Commit f4f75ad5 ("efi: efistub: Convert into static library")
introduced a static library for EFI stub, libstub.
The EFI libstub directory is referenced by the kernel build system via
a obj subdirectory rule in:
drivers/firmware/efi/Makefile
Unfortunately, arm64 also references the EFI libstub via:
libs-$(CONFIG_EFI_STUB) += drivers/firmware/efi/libstub/
If we're unlucky, the kernel build system can enter libstub via two
simultaneous threads resulting in build failures such as:
fixdep: error opening depfile: drivers/firmware/efi/libstub/.efi-stub-helper.o.d: No such file or directory
scripts/Makefile.build:257: recipe for target 'drivers/firmware/efi/libstub/efi-stub-helper.o' failed
make[1]: *** [drivers/firmware/efi/libstub/efi-stub-helper.o] Error 2
Makefile:939: recipe for target 'drivers/firmware/efi/libstub' failed
make: *** [drivers/firmware/efi/libstub] Error 2
make: *** Waiting for unfinished jobs....
This patch adjusts the arm64 Makefile to reference the compiled library
explicitly (as is currently done in x86), rather than the directory.
Fixes: f4f75ad5 efi: efistub: Convert into static library
Signed-off-by: Steve Capper <steve.capper@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Catalin Marinas:
"arm64 updates for 3.20:
- reimplementation of the virtual remapping of UEFI Runtime Services
in a way that is stable across kexec
- emulation of the "setend" instruction for 32-bit tasks (user
endianness switching trapped in the kernel, SCTLR_EL1.E0E bit set
accordingly)
- compat_sys_call_table implemented in C (from asm) and made it a
constant array together with sys_call_table
- export CPU cache information via /sys (like other architectures)
- DMA API implementation clean-up in preparation for IOMMU support
- macros clean-up for KVM
- dropped some unnecessary cache+tlb maintenance
- CONFIG_ARM64_CPU_SUSPEND clean-up
- defconfig update (CPU_IDLE)
The EFI changes going via the arm64 tree have been acked by Matt
Fleming. There is also a patch adding sys_*stat64 prototypes to
include/linux/syscalls.h, acked by Andrew Morton"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (47 commits)
arm64: compat: Remove incorrect comment in compat_siginfo
arm64: Fix section mismatch on alloc_init_p[mu]d()
arm64: Avoid breakage caused by .altmacro in fpsimd save/restore macros
arm64: mm: use *_sect to check for section maps
arm64: drop unnecessary cache+tlb maintenance
arm64:mm: free the useless initial page table
arm64: Enable CPU_IDLE in defconfig
arm64: kernel: remove ARM64_CPU_SUSPEND config option
arm64: make sys_call_table const
arm64: Remove asm/syscalls.h
arm64: Implement the compat_sys_call_table in C
syscalls: Declare sys_*stat64 prototypes if __ARCH_WANT_(COMPAT_)STAT64
compat: Declare compat_sys_sigpending and compat_sys_sigprocmask prototypes
arm64: uapi: expose our struct ucontext to the uapi headers
smp, ARM64: Kill SMP single function call interrupt
arm64: Emulate SETEND for AArch32 tasks
arm64: Consolidate hotplug notifier for instruction emulation
arm64: Track system support for mixed endian EL0
arm64: implement generic IOMMU configuration
arm64: Combine coherent and non-coherent swiotlb dma_ops
As dts files have been reorganised under vendor subdirs, dtb files
cannot be removed with "make distclean" now. Thus, this patch moves
dtb files under archclean rule and removes unnecessary entries.
Cc: Robert Richter <rrichter@cavium.com>
Signed-off-by: Jungseok Lee <jungseoklee85@gmail.com>
The arm64 kernel builds fine without the libgcc. Actually it should not
be used at all in the kernel. The following are the reasons indicated
by Russell King:
Although libgcc is part of the compiler, libgcc is built with the
expectation that it will be running in userland - it expects to link
to a libc. That's why you can't build libgcc without having the glibc
headers around.
Meanwhile, having the kernel build the compiler support functions that
it needs ensures that (a) we know what compiler support functions are
being used, (b) we know the implementation of those support functions
are sane for use in the kernel, (c) we can build them with appropriate
compiler flags for best performance, and (d) we remove an unnecessary
dependency on the build toolchain.
Signed-off-by: Kevin Hao <haokexin@gmail.com>
Acked-by: Will Deacon <will.deacon@arm.com>
Add dtb files to build targets and let kbuild handle them. Thus,
special dtbs rules can be removed. This eases Makefiles and the
implementation of the support of vendor dtb subdirectories.
