enable_step_tsk is the only user of disable_dbg, which doesn't respect
our 'dai' order for exception masking. enable_step_tsk may enable
single-step, so previously needed to mask debug exceptions to prevent us
from single-stepping kernel_exit. enable_step_tsk is called at the end
of the ret_to_user loop, which has already masked all exceptions so this
is no longer needed.
Remove disable_dbg, add a comment that enable_step_tsk's caller should
have masked debug.
Signed-off-by: James Morse <james.morse@arm.com>
Reviewed-by: Julien Thierry <julien.thierry@arm.com>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
There are a few places where we want to mask all exceptions. Today we
do this in a piecemeal fashion, typically we expect the caller to
have masked irqs and the arch code masks debug exceptions, ignoring
serror which is probably masked.
Make it clear that 'mask all exceptions' is the intention by adding
helpers to do exactly that.
This will let us unmask SError without having to add 'oh and SError'
to these paths.
Literal values are being used to set single stepping in mdscr from assembly
code. There are already existing defines representing those values, use
those instead of the literal values.
Signed-off-by: Julien Thierry <julien.thierry@arm.com>
Reviewed-by: Alex Bennée <alex.bennee@linaro.org>
Acked-by: Mark Rutland <mark.rutland@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mark/linux into for-next/core
* 'arm64/vmap-stack' of git://git.kernel.org/pub/scm/linux/kernel/git/mark/linux:
arm64: add VMAP_STACK overflow detection
arm64: add on_accessible_stack()
arm64: add basic VMAP_STACK support
arm64: use an irq stack pointer
arm64: assembler: allow adr_this_cpu to use the stack pointer
arm64: factor out entry stack manipulation
efi/arm64: add EFI_KIMG_ALIGN
arm64: move SEGMENT_ALIGN to <asm/memory.h>
arm64: clean up irq stack definitions
arm64: clean up THREAD_* definitions
arm64: factor out PAGE_* and CONT_* definitions
arm64: kernel: remove {THREAD,IRQ_STACK}_START_SP
fork: allow arch-override of VMAP stack alignment
arm64: remove __die()'s stack dump
Given that adr_this_cpu already requires a temp register in addition
to the destination register, tweak the instruction sequence so that sp
may be used as well.
This will simplify switching to per-cpu stacks in subsequent patches. While
this limits the range of adr_this_cpu, to +/-4GiB, we don't currently use
adr_this_cpu in modules, and this is not problematic for the main kernel image.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
[Mark: add more commit text]
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Reviewed-by: Will Deacon <will.deacon@arm.com>
Tested-by: Laura Abbott <labbott@redhat.com>
Cc: James Morse <james.morse@arm.com>
* 'arm64/exception-stack' of git://git.kernel.org/pub/scm/linux/kernel/git/mark/linux:
arm64: unwind: remove sp from struct stackframe
arm64: unwind: reference pt_regs via embedded stack frame
arm64: unwind: disregard frame.sp when validating frame pointer
arm64: unwind: avoid percpu indirection for irq stack
arm64: move non-entry code out of .entry.text
arm64: consistently use bl for C exception entry
arm64: Add ASM_BUG()
Add a clean-to-point-of-persistence cache maintenance helper, and wire
up the basic architectural support for the pmem driver based on it.
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
[catalin.marinas@arm.com: move arch_*_pmem() functions to arch/arm64/mm/flush.c]
[catalin.marinas@arm.com: change dmb(sy) to dmb(osh)]
Currently, cpu_switch_to and ret_from_fork both live in .entry.text,
though neither form the critical path for an exception entry.
In subsequent patches, we will require that code in .entry.text is part
of the critical path for exception entry, for which we can assume
certain properties (e.g. the presence of exception regs on the stack).
Neither cpu_switch_to nor ret_from_fork will meet these requirements, so
we must move them out of .entry.text. To ensure that neither are kprobed
after being moved out of .entry.text, we must explicitly blacklist them,
requiring a new NOKPROBE() asm helper.
