This is the 5.4.47 stable release
All conflicts resolved in favour of HEAD, i.e. 5.4-2.1.x-imx
arch/arm/boot/dts/imx6qdl.dtsi
arch/arm/mach-imx/Kconfig
arch/arm/mach-imx/common.h
arch/arm/mach-imx/suspend-imx6.S
arch/arm64/boot/dts/freescale/imx8qxp-mek.dts
arch/powerpc/include/asm/cacheflush.h
drivers/cpufreq/imx6q-cpufreq.c
drivers/dma/imx-sdma.c
drivers/edac/synopsys_edac.c
drivers/firmware/imx/imx-scu.c
drivers/net/ethernet/freescale/fec.h
drivers/net/ethernet/freescale/fec_main.c
drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
drivers/net/phy/phy_device.c
drivers/perf/fsl_imx8_ddr_perf.c
drivers/usb/cdns3/gadget.c
drivers/usb/dwc3/gadget.c
include/uapi/linux/dma-buf.h
[ Upstream commit 05460849c3b51180d5ada3373d0449aea19075e4 ]
Cores affected by Neoverse-N1 #1542419 could execute a stale instruction
when a branch is updated to point to freshly generated instructions.
To workaround this issue we need user-space to issue unnecessary
icache maintenance that we can trap. Start by hiding CTR_EL0.DIC.
Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Signed-off-by: James Morse <james.morse@arm.com>
Merge Linux stable release v5.4.24 into imx_5.4.y
* tag 'v5.4.24': (3306 commits)
Linux 5.4.24
blktrace: Protect q->blk_trace with RCU
kvm: nVMX: VMWRITE checks unsupported field before read-only field
Signed-off-by: Jason Liu <jason.hui.liu@nxp.com>
arch/arm/boot/dts/imx6sll-evk.dts
arch/arm/boot/dts/imx7ulp.dtsi
arch/arm64/boot/dts/freescale/fsl-ls1028a.dtsi
drivers/clk/imx/clk-composite-8m.c
drivers/gpio/gpio-mxc.c
drivers/irqchip/Kconfig
drivers/mmc/host/sdhci-of-esdhc.c
drivers/mtd/nand/raw/gpmi-nand/gpmi-nand.c
drivers/net/can/flexcan.c
drivers/net/ethernet/freescale/dpaa/dpaa_eth.c
drivers/net/ethernet/mscc/ocelot.c
drivers/net/ethernet/stmicro/stmmac/stmmac_main.c
drivers/net/phy/realtek.c
drivers/pci/controller/mobiveil/pcie-mobiveil-host.c
drivers/tee/optee/shm_pool.c
kernel/sched/cpufreq.c
net/core/xdp.c
sound/soc/fsl/fsl_esai.c
sound/soc/fsl/fsl_sai.c
sound/soc/sof/core.c
sound/soc/sof/imx/Kconfig
sound/soc/sof/loader.c
commit a4376f2fbcc8084832f2f114577c8d68234c7903 upstream.
This is required for clone3 which passes the TLS value through a
struct rather than a register.
Signed-off-by: Amanieu d'Antras <amanieu@gmail.com>
Cc: <stable@vger.kernel.org> # 5.3.x
Acked-by: Will Deacon <will@kernel.org>
Link: https://lore.kernel.org/r/20200102172413.654385-3-amanieu@gmail.com
Signed-off-by: Christian Brauner <christian.brauner@ubuntu.com>
Older imx releases increased this based on SOC_IMX8 but that symbol is
gone and the expectation is that SOC-selection symbols like "ARCH_MXC"
will almost always be defined and shouldn't be used to make incompatible
config decisions.
Make the value of FORCE_MAX_ZONEORDER configurable so this can be
adjusted in a .config file.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
Reviewed-by: Li Yang <Leoyang.li@nxp.com>
Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com>
Workaround for Cavium/Marvell ThunderX2 erratum #219.
* errata/tx2-219:
arm64: Allow CAVIUM_TX2_ERRATUM_219 to be selected
arm64: Avoid Cavium TX2 erratum 219 when switching TTBR
arm64: Enable workaround for Cavium TX2 erratum 219 when running SMT
arm64: KVM: Trap VM ops when ARM64_WORKAROUND_CAVIUM_TX2_219_TVM is set
Allow the user to select the workaround for TX2-219, and update
the silicon-errata.rst file to reflect this.
Signed-off-by: Will Deacon <will@kernel.org>
CONFIG_COMPAT_VDSO is defined by passing '-DCONFIG_COMPAT_VDSO' to the
compiler when the generic compat vDSO code is in use. It's much cleaner
and simpler to expose this as a proper Kconfig option (like x86 does),
so do that and remove the bodge.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
The .config file and the generated include/config/auto.conf can
end up out of sync after a set of commands since
CONFIG_CROSS_COMPILE_COMPAT_VDSO is not updated correctly.
The sequence can be reproduced as follows:
$ make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- defconfig
$ make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- menuconfig
[set CONFIG_CROSS_COMPILE_COMPAT_VDSO="arm-linux-gnueabihf-"]
Which results in:
arch/arm64/Makefile:62: CROSS_COMPILE_COMPAT not defined or empty,
the compat vDSO will not be built
even though the compat vDSO has been built:
$ file arch/arm64/kernel/vdso32/vdso.so
arch/arm64/kernel/vdso32/vdso.so: ELF 32-bit LSB pie executable, ARM,
EABI5 version 1 (SYSV), dynamically linked,
BuildID[sha1]=c67f6c786f2d2d6f86c71f708595594aa25247f6, stripped
A similar case that involves changing the configuration parameter
multiple times can be reconducted to the same family of problems.
