path: root/arch/arm/plat-omap/mailbox.c
2013-06-11mailbox/omap: move the OMAP mailbox framework to driversSuman Anna
The mailbox hardware (in OMAP) uses a queued mailbox interrupt mechanism that provides a communication channel between processors through a set of registers and their associated interrupt signals by sending and receiving messages. The OMAP mailbox framework/driver code is moved to be under drivers/mailbox, in preparation for adapting to a common mailbox driver framework. This allows the build for OMAP mailbox to be enabled (it was disabled during the multi-platform support). As part of the migration from plat and mach code: - Kconfig symbols have been renamed to build OMAP1 or OMAP2+ drivers. - mailbox.h under plat-omap/plat/include has been split into a public and private header files. The public header has only the API related functions and types. - The module name mailbox.ko from plat-omap is changed to omap-mailbox.ko - The module name mailbox_mach.ko from mach-omapX is changed as mailbox_omap1.ko for OMAP1 mailbox_omap2.ko for OMAP2+ Cc: Tony Lindgren <tony@atomide.com> [gregkh@linuxfoundation.org: ack for staging part] Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Omar Ramirez Luna <omar.ramirez@copitl.com> Signed-off-by: Suman Anna <s-anna@ti.com>
2013-06-11omap: mailbox: call request_irq after mbox queues are allocatedSuman Anna
The OMAP mailbox startup code is enabling the interrupt before any of the associated mailbox queues are allocated. Move this code so that the interrupt configuration for a mailbox is together. Signed-off-by: Fernando Guzman Lugo <lugo.fernando@gmail.com> Signed-off-by: Suman Anna <s-anna@ti.com>
2012-08-20workqueue: deprecate flush[_delayed]_work_sync()Tejun Heo
flush[_delayed]_work_sync() are now spurious. Mark them deprecated and convert all users to flush[_delayed]_work(). If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant and the regular flushes guarantee that the work item is not pending or running on any CPU on return, so there's no reason to use the sync flushes at all and they're going away. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Avi Kivity <avi@redhat.com>
2012-05-13ARM: OMAP: enable mailbox irq per instanceJuan Gutierrez
The machine-specific omap2_mbox_startup is called only once to initialize the whole mbox module, and as a result, enabling the mbox irq at that point only works for the very first mailbox instance opened. Instead, this patch makes sure enable_irq() is called every time a new mbox instance is opened. In addition, we're now enabling the mbox's irq only after its notifier_block is registered, to avoid possible race of receiving an interrupt without invoking the user's notifier callback. Signed-off-by: Juan Gutierrez <jgutierrez@ti.com> Signed-off-by: Suman Anna <s-anna@ti.com> [ohad@wizery.com: slightly reworded the commit log] Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
2012-03-05ARM: OMAP: mailbox: trivial whitespace fixFelipe Contreras
Trivial whitespace fix Signed-off-by: Felipe Contreras <felipe.contreras@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-10-31arm: fix implicit module.h users by adding it to arch/arm as required.Paul Gortmaker
These files will fail to compile if we dont clean them up in advance and have them include the appropriate headers they need. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-16Merge branch 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix build failure introduced by s/freezeable/freezable/ workqueue: add system_freezeable_wq rds/ib: use system_wq instead of rds_ib_fmr_wq net/9p: replace p9_poll_task with a work net/9p: use system_wq instead of p9_mux_wq xfs: convert to alloc_workqueue() reiserfs: make commit_wq use the default concurrency level ocfs2: use system_wq instead of ocfs2_quota_wq ext4: convert to alloc_workqueue() scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path scsi/be2iscsi,qla2xxx: convert to alloc_workqueue() misc/iwmc3200top: use system_wq instead of dedicated workqueues i2o: use alloc_workqueue() instead of create_workqueue() acpi: kacpi*_wq don't need WQ_MEM_RECLAIM fs/aio: aio_wq isn't used in memory reclaim path input/tps6507x-ts: use system_wq instead of dedicated workqueue cpufreq: use system_wq instead of dedicated workqueues wireless/ipw2x00: use system_wq instead of dedicated workqueues arm/omap: use system_wq in mailbox workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