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
- Errata workarounds for Qualcomm's Falkor CPU
- Qualcomm L2 Cache PMU driver
- Qualcomm SMCCC firmware quirk
- Support for DEBUG_VIRTUAL
- CPU feature detection for userspace via MRS emulation
- Preliminary work for the Statistical Profiling Extension
- Misc cleanups and non-critical fixes
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (74 commits)
arm64/kprobes: consistently handle MRS/MSR with XZR
arm64: cpufeature: correctly handle MRS to XZR
arm64: traps: correctly handle MRS/MSR with XZR
arm64: ptrace: add XZR-safe regs accessors
arm64: include asm/assembler.h in entry-ftrace.S
arm64: fix warning about swapper_pg_dir overflow
arm64: Work around Falkor erratum 1003
arm64: head.S: Enable EL1 (host) access to SPE when entered at EL2
arm64: arch_timer: document Hisilicon erratum 161010101
arm64: use is_vmalloc_addr
arm64: use linux/sizes.h for constants
arm64: uaccess: consistently check object sizes
perf: add qcom l2 cache perf events driver
arm64: remove wrong CONFIG_PROC_SYSCTL ifdef
ARM: smccc: Update HVC comment to describe new quirk parameter
arm64: do not trace atomic operations
ACPI/IORT: Fix the error return code in iort_add_smmu_platform_device()
ACPI/IORT: Fix iort_node_get_id() mapping entries indexing
arm64: mm: enable CONFIG_HOLES_IN_ZONE for NUMA
perf: xgene: Include module.h
The Qualcomm Datacenter Technologies Falkor v1 CPU may allocate TLB entries
using an incorrect ASID when TTBRx_EL1 is being updated. When the erratum
is triggered, page table entries using the new translation table base
address (BADDR) will be allocated into the TLB using the old ASID. All
circumstances leading to the incorrect ASID being cached in the TLB arise
when software writes TTBRx_EL1[ASID] and TTBRx_EL1[BADDR], a memory
operation is in the process of performing a translation using the specific
TTBRx_EL1 being written, and the memory operation uses a translation table
descriptor designated as non-global. EL2 and EL3 code changing the EL1&0
ASID is not subject to this erratum because hardware is prohibited from
performing translations from an out-of-context translation regime.
Consider the following pseudo code.
write new BADDR and ASID values to TTBRx_EL1
Replacing the above sequence with the one below will ensure that no TLB
entries with an incorrect ASID are used by software.
write reserved value to TTBRx_EL1[ASID]
ISB
write new value to TTBRx_EL1[BADDR]
ISB
write new value to TTBRx_EL1[ASID]
ISB
When the above sequence is used, page table entries using the new BADDR
value may still be incorrectly allocated into the TLB using the reserved
ASID. Yet this will not reduce functionality, since TLB entries incorrectly
tagged with the reserved ASID will never be hit by a later instruction.
Based on work by Shanker Donthineni <shankerd@codeaurora.org>
Signed-off-by: Christopher Covington <cov@codeaurora.org>
When CONFIG_RANDOMIZE_MODULE_REGION_FULL=y, the offset between loaded
modules and the core kernel may exceed 4 GB, putting symbols exported
by the core kernel out of the reach of the ordinary adrp/add instruction
pairs used to generate relative symbol references. So make the adr_l
macro emit a movz/movk sequence instead when executing in module context.
While at it, remove the pointless special case for the stack pointer.
Acked-by: Will Deacon <will.deacon@arm.com>
This patch adds the uaccess macros/functions to disable access to user
space by setting TTBR0_EL1 to a reserved zeroed page. Since the value
written to TTBR0_EL1 must be a physical address, for simplicity this
patch introduces a reserved_ttbr0 page at a constant offset from
swapper_pg_dir. The uaccess_disable code uses the ttbr1_el1 value
adjusted by the reserved_ttbr0 offset.
Enabling access to user is done by restoring TTBR0_EL1 with the value
from the struct thread_info ttbr0 variable. Interrupts must be disabled
during the uaccess_ttbr0_enable code to ensure the atomicity of the
thread_info.ttbr0 read and TTBR0_EL1 write. This patch also moves the
get_thread_info asm macro from entry.S to assembler.h for reuse in the
uaccess_ttbr0_* macros.
Cc: Mark Rutland <mark.rutland@arm.com>
This patch takes the errata workaround code out of cpu_do_switch_mm into
a dedicated post_ttbr0_update_workaround macro which will be reused in a
subsequent patch.