Signed-off-by: Robert Richter <rrichter@cavium.com>
Move dtbs install rules to Makefile.dtbinst. This change is needed to
implement support for dts vendor subdirs. The change makes Makefiles
easier and smaller as no longer the dtbs_install rule needs to be
defined. Another advantage is that install goals are not encoded in
targets anymore (%.dtb_dtbinst_).
This adds the dtbs_install make target to arm64. The target has been
introduced already to arch/arm with the following commit:
f4d4ffc03efc kbuild: dtbs_install: new make target
Implementation for arm64 is the same as for arm.
With 'dtbs_install' all config enabled dtb files are installed to
either the INSTALL_DTBS_PATH directory or the default location:
$INSTALL_PATH/dtbs/$KERNELRELEASE
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild
Pull kbuild changes from Michal Marek:
- fix for handling dependencies of *-objs targets by Masahiro Yamada
- lots of cleanups in the kbuild machinery, also by Masahiro
- fixes for the kconfig build to use an UTF-8 capable ncurses library
if possible and to build on not-so-standard installs
- some more minor fixes
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild:
kbuild: Do not reference *-n variables in the Makefile
kbuild: simplify build, clean, modbuiltin shorthands
kbuild: arm: Do not define "comma" twice
kbuild: remove obj-n and lib-n handling
kbuild: remove unnecessary variable initializaions
kbuild: remove unnecessary "obj- := dummy.o" trick
kbuild: handle C=... and M=... after entering into build directory
kbuild: use $(Q) for sub-make target
kbuild: fake the "Entering directory ..." message more simply
kconfig/lxdialog: get ncurses CFLAGS with pkg-config
kconfig: nconfig: fix multi-byte UTF handling
kconfig: lxdialog: fix spelling
kbuild: Make scripts executable
kbuild: remove redundant clean-files from scripts/kconfig/Makefile
kbuild: refactor script/kconfig/Makefile
kbuild: handle the dependency of multi-objs hostprogs appropriately
kbuild: handle multi-objs dependency appropriately
The definition of "comma" exists in scripts/Kbuild.include.
We should not double it.
The JIT compiler emits A64 instructions. It supports eBPF only.
Legacy BPF is supported thanks to conversion by BPF core.
JIT is enabled in the same way as for other architectures:
echo 1 > /proc/sys/net/core/bpf_jit_enable
Or for additional compiler output:
echo 2 > /proc/sys/net/core/bpf_jit_enable
See Documentation/networking/filter.txt for more information.
The implementation passes all 57 tests in lib/test_bpf.c
on ARMv8 Foundation Model :) Also tested by Will on Juno platform.
Signed-off-by: Zi Shen Lim <zlim.lnx@gmail.com>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
When booting via UEFI, the kernel Image is loaded at a 4 kB boundary and
the embedded EFI stub is executed in place. The EFI stub relocates the
Image to reside TEXT_OFFSET bytes above a 2 MB boundary, and jumps into
the kernel proper.
In AArch64, PC relative symbol references are emitted using adrp/add or
adrp/ldr pairs, where the offset into a 4 kB page is resolved using a
separate :lo12: relocation. This implicitly assumes that the code will
always be executed at the same relative offset with respect to a 4 kB
boundary, or the references will point to the wrong address.
This means we should link the kernel at a 4 kB aligned base address in
order to remain compatible with the base address the UEFI loader uses
when doing the initial load of Image. So update the code that generates
TEXT_OFFSET to choose a multiple of 4 kB.
At the same time, update the code so it chooses from the interval [0..2MB)
as the author originally intended.