Remove the use of CONFIG_CROSS_COMPILE_COMPAT_VDSO altogether and
instead rely on the cross-compiler prefix coming from the environment
via CROSS_COMPILE_COMPAT, much like we do for the rest of the kernel.
Cc: Will Deacon <will@kernel.org>
Reported-by: Will Deacon <will@kernel.org>
Signed-off-by: Vincenzo Frascino <vincenzo.frascino@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull kernel lockdown mode from James Morris:
"This is the latest iteration of the kernel lockdown patchset, from
Matthew Garrett, David Howells and others.
From the original description:
This patchset introduces an optional kernel lockdown feature,
intended to strengthen the boundary between UID 0 and the kernel.
When enabled, various pieces of kernel functionality are restricted.
Applications that rely on low-level access to either hardware or the
kernel may cease working as a result - therefore this should not be
enabled without appropriate evaluation beforehand.
The majority of mainstream distributions have been carrying variants
of this patchset for many years now, so there's value in providing a
doesn't meet every distribution requirement, but gets us much closer
to not requiring external patches.
There are two major changes since this was last proposed for mainline:
- Separating lockdown from EFI secure boot. Background discussion is
covered here: https://lwn.net/Articles/751061/
- Implementation as an LSM, with a default stackable lockdown LSM
module. This allows the lockdown feature to be policy-driven,
rather than encoding an implicit policy within the mechanism.
The new locked_down LSM hook is provided to allow LSMs to make a
policy decision around whether kernel functionality that would allow
tampering with or examining the runtime state of the kernel should be
permitted.
The included lockdown LSM provides an implementation with a simple
policy intended for general purpose use. This policy provides a coarse
level of granularity, controllable via the kernel command line:
lockdown={integrity|confidentiality}
Enable the kernel lockdown feature. If set to integrity, kernel features
that allow userland to modify the running kernel are disabled. If set to
confidentiality, kernel features that allow userland to extract
confidential information from the kernel are also disabled.
This may also be controlled via /sys/kernel/security/lockdown and
overriden by kernel configuration.
New or existing LSMs may implement finer-grained controls of the
lockdown features. Refer to the lockdown_reason documentation in
include/linux/security.h for details.
The lockdown feature has had signficant design feedback and review
across many subsystems. This code has been in linux-next for some
weeks, with a few fixes applied along the way.
Stephen Rothwell noted that commit 9d1f8be5cf42 ("bpf: Restrict bpf
when kernel lockdown is in confidentiality mode") is missing a
Signed-off-by from its author. Matthew responded that he is providing
this under category (c) of the DCO"
* 'next-lockdown' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (31 commits)
kexec: Fix file verification on S390
security: constify some arrays in lockdown LSM
lockdown: Print current->comm in restriction messages
efi: Restrict efivar_ssdt_load when the kernel is locked down
tracefs: Restrict tracefs when the kernel is locked down
debugfs: Restrict debugfs when the kernel is locked down
kexec: Allow kexec_file() with appropriate IMA policy when locked down
lockdown: Lock down perf when in confidentiality mode
bpf: Restrict bpf when kernel lockdown is in confidentiality mode
lockdown: Lock down tracing and perf kprobes when in confidentiality mode
lockdown: Lock down /proc/kcore
x86/mmiotrace: Lock down the testmmiotrace module
lockdown: Lock down module params that specify hardware parameters (eg. ioport)
lockdown: Lock down TIOCSSERIAL
lockdown: Prohibit PCMCIA CIS storage when the kernel is locked down
acpi: Disable ACPI table override if the kernel is locked down
acpi: Ignore acpi_rsdp kernel param when the kernel has been locked down
ACPI: Limit access to custom_method when the kernel is locked down
x86/msr: Restrict MSR access when the kernel is locked down
x86: Lock down IO port access when the kernel is locked down
This commits selects ARCH_HAS_ELF_RANDOMIZE when an arch uses the generic
topdown mmap layout functions so that this security feature is on by
default.
Note that this commit also removes the possibility for arm64 to have elf
randomization and no MMU: without MMU, the security added by randomization
is worth nothing.
Link: http://lkml.kernel.org/r/20190730055113.23635-6-alex@ghiti.fr
Signed-off-by: Alexandre Ghiti <alex@ghiti.fr>
Reviewed-by: Luis Chamberlain <mcgrof@kernel.org>
Cc: Albert Ou <aou@eecs.berkeley.edu>
Cc: James Hogan <jhogan@kernel.org>
Cc: Palmer Dabbelt <palmer@sifive.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Russell King <linux@armlinux.org.uk>
arm64 handles top-down mmap layout in a way that can be easily reused by
other architectures, so make it available in mm. It then introduces a new
config ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT that can be set by other
architectures to benefit from those functions. Note that this new config
depends on MMU being enabled, if selected without MMU support, a warning
will be thrown.