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Shortly we will want to load a percpu variable in the return from
userspace path. We can save an instruction by folding the addition of
the percpu offset into the load instruction, and this patch adds a new
helper to do so.
At the same time, we clean up this_cpu_ptr for consistency. As with
{adr,ldr,str}_l, we change the template to take the destination register
first, and name this dst. Secondly, we rename the macro to adr_this_cpu,
following the scheme of adr_l, and matching the newly added
ldr_this_cpu.
NOP sequences tend to get used for padding out alternative sections
and uarch-specific pipeline flushes in errata workarounds.
This patch adds macros for generating these sequences as both inline
asm blocks, but also as strings suitable for embedding in other asm
blocks directly.
Systems with differing CPU i-cache/d-cache line sizes can cause
problems with the cache management by software when the execution
is migrated from one to another. Usually, the application reads
the cache size on a CPU and then uses that length to perform cache
operations. However, if it gets migrated to another CPU with a smaller
cache line size, things could go completely wrong. To prevent such
cases, always use the smallest cache line size among the CPUs. The
kernel CPU feature infrastructure already keeps track of the safe
value for all CPUID registers including CTR. This patch works around
the problem by :
For kernel, dynamically patch the kernel to read the cache size
from the system wide copy of CTR_EL0.
For applications, trap read accesses to CTR_EL0 (by clearing the SCTLR.UCT)
and emulate the mrs instruction to return the system wide safe value
of CTR_EL0.
For faster access (i.e, avoiding to lookup the system wide value of CTR_EL0
via read_system_reg), we keep track of the pointer to table entry for
CTR_EL0 in the CPU feature infrastructure.
Cc: Andre Przywara <andre.przywara@arm.com>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
On systems with mismatched i/d cache min line sizes, we need to use
the smallest size possible across all CPUs. This will be done by fetching
the system wide safe value from CPU feature infrastructure.
However the some special users(e.g kexec, hibernate) would need the line
size on the CPU (rather than the system wide), when either the system
wide feature may not be accessible or it is guranteed that the caller
executes with a gurantee of no migration.
Provide another helper which will fetch cache line size on the current CPU.
Acked-by: James Morse <james.morse@arm.com>
Reviewed-by: Geoff Levand <geoff@infradead.org>
The newly introduced dcache_by_line_op macro is used at least in
one occassion at the moment to issue a "dc cvau" instruction,
which is affected by ARM errata 819472, 826319, 827319 and 824069.
Change the macro to allow for alternative patching in there to
protect affected Cortex-A53 cores.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
[catalin.marinas@arm.com: indentation fixups]
Kexec and hibernate need to copy pages of memory, but may not have all
of the kernel mapped, and are unable to call copy_page().
Add a simplistic copy_page() macro, that can be inlined in these
situations. lib/copy_page.S provides a bigger better version, but
uses more registers.
Signed-off-by: Geoff Levand <geoff@infradead.org>
[Changed asm label to 9998, added commit message]
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
To allow the assembler macros defined in arch/arm64/mm/proc-macros.S to
be used outside the mm code move the contents of proc-macros.S to
asm/assembler.h. Also, delete proc-macros.S, and fix up all references
to proc-macros.S.
Acked-by: Pavel Machek <pavel@ucw.cz>
[rebased, included dcache_by_line_op]
Implement a macro mov_q that can be used to move an immediate constant
into a 64-bit register, using between 2 and 4 movz/movk instructions
(depending on the operand)
We haven't used the push/pop macros for a while now, as it's typically
better to use immediate offsets for batches of accesses to the stack, as
we now do in the entry assembly for the kernel and hyp code.
Remove the unused macros.
Cc: Marc Zyngier <marc.zyngier@arm.com>
Instead of using absolute addresses for both the exception location
and the fixup, use offsets relative to the exception table entry values.
Not only does this cut the size of the exception table in half, it is
also a prerequisite for KASLR, since absolute exception table entries
are subject to dynamic relocation, which is incompatible with the sorting
of the exception table that occurs at build time.
This patch also introduces the _ASM_EXTABLE preprocessor macro (which
exists on x86 as well) and its _asm_extable assembly counterpart, as
shorthands to emit exception table entries.