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Pull EFI changes from Ingo Molnar:
"Main changes in this cycle are:
- arm64 efi stub fixes, preservation of FP/SIMD registers across
firmware calls, and conversion of the EFI stub code into a static
library - Ard Biesheuvel
- Xen EFI support - Daniel Kiper
- Support for autoloading the efivars driver - Lee, Chun-Yi
- Use the PE/COFF headers in the x86 EFI boot stub to request that
the stub be loaded with CONFIG_PHYSICAL_ALIGN alignment - Michael
Brown
- Consolidate all the x86 EFI quirks into one file - Saurabh Tangri
- Additional error logging in x86 EFI boot stub - Ulf Winkelvos
- Support loading initrd above 4G in EFI boot stub - Yinghai Lu
- EFI reboot patches for ACPI hardware reduced platforms"
* 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits)
efi/arm64: Handle missing virtual mapping for UEFI System Table
arch/x86/xen: Silence compiler warnings
x86/efi: Request desired alignment via the PE/COFF headers
x86/efi: Add better error logging to EFI boot stub
efi: Autoload efivars
efi: Update stale locking comment for struct efivars
arch/x86: Remove efi_set_rtc_mmss()
arch/x86: Replace plain strings with constants
xen: Put EFI machinery in place
xen: Define EFI related stuff
arch/x86: Remove redundant set_bit(EFI_MEMMAP) call
arch/x86: Remove redundant set_bit(EFI_SYSTEM_TABLES) call
efi: Introduce EFI_PARAVIRT flag
arch/x86: Do not access EFI memory map if it is not available
efi: Use early_mem*() instead of early_io*()
arch/ia64: Define early_memunmap()
x86/reboot: Add EFI reboot quirk for ACPI Hardware Reduced flag
efi/reboot: Allow powering off machines using EFI
efi/reboot: Add generic wrapper around EfiResetSystem()
This patch changes both x86 and arm64 efistub implementations
from #including shared .c files under drivers/firmware/efi to
building shared code as a static library.
The x86 code uses a stub built into the boot executable which
uncompresses the kernel at boot time. In this case, the library is
linked into the decompressor.
In the arm64 case, the stub is part of the kernel proper so the library
is linked into the kernel proper as well.
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
The arm64 Image header contains a text_offset field which bootloaders
are supposed to read to determine the offset (from a 2MB aligned "start
of memory" per booting.txt) at which to load the kernel. The offset is
not well respected by bootloaders at present, and due to the lack of
variation there is little incentive to support it. This is unfortunate
for the sake of future kernels where we may wish to vary the text offset
(even zeroing it).
This patch adds options to arm64 to enable fuzz-testing of text_offset.
CONFIG_ARM64_RANDOMIZE_TEXT_OFFSET forces the text offset to a random
16-byte aligned value value in the range [0..2MB) upon a build of the
kernel. It is recommended that distribution kernels enable randomization
to test bootloaders such that any compliance issues can be fixed early.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Tom Rini <trini@ti.com>
This patch adds support for the SHA-1 Secure Hash Algorithm for CPUs that
have support for the SHA-1 part of the ARM v8 Crypto Extensions.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
This patch adds big-endian support to the AArch64 top-level Makefile.
This currently just passes the relevant flags to the toolchain and is
predicated on a Kconfig option that will be introduced later on.
Provide a vdso_install target in the arm64 Makefile, as other architectures
with a vdso do.
Signed-off-by: Kyle McMartin <kyle@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms into upstream
* 'kvm-arm64/kvm-for-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms: (33 commits)
arm64: KVM: document kernel object mappings in HYP
arm64: KVM: MAINTAINERS update
arm64: KVM: userspace API documentation
arm64: KVM: enable initialization of a 32bit vcpu
arm64: KVM: 32bit guest fault injection
arm64: KVM: 32bit specific register world switch
arm64: KVM: CPU specific 32bit coprocessor access
arm64: KVM: 32bit handling of coprocessor traps
arm64: KVM: 32bit conditional execution emulation
arm64: KVM: 32bit GP register access
arm64: KVM: define 32bit specific registers
arm64: KVM: Build system integration
arm64: KVM: PSCI implementation
arm64: KVM: Plug the arch timer
ARM: KVM: timer: allow DT matching for ARMv8 cores
arm64: KVM: Plug the VGIC
arm64: KVM: Exit handling
arm64: KVM: HYP mode world switch implementation
arm64: KVM: hypervisor initialization code
arm64: KVM: guest one-reg interface
arch/arm64/Makefile
Only the Makefile is plugged in. The Kconfig stuff is in a separate
patch to allow for an easier merge process.
Reviewed-by: Christopher Covington <cov@codeaurora.org>
Introduce CONFIG_XEN and the implementation of hypercall.S (that is
the only ARMv8 specific code in Xen support for ARM).
Compile enlighten.c and grant_table.c from arch/arm.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
The arch/arm64/Makefile was not passing the right target to the
boot/dts/Makefile.
Based on Rob Herring's patches for arch/arm, this patch adds a dtbs
target to arch/arm64/boot/Makefile.
The current rules have the .dtb files build in a different directory
from the .dts files. This patch changes arm64 to use the generic dtb
rule which builds .dtb files in the same directory as the source .dts.
This requires moving parts of arch/arm64/boot/Makefile into newly created
arch/arm64/boot/dts/Makefile, and updating arch/arm64/Makefile to call the
new Makefile.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
This patch adds Makefile and Kconfig files required for building an
AArch64 kernel.
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Olof Johansson <olof@lixom.net>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