Link: http://lkml.kernel.org/r/20190730055113.23635-5-alex@ghiti.fr
Suggested-by: Christoph Hellwig <hch@infradead.org>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes from Will Deacon:
"We've had a few arm64 fixes trickle in this week. Nothing catastophic,
but all things that should be addressed:
- Fix clang build breakage with CONFIG_OPTIMIZE_INLINING=y
- Fix compilation of pointer tagging selftest
- Fix COND_SYSCALL definitions to work with CFI checks
- Fix stale documentation reference in our Kconfig"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
arm64: Fix reference to docs for ARM64_TAGGED_ADDR_ABI
arm64: fix function types in COND_SYSCALL
selftests, arm64: add kernel headers path for tags_test
arm64: fix unreachable code issue with cmpxchg
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull Kbuild updates from Masahiro Yamada:
- add modpost warn exported symbols marked as 'static' because 'static'
and EXPORT_SYMBOL is an odd combination
- break the build early if gold linker is used
- optimize the Bison rule to produce .c and .h files by a single
pattern rule
- handle PREEMPT_RT in the module vermagic and UTS_VERSION
- warn CONFIG options leaked to the user-space except existing ones
- make single targets work properly
- rebuild modules when module linker scripts are updated
- split the module final link stage into scripts/Makefile.modfinal
- fix the missed error code in merge_config.sh
- improve the error message displayed on the attempt of the O= build in
unclean source tree
- remove 'clean-dirs' syntax
- disable -Wimplicit-fallthrough warning for Clang
- add CONFIG_CC_OPTIMIZE_FOR_SIZE_O3 for ARC
- remove ARCH_{CPP,A,C}FLAGS variables
- add $(BASH) to run bash scripts
- change *CFLAGS_<basetarget>.o to take the relative path to $(obj)
instead of the basename
- stop suppressing Clang's -Wunused-function warnings when W=1
- fix linux/export.h to avoid genksyms calculating CRC of trimmed
exported symbols
- misc cleanups
* tag 'kbuild-v5.4' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (63 commits)
genksyms: convert to SPDX License Identifier for lex.l and parse.y
modpost: use __section in the output to *.mod.c
modpost: use MODULE_INFO() for __module_depends
export.h, genksyms: do not make genksyms calculate CRC of trimmed symbols
export.h: remove defined(__KERNEL__), which is no longer needed
kbuild: allow Clang to find unused static inline functions for W=1 build
kbuild: rename KBUILD_ENABLE_EXTRA_GCC_CHECKS to KBUILD_EXTRA_WARN
kbuild: refactor scripts/Makefile.extrawarn
merge_config.sh: ignore unwanted grep errors
kbuild: change *FLAGS_<basetarget>.o to take the path relative to $(obj)
modpost: add NOFAIL to strndup
modpost: add guid_t type definition
kbuild: add $(BASH) to run scripts with bash-extension
kbuild: remove ARCH_{CPP,A,C}FLAGS
kbuild,arc: add CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE_O3 for ARC
kbuild: Do not enable -Wimplicit-fallthrough for clang for now
kbuild: clean up subdir-ymn calculation in Makefile.clean
kbuild: remove unneeded '+' marker from cmd_clean
kbuild: remove clean-dirs syntax
kbuild: check clean srctree even earlier
Pull dma-mapping updates from Christoph Hellwig:
- add dma-mapping and block layer helpers to take care of IOMMU merging
for mmc plus subsequent fixups (Yoshihiro Shimoda)
- rework handling of the pgprot bits for remapping (me)
- take care of the dma direct infrastructure for swiotlb-xen (me)
- improve the dma noncoherent remapping infrastructure (me)
- better defaults for ->mmap, ->get_sgtable and ->get_required_mask
(me)
- cleanup mmaping of coherent DMA allocations (me)
- various misc cleanups (Andy Shevchenko, me)
* tag 'dma-mapping-5.4' of git://git.infradead.org/users/hch/dma-mapping: (41 commits)
mmc: renesas_sdhi_internal_dmac: Add MMC_CAP2_MERGE_CAPABLE
mmc: queue: Fix bigger segments usage
arm64: use asm-generic/dma-mapping.h
swiotlb-xen: merge xen_unmap_single into xen_swiotlb_unmap_page
swiotlb-xen: simplify cache maintainance
swiotlb-xen: use the same foreign page check everywhere
swiotlb-xen: remove xen_swiotlb_dma_mmap and xen_swiotlb_dma_get_sgtable
xen: remove the exports for xen_{create,destroy}_contiguous_region
xen/arm: remove xen_dma_ops
xen/arm: simplify dma_cache_maint
xen/arm: use dev_is_dma_coherent
xen/arm: consolidate page-coherent.h
xen/arm: use dma-noncoherent.h calls for xen-swiotlb cache maintainance
arm: remove wrappers for the generic dma remap helpers
dma-mapping: introduce a dma_common_find_pages helper
dma-mapping: always use VM_DMA_COHERENT for generic DMA remap
vmalloc: lift the arm flag for coherent mappings to common code
dma-mapping: provide a better default ->get_required_mask
dma-mapping: remove the dma_declare_coherent_memory export
remoteproc: don't allow modular build
The referenced file does not exist, but tagged-address-abi.rst does.