Unfortunately, the current way of using the linker to emit build time
constants into the Image header will no longer work once we switch to
the use of PIE executables. The reason is that such constants are emitted
into the binary using R_AARCH64_ABS64 relocations, which are resolved at
runtime, not at build time, and the places targeted by those relocations
will contain zeroes before that.
So refactor the endian swapping linker script constant generation code so
that it emits the upper and lower 32-bit words separately.
irq_stack is a per_cpu variable, that needs to be access from entry.S.
Use an assembler macro instead of the unreadable details.
For more control over which functions are called with the MMU off or
with the UEFI 1:1 mapping active, annotate some assembler routines as
position independent. This is done by introducing ENDPIPROC(), which
replaces the ENDPROC() declaration of those routines.
Nobody seems to be producing !SMP systems anymore, so this is just
becoming a source of kernel bugs, particularly if people want to use
coherent DMA with non-shared pages.
This patch forces CONFIG_SMP=y for arm64, removing a modest amount of
code in the process.
Commit 68234df4ea79 ("arm64: kill flush_cache_all()") removed the
only users of these macros.
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
The adrp instruction is mostly used in combination with either
an add, a ldr or a str instruction with the low bits of the
referenced symbol in the 12-bit immediate of the followup
instruction.
Introduce the macros adr_l, ldr_l and str_l that encapsulate
these common patterns.
Tested-by: Mark Rutland <mark.rutland@arm.com>
asm/assembler.h lacks the usual guard against multiple inclusion,
leading to a compilation failure if it is accidentally included
twice.
Using the classic #ifndef/#define/#endif construct solves the issue.
Since mdscr_el1 is part of the debug register group, it is highly likely
to be trapped by a hypervisor to prevent virtual machines from debugging
(buggering?) each other. Unfortunately, this absolutely destroys our
performance, since we access the register on many of our low-level
fault handling paths to keep track of the various debug state machines.
This patch removes our dependency on mdscr_el1 in the case that debugging
is not being used. More specifically we:
- Use TIF_SINGLESTEP to indicate that a task is stepping at EL0 and
avoid disabling step in the MDSCR when we don't need to.
MDSCR_EL1.SS handling is moved to kernel_entry, when trapping from
userspace.
- Ensure debug exceptions are re-enabled on *all* exception entry
paths, even the debug exception handling path (where we re-enable
exceptions after invoking the handler). Since we can now rely on
MDSCR_EL1.SS being cleared by the entry code, exception handlers can
usually enable debug immediately before enabling interrupts.
- Remove all debug exception unmasking from ret_to_user and
el1_preempt, since we will never get here with debug exceptions
masked.
This results in a slight change to kernel debug behaviour, where we now
step into interrupt handlers and data aborts from EL1 when debugging the
kernel, which is actually a useful thing to do. A side-effect of this is
that it *does* potentially prevent stepping off {break,watch}points when
there is a high-frequency interrupt source (e.g. a timer), so a debugger
would need to use either breakpoints or manually disable interrupts to
get around this issue.
With this patch applied, guest performance is restored under KVM when
debug register accesses are trapped (and we get a measurable performance
increase on the host on Cortex-A57 too).
Cc: Ian Campbell <ian.campbell@citrix.com>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
Add CPU_LE and CPU_BE to select assembler code in little and big
endian configurations respectively.
Signed-off-by: Matthew Leach <matthew.leach@arm.com>
The arm64 port contains wrappers for arm32 syscalls that pass 64-bit
values. These wrappers concatenate the two registers to hold a 64-bit
value in a single X register. On BE, however, the lower and higher
words are swapped.
Create a new assembler macro, regs_to_64, that when on BE systems
swaps the registers in the orr instruction.
When we take an exception at EL1, we only want to enable debug
exceptions if we're not currently stepping, otherwise we can easily get
stuck in a loop stepping into interrupt handlers.
Unfortunately, the current code tests the wrong bit in the mdscr, so fix
that.
This macro is also useful to other bits defining vectors (hypervisor
stub, KVM...).
Move it to a common location.
This patch introduces several assembly macros and definitions used in
the .S files across arch/arm64/ like IRQ disabling/enabling, together
with asm-offsets.c.
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Olof Johansson <olof@lixom.net>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