2011-02-14OMAP2+: mailbox: fix lookups for multiple mailboxesKevin Hilman
The pointer math in omap_mbox_get() is not quite right, and leads to passing NULL to strcmp() when searching for an mbox that is not first in the list. Convert to using array indexing as is done in all the other functions which walk the mbox list. Tested on OMAP2420/n810, OMAP3630/zoom3, OMAP4430/Blaze Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-01-26arm/omap: use system_wq in mailboxTejun Heo
With cmwq, there's no reason to use a separate workqueue for mailbox. Use the system_wq instead. mbox->rxq->work is sync flushed in omap_mbox_fini() to make sure it's not running on any cpu, which makes sure that no mbox work is running when omap_mbox_exit() is entered. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Hari Kanigeri <hari.kanigeri@gmail.com> Cc: Tony Lindgren <tony@atomide.com> Cc: linux-omap@vger.kernel.org
2010-12-02OMAP: mailbox: add notification support for multiple readersKanigeri, Hari
In the current mailbox driver, the mailbox internal pointer for callback can be directly manipulated by the Users, so a second User can easily corrupt the first user's callback pointer. The initial effort to correct this issue can be referred here: https://patchwork.kernel.org/patch/107520/ Along with fixing the above stated issue, this patch adds the flexibility option to register notifications from multiple readers to the events received on a mailbox instance. The discussion regarding this can be referred here. http://www.mail-archive.com/linux-omap@vger.kernel.org/msg30671.html Signed-off-by: Hari Kanigeri <h-kanigeri2@ti.com> Signed-off-by: Fernando Guzman Lugo <x0095840@ti.com> Acked-by: Hiroshi Doyu <hiroshi.doyu@nokia.com>
2010-12-02OMAP: mailbox: send message in process contextKanigeri, Hari
Schedule the Tasklet to send only when mailbox fifo is full and there are pending messages in kfifo, else send the message directly in the Process context. This would avoid needless scheduling of Tasklet for every message transfer Signed-off-by: Hari Kanigeri <h-kanigeri2@ti.com> Acked-by: Hiroshi Doyu <hiroshi.doyu@nokia.com>
2010-12-02OMAP: mailbox: fix checkpatch warningsKanigeri, Hari
Fix the following checkpatch warnings observed in mailbox module. WARNING: please, no space for starting a line, excluding comments + fail_alloc_rxq:$ WARNING: please, no space for starting a line, excluding comments + fail_alloc_txq:$ WARNING: please, no space for starting a line, excluding comments + fail_request_irq:$ WARNING: line over 80 characters + mbox_kfifo_size = max_t(unsigned int, mbox_kfifo_size, sizeof(mbox_msg_t)); Signed-off-by: Hari Kanigeri <h-kanigeri2@ti.com> Acked-by: Hiroshi Doyu <hiroshi.doyu@nokia.com>
2010-12-02OMAP: mailbox: change full flag per mailbox queue instead of globalFernando Guzman Lugo
The variable rq_full flag is a global variable, so if there are multiple mailbox users there will be conflicts. Now there is a full flag per mailbox queue. Reported-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Fernando Guzman Lugo <x0095840@ti.com> Signed-off-by: Hari Kanigeri <h-kanigeri2@ti.com> Acked-by: Hiroshi Doyu <hiroshi.doyu@nokia.com>
2010-08-04omap: mailbox: reorganize headersFelipe Contreras
Remove kernel.h and module.h since they are not used correctly anyway. Also, remove device.h since it comes along with platform_device.h (always will I guess). Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: simplify omap_mbox_register()Felipe Contreras
No need to dynamically register mailboxes one by one. Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap mailbox: Set a device in logical mbox instance for traceabilityHiroshi DOYU
With this patch, you'll get the following sysfs directories. This structure implies that a single platform device, "omap2-mailbox" holds multiple logical mbox instances. This could be the base to add sysfs files for each logical mboxes. Then userland application can access a mbox through sysfs entries if necessary(ex: setting kfifo size dynamically) ~# tree -d -L 2 /sys/devices/platform/omap2-mailbox/ /sys/devices/platform/omap2-mailbox/ |-- driver -> ../../../bus/platform/drivers/omap2-mailbox |-- mbox | |-- dsp <- they are each instances of logical mailbox. | |-- ducati | |-- iva2 | |-- mbox01 | |-- mbox02 | |-- mbox03 | |-- ..... | `-- tesla |-- power `-- subsystem -> ../../../bus/platform This was wrongly dropped by: commit c7c158e57bce6220644f2bcd65d82e1468aa40ec Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: convert block api to kfifoOhad Ben-Cohen