Signed-off-by: Jeremy Cline <jcline@redhat.com>
* for-next/atomics: (10 commits)
Rework LSE instruction selection to use static keys instead of alternatives
'for-next/error-injection', 'for-next/perf', 'for-next/psci-cpuidle', 'for-next/rng', 'for-next/smpboot', 'for-next/tbi' and 'for-next/tlbi' into for-next/core
* for-next/52-bit-kva: (25 commits)
Support for 52-bit virtual addressing in kernel space
* for-next/cpu-topology: (9 commits)
Move CPU topology parsing into core code and add support for ACPI 6.3
* for-next/error-injection: (2 commits)
Support for function error injection via kprobes
* for-next/perf: (8 commits)
Support for i.MX8 DDR PMU and proper SMMUv3 group validation
* for-next/psci-cpuidle: (7 commits)
Move PSCI idle code into a new CPUidle driver
* for-next/rng: (4 commits)
Support for 'rng-seed' property being passed in the devicetree
* for-next/smpboot: (3 commits)
Reduce fragility of secondary CPU bringup in debug configurations
* for-next/tbi: (10 commits)
Introduce new syscall ABI with relaxed requirements for pointer tags
* for-next/tlbi: (6 commits)
Handle spurious page faults arising from kernel space
Support for LSE atomic instructions (CONFIG_ARM64_LSE_ATOMICS) relies on
a static key to select between the legacy LL/SC implementation which is
available on all arm64 CPUs and the super-duper LSE implementation which
is available on CPUs implementing v8.1 and later.
Unfortunately, when building a kernel with CONFIG_JUMP_LABEL disabled
(e.g. because the toolchain doesn't support 'asm goto'), the static key
inside the atomics code tries to use atomics itself. This results in a
mess of circular includes and a build failure:
In file included from ./arch/arm64/include/asm/lse.h:11,
from ./arch/arm64/include/asm/atomic.h:16,
from ./include/linux/atomic.h:7,
from ./include/asm-generic/bitops/atomic.h:5,
from ./arch/arm64/include/asm/bitops.h:26,
from ./include/linux/bitops.h:19,
from ./include/linux/kernel.h:12,
from ./include/asm-generic/bug.h:18,
from ./arch/arm64/include/asm/bug.h:26,
from ./include/linux/bug.h:5,
from ./include/linux/page-flags.h:10,
from kernel/bounds.c:10:
./include/linux/jump_label.h: In function ‘static_key_count’:
./include/linux/jump_label.h:254:9: error: implicit declaration of function ‘atomic_read’ [-Werror=implicit-function-declaration]
return atomic_read(&key->enabled);
[ ... more of the same ... ]
Since LSE atomic instructions are not critical to the operation of the
kernel, make them depend on JUMP_LABEL at compile time.
Reviewed-by: Andrew Murray <andrew.murray@arm.com>
arch_dma_mmap_pgprot is used for two things:
1) to override the "normal" uncached page attributes for mapping
memory coherent to devices that can't snoop the CPU caches
2) to provide the special DMA_ATTR_WRITE_COMBINE semantics on older
arm systems and some mips platforms
Replace one with the pgprot_dmacoherent macro that is already provided
by arm and much simpler to use, and lift the DMA_ATTR_WRITE_COMBINE
handling to common code with an explicit arch opt-in.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> # m68k
Acked-by: Paul Burton <paul.burton@mips.com> # mips
Add CONFIG_ASM_MODVERSIONS. This allows to remove one if-conditional
nesting in scripts/Makefile.build.
scripts/Makefile.build is run every time Kbuild descends into a
sub-directory. So, I want to avoid $(wildcard ...) evaluation
where possible although computing $(wildcard ...) is so cheap that
it may not make measurable performance difference.
This is a preparatory patch for kexec_file_load() lockdown. A locked down
kernel needs to prevent unsigned kernel images from being loaded with
kexec_file_load(). Currently, the only way to force the signature
verification is compiling with KEXEC_VERIFY_SIG. This prevents loading
usigned images even when the kernel is not locked down at runtime.
This patch splits KEXEC_VERIFY_SIG into KEXEC_SIG and KEXEC_SIG_FORCE.
Analogous to the MODULE_SIG and MODULE_SIG_FORCE for modules, KEXEC_SIG
turns on the signature verification but allows unsigned images to be
loaded. KEXEC_SIG_FORCE disallows images without a valid signature.
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Signed-off-by: Matthew Garrett <mjg59@google.com>
cc: kexec@lists.infradead.org
Signed-off-by: James Morris <jmorris@namei.org>
Most of the machinery is now in place to enable 52-bit kernel VAs that
are detectable at boot time.
This patch adds a Kconfig option for 52-bit user and kernel addresses
and plumbs in the requisite CONFIG_ macros as well as sets TCR.T1SZ,
physvirt_offset and vmemmap at early boot.
To simplify things this patch also removes the 52-bit user/48-bit kernel
kconfig option.
Signed-off-by: Steve Capper <steve.capper@arm.com>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
KASAN_SHADOW_OFFSET is a constant that is supplied to gcc as a command
line argument and affects the codegen of the inline address sanetiser.
Essentially, for an example memory access:
*ptr1 = val;
The compiler will insert logic similar to the below:
shadowValue = *(ptr1 >> KASAN_SHADOW_SCALE_SHIFT + KASAN_SHADOW_OFFSET)
if (somethingWrong(shadowValue))
flagAnError();
This code sequence is inserted into many places, thus
KASAN_SHADOW_OFFSET is essentially baked into many places in the kernel
text.
