path: root/arch/arm/vfp
2012-10-29ARM: 7566/1: vfp: fix save and restore when running on pre-VFPv3 and ↵Paul Walmsley
CONFIG_VFPv3 set After commit 846a136881b8f73c1f74250bf6acfaa309cab1f2 ("ARM: vfp: fix saving d16-d31 vfp registers on v6+ kernels"), the OMAP 2430SDP board started crashing during boot with omap2plus_defconfig: [ 3.875122] mmcblk0: mmc0:e624 SD04G 3.69 GiB [ 3.915954] mmcblk0: p1 [ 4.086639] Internal error: Oops - undefined instruction: 0 [#1] SMP ARM [ 4.093719] Modules linked in: [ 4.096954] CPU: 0 Not tainted (3.6.0-02232-g759e00b #570) [ 4.103149] PC is at vfp_reload_hw+0x1c/0x44 [ 4.107666] LR is at __und_usr_fault_32+0x0/0x8 It turns out that the context save/restore fix unmasked a latent bug in commit 5aaf254409f8d58229107b59507a8235b715a960 ("ARM: 6203/1: Make VFPv3 usable on ARMv6"). When CONFIG_VFPv3 is set, but the kernel is booted on a pre-VFPv3 core, the code attempts to save and restore the d16-d31 VFP registers. These are only present on non-D16 VFPv3+, so this results in an undefined instruction exception. The code didn't crash before commit 846a136 because the save and restore code was only touching d0-d15, present on all VFP. Fix by implementing a request from Russell King to add a new HWCAP flag that affirmatively indicates the presence of the d16-d31 registers: http://marc.info/?l=linux-arm-kernel&m=135013547905283&w=2 and some feedback from Måns to clarify the name of the HWCAP flag. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Dave Martin <dave.martin@linaro.org> Cc: Måns Rullgård <mans.rullgard@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-08-11ARM: 7483/1: vfp: only advertise VFPv4 in hwcaps if CONFIG_VFPv3 is enabledWill Deacon
VFPv4 support depends on the VFPv3 context save/restore code, so only advertise support in the hwcaps if the kernel can actually handle it. Cc: <stable@vger.kernel.org> # 3.1+ Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-08-01Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "This fixes various issues found during July" * 'fixes' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7479/1: mm: avoid NULL dereference when flushing gate_vma with VIVT caches ARM: Fix undefined instruction exception handling ARM: 7480/1: only call smp_send_stop() on SMP ARM: 7478/1: errata: extend workaround for erratum #720789 ARM: 7477/1: vfp: Always save VFP state in vfp_pm_suspend on UP ARM: 7476/1: vfp: only clear vfp state for current cpu in vfp_pm_suspend ARM: 7468/1: ftrace: Trace function entry before updating index ARM: 7467/1: mutex: use generic xchg-based implementation for ARMv6+ ARM: 7466/1: disable interrupt before spinning endlessly ARM: 7465/1: Handle >4GB memory sizes in device tree and mem=size@start option
2012-07-31ARM: Fix undefined instruction exception handlingRussell King
While trying to get a v3.5 kernel booted on the cubox, I noticed that VFP does not work correctly with VFP bounce handling. This is because of the confusion over 16-bit vs 32-bit instructions, and where PC is supposed to point to. The rule is that FP handlers are entered with regs->ARM_pc pointing at the _next_ instruction to be executed. However, if the exception is not handled, regs->ARM_pc points at the faulting instruction. This is easy for ARM mode, because we know that the next instruction and previous instructions are separated by four bytes. This is not true of Thumb2 though. Since all FP instructions are 32-bit in Thumb2, it makes things easy. We just need to select the appropriate adjustment. Do this by moving the adjustment out of do_undefinstr() into the assembly code, as only the assembly code knows whether it's dealing with a 32-bit or 16-bit instruction. Cc: <stable@vger.kernel.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-07-31ARM: 7477/1: vfp: Always save VFP state in vfp_pm_suspend on UPColin Cross
