commit 94a5d8790e79ab78f499d2d9f1ff2cab63849d9f upstream.
Without including psci.h and arm-smccc.h, we now get a build failure in
some configurations:
arch/arm64/kernel/cpu_errata.c: In function 'arm64_update_smccc_conduit':
arch/arm64/kernel/cpu_errata.c:278:10: error: 'psci_ops' undeclared (first use in this function); did you mean 'sysfs_ops'?
arch/arm64/kernel/cpu_errata.c: In function 'arm64_set_ssbd_mitigation':
arch/arm64/kernel/cpu_errata.c:311:3: error: implicit declaration of function 'arm_smccc_1_1_hvc' [-Werror=implicit-function-declaration]
arm_smccc_1_1_hvc(ARM_SMCCC_ARCH_WORKAROUND_2, state, NULL);
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
commit 314d53d297980676011e6fd83dac60db4a01dc70 upstream.
Track mismatches in the cache type register (CTR_EL0), other
than the D/I min line sizes and trap user accesses if there are any.
Fixes: be68a8aaf925 ("arm64: cpufeature: Fix CTR_EL0 field definitions")
Cc: <stable@vger.kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
commit 4c4a39dd5fe2d13e2d2fa5fceb8ef95d19fc389a upstream.
If there is a mismatch in the I/D min line size, we must
always use the system wide safe value both in applications
and in the kernel, while performing cache operations. However,
we have been checking more bits than just the min line sizes,
which triggers false negatives. We may need to trap the user
accesses in such cases, but not necessarily patch the kernel.
This patch fixes the check to do the right thing as advertised.
A new capability will be added to check mismatches in other
fields and ensure we trap the CTR accesses.
Reported-by: Will Deacon <will.deacon@arm.com>
commit 647d0519b53f440a55df163de21c52a8205431cc upstream.
On a system where firmware can dynamically change the state of the
mitigation, the CPU will always come up with the mitigation enabled,
including when coming back from suspend.
If the user has requested "no mitigation" via a command line option,
let's enforce it by calling into the firmware again to disable it.
Similarily, for a resume from hibernate, the mitigation could have
been disabled by the boot kernel. Let's ensure that it is set
back on in that case.
Acked-by: Will Deacon <will.deacon@arm.com>
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
commit 986372c4367f46b34a3c0f6918d7fb95cbdf39d6 upstream.
In order to avoid checking arm64_ssbd_callback_required on each
kernel entry/exit even if no mitigation is required, let's
add yet another alternative that by default jumps over the mitigation,
and that gets nop'ed out if we're doing dynamic mitigation.
Think of it as a poor man's static key...
Reviewed-by: Julien Grall <julien.grall@arm.com>
commit a43ae4dfe56a01f5b98ba0cb2f784b6a43bafcc6 upstream.
On a system where the firmware implements ARCH_WORKAROUND_2,
it may be useful to either permanently enable or disable the
workaround for cases where the user decides that they'd rather
not get a trap overhead, and keep the mitigation permanently
on or off instead of switching it on exception entry/exit.
In any case, default to the mitigation being enabled.
commit a725e3dda1813ed306734823ac4c65ca04e38500 upstream.
As for Spectre variant-2, we rely on SMCCC 1.1 to provide the
discovery mechanism for detecting the SSBD mitigation.
A new capability is also allocated for that purpose, and a
config option.
Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com>
commit 5cf9ce6e5ea50f805c6188c04ed0daaec7b6887d upstream.
In a heterogeneous system, we can end up with both affected and
unaffected CPUs. Let's check their status before calling into the
firmware.
commit 8e2906245f1e3b0d027169d9f2e55ce0548cb96e upstream.
In order for the kernel to protect itself, let's call the SSBD mitigation
implemented by the higher exception level (either hypervisor or firmware)
on each transition between userspace and kernel.
We must take the PSCI conduit into account in order to target the
right exception level, hence the introduction of a runtime patching
callback.
[ Upstream commit e21da1c992007594d391e7b301779cf30f438691 ]
A recent update to the ARM SMCCC ARCH_WORKAROUND_1 specification
allows firmware to return a non zero, positive value to describe
that although the mitigation is implemented at the higher exception
level, the CPU on which the call is made is not affected.
Let's relax the check on the return value from ARCH_WORKAROUND_1
so that we only error out if the returned value is negative.
Fixes: b092201e0020 ("arm64: Add ARM_SMCCC_ARCH_WORKAROUND_1 BP hardening support")
commit 3a0a397ff5ff8b56ca9f7908b75dee6bf0b5fabb upstream.
Now that we've standardised on SMCCC v1.1 to perform the branch
prediction invalidation, let's drop the previous band-aid.
If vendors haven't updated their firmware to do SMCCC 1.1, they
haven't updated PSCI either, so we don't loose anything.