If we want to run a single kernel binary with multiple address spaces,
then we need to do this with KASAN_SHADOW_OFFSET fixed.
Thankfully, due to the way the KASAN_SHADOW_OFFSET is used to provide
shadow addresses we know that the end of the shadow region is constant
w.r.t. VA space size:
KASAN_SHADOW_END = ~0 >> KASAN_SHADOW_SCALE_SHIFT + KASAN_SHADOW_OFFSET
This means that if we increase the size of the VA space, the start of
the KASAN region expands into lower addresses whilst the end of the
KASAN region is fixed.
Currently the arm64 code computes KASAN_SHADOW_OFFSET at build time via
build scripts with the VA size used as a parameter. (There are build
time checks in the C code too to ensure that expected values are being
derived). It is sufficient, and indeed is a simplification, to remove
the build scripts (and build time checks) entirely and instead provide
KASAN_SHADOW_OFFSET values.
This patch removes the logic to compute the KASAN_SHADOW_OFFSET in the
arm64 Makefile, and instead we adopt the approach used by x86 to supply
offset values in kConfig. To help debug/develop future VA space changes,
the Makefile logic has been preserved in a script file in the arm64
Documentation folder.
Inspired by the commit 7cd01b08d35f ("powerpc: Add support for function
error injection"), this patch supports function error injection for
Arm64.
This patch mainly support two functions: one is regs_set_return_value()
which is used to overwrite the return value; the another function is
override_function_with_return() which is to override the probed
function returning and jump to its caller.
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Leo Yan <leo.yan@linaro.org>
It is not desirable to relax the ABI to allow tagged user addresses into
the kernel indiscriminately. This patch introduces a prctl() interface
for enabling or disabling the tagged ABI with a global sysctl control
for preventing applications from enabling the relaxed ABI (meant for
testing user-space prctl() return error checking without reconfiguring
the kernel). The ABI properties are inherited by threads of the same
application and fork()'ed children but cleared on execve(). A Kconfig
option allows the overall disabling of the relaxed ABI.
The PR_SET_TAGGED_ADDR_CTRL will be expanded in the future to handle
MTE-specific settings like imprecise vs precise exceptions.
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
RELR is a relocation packing format for relative relocations.
The format is described in a generic-abi proposal:
https://groups.google.com/d/topic/generic-abi/bX460iggiKg/discussion
The LLD linker can be instructed to pack relocations in the RELR
format by passing the flag --pack-dyn-relocs=relr.
This patch adds a new config option, CONFIG_RELR. Enabling this option
instructs the linker to pack vmlinux's relative relocations in the RELR
format, and causes the kernel to apply the relocations at startup along
with the RELA relocations. RELA relocations still need to be applied
because the linker will emit RELA relative relocations if they are
unrepresentable in the RELR format (i.e. address not a multiple of 2).
Enabling CONFIG_RELR reduces the size of a defconfig kernel image
with CONFIG_RANDOMIZE_BASE by 3.5MB/16% uncompressed, or 550KB/5%
compressed (lz4).
Signed-off-by: Peter Collingbourne <pcc@google.com>
Tested-by: Nick Desaulniers <ndesaulniers@google.com>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux
Pull RISC-V updates from Paul Walmsley:
- Hugepage support
- "Image" header support for RISC-V kernel binaries, compatible with
the current ARM64 "Image" header
- Initial page table setup now split into two stages
- CONFIG_SOC support (starting with SiFive SoCs)
- Avoid reserving memory between RAM start and the kernel in
setup_bootmem()
- Enable high-res timers and dynamic tick in the RV64 defconfig
- Remove long-deprecated gate area stubs
- MAINTAINERS updates to switch to the newly-created shared RISC-V git
tree, and to fix a get_maintainers.pl issue for patches involving
SiFive E-mail addresses
Also, one integration fix to resolve a build problem introduced during
in the v5.3-rc1 merge window:
- Fix build break after macro-to-function conversion in
asm-generic/cacheflush.h
* tag 'riscv/for-v5.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux:
riscv: fix build break after macro-to-function conversion in generic cacheflush.h
RISC-V: Add an Image header that boot loader can parse.