vfp_pm_suspend should save the VFP state in suspend after any lazy context switch. If it only saves when the VFP is enabled, the state can get lost when, on a UP system: Thread 1 uses the VFP Context switch occurs to thread 2, VFP is disabled but the VFP context is not saved Thread 2 initiates suspend vfp_pm_suspend is called with the VFP disabled, and the unsaved VFP context of Thread 1 in the registers Modify vfp_pm_suspend to save the VFP context whenever vfp_current_hw_state is not NULL. Includes a fix from Ido Yariv <ido@wizery.com>, who pointed out that on SMP systems, the state pointer can be pointing to a freed task struct if a task exited on another cpu, fixed by using #ifndef CONFIG_SMP in the new if clause. Cc: Barry Song <bs14@csr.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Ido Yariv <ido@wizery.com> Cc: Daniel Drake <dsd@laptop.org> Cc: Will Deacon <will.deacon@arm.com> Cc: stable@vger.kernel.org Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-07-31ARM: 7476/1: vfp: only clear vfp state for current cpu in vfp_pm_suspendColin Cross
vfp_pm_suspend runs on each cpu, only clear the hardware state pointer for the current cpu. Prevents a possible crash if one cpu clears the hw state pointer when another cpu has already checked if it is valid. Cc: stable@vger.kernel.org Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-07-30arch: remove direct definitions of KERN_<LEVEL> usesJoe Perches
Add #include <linux/kern_levels.h> so that the #define KERN_<LEVEL> macros don't have to be duplicated. Signed-off-by: Joe Perches <joe@perches.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Kay Sievers <kay@vrfy.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-21Merge branch 'misc' into for-linusRussell King
Conflicts: arch/arm/kernel/ptrace.c
2012-05-17ARM: 7419/1: vfp: fix VFP flushing regression on sigreturn pathWill Deacon
Commit ff9a184c ("ARM: 7400/1: vfp: clear fpscr length and stride bits on entry to sig handler") flushes the VFP state prior to entering a signal handler so that a VFP operation inside the handler will trap and force a restore of ABI-compliant registers. Reflushing and disabling VFP on the sigreturn path is predicated on the saved thread state indicating that VFP was used by the handler -- however for SMP platforms this is only set on context-switch, making the check unreliable and causing VFP register corruption in userspace since the register values are not necessarily those restored from the sigframe. This patch unconditionally flushes the VFP state after a signal handler. Since we already perform the flush before the handler and the flushing itself happens lazily, the redundant flush when VFP is not used by the handler is essentially a nop. Reported-by: Jon Medhurst <tixy@linaro.org> Signed-off-by: Jon Medhurst <tixy@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-05-12ARM: 7417/1: vfp: ensure preemption is disabled when enabling VFP accessWill Deacon
The vfp_enable function enables access to the VFP co-processor register space (cp10 and cp11) on the current CPU and must be called with preemption disabled. Unfortunately, the vfp_init late initcall does not disable preemption and can lead to an oops during boot if thread migration occurs at the wrong time and we end up attempting to access the FPSID on a CPU with VFP access disabled. This patch fixes the initcall to call vfp_enable from a non-preemptible context on each CPU and adds a BUG_ON(preemptible) to ensure that any similar problems are easily spotted in the future. Cc: stable@vger.kernel.org Reported-by: Hyungwoo Yang <hwoo.yang@gmail.com> Signed-off-by: Hyungwoo Yang <hyungwooy@nvidia.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-05-11ARM: 7415/1: vfp: convert printk's to pr_*'sNicolas Pitre
This is mainly to get rid of the "vfp_pm_suspend: saving vfp state" message flooding the kernel message ring by default. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-04-23ARM: 7400/1: vfp: clear fpscr length and stride bits on entry to sig handlerWill Deacon
The ARM PCS mandates that the length and stride bits of the fpscr are cleared on entry to and return from a public interface. Although signal handlers run asynchronously with respect to the interrupted function, the handler itself expects to run as though it has been called like a normal function. This patch updates the state mirroring the VFP hardware before entry to a signal handler so that it adheres to the PCS. Furthermore, we disable VFP to ensure that we trap on any floating point operation performed by the signal handler and synchronise the hardware appropriately. A check is inserted after the signal handler to avoid redundant flushing if VFP was not used. Reported-by: Peter Maydell <peter.maydell@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-04-23ARM: 7399/1: vfp: move user vfp state save/restore code out of signal.cWill Deacon