The underlying buffering implementation of mailbox is converted from block API to kfifo due to the simplicity and speed of kfifo. The default size of the kfifo buffer is set to 256 bytes. This value is configurable at compile time (via CONFIG_OMAP_MBOX_KFIFO_SIZE), and can be changed at runtime (via the mbox_kfifo_size module parameter). Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Hari Kanigeri <h-kanigeri2@ti.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: remove (un)likely macros from cold pathsOhad Ben-Cohen
Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox cleanup: split MODULE_AUTHOR lineOhad Ben-Cohen
use multiple MODULE_AUTHOR lines for multiple authors Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04omap: mailbox: convert rwlocks to spinlockOhad Ben-Cohen
rwlocks are slower and have potential starvation issues therefore spinlocks are generally preferred. see also: http://lwn.net/Articles/364583/ Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Kanigeri Hari <h-kanigeri2@ti.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04Mailbox: disable mailbox interrupt when request queueFernando Guzman Lugo
when blk_get_request fails to get the request it is returning without read the message from the mailbox fifo, then when it leaves the isr and interruption is trigger again and again and the workqueue which get elements from the request queue is never executed and the kernel is stuck and shows a softlockup message. Now the mailbox interrupt is disabled when request queue is full and enabled when it pop a elememt form the request queue. Signed-off-by: Fernando Guzman Lugo <x0095840@ti.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04Mailbox: new mutext lock for h/w mailbox configurationHiroshi DOYU
mailbox startup and shutdown are being executed against a single H/W module, and a mailbox H/W module is totally __independent__ of the registration of logical mailboxes. So, an independent mutext should be used for startup and shutdown. Signed-off-by: Fernando Guzman Lugo <x0095840@ti.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04Mailbox: Check valid registered callback before callingFernando Guzman Lugo
This patch checks if the mailbox user has assinged a valid callback fuction before calling it. Signed-off-by: Fernando Guzman Lugo <x0095840@ti.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04Mailbox: flush pending deferred works before freeing blk queueFernando Guzman Lugo
flush pending deferred works before freeing blk_queue to prevent any attempt of access to blk_queue after it was freed Signed-off-by: Fernando Guzman Lugo <x0095840@ti.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2010-08-04Mailbox: free mailbox interrupt before freeing blk queueFernando Guzman Lugo
Free interrupt before freeing blk_queue to avoid any attempt of access to blk_queue after it was freed. Signed-off-by: Fernando Guzman Lugo <x0095840@ti.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-23omap2/3/4: mailbox: use dedicated work queue for handling mailbox rx interruptRob Clark
keventd_wq is a shared work-queue, and should not be used when we need fast deterministic response. Instead mailbox driver should use it's own private work-queue, with it's own thread, to ensure that handling of RX interrupts are not delayed by other drivers. The tasklet is still used for transmission of mbox messages. Signed-off-by: Rob Clark <rob@ti.com> Signed-off-by: C A Subramaniam <subramaniam.ca@ti.com> Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22omap: mailbox: OMAP4 Mailbox-driver Patch to support tasklet implementationC A Subramaniam
This patch uses a tasklet implementation for sending mailbox messages. Signed-off-by: C A Subramaniam <subramaniam.ca@ti.com> Signed-off-by: Ramesh Gupta G <grgupta@ti.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22omap: mailbox: OMAP4 Mailbox Patch to change the IRQ flag from IRQF_DISABLED ↵C A Subramaniam
