v4.19.1-rt3
commit 578bdaabd015b9b164842c3e8ace9802f38e7ecc upstream.
These are unused, undesired, and have never actually been used by
anybody. The original authors of this code have changed their mind about
its inclusion. While originally proposed for disk encryption on low-end
devices, the idea was discarded [1] in favor of something else before
that could really get going. Therefore, this patch removes Speck.
[1] https://marc.info/?l=linux-crypto-vger&m=153359499015659
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Acked-by: Eric Biggers <ebiggers@google.com>
Cc: stable@vger.kernel.org
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
NEON in kernel mode is used by the crypto algorithms and raid6 code.
While the raid6 code looks okay, the crypto algorithms do not: NEON
is enabled on first invocation and may allocate/free/map memory before
the NEON mode is disabled again.
This needs to be changed until it can be enabled.
On ARM NEON in kernel mode can be simply disabled. on ARM64 it needs to
stay on due to possible EFI callbacks so here I disable each algorithm.
Cc: stable-rt@vger.kernel.org
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Add support for the SM4 symmetric cipher implemented using the special
SM4 instructions introduced in ARM architecture revision 8.2.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Add a NEON-accelerated implementation of Speck128-XTS and Speck64-XTS
for ARM64. This is ported from the 32-bit version. It may be useful on
devices with 64-bit ARM CPUs that don't have the Cryptography
Extensions, so cannot do AES efficiently -- e.g. the Cortex-A53
processor on the Raspberry Pi 3.
It generally works the same way as the 32-bit version, but there are
some slight differences due to the different instructions, registers,
and syntax available in ARM64 vs. in ARM32. For example, in the 64-bit
version there are enough registers to hold the XTS tweaks for each
128-byte chunk, so they don't need to be saved on the stack.
Benchmarks on a Raspberry Pi 3 running a 64-bit kernel:
Algorithm Encryption Decryption
Speck64/128-XTS (NEON) 92.2 MB/s 92.2 MB/s
Speck128/256-XTS (NEON) 75.0 MB/s 75.0 MB/s
Speck128/256-XTS (generic) 47.4 MB/s 35.6 MB/s
AES-128-XTS (NEON bit-sliced) 33.4 MB/s 29.6 MB/s
AES-256-XTS (NEON bit-sliced) 24.6 MB/s 21.7 MB/s
The code performs well on higher-end ARM64 processors as well, though
such processors tend to have the Crypto Extensions which make AES
preferred. For example, here are the same benchmarks run on a HiKey960
(with CPU affinity set for the A73 cores), with the Crypto Extensions
implementation of AES-256-XTS added:
AES-256-XTS (Crypto Extensions) 1273.3 MB/s 1274.7 MB/s
Speck64/128-XTS (NEON) 359.8 MB/s 348.0 MB/s
Speck128/256-XTS (NEON) 292.5 MB/s 286.1 MB/s
Speck128/256-XTS (generic) 186.3 MB/s 181.8 MB/s
AES-128-XTS (NEON bit-sliced) 142.0 MB/s 124.3 MB/s
AES-256-XTS (NEON bit-sliced) 104.7 MB/s 91.1 MB/s
Implement the Chinese SM3 secure hash algorithm using the new
special instructions that have been introduced as an optional
extension in ARMv8.2.
Tested-by: Steve Capper <steve.capper@arm.com>
Implement the various flavours of SHA3 using the new optional
EOR3/RAX1/XAR/BCAX instructions introduced by ARMv8.2.
Implement the SHA-512 using the new special instructions that have
been introduced as an optional extension in ARMv8.2.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Currently, the AES-GCM implementation for arm64 systems that support the
ARMv8 Crypto Extensions is based on the generic GCM module, which combines
the AES-CTR implementation using AES instructions with the PMULL based
GHASH driver. This is suboptimal, given the fact that the input data needs
to be loaded twice, once for the encryption and again for the MAC
calculation.
On Cortex-A57 (r1p2) and other recent cores that implement micro-op fusing
for the AES instructions, AES executes at less than 1 cycle per byte, which
means that any cycles wasted on loading the data twice hurt even more.
So implement a new GCM driver that combines the AES and PMULL instructions
at the block level. This improves performance on Cortex-A57 by ~37% (from
3.5 cpb to 2.6 cpb)
Of the various chaining modes implemented by the bit sliced AES driver,
only CTR is exposed as a synchronous cipher, and requires a fallback in
order to remain usable once we update the kernel mode NEON handling logic
to disallow nested use. So wire up the existing CTR fallback C code.
To accommodate systems that may disallow use of the NEON in kernel mode
in some circumstances, introduce a C fallback for synchronous AES in CTR
mode, and use it if may_use_simd() returns false.