The user VFP state must be preserved (subject to ucontext modifications) across invocation of a signal handler and this is currently handled by vfp_{preserve,restore}_context in signal.c Since this code requires intimate low-level knowledge of the VFP state, this patch moves it into vfpmodule.c. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-28Disintegrate asm/system.h for ARMDavid Howells
Disintegrate asm/system.h for ARM. Signed-off-by: David Howells <dhowells@redhat.com> cc: Russell King <linux@arm.linux.org.uk> cc: linux-arm-kernel@lists.infradead.org
2012-03-28ARM: move CP15 definitions to separate header fileRussell King
Avoid namespace conflicts with drivers over the CP15 definitions by moving CP15 related prototypes and definitions to a private header file. Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> [Tegra] Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> [EP93xx] Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com>
2011-10-31arm: remove several unnecessary module.h include instancesPaul Gortmaker
Building these files does not reveal a hidden need for any of these. Since module.h brings in the whole kitchen sink, it just needlessly adds 30k+ lines to the cpp burden. There are probably lots more, but ARM files of mach-* and plat-* don't get coverage via a simple yesconfig build. They will have to be cleaned up and tested via using their respective configs. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-28Merge branch 'devel-stable' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits) ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET ARM: gic, local timers: use the request_percpu_irq() interface ARM: gic: consolidate PPI handling ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H ARM: mach-s5p64x0: remove mach/memory.h ARM: mach-s3c64xx: remove mach/memory.h ARM: plat-mxc: remove mach/memory.h ARM: mach-prima2: remove mach/memory.h ARM: mach-zynq: remove mach/memory.h ARM: mach-bcmring: remove mach/memory.h ARM: mach-davinci: remove mach/memory.h ARM: mach-pxa: remove mach/memory.h ARM: mach-ixp4xx: remove mach/memory.h ARM: mach-h720x: remove mach/memory.h ARM: mach-vt8500: remove mach/memory.h ARM: mach-s5pc100: remove mach/memory.h ARM: mach-tegra: remove mach/memory.h ARM: plat-tcc: remove mach/memory.h ARM: mach-mmp: remove mach/memory.h ARM: mach-cns3xxx: remove mach/memory.h ... Fix up mostly pretty trivial conflicts in: - arch/arm/Kconfig - arch/arm/include/asm/localtimer.h - arch/arm/kernel/Makefile - arch/arm/mach-shmobile/board-ap4evb.c - arch/arm/mach-u300/core.c - arch/arm/mm/dma-mapping.c - arch/arm/mm/proc-v7.S - arch/arm/plat-omap/Kconfig largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP -> CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
2011-10-01ARM: vfp: use -mfloat-abi=soft to build vfpArnd Bergmann
Distros are starting to ship with toolchains defaulting to hardfloat. Using such a compiler to build the kernel fails in the VFP directory with arch/arm/vfp/entry.S:1:0: sorry, unimplemented: -mfloat-abi=hard and VFP Adding -mfloat-abi=soft to the gcc command line fixes this. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-09-23ARM: vfp: Fix the comment to make it consistent with the code.Santosh Shilimkar
Function vfp_force_reload() clears vfp_current_hw_state, so update the comment accordingly. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2011-09-23ARM: vfp: Use cpu pm notifiers to save vfp stateColin Cross
When the cpu is powered down in a low power mode, the vfp registers may be reset. This patch uses CPU_PM_ENTER and CPU_PM_EXIT notifiers to save and restore the cpu's vfp registers. Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Tested-and-Acked-by: Shawn Guo <shawn.guo@linaro.org> Tested-by: Vishwanath BS <vishwanath.bs@ti.com>
2011-07-22Merge branch 'devel-stable' into for-nextRussell King
Conflicts: arch/arm/kernel/entry-armv.S
2011-07-09ARM: vfp: ensure that thread flushing works if preemptedRussell King