to IRQF_SHARED Currently, this facilitates both the tesla and ducati sides to request for the same irq through an omap_mbox_get() call. Signed-off-by: C A Subramaniam <subramaniam.ca@ti.com> Signed-off-by: Ramesh Gupta G <grgupta@ti.com> Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22omap: mailbox: Adds code changes to support OMAP4 mailboxC A Subramaniam
This patch adds code changes in the mailbox driver module to add support for OMAP4 mailbox. Signed-off-by: Hari Kanigeri <h-kanigeri2@ti.com> Signed-off-by: C A Subramaniam <subramaniam.ca@ti.com> Signed-off-by: Ramesh Gupta G <grgupta@ti.com> Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22omap: mailbox: Expose omap_mbox_enable()/disable_irq()Hiroshi DOYU
Expose omap_mbox_enable()/disable_irq() Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2009-11-22omap: mailbox: remove unnecessary arg for omap_mbox_msg_sendC A Subramaniam
Also removed from tx_data Signed-off-by: C A Subramaniam <subramaniam.ca@ti.com> Acked-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22omap: mailbox: remove disable_/enable_mbox_irq in isrHiroshi DOYU
No need to handle it in isr, since irq won't happen during isr. Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22omap: mailbox: remove class interfaceHiroshi DOYU
It's not used at present. Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-11-22omap: mailbox: remove sequence bit checkingHiroshi DOYU
Any protocol should be handled in the upper layer and mailbox driver shouldn't care about the contents of messages. Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-10-20omap: headers: Move remaining headers from include/mach to include/platTony Lindgren
Move the remaining headers under plat-omap/include/mach to plat-omap/include/plat. Also search and replace the files using these headers to include using the right path. This was done with: #!/bin/bash mach_dir_old="arch/arm/plat-omap/include/mach" plat_dir_new="arch/arm/plat-omap/include/plat" headers=$(cd $mach_dir_old && ls *.h) omap_dirs="arch/arm/*omap*/ \ drivers/video/omap \ sound/soc/omap" other_files="drivers/leds/leds-ams-delta.c \ drivers/mfd/menelaus.c \ drivers/mfd/twl4030-core.c \ drivers/mtd/nand/ams-delta.c" for header in $headers; do old="#include <mach\/$header" new="#include <plat\/$header" for dir in $omap_dirs; do find $dir -type f -name \*.[chS] | \ xargs sed -i "s/$old/$new/" done find drivers/ -type f -name \*omap*.[chS] | \ xargs sed -i "s/$old/$new/" for file in $other_files; do sed -i "s/$old/$new/" $file done done for header in $(ls $mach_dir_old/*.h); do git mv $header $plat_dir_new/ done Signed-off-by: Tony Lindgren <tony@atomide.com>
2009-05-11block: implement and enforce request peek/start/fetchTejun Heo
Till now block layer allowed two separate modes of request execution. A request is always acquired from the request queue via elv_next_request(). After that, drivers are free to either dequeue it or process it without dequeueing. Dequeue allows elv_next_request() to return the next request so that multiple requests can be in flight. Executing requests without dequeueing has its merits mostly in allowing drivers for simpler devices which can't do sg to deal with segments only without considering request boundary. However, the benefit this brings is dubious and declining while the cost of the API ambiguity is increasing. Segment based drivers are usually for very old or limited devices and as converting to dequeueing model isn't difficult, it doesn't justify the API overhead it puts on block layer and its more modern users. Previous patches converted all block low level drivers to dequeueing model. This patch completes the API transition by... * renaming elv_next_request() to blk_peek_request() * renaming blkdev_dequeue_request() to blk_start_request() * adding blk_fetch_request() which is combination of peek and start * disallowing completion of queued (not started) requests * applying new API to all LLDs Renamings are for consistency and to break out of tree code so that it's apparent that out of tree drivers need updating. [ Impact: block request issue API cleanup, no functional change ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Mike Miller <mike.miller@hp.com> Cc: unsik Kim <donari75@gmail.com> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Laurent Vivier <Laurent@lvivier.info> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Stefan Weinhuber <wein@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: convert to dequeueing model (easy ones)Tejun Heo