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport]
Tested-by: Greg Hackmann <ghackmann@google.com>
commit b092201e0020614127f495c092e0a12d26a2116e upstream.
Add the detection and runtime code for ARM_SMCCC_ARCH_WORKAROUND_1.
It is lovely. Really.
commit f3d795d9b360523beca6d13ba64c2c532f601149 upstream.
Use PSCI based mitigation for speculative execution attacks targeting
the branch predictor. We use the same mechanism as the one used for
Cortex-A CPUs, we expect the PSCI version call to have a side effect
of clearing the BTBs.
Signed-off-by: Jayachandran C <jnair@caviumnetworks.com>
commit aa6acde65e03186b5add8151e1ffe36c3c62639b upstream.
Cortex-A57, A72, A73 and A75 are susceptible to branch predictor aliasing
and can theoretically be attacked by malicious code.
This patch implements a PSCI-based mitigation for these CPUs when available.
The call into firmware will invalidate the branch predictor state, preventing
any malicious entries from affecting other victim contexts.
Co-developed-by: Marc Zyngier <marc.zyngier@arm.com>
commit 06f1494f837da8997d670a1ba87add7963b08922 upstream.
Some minor erratum may not be fixed in further revisions of a core,
leading to a situation where the workaround needs to be updated each
time an updated core is released.
Introduce a MIDR_ALL_VERSIONS match helper that will work for all
versions of that MIDR, once and for all.
Acked-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
commit 0f15adbb2861ce6f75ccfc5a92b19eae0ef327d0 upstream.
Aliasing attacks against CPU branch predictors can allow an attacker to
redirect speculative control flow on some CPUs and potentially divulge
information from one context to another.
This patch adds initial skeleton code behind a new Kconfig option to
enable implementation-specific mitigations against these attacks for
CPUs that are affected.
[v4.9: copy bp hardening cb via text mapping]
commit 55b35d070c2534dfb714b883f3c3ae05d02032da upstream.
When a CPU is brought up after we have finalised the system
wide capabilities (i.e, features and errata), we make sure the
new CPU doesn't need a new errata work around which has not been
detected already. However we don't run enable() method on the new
CPU for the errata work arounds already detected. This could
cause the new CPU running without potential work arounds.
It is upto the "enable()" method to decide if this CPU should
do something about the errata.
Fixes: commit 6a6efbb45b7d95c84 ("arm64: Verify CPU errata work arounds on hotplugged CPU")
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Dave Martin <dave.martin@arm.com>
The enable() call for a cpufeature/errata is called using on_each_cpu().
This issues a cross-call IPI to get the work done. Implicitly, this
stashes the running PSTATE in SPSR when the CPU receives the IPI, and
restores it when we return. This means an enable() call can never modify
PSTATE.
To allow PAN to do this, change the on_each_cpu() call to use
stop_machine(). This schedules the work on each CPU which allows
us to modify PSTATE.
This involves changing the protype of all the enable() functions.
enable_cpu_capabilities() is called during boot and enables the feature
on all online CPUs. This path now uses stop_machine(). CPU features for
hotplug'd CPUs are enabled by verify_local_cpu_features() which only
acts on the local CPU, and can already modify the running PSTATE as it
is called from secondary_start_kernel().
Reported-by: Tony Thompson <anthony.thompson@arm.com>
Reported-by: Vladimir Murzin <vladimir.murzin@arm.com>
Signed-off-by: James Morse <james.morse@arm.com>
Cc: Suzuki K Poulose <suzuki.poulose@arm.com>
Systems with differing CPU i-cache/d-cache line sizes can cause
problems with the cache management by software when the execution
is migrated from one to another. Usually, the application reads
the cache size on a CPU and then uses that length to perform cache
operations. However, if it gets migrated to another CPU with a smaller
cache line size, things could go completely wrong. To prevent such
cases, always use the smallest cache line size among the CPUs. The
kernel CPU feature infrastructure already keeps track of the safe
value for all CPUID registers including CTR. This patch works around
the problem by :
For kernel, dynamically patch the kernel to read the cache size
from the system wide copy of CTR_EL0.
For applications, trap read accesses to CTR_EL0 (by clearing the SCTLR.UCT)
and emulate the mrs instruction to return the system wide safe value
of CTR_EL0.
For faster access (i.e, avoiding to lookup the system wide value of CTR_EL0
via read_system_reg), we keep track of the pointer to table entry for
CTR_EL0 in the CPU feature infrastructure.
This is a cosmetic change to rename the functions dealing with
the errata work arounds to be more consistent with their naming.
1) check_local_cpu_errata() => update_cpu_errata_workarounds()
check_local_cpu_errata() actually updates the system's errata work
arounds. So rename it to reflect the same.
2) verify_local_cpu_errata() => verify_local_cpu_errata_workarounds()
Use errata_workarounds instead of _errata.