Prevent a preemption event causing the initialized VFP state being overwritten by ensuring that the VFP hardware access is disabled prior to starting initialization. We can then do this in safety while still allowing preemption to occur. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-09ARM: vfp: fix a hole in VFP thread migrationRussell King
Fix a hole in the VFP thread migration. Lets define two threads. Thread 1, we'll call 'interesting_thread' which is a thread which is running on CPU0, using VFP (so vfp_current_hw_state[0] = &interesting_thread->vfpstate) and gets migrated off to CPU1, where it continues execution of VFP instructions. Thread 2, we'll call 'new_cpu0_thread' which is the thread which takes over on CPU0. This has also been using VFP, and last used VFP on CPU0, but doesn't use it again. The following code will be executed twice: cpu = thread->cpu; /* * On SMP, if VFP is enabled, save the old state in * case the thread migrates to a different CPU. The * restoring is done lazily. */ if ((fpexc & FPEXC_EN) && vfp_current_hw_state[cpu]) { vfp_save_state(vfp_current_hw_state[cpu], fpexc); vfp_current_hw_state[cpu]->hard.cpu = cpu; } /* * Thread migration, just force the reloading of the * state on the new CPU in case the VFP registers * contain stale data. */ if (thread->vfpstate.hard.cpu != cpu) vfp_current_hw_state[cpu] = NULL; The first execution will be on CPU0 to switch away from 'interesting_thread'. interesting_thread->cpu will be 0. So, vfp_current_hw_state[0] points at interesting_thread->vfpstate. The hardware state will be saved, along with the CPU number (0) that it was executing on. 'thread' will be 'new_cpu0_thread' with new_cpu0_thread->cpu = 0. Also, because it was executing on CPU0, new_cpu0_thread->vfpstate.hard.cpu = 0, and so the thread migration check is not triggered. This means that vfp_current_hw_state[0] remains pointing at interesting_thread. The second execution will be on CPU1 to switch _to_ 'interesting_thread'. So, 'thread' will be 'interesting_thread' and interesting_thread->cpu now will be 1. The previous thread executing on CPU1 is not relevant to this so we shall ignore that. We get to the thread migration check. Here, we discover that interesting_thread->vfpstate.hard.cpu = 0, yet interesting_thread->cpu is now 1, indicating thread migration. We set vfp_current_hw_state[1] to NULL. So, at this point vfp_current_hw_state[] contains the following: [0] = &interesting_thread->vfpstate [1] = NULL Our interesting thread now executes a VFP instruction, takes a fault which loads the state into the VFP hardware. Now, through the assembly we now have: [0] = &interesting_thread->vfpstate [1] = &interesting_thread->vfpstate CPU1 stops due to ptrace (and so saves its VFP state) using the thread switch code above), and CPU0 calls vfp_sync_hwstate(). if (vfp_current_hw_state[cpu] == &thread->vfpstate) { vfp_save_state(&thread->vfpstate, fpexc | FPEXC_EN); BANG, we corrupt interesting_thread's VFP state by overwriting the more up-to-date state saved by CPU1 with the old VFP state from CPU0. Fix this by ensuring that we have sane semantics for the various state describing variables: 1. vfp_current_hw_state[] points to the current owner of the context information stored in each CPUs hardware, or NULL if that state information is invalid. 2. thread->vfpstate.hard.cpu always contains the most recent CPU number which the state was loaded into or NR_CPUS if no CPU owns the state. So, for a particular CPU to be a valid owner of the VFP state for a particular thread t, two things must be true: vfp_current_hw_state[cpu] == &t->vfpstate && t->vfpstate.hard.cpu == cpu. and that is valid from the moment a CPU loads the saved VFP context into the hardware. This gives clear and consistent semantics to interpreting these variables. This patch also fixes thread copying, ensuring that t->vfpstate.hard.cpu is invalidated, otherwise CPU0 may believe it was the last owner. The hole can happen thus: - thread1 runs on CPU2 using VFP, migrates to CPU3, exits and thread_info freed. - New thread allocated from a previously running thread on CPU2, reusing memory for thread1 and copying vfp.hard.cpu. At this point, the following