RISC-V: Setup initial page tables in two stages
riscv: remove free_initrd_mem
riscv: ccache: Remove unused variable
riscv: Introduce huge page support for 32/64bit kernel
x86, arm64: Move ARCH_WANT_HUGE_PMD_SHARE config in arch/Kconfig
RISC-V: Fix memory reservation in setup_bootmem()
riscv: defconfig: enable SOC_SIFIVE
riscv: select SiFive platform drivers with SOC_SIFIVE
arch: riscv: add config option for building SiFive's SoC resource
riscv: Remove gate area stubs
MAINTAINERS: change the arch/riscv git tree to the new shared tree
MAINTAINERS: don't automatically patches involving SiFive to the linux-riscv list
RISC-V: defconfig: Enable NO_HZ_IDLE and HIGH_RES_TIMERS
Merge more updates from Andrew Morton:
"VM:
- z3fold fixes and enhancements by Henry Burns and Vitaly Wool
- more accurate reclaimed slab caches calculations by Yafang Shao
- fix MAP_UNINITIALIZED UAPI symbol to not depend on config, by
Christoph Hellwig
- !CONFIG_MMU fixes by Christoph Hellwig
- new novmcoredd parameter to omit device dumps from vmcore, by
Kairui Song
- new test_meminit module for testing heap and pagealloc
initialization, by Alexander Potapenko
- ioremap improvements for huge mappings, by Anshuman Khandual
- generalize kprobe page fault handling, by Anshuman Khandual
- device-dax hotplug fixes and improvements, by Pavel Tatashin
- enable synchronous DAX fault on powerpc, by Aneesh Kumar K.V
- add pte_devmap() support for arm64, by Robin Murphy
- unify locked_vm accounting with a helper, by Daniel Jordan
- several misc fixes
core/lib:
- new typeof_member() macro including some users, by Alexey Dobriyan
- make BIT() and GENMASK() available in asm, by Masahiro Yamada
- changed LIST_POISON2 on x86_64 to 0xdead000000000122 for better
code generation, by Alexey Dobriyan
- rbtree code size optimizations, by Michel Lespinasse
- convert struct pid count to refcount_t, by Joel Fernandes
get_maintainer.pl:
- add --no-moderated switch to skip moderated ML's, by Joe Perches
misc:
- ptrace PTRACE_GET_SYSCALL_INFO interface
- coda updates
- gdb scripts, various"
[ Using merge message suggestion from Vlastimil Babka, with some editing - Linus ]
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (100 commits)
fs/select.c: use struct_size() in kmalloc()
mm: add account_locked_vm utility function
arm64: mm: implement pte_devmap support
mm: introduce ARCH_HAS_PTE_DEVMAP
mm: clean up is_device_*_page() definitions
mm/mmap: move common defines to mman-common.h
mm: move MAP_SYNC to asm-generic/mman-common.h
device-dax: "Hotremove" persistent memory that is used like normal RAM
mm/hotplug: make remove_memory() interface usable
device-dax: fix memory and resource leak if hotplug fails
include/linux/lz4.h: fix spelling and copy-paste errors in documentation
ipc/mqueue.c: only perform resource calculation if user valid
include/asm-generic/bug.h: fix "cut here" for WARN_ON for __WARN_TAINT architectures
scripts/gdb: add helpers to find and list devices
scripts/gdb: add lx-genpd-summary command
drivers/pps/pps.c: clear offset flags in PPS_SETPARAMS ioctl
kernel/pid.c: convert struct pid count to refcount_t
drivers/rapidio/devices/rio_mport_cdev.c: NUL terminate some strings
select: shift restore_saved_sigmask_unless() into poll_select_copy_remaining()
select: change do_poll() to return -ERESTARTNOHAND rather than -EINTR
In order for things like get_user_pages() to work on ZONE_DEVICE memory,
we need a software PTE bit to identify device-backed PFNs. Hook this up
along with the relevant helpers to join in with ARCH_HAS_PTE_DEVMAP.
[robin.murphy@arm.com: build fixes]
Link: http://lkml.kernel.org/r/13026c4e64abc17133bbfa07d7731ec6691c0bcd.1559050949.git.robin.murphy@arm.com
Link: http://lkml.kernel.org/r/817d92886fc3b33bcbf6e105ee83a74babb3a5aa.1558547956.git.robin.murphy@arm.com
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Anshuman Khandual <anshuman.khandual@arm.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: David Hildenbrand <david@redhat.com>
Cc: Ira Weiny <ira.weiny@intel.com>
Cc: Jerome Glisse <jglisse@redhat.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Oliver O'Halloran <oohall@gmail.com>
The Kdump documentation describes procedures with admins use
in order to solve issues on their systems.
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Converts ARM the text files to ReST, preparing them to be an
architecture book.
The conversion is actually:
- add blank lines and identation in order to identify paragraphs;
- fix tables markups;
- add some lists markups;
- mark literal blocks;
- adjust title markups.
At its new index.rst, let's add a :orphan: while this is not linked to
the main index.rst file, in order to avoid build warnings.
Reviewed-by Corentin Labbe <clabbe.montjoie@gmail.com> # For sun4i-ss
We only support the generic GUP now, so rename the config option to
be more clear, and always use the mm/Kconfig definition of the
symbol and select it from the arch Kconfigs.
Link: http://lkml.kernel.org/r/20190625143715.1689-11-hch@lst.de
Reviewed-by: Khalid Aziz <khalid.aziz@oracle.com>
Reviewed-by: Jason Gunthorpe <jgg@mellanox.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
Cc: Nicholas Piggin <npiggin@gmail.com>
Cc: Rich Felker <dalias@libc.org>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Pull Documentation updates from Jonathan Corbet:
"It's been a relatively busy cycle for docs:
- A fair pile of RST conversions, many from Mauro. These create more
than the usual number of simple but annoying merge conflicts with
other trees, unfortunately. He has a lot more of these waiting on
the wings that, I think, will go to you directly later on.
- A new document on how to use merges and rebases in kernel repos,
and one on Spectre vulnerabilities.
- Various improvements to the build system, including automatic
markup of function() references because some people, for reasons I
will never understand, were of the opinion that
:c:func:``function()`` is unattractive and not fun to type.
- We now recommend using sphinx 1.7, but still support back to 1.4.
