commit 1e5e929c009559bd7e898ac8e17a5d01037cb057 upstream.
Commit 34993594181d ("arm64: tegra: Enable HDMI on Jetson TX1")
added a regulator for HDMI on the Jetson TX1 platform. This regulator
has an active high enable, but the GPIO specifier for enabling the
regulator incorrectly defines it as active-low. This causes the
following warning to occur on boot ...
WARNING KERN regulator@10 GPIO handle specifies active low - ignored
The fixed-regulator binding does not use the active-low flag from the
gpio specifier and purely relies of the presence of the
'enable-active-high' property to determine if it is active high or low
(if this property is omitted). Fix this warning by setting the GPIO
to active-high in the GPIO specifier which aligns with the presense of
the 'enable-active-high' property.
Fixes: 34993594181d ("arm64: tegra: Enable HDMI on Jetson TX1")
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Enable the XUSB controller on Jetson TX1. One of the USB 3.0 lanes goes
to an internal ethernet interface, while a second USB 3.0 lane supports
the USB-A receptacle on the I/O board.
Some variants of the Jetson TX1 ship with a 8.0" WUXGA TFT LCD panel
connected via four DSI lanes.
Add power supplies for the SD/MMC card slot. Note that vmmc-supply is
currently restricted to 3.3 V because we don't support switching the
mode yet.
Add a device tree node for the MAX77620 PMIC found on the p2180
processor module (Jetson TX1). Also add supporting power supplies,
such as the main 5 V system supply.
Add a gpio-keys device tree node to represent the Power, Volume Up and
Volume Down keys found on Jetson TX1.
When Tegra124 support was first merged the unit-addresses of all devices
were listed with a "0," prefix to encode the reg property's second cell.
It turns out that this notation is not correct, and the "," separator is
only used to separate fields in the unit address (such as the device and
function number in PCI devices), not individual cells for addresses with
more than one cell.
The NVIDIA P2597 I/O board is a carrier board for the Jetson TX1 module
and together they are also known as the Jetson TX1 Developer Kit. The
I/O board provides an RJ45 connector routed to the network adapter that
is part of the Jetson TX1 module. It exposes many other connectors such
as SATA, USB 3.0, HDMI, JTAG and PCIe, among others, as well. Dedicated
connectors allow display and camera modules to be attached. A full-size
SD slot is provided to extend storage beyond the 32 GiB of eMMC found
on the Jetson TX1 module.