are true: new_thread1->vfpstate.hard.cpu == 2 &new_thread1->vfpstate == vfp_current_hw_state[2] Lastly, this also addresses thread flushing in a similar way to thread copying. Hole is: - thread runs on CPU0, using VFP, migrates to CPU1 but does not use VFP. - thread calls execve(), so thread flush happens, leaving vfp_current_hw_state[0] intact. This vfpstate is memset to 0 causing thread->vfpstate.hard.cpu = 0. - thread migrates back to CPU0 before using VFP. At this point, the following are true: thread->vfpstate.hard.cpu == 0 &thread->vfpstate == vfp_current_hw_state[0] Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-09ARM: vfp: rename check_exception to vfp_hw_state_validRussell King
Rename this branch to more accurately reflect why its taken, rather than what the following code does. It is the only caller of this code. This helps to clarify following changes, yet this change results in no actual code change. Document the VFP hardware state at the target of this branch. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-09ARM: vfp: rename last_VFP_context to vfp_current_hw_stateRussell King
Rename the slightly confusing 'last_VFP_context' variable to be more descriptive of what it actually is. This variable stores a pointer to the current owner's vfpstate structure for the context held in the VFP hardware. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-07ARM: vfp: add VFPv4 capability detection and populate elf_hwcapWill Deacon
The presence of VFPv4 cannot be detected simply by looking at the FPSID subarchitecture field, as a value >= 2 signifies the architecture as VFPv3 or later. This patch reads from MVFR1 to check whether or not the fused multiply accumulate instructions are supported. Since these are introduced with VFPv4, this tells us what we need to know. Signed-off-by: Will Deacon <will.deacon@arm.com>
2011-04-24ARM: Use struct syscore_ops instead of sysdevs for PM in common codeRafael J. Wysocki
Convert some ARM architecture's common code to using struct syscore_ops objects for power management instead of sysdev classes and sysdevs. This simplifies the code and reduces the kernel's memory footprint. It also is necessary for removing sysdevs from the kernel entirely in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-10ARM: 6868/1: Preserve the VFP state during forkCatalin Marinas
VFP registers d16-d31 are callee saved registers and must be preserved during function calls, including fork(). The VFP configuration should also be preserved. The patch copies the full VFP state to the child process. Reported-by: Paul Wright <paul.wright@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-04-10ARM: 6867/1: Introduce THREAD_NOTIFY_COPY for copy_thread() hooksCatalin Marinas
This patch adds THREAD_NOTIFY_COPY for calling registered handlers during the copy_thread() function call. It also changes the VFP handler to use a switch statement rather than if..else and ignore this event. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-17arm: change to new flag variablesmatt mooney
Replace EXTRA_CFLAGS with ccflags-y and EXTRA_AFLAGS with asflags-y. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-02-23ARM: vfp: improve commentry for hotplug eventsRussell King
Improve the documentation for the VFP hotplug notifier handler, so that people better understand what's going on there and what has been done for them. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-23ARM: fix some sparse errors in generic ARM codeRussell King
arch/arm/kernel/return_address.c:37:6: warning: symbol 'return_address' was not declared. Should it be static? arch/arm/kernel/setup.c:76:14: warning: symbol 'processor_id' was not declared. Should it be static? arch/arm/kernel/traps.c:259:1: warning: symbol 'die_lock' was not declared. Should it be static? arch/arm/vfp/vfpmodule.c:156:6: warning: symbol 'vfp_raise_sigfpe' was not declared. Should it be static? Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-06Merge branch 'misc' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/common/Makefile arch/arm/kernel/Makefile arch/arm/kernel/smp.c
2010-12-20ARM: VFP: re-initialize VFP coprocessor access enables on CPU hotplugRussell King