plat-omap/mailbox, floppy, viocd, mspro_block, i2o_block and mmc/card/queue are already pretty close to dequeueing model and can be converted with simple changes. Convert them. While at it, * xen-blkfront: !fs check moved downwards to share dequeue call with normal path. * mspro_block: __blk_end_request(..., blk_rq_cur_byte()) converted to __blk_end_request_cur() * mmc/card/queue: loop of __blk_end_request() converted to __blk_end_request_all() [ Impact: dequeue in-flight request ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Alex Dubov <oakad@yahoo.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28arm-omap: don't abuse rq->dataTejun Heo
omap mailbox uses rq->data as the second opaque pointer to carry mbox_msg_t and rq->special message argument which is needed only for tx. Add and use omap_msg_tx_data struct for tx and use rq->special for mbox_msg_t for rx such that only rq->special is used as opaque pointer. [ Impact: cleanup rq->data usage, extra kmalloc in msg_send ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk>
2009-04-28block: implement and use [__]blk_end_request_all()Tejun Heo
There are many [__]blk_end_request() call sites which call it with full request length and expect full completion. Many of them ensure that the request actually completes by doing BUG_ON() the return value, which is awkward and error-prone. This patch adds [__]blk_end_request_all() which takes @rq and @error and fully completes the request. BUG_ON() is added to to ensure that this actually happens. Most conversions are simple but there are a few noteworthy ones. * cdrom/viocd: viocd_end_request() replaced with direct calls to __blk_end_request_all(). * s390/block/dasd: dasd_end_request() replaced with direct calls to __blk_end_request_all(). * s390/char/tape_block: tapeblock_end_request() replaced with direct calls to blk_end_request_all(). [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Mike Miller <mike.miller@hp.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-23omap mailbox: remove unnecessary header file inclusionHiroshi DOYU
2009-03-23omap mailbox: convert sequence bit checking to module paramterHiroshi DOYU
2009-03-23omap mailbox: move mailbox.h into mailbox.cHiroshi DOYU
no need to keep mailbox.h separately. Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2009-03-23omap mailbox: fix empty struct device for omap_mboxHiroshi DOYU
Since "mbox->dev" doesn't exist and isn't created either at registration, this patch will create "struct device", which belongs to "omap-mailbox" class and set this pointer for the member of "struct omap_mbox". Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-21arm: bus_id -> dev_name() and dev_set_name() conversionsKay Sievers
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21driver core: remove KOBJ_NAME_LEN defineKay Sievers
Kobjects do not have a limit in name size since a while, so stop pretending that they do. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-09ARM: OMAP: Fix Unbalanced enable for IRQ in omap mailboxHiroshi DOYU
2008-01-29Merge branch 'blk-end-request' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'blk-end-request' of git://git.kernel.dk/linux-2.6-block: (30 commits) blk_end_request: changing xsysace (take 4) blk_end_request: changing ub (take 4) blk_end_request: cleanup of request completion (take 4) blk_end_request: cleanup 'uptodate' related code (take 4) blk_end_request: remove/unexport end_that_request_* (take 4) blk_end_request: changing scsi (take 4) blk_end_request: add bidi completion interface (take 4) blk_end_request: changing ide-cd (take 4) blk_end_request: add callback feature (take 4) blk_end_request: changing ide normal caller (take 4) blk_end_request: changing cpqarray (take 4) blk_end_request: changing cciss (take 4) blk_end_request: changing ide-scsi (take 4) blk_end_request: changing s390 (take 4) blk_end_request: changing mmc (take 4) blk_end_request: changing i2o_block (take 4) blk_end_request: changing viocd (take 4) blk_end_request: changing xen-blkfront (take 4) blk_end_request: changing viodasd (take 4) blk_end_request: changing sx8 (take 4) ...