- Lots of smaller improvements, warning fixes, typo fixes, etc"
* tag 'docs-5.3' of git://git.lwn.net/linux: (129 commits)
docs: automarkup.py: ignore exceptions when seeking for xrefs
docs: Move binderfs to admin-guide
Disable Sphinx SmartyPants in HTML output
doc: RCU callback locks need only _bh, not necessarily _irq
docs: format kernel-parameters -- as code
Doc : doc-guide : Fix a typo
platform: x86: get rid of a non-existent document
Add the RCU docs to the core-api manual
Documentation: RCU: Add TOC tree hooks
Documentation: RCU: Rename txt files to rst
Documentation: RCU: Convert RCU UP systems to reST
Documentation: RCU: Convert RCU linked list to reST
Documentation: RCU: Convert RCU basic concepts to reST
docs: filesystems: Remove uneeded .rst extension on toctables
scripts/sphinx-pre-install: fix out-of-tree build
docs: zh_CN: submitting-drivers.rst: Remove a duplicated Documentation/
Documentation: PGP: update for newer HW devices
Documentation: Add section about CPU vulnerabilities for Spectre
Documentation: platform: Delete x86-laptop-drivers.txt
docs: Note that :c:func: should no longer be used
Pull timer updates from Thomas Gleixner:
"The timer and timekeeping departement delivers:
Core:
- The consolidation of the VDSO code into a generic library including
the conversion of x86 and ARM64. Conversion of ARM and MIPS are en
route through the relevant maintainer trees and should end up in
5.4.
This gets rid of the unnecessary different copies of the same code
and brings all architectures on the same level of VDSO
functionality.
- Make the NTP user space interface more robust by restricting the
TAI offset to prevent undefined behaviour. Includes a selftest.
- Validate user input in the compat settimeofday() syscall to catch
invalid values which would be turned into valid values by a
multiplication overflow
- Consolidate the time accessors
- Small fixes, improvements and cleanups all over the place
Drivers:
- Support for the NXP system counter, TI davinci timer
- Move the Microsoft HyperV clocksource/events code into the
drivers/clocksource directory so it can be shared between x86 and
ARM64.
- Overhaul of the Tegra driver
- Delay timer support for IXP4xx
- Small fixes, improvements and cleanups as usual"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits)
time: Validate user input in compat_settimeofday()
timer: Document TIMER_PINNED
clocksource/drivers: Continue making Hyper-V clocksource ISA agnostic
clocksource/drivers: Make Hyper-V clocksource ISA agnostic
MAINTAINERS: Fix Andy's surname and the directory entries of VDSO
hrtimer: Use a bullet for the returns bullet list
arm64: vdso: Fix compilation with clang older than 8
arm64: compat: Fix __arch_get_hw_counter() implementation
arm64: Fix __arch_get_hw_counter() implementation
lib/vdso: Make delta calculation work correctly
MAINTAINERS: Add entry for the generic VDSO library
arm64: compat: No need for pre-ARMv7 barriers on an ARMv8 system
arm64: vdso: Remove unnecessary asm-offsets.c definitions
vdso: Remove superfluous #ifdef __KERNEL__ in vdso/datapage.h
clocksource/drivers/davinci: Add support for clocksource
clocksource/drivers/davinci: Add support for clockevents
clocksource/drivers/tegra: Set up maximum-ticks limit properly
clocksource/drivers/tegra: Cycles can't be 0
clocksource/drivers/tegra: Restore base address before cleanup
clocksource/drivers/tegra: Add verbose definition for 1MHz constant
ARCH_WANT_HUGE_PMD_SHARE config was declared in both architectures:
move this declaration in arch/Kconfig and make those architectures
select it.
Reviewed-by: Palmer Dabbelt <palmer@sifive.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com> # for arm64
Reviewed-by: Hanjun Guo <guohanjun@huawei.com>
Signed-off-by: Paul Walmsley <paul.walmsley@sifive.com>
Otherwise, selecting it without MODULES leads to build failures.
Fixes: 58557e486f89 ("arm64: Allow user selection of ARM64_MODULE_PLTS")
Wire up the special helper functions to manipulate aliases of vmalloc
regions in the linear map.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@arm.com>
Make ARM64_MODULE_PLTS a selectable Kconfig symbol, since some people
might have very big modules spilling out of the dedicated module area
into vmalloc. Help text is copied from the ARM 32-bit counterpart and
modified to a mention of KASLR and specific ARM errata workaround(s).
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Add vDSO compat support to the arm64 build system.
Tested-by: Shijith Thotton <sthotton@marvell.com>
Tested-by: Andre Przywara <andre.przywara@arm.com>
Cc: linux-mips@vger.kernel.org
Cc: linux-kselftest@vger.kernel.org
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: Mark Salyzyn <salyzyn@android.com>
Cc: Peter Collingbourne <pcc@google.com>
Cc: Shuah Khan <shuah@kernel.org>
Cc: Dmitry Safonov <0x7f454c46@gmail.com>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Huw Davies <huw@codeweavers.com>
Link: https://lkml.kernel.org/r/20190621095252.32307-16-vincenzo.frascino@arm.com
To take advantage of the commonly defined vdso interface for gettimeofday()
the architectural code requires an adaptation.
Re-implement the gettimeofday VDSO in C in order to use lib/vdso.
With the new implementation arm64 gains support for CLOCK_BOOTTIME
and CLOCK_TAI.