We can not guarantee that VFP will be enabled when CPU hotplug brings a CPU back online from a reset state. Add a hotplug CPU notifier to ensure that the VFP coprocessor access is enabled whenever a CPU comes back online. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-30ARM: 6498/1: vfp: Correct data alignment for CONFIG_THUMB2_KERNELDave Martin
Directives such as .long and .word do not magically cause the assembler location counter to become aligned in gas. As a result, using these directives in code sections can result in misaligned data words when building a Thumb-2 kernel (CONFIG_THUMB2_KERNEL). This is a Bad Thing, since the ABI permits the compiler to assume that fundamental types of word size or above are word- aligned when accessing them from C. If the data is not really word-aligned, this can cause impaired performance and stray alignment faults in some circumstances. In general, the following rules should be applied when using data word declaration directives inside code sections: * .quad and .double: .align 3 * .long, .word, .single, .float: .align (or .align 2) * .short: No explicit alignment required, since Thumb-2 instructions are always 2 or 4 bytes in size. immediately after an instruction. Reviewed-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Dave Martin <dave.martin@linaro.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-09ARM: 6203/1: Make VFPv3 usable on ARMv6Tony Lindgren
MVFR0 and MVFR1 are only available starting with ARM1136 r1p0 release according to "B.5 VFP changes" in DDI0211F_arm1136_r1p0_trm.pdf. This is also when TLS register got added, so we can use HAS_TLS also to test for MVFR0 and MVFR1. Otherwise VFPFMRX and VFPFMXR access fails and we get: Internal error: Oops - undefined instruction: 0 [#1] PC is at no_old_VFP_process+0x8/0x3c LR is at __und_svc+0x48/0x80 ... Signed-off-by: Tony Lindgren <tony@atomide.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-27ARM: VFP: Fix vfp_put_double() for d16-d31Russell King
vfp_put_double() takes the double value in r0,r1 not r1,r2. Reported-by: Tarun Kanti DebBarma <tarun.kanti@ti.com> Cc: <stable@kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-14ARM: 6050/1: VFP: fix the SMP versions of vfp_{sync,flush}_hwstateImre Deak
From: Imre Deak <imre.deak@nokia.com> Recently the UP versions of these functions were refactored and as a side effect it became possible to call them for the current thread. This isn't true for the SMP versions however, so fix this up. Signed-off-by: Imre Deak <imre.deak@nokia.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-28ARM: 5997/1: ARM: Correct the VFPv3 detectionCatalin Marinas
A CPU has VFPv3 hardware if the FPSID[19:16] bits are 2 or more. Currently Linux was only checking for 3 or more. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-01Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits) ARM: Eliminate decompressor -Dstatic= PIC hack ARM: 5958/1: ARM: U300: fix inverted clk round rate ARM: 5956/1: misplaced parentheses ARM: 5955/1: ep93xx: move timer defines into core.c and document ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c ARM: 5953/1: ep93xx: fix broken build of clock.c ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig ARM: 5949/1: NUC900 add gpio virtual memory map ARM: 5948/1: Enable timer0 to time4 clock support for nuc910 ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk ARM: make_coherent(): fix problems with highpte, part 2 MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself ARM: 5945/1: ep93xx: include correct irq.h in core.c ARM: 5933/1: amba-pl011: support hardware flow control ARM: 5930/1: Add PKMAP area description to memory.txt. ARM: 5929/1: Add checks to detect overlap of memory regions. ARM: 5928/1: Change type of VMALLOC_END to unsigned long. ARM: 5927/1: Make delimiters of DMA area globally visibly. ARM: 5926/1: Add "Virtual kernel memory..." printout. ARM: 5920/1: OMAP4: Enable L2 Cache ... Fix up trivial conflict in arch/arm/mach-mx25/clock.c
2010-02-15ARM: vfp ptrace: no point flushing hw context for PTRACE_GETVFPREGSRussell King
If we're only reading the VFP context via the ptrace call, there's no need to invalidate the hardware context - we only need to do that on PTRACE_SETVFPREGS. This allows more efficient monitoring of a traced task. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-15ARM: vfp: fix vfp_sync_state()Russell King
