Pull ARM soc cleanups, part 2 from Olof Johansson:
"A shorter cleanup branch submitted separately due to dependencies with
some of the previous topics.
Major thing here is that the Broadcom bcmring platform is removed.
It's an SoC that's used on some stationary VoIP platforms, and is in
desperate need of some cleanup. Broadcom came back and suggested that
we just deprecate the platform for now, since they aren't going to
spend the resources needed on cleaning it up, and there are no users
of the platform directly from mainline."
Fix some conflicts due to BCM2835 getting added next to the removed
BCMRING, and removal of tegra files that had been converted to
devicetree.
* tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: Orion5x: ts78xx: Add IOMEM for virtual addresses.
ARM: ux500: use __iomem pointers for MMIO
ARM: Remove mach-bcmring
ARM: clps711x: Remove board support for CEIVA
ARM: clps711x: Fix register definitions
ARM: clps711x: Fix lowlevel debug-macro
ARM: clps711x: Added simple clock framework
pinctrl: tegra: move pinconf-tegra.h content into drivers/pinctrl
ARM: tegra: delete unused headers
ARM: tegra: remove useless includes of <mach/*.h>
ARM: tegra: remove dead code
The current kernel does not fit in the CEIVA ROM. Also, some functional
has already been removed due migrate from 2.6 to 3.0, and it seems that
no one uses this platform. So, remove support for this board and modules
specific only to this board.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
This patch removes the ARM architecture mach-pnx4008. No direct support or user
feedback since 2006. Acknowledgements from NXP/Philips and Linux arm-soc
maintainers.
Signed-off-by: Roland Stigge <stigge@antcom.de>
The eSata SheevaPlug and QNAP TS-209 devices were removed from
mach-types due to naming mismatches between machine_is_xxx(), CONFIG_XXX
and MACH_TYPE_XXX.
This patch fixes those mismatches and adds the devices back into
mach-types.
Acked-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Jon Medhurst <tixy@yxit.co.uk>
Add entry m28evk to fix the following mxs build breakage.
CHK include/generated/compile.h
CC arch/arm/mach-mxs/clock-mx28.o
arch/arm/mach-mxs/clock-mx28.c: In function 'clk_misc_init':
arch/arm/mach-mxs/clock-mx28.c:748: error: implicit declaration of
function 'machine_is_m28evk'
make[1]: *** [arch/arm/mach-mxs/clock-mx28.o] Error 1
make: *** [arch/arm/mach-mxs] Error 2
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Add vision_ep9307, rwi_ews, usb_a9g20, karo, apf9328, tx37, tx25,
tx51, mx51_m2id, pca101, gplugd, smdk4212 and smdk4412.
I made some changes to the entry in the ARM Machine Registry after
submission which was the wrong thing to do.
This patch should help to fix this error.
Signed-off-by: Eric Bénard <eric@eukrea.com>
Machine database already updated:
http://www.arm.linux.org.uk/developer/machines/list.php?id=3284
Signed-off-by: Oleg Drokin <green@linuxhacker.ru>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
As many entries have never been submitted to mainline, there's no point
them existing in this file. So remove the entries which aren't relevant
for mainline.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
This update is required for Tavor and SAAR
Update mach-types. Remove invalid or incorrect entries.
Usual mach-types update.