The arm64 kernel will shortly disallow nested kernel mode NEON.
So honour this in the ARMv8 Crypto Extensions implementation of
CCM-AES, and fall back to a scalar implementation using the generic
crypto helpers for AES, XOR and incrementing the CTR counter.
The arm64 kernel will shortly disallow nested kernel mode NEON, so
add a fallback to scalar code that can be invoked in that case.
add a fallback to scalar C code that can be invoked in that case.
The PMULL based CRC32 implementation already contains code based on the
separate, optional CRC32 instructions to fallback to when operating on
small quantities of data. We can expose these routines directly on systems
that lack the 64x64 PMULL instructions but do implement the CRC32 ones,
which makes the driver that is based solely on those CRC32 instructions
redundant. So remove it.
Note that this aligns arm64 with ARM, whose accelerated CRC32 driver
also combines the CRC32 extension based and the PMULL based versions.
Tested-by: Matthias Brugger <mbrugger@suse.com>
The new bitsliced NEON implementation of AES uses a fallback in two
places: CBC encryption (which is strictly sequential, whereas this
driver can only operate efficiently on 8 blocks at a time), and the
XTS tweak generation, which involves encrypting a single AES block
with a different key schedule.
The plain (i.e., non-bitsliced) NEON code is more suitable as a fallback,
given that it is faster than scalar on low end cores (which is what
the NEON implementations target, since high end cores have dedicated
instructions for AES), and shows similar behavior in terms of D-cache
footprint and sensitivity to cache timing attacks. So switch the fallback
handling to the plain NEON driver.
This is a reimplementation of the NEON version of the bit-sliced AES
algorithm. This code is heavily based on Andy Polyakov's OpenSSL version
for ARM, which is also available in the kernel. This is an alternative for
the existing NEON implementation for arm64 authored by me, which suffers
from poor performance due to its reliance on the pathologically slow four
register variant of the tbl/tbx NEON instruction.
This version is about ~30% (*) faster than the generic C code, but only in
cases where the input can be 8x interleaved (this is a fundamental property
of bit slicing). For this reason, only the chaining modes ECB, XTS and CTR
are implemented. (The significance of ECB is that it could potentially be
used by other chaining modes)
* Measured on Cortex-A57. Note that this is still an order of magnitude
slower than the implementations that use the dedicated AES instructions
introduced in ARMv8, but those are part of an optional extension, and so
it is good to have a fallback.
This adds a scalar implementation of AES, based on the precomputed tables
that are exposed by the generic AES code. Since rotates are cheap on arm64,
this implementation only uses the 4 core tables (of 1 KB each), and avoids
the prerotated ones, reducing the D-cache footprint by 75%.
On Cortex-A57, this code manages 13.0 cycles per byte, which is ~34% faster
than the generic C code. (Note that this is still >13x slower than the code
that uses the optional ARMv8 Crypto Extensions, which manages <1 cycles per
byte.)
This is a straight port to arm64/NEON of the x86 SSE3 implementation
of the ChaCha20 stream cipher. It uses the new skcipher walksize
attribute to process the input in strides of 4x the block size.
This patch reverts the following commits:
8621caa0d45e731f2e9f5889ff5bb384fcd6e059
8096667273477e735b0072b11a6d617ccee45e5f
I should not have applied them because they had already been
obsoleted by a subsequent patch series. They also cause a build
failure because of the subsequent commit 9ae433bc79f9.
Fixes: 9ae433bc79f ("crypto: chacha20 - convert generic and...")
This is a combination of the the Intel algorithm implemented using SSE
and PCLMULQDQ instructions from arch/x86/crypto/crc32-pclmul_asm.S, and
the new CRC32 extensions introduced for both 32-bit and 64-bit ARM in
version 8 of the architecture. Two versions of the above combo are
provided, one for CRC32 and one for CRC32C.
The PMULL/NEON algorithm is faster, but operates on blocks of at least
64 bytes, and on multiples of 16 bytes only. For the remaining input,
or for all input on systems that lack the PMULL 64x64->128 instructions,
the CRC32 instructions will be used.
This is a transliteration of the Intel algorithm implemented
using SSE and PCLMULQDQ instructions that resides in the file
arch/x86/crypto/crct10dif-pcl-asm_64.S, but simplified to only
operate on buffers that are 16 byte aligned (but of any size)
The skcipher conversion for ARM missed the select on CRYPTO_SIMD,
causing build failures if SIMD was not otherwise enabled.
Fixes: da40e7a4ba4d ("crypto: aes-ce - Convert to skcipher")
Fixes: 211f41af534a ("crypto: aesbs - Convert to skcipher")
This integrates both the accelerated scalar and the NEON implementations
of SHA-224/256 as well as SHA-384/512 from the OpenSSL project.