The more I look at vfp_sync_state(), the more I believe it's trying to do its job in a really obscure way. Essentially, last_VFP_context[] tracks who owns the state in the VFP hardware. If last_VFP_context[] is the context for the thread which we're interested in, then the VFP hardware has context which is not saved in the software state - so we need to bring the software state up to date. If last_VFP_context[] is for some other thread, we really don't care what state the VFP hardware is in; it doesn't contain any information pertinent to the thread we're trying to deal with - so don't touch the hardware. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-01ARM: 5909/1: ARM: Correct the FPSCR bits setting when raising exceptionsCatalin Marinas
Commit c98929c07a removed the clearing of the FPSCR[31:28] bits from the vfp_raise_exceptions() function and the new bits are or'ed with the old FPSCR bits leading to unexpected results (the original commit was referring to the cumulative bits - FPSCR[4:0]). Reported-by: Tom Hameenanttila <tmhameen@marvell.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-18ARM: Convert VFP/Crunch/XscaleCP thread_release() to exit_thread()Russell King
This avoids races in the VFP code where the dead thread may have state on another CPU. By moving this code to exit_thread(), we will be running as the thread, and therefore be running on the current CPU. This means that we can ensure that the only local state is accessed in the thread notifiers. Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-13ARM: VFP: fix vfp thread init bug and document vfp notifier entry conditionsRussell King
When the VFP notifier is called for flush_thread(), we may be preemptible, meaning we might migrate to another CPU, which means referencing the current CPU number without some form of locking is invalid, and can cause data corruption. For the most cases, this isn't a problem since atomic notifiers are run under rcu lock, which for most configurations results in preemption being disabled - except when the preemptable tree-based rcu implementation is selected. Let's make it safe anyway. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-24Thumb-2: Implement the unified VFP supportCatalin Marinas
This patch modifies the VFP files for the ARM/Thumb-2 unified assembly syntax. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-07-24Thumb-2: Add some .align statements to the .S filesCatalin Marinas
Since the Thumb-2 instructions can be 16-bit wide, data in the .text sections may not be aligned to a 32-bit word and this leads to unaligned exceptions. This patch does not affect the ARM code generation. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2009-05-30Fix the VFP handling on the Feroceon CPUCatalin Marinas
This CPU generates synchronous VFP exceptions in a non-standard way - the FPEXC.EX bit set but without the FPSCR.IXE bit being set like in the VFP subarchitecture 1 or just the FPEXC.DEX bit like in VFP subarchitecture 2. The main problem is that the faulty instruction (which needs to be emulated in software) will be restarted several times (normally until a context switch disables the VFP). This patch ensures that the VFP exception is treated as synchronous. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Nicolas Pitre <nico@cam.org>
2009-04-01[ARM] 5440/1: Fix VFP state corruption due to preemption during VFP exceptionsGeorge G. Davis
We've observed that ARM VFP state can be corrupted during VFP exception handling when PREEMPT is enabled. The exact conditions are difficult to reproduce but appear to occur during VFP exception handling when a task causes a VFP exception which is handled via VFP_bounce and is then preempted by yet another task which in turn causes yet another VFP exception. Since the VFP_bounce code is not preempt safe, VFP state then becomes corrupt. In order to prevent preemption from occuring while handling a VFP exception, this patch disables preemption while handling VFP exceptions. Signed-off-by: George G. Davis <gdavis@mvista.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