[ tglx: Reformatted the function line breaks ]
Link: https://lkml.kernel.org/r/20190621095252.32307-5-vincenzo.frascino@arm.com
Now that Pseudo-NMI are fixed, allow the use of that option again
This reverts commit 96a13f57b946be7a6c10405e4bd780c0b6b6fe63 ("arm64:
Kconfig: Make ARM64_PSEUDO_NMI depend on BROKEN for now").
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Julien Thierry <julien.thierry@arm.com>
Using IRQ priority masking to enable/disable interrupts is a bit
sensitive as it requires to deal with both ICC_PMR_EL1 and PSR.I.
Introduce some validity checks to both highlight the states in which
functions dealing with IRQ enabling/disabling can (not) be called, and
bark a warning when called in an unexpected state.
Since these checks are done on hotpaths, introduce a build option to
choose whether to do the checking.
Convert kdump documentation to ReST and add it to the
user faced manual, as the documents are mainly focused on
sysadmins that would be enabling kdump.
Note: the vmcoreinfo.rst has one very long title on one of its
sub-sections:
PG_lru|PG_private|PG_swapcache|PG_swapbacked|PG_slab|PG_hwpoision|PG_head_mask|PAGE_BUDDY_MAPCOUNT_VALUE(~PG_buddy)|PAGE_OFFLINE_MAPCOUNT_VALUE(~PG_offline)
I opted to break this one, into two entries with the same content,
in order to make it easier to display after being parsed in html and PDF.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
'default n' is the default value for any bool or tristate Kconfig
setting so there is no need to write it explicitly.
Also since commit f467c5640c29 ("kconfig: only write '# CONFIG_FOO
is not set' for visible symbols") the Kconfig behavior is the same
regardless of 'default n' being present or not:
One side effect of (and the main motivation for) this change is making
the following two definitions behave exactly the same:
config FOO
bool
config FOO
bool
default n
With this change, neither of these will generate a
'# CONFIG_FOO is not set' line (assuming FOO isn't selected/implied).
That might make it clearer to people that a bare 'default n' is
redundant.
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
This change makes CONFIG_ZONE_DMA32 defuly y and allows users
to overwrite it only when CONFIG_EXPERT=y.
For the SoCs that do not need CONFIG_ZONE_DMA32, this is the
first step to manage all available memory by a single
zone(normal zone) to reduce the overhead of multiple zones.
The change also fixes a build error when CONFIG_NUMA=y and
CONFIG_ZONE_DMA32=n.
arch/arm64/mm/init.c:195:17: error: use of undeclared identifier 'ZONE_DMA32'
max_zone_pfns[ZONE_DMA32] = PFN_DOWN(max_zone_dma_phys());
Change since v1:
1. only expose CONFIG_ZONE_DMA32 when CONFIG_EXPERT=y
2. remove redundant IS_ENABLED(CONFIG_ZONE_DMA32)
Cc: Robin Murphy <robin.murphy@arm.com>
Signed-off-by: Miles Chen <miles.chen@mediatek.com>
Pull more arm64 fixes from Will Deacon:
- Fix incorrect LDADD instruction encoding in our disassembly macros
- Disable the broken ARM64_PSEUDO_NMI support for now
- Add workaround for Cortex-A76 CPU erratum #1463225
- Handle Cortex-A76/Neoverse-N1 erratum #1418040 w/ existing workaround
- Fix IORT build failure if IOMMU_SUPPORT=n
- Fix place-relative module relocation range checking and its
interaction with KASLR
arm64: insn: Add BUILD_BUG_ON() for invalid masks
arm64: insn: Fix ldadd instruction encoding
arm64: Kconfig: Make ARM64_PSEUDO_NMI depend on BROKEN for now
arm64: Handle erratum 1418040 as a superset of erratum 1188873
arm64/module: deal with ambiguity in PRELxx relocation ranges
ACPI/IORT: Fix build error when IOMMU_SUPPORT is disabled
arm64/kernel: kaslr: reduce module randomization range to 2 GB
arm64: errata: Add workaround for Cortex-A76 erratum #1463225
arm64: Remove useless message during oops
Although we merged support for pseudo-nmi using interrupt priority
masking in 5.1, we've since uncovered a number of non-trivial issues
with the implementation. Although there are patches pending to address
these problems, we're facing issues that prevent us from merging them at
this current time:
https://lkml.kernel.org/r/1556553607-46531-1-git-send-email-julien.thierry@arm.com
For now, simply mark this optional feature as BROKEN in the hope that we
can fix things properly in the near future.
Cc: <stable@vger.kernel.org> # 5.1
Cc: Julien Thierry <julien.thierry@arm.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
We already mitigate erratum 1188873 affecting Cortex-A76 and
Neoverse-N1 r0p0 to r2p0. It turns out that revisions r0p0 to
r3p1 of the same cores are affected by erratum 1418040, which
has the same workaround as 1188873.
Let's expand the range of affected revisions to match 1418040,
and repaint all occurences of 1188873 to 1418040. Whilst we're
there, do a bit of reformating in silicon-errata.txt and drop
a now unnecessary dependency on ARM_ARCH_TIMER_OOL_WORKAROUND.
Revisions of the Cortex-A76 CPU prior to r4p0 are affected by an erratum
that can prevent interrupts from being taken when single-stepping.
This patch implements a software workaround to prevent userspace from
effectively being able to disable interrupts.
Cc: Marc Zyngier <marc.zyngier@arm.com>
