plat-omap/sram.c:273:12: warning: symbol 'omap1_sram_init' was not declared. Should it be static?
Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Flush the writes to IRQSTATUS_L0 register in the DMA interrupt handler by reading the register
directly after write. This prevents the spurious DMA interrupts noted when using VDD_OPP 1
Signed-off-by: Mathias Nyman <mathias.nyman@nokia.com>
Acked-by: Santosh Shilimkar <Santosh.shilimkar@ti.com>
Implement the suggested workaround for OMAP3 regarding to sDMA draining
issue, when the channel is disabled on the fly.
This errata affects the following configuration:
sDMA transfer is source synchronized
Buffering is enabled
SmartStandby is selected.
The issue can be easily reproduced by creating overrun situation while
recording audio.
Either introduce load to the CPU:
nice -19 arecord -D hw:0 -M -B 10000 -F 5000 -f dat > /dev/null & \
dd if=/dev/urandom of=/dev/null
or suspending the arecord, and resuming it:
CTRL+Z; fg; CTRL+Z; fg; ...
In case of overrun audio stops DMA, and restarts it (without reseting
the sDMA channel). When we hit this errata in stop case (sDMA drain did
not complete), at the coming start the sDMA will not going to be
operational (it is still draining).
This leads to DMA stall condition.
On OMAP3 we can recover with sDMA channel reset, it has been observed
that by introducing unrelated sDMA activity might also help (reading
from MMC for example).
The same errata exists for OMAP2, where the suggestion is to disable the
buffering to avoid this type of error.
On OMAP3 the suggestion is to set sDMA to NoStandby before disabling
the channel, and wait for the drain to finish, than configure sDMA to
SmartStandby again.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Acked-by: Jarkko Nikula <jhnikula@gmail.com>
Acked-by : Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by : Manjunath Kondaiah G <manjugk@ti.com>
An errata workaround for omap24xx is not setting the buffering disable bit
25 what is the purpose but channel enable bit 7 instead.
Background for this fix is the DMA stalling issue with ASoC omap-mcbsp
driver. Peter Ujfalusi <peter.ujfalusi@nokia.com> has found an issue in
recording that the DMA stall could happen if there were a buffer overrun
detected by ALSA and the DMA was stopped and restarted due that. This
problem is known to occur on both OMAP2420 and OMAP3. It can recover on
OMAP3 after dma free, dma request and reconfiguration cycle. However, on
OMAP2420 it seems that only way to recover is a reset.
Problem was not visible before the commit c12abc0. That commit changed that
the McBSP transmitter/receiver is released from reset only when needed. That
is, only enabled McBSP transmitter without transmission was able to prevent
this DMA stall problem in receiving side and underlying problem did not show
up until now. McBSP transmitter itself seems to no be reason since DMA
stall does not recover by enabling the transmission after stall.
Debugging showed that there were a DMA write active during DMA stop time and
it never completed even when restarting the DMA. Experimenting showed that
the DMA buffering disable bit could be used to avoid stalling when using
source synchronized transfers. However that could have performance hit and
OMAP3 TRM states that buffering disable is not allowed for destination
synchronized transfers so subsequent patch will implement a method to
complete DMA writes when stopping.
This patch is based on assumtion that complete lock-up on OMAP2420 is
different but related problem. I don't have access to OMAP2420 errata but
I believe this old workaround here is put for a reason but unfortunately
a wrong bit was typed and problem showed up only now.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Acked-by: Manjunath Kondaiah G <manjugk@ti.com>
Omap DMA controller can prefetch data in advance in case of
destination synchronized data transfer. This may increase
performance when target HW block doesn't have fifo.
Data is waiting for transfer request in DMA fifo instead of read from memory.
Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com>
Multi line comments are fixed as per CodingStyle
guidelines.
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Signed-off-by: Manjunatha GK <manjugk@ti.com>
If we are softbooting another kernel using kexec, DMA controller state is not
known when we are performing omap_init_dma(). It is possible that some DMA
channels are already active. For example after kexec we get:
<4>IRQ 0020 for non-allocated DMAchannel 5
To prevent any weird things happening, we disable all channel interrupts during
init.
Signed-off-by: Mika Westerberg <ext-mika.1.westerberg@nokia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (39 commits)
omap: delete unused bootloader tag variables
omap: Devkit8000: Remove unused pins
omap: Devkit8000: Change position of init calls
omap: Devkit8000: Remove unnecessary include file
omap: Devkit8000: Fix typo in pin name
omap: Devkit8000: Add missing package selection
omap: Devkit8000: Fix typo in supplies
n8x0_defconfig: remove CONFIG_NILFS2_FS override
omap: board-sdp-flash.c: Fix typos in debug output
omap4: Fix McBSP4 base address
omap: rx51_defconfig: Remove CONFIG_SYSFS_DEPRECATED*=y options
omap: rx51_defconfig: Remove duplicate phonet
omap: fix a gpmc nand problem
AM3517: initialize i2c subsystem after mux subsystem
omap: remove one of the define of INT_34XX_BENCH_MPU_EMUL
omap: fix the compile error if CONFIG_MTD_NAND_OMAP2 is notenabled
OMAP4: Clocks: Change SPI Instance Names
omap: Devkit8000: Fix wrong usb port on Devkit8000
OMAP4: Fix for CONTROL register Base
OMAP4-HSMMC: FIX for MMC5 Controller IRQ Base
The register DMA4_CDAC needs to be initialized to zero
before starting DMA transfer.
Cc: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Govindraj R <govindraj.raja@ti.com>
Reported-by:S, Venkatraman <svenkatr@ti.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This patch removes all the omap4 specific irq line
defines from plat/irqs.h and includes auto-generated
irqs-44xx.h
All the legacy naming style defines are replaced with the one
from irqs-44xx.h
Reviewed-by: Kevin Hilman <khilman@deeprootsystems.com>
Reviewed-by: Paul Walmsley <paul@pwsan.com>
[tony@atomide.com: updated to compile with usb-musb.c]
The commit 'ba50ea7e' reserves DMA channels 0 and 1 on high
security devices, in order to avoid collision between kernel
dma transfers and ROM code dma transfers.
This fix is applicable only for OMAP3 so add an appropriate
check.
CC: Kalle Jokiniemi <kalle.jokiniemi@digia.com>
CC: Kevin Hilman <khilman@deeprootsystems.com>
This patch enables smart-idle idlemodes and autoidle for sDMA
on OMAP4
omap: Replace orred CONFIG_ARCH_OMAP2/3/4 with CONFIG_ARCH_OMAP2PLUS
omap_dma_unlink_lch()
The same flag and bits were tested twice.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