Relative performance compared to the respective generic C versions:
| SHA256-scalar | SHA256-NEON* | SHA512 |
Cortex-A53 | 1.63x | 1.63x | 2.34x |
Cortex-A57 | 1.43x | 1.59x | 1.95x |
Cortex-A73 | 1.26x | 1.56x | ? |
The core crypto code was authored by Andy Polyakov of the OpenSSL
project, in collaboration with whom the upstream code was adapted so
that this module can be built from the same version of sha512-armv8.pl.
The version in this patch was taken from OpenSSL commit 32bbb62ea634
("sha/asm/sha512-armv8.pl: fix big-endian support in __KERNEL__ case.")
* The core SHA algorithm is fundamentally sequential, but there is a
secondary transformation involved, called the schedule update, which
can be performed independently. The NEON version of SHA-224/SHA-256
only implements this part of the algorithm using NEON instructions,
the sequential part is always done using scalar instructions.
Pull crypto update from Herbert Xu:
- The crypto API is now documented :)
- Disallow arbitrary module loading through crypto API.
- Allow get request with empty driver name through crypto_user.
- Allow speed testing of arbitrary hash functions.
- Add caam support for ctr(aes), gcm(aes) and their derivatives.
- nx now supports concurrent hashing properly.
- Add sahara support for SHA1/256.
- Add ARM64 version of CRC32.
- Misc fixes.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (77 commits)
crypto: tcrypt - Allow speed testing of arbitrary hash functions
crypto: af_alg - add user space interface for AEAD
crypto: qat - fix problem with coalescing enable logic
crypto: sahara - add support for SHA1/256
crypto: sahara - replace tasklets with kthread
crypto: sahara - add support for i.MX53
crypto: sahara - fix spinlock initialization
crypto: arm - replace memset by memzero_explicit
crypto: powerpc - replace memset by memzero_explicit
crypto: sha - replace memset by memzero_explicit
crypto: sparc - replace memset by memzero_explicit
crypto: algif_skcipher - initialize upon init request
crypto: algif_skcipher - removed unneeded code
crypto: algif_skcipher - Fixed blocking recvmsg
crypto: drbg - use memzero_explicit() for clearing sensitive data
crypto: drbg - use MODULE_ALIAS_CRYPTO
crypto: include crypto- module prefix in template
crypto: user - add MODULE_ALIAS
crypto: sha-mb - remove a bogus NULL check
crytpo: qat - Fix 64 bytes requests
This module registers a crc32 algorithm and a crc32c algorithm
that use the optional CRC32 and CRC32C instructions in ARMv8.
Tested on AMD Seattle.
Improvement compared to crc32c-generic algorithm:
TCRYPT CRC32C speed test shows ~450% speedup.
Simple dd write tests to btrfs filesystem show ~30% speedup.
Signed-off-by: Yazen Ghannam <yazen.ghannam@linaro.org>
Acked-by: Steve Capper <steve.capper@linaro.org>
This patch implements the AES key schedule generation using ARMv8
Crypto Instructions. It replaces the table based C implementation
in aes_generic.ko, which means we can drop the dependency on that
module.
Tested-by: Steve Capper <steve.capper@linaro.org>
This adds ARMv8 implementations of AES in ECB, CBC, CTR and XTS modes,
both for ARMv8 with Crypto Extensions and for plain ARMv8 NEON.
The Crypto Extensions version can only run on ARMv8 implementations that
have support for these optional extensions.
The plain NEON version is a table based yet time invariant implementation.
All S-box substitutions are performed in parallel, leveraging the wide range
of ARMv8's tbl/tbx instructions, and the huge NEON register file, which can
comfortably hold the entire S-box and still have room to spare for doing the
actual computations.
The key expansion routines were borrowed from aes_generic.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
This patch adds support for the AES-CCM encryption algorithm for CPUs that
have support for the AES part of the ARM v8 Crypto Extensions.
This patch adds support for the AES symmetric encryption algorithm for CPUs
that have support for the AES part of the ARM v8 Crypto Extensions.
This is a port to ARMv8 (Crypto Extensions) of the Intel implementation of the
GHASH Secure Hash (used in the Galois/Counter chaining mode). It relies on the
optional PMULL/PMULL2 instruction (polynomial multiply long, what Intel call
carry-less multiply).
This patch adds support for the SHA-224 and SHA-256 Secure Hash Algorithms
for CPUs that have support for the SHA-2 part of the ARM v8 Crypto Extensions.
This patch adds support for the SHA-1 Secure Hash Algorithm for CPUs that
have support for the SHA-1 part of the ARM v8 Crypto Extensions.
