path: root/arch/arm/tools
2010-02-20ARM: Update mach-typesRussell King
2010-01-28[ARM] Update mach-typesRussell King
2009-12-17Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: PCMCIA: fix pxa2xx_lubbock modular build error [ARM] Update mach-types [ARM] pxa: fix no reference of cpu_is_pxa25x() in devices.c [ARM] pxa/cm-x300: add PWM backlight support revert "[ARM] pxa/cm-x300: add PWM backlight support" ARM: use flush_kernel_dcache_area() for dmabounce ARM: add size argument to __cpuc_flush_dcache_page ARM: 5848/1: kill flush_ioremap_region() ARM: cache-l2x0: make better use of background cache handling ARM: cache-l2x0: avoid taking spinlock for every iteration [ARM] Kirkwood: Add LaCie Network Space v2 support ARM: dove: fix the mm mmu flags of the pj4 procinfo
2009-12-16[ARM] Update mach-typesRussell King
2009-12-12arm: move mach-types to include/generatedSam Ravnborg
Simplified arch/arm/Makefile by dropping the maketools target It was undocumented and not needed Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-11-25[ARM] Update mach-typesRussell King
2009-09-18[ARM] Update mach-typesRussell King
2009-09-12[ARM] Update mach-typesRussell King
2009-08-01[ARM] Update mach-typesRussell King
2009-07-09[ARM] Update mach-typesRussell King
2009-06-20[ARM] Update mach-typesRussell King
2009-05-29[ARM] update mach-typesRussell King
2009-03-23[ARM] update mach-typesNicolas Pitre
Signed-off-by: Nicolas Pitre <nico@marvell.com>
2009-03-12[ARM] update mach-typesRussell King
2008-11-30[ARM] Update mach-typesRussell King
2008-09-25[ARM] Update mach-typesRussell King
2008-08-16[ARM] update mach-typesRussell King
2008-08-07[ARM] Add support for arch/arm/mach-*/include and arch/arm/plat-*/includeRussell King
2008-07-13[ARM] Update mach-typesRussell King
This update is required for Tavor and SAAR Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-07[ARM] mach-types updateRussell King
Update mach-types. Remove invalid or incorrect entries. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-19[ARM] Update mach-typesRussell King
2008-01-26[ARM] Update mach-typesRussell King
2007-05-11[ARM] Update mach-typesRussell King
2007-04-16[ARM] Update mach-typesRussell King
2007-01-24[ARM] Update mach-typesRussell King
2006-12-07[ARM] Update mach-typesRussell King
2006-10-16[ARM] Update mach-typesRussell King
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-25[ARM] Update mach-typesRussell King
2006-06-26[ARM] Update mach-typesRussell King
Usual mach-types update. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-08[ARM] Update mach-typesRussell King
2006-02-22[ARM] Update mach-typesRussell King
2006-01-09[ARM] Update mach-typesRussell King
2005-11-25[ARM] Update mach-typesRussell King
2005-11-11[ARM] Update mach-typesRussell King
2005-10-10[ARM] Update mach-typesRussell King
2005-06-27[PATCH] ARM: Update mach-typesRussell King