Acked-by: Andre Przywara <andre.przywara@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Catalin Marinas:
- Kexec support for arm64
- Kprobes support
- Expose MIDR_EL1 and REVIDR_EL1 CPU identification registers to sysfs
- Trapping of user space cache maintenance operations and emulation in
the kernel (CPU errata workaround)
- Clean-up of the early page tables creation (kernel linear mapping,
EFI run-time maps) to avoid splitting larger blocks (e.g. pmds) into
smaller ones (e.g. ptes)
- VDSO support for CLOCK_MONOTONIC_RAW in clock_gettime()
- ARCH_HAS_KCOV enabled for arm64
- Optimise IP checksum helpers
- SWIOTLB optimisation to only allocate/initialise the buffer if the
available RAM is beyond the 32-bit mask
- Properly handle the "nosmp" command line argument
- Fix for the initialisation of the CPU debug state during early boot
- vdso-offsets.h build dependency workaround
- Build fix when RANDOMIZE_BASE is enabled with MODULES off
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (64 commits)
arm64: arm: Fix-up the removal of the arm64 regs_query_register_name() prototype
arm64: Only select ARM64_MODULE_PLTS if MODULES=y
arm64: mm: run pgtable_page_ctor() on non-swapper translation table pages
arm64: mm: make create_mapping_late() non-allocating
arm64: Honor nosmp kernel command line option
arm64: Fix incorrect per-cpu usage for boot CPU
arm64: kprobes: Add KASAN instrumentation around stack accesses
arm64: kprobes: Cleanup jprobe_return
arm64: kprobes: Fix overflow when saving stack
arm64: kprobes: WARN if attempting to step with PSTATE.D=1
arm64: debug: remove unused local_dbg_{enable, disable} macros
arm64: debug: remove redundant spsr manipulation
arm64: debug: unmask PSTATE.D earlier
arm64: localise Image objcopy flags
arm64: ptrace: remove extra define for CPSR's E bit
kprobes: Add arm64 case in kprobe example module
arm64: Add kernel return probes support (kretprobes)
arm64: Add trampoline code for kretprobes
arm64: kprobes instruction simulation support
arm64: Treat all entry code as non-kprobe-able
Cavium erratum 27456 commit 104a0c02e8b1
("arm64: Add workaround for Cavium erratum 27456")
is applicable for thunderx-81xx pass1.0 SoC as well.
Adding code to enable to 81xx.
Signed-off-by: Ganapatrao Kulkarni <gkulkarni@cavium.com>
Reviewed-by: Andrew Pinski <apinski@cavium.com>
The ARM errata 819472, 826319, 827319 and 824069 for affected
Cortex-A53 cores demand to promote "dc cvau" instructions to
"dc civac". Since we allow userspace to also emit those instructions,
we should make sure that "dc cvau" gets promoted there too.
So lets grasp the nettle here and actually trap every userland cache
maintenance instruction once we detect at least one affected core in
the system.
We then emulate the instruction by executing it on behalf of userland,
promoting "dc cvau" to "dc civac" on the way and injecting access
fault back into userspace.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
[catalin.marinas@arm.com: s/set_segfault/arm64_notify_segfault/]
Currently we call the (optional) enable function for CPU _features_
only. As CPU _errata_ descriptions share the same data structure and
having an enable function is useful for errata as well (for instance
to set bits in SCTLR), lets call it when enumerating erratas too.
CPU Errata work arounds are detected and applied to the
kernel code at boot time and the data is then freed up.
If a new hotplugged CPU requires a work around which
was not applied at boot time, there is nothing we can
do but simply fail the booting.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Add scope parameter to the arm64_cpu_capabilities::matches(), so that
this can be reused for checking the capability on a given CPU vs the
system wide. The system uses the default scope associated with the
capability for initialising the CPU_HWCAPs and ELF_HWCAPs.
Cc: James Morse <james.morse@arm.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
On ThunderX T88 pass 1.x through 2.1 parts, broadcast TLBI
instructions may cause the icache to become corrupted if it contains
data for a non-current ASID.
This patch implements the workaround (which invalidates the local
icache when switching the mm) by using code patching.
Signed-off-by: Andrew Pinski <apinski@cavium.com>
Signed-off-by: David Daney <david.daney@cavium.com>
Reviewed-by: Will Deacon <will.deacon@arm.com>
Most CPUs have a hardware prefetcher which generally performs better
without explicit prefetch instructions issued by software, however
some CPUs (e.g. Cavium ThunderX) rely solely on explicit prefetch
instructions.
This patch adds an alternative pattern (ARM64_HAS_NO_HW_PREFETCH) to
allow our library code to make use of explicit prefetch instructions
during things like copy routines only when the CPU does not have the
capability to perform the prefetching itself.
Tested-by: Andrew Pinski <apinski@cavium.com>
Cortex-A57 parts up to r1p2 can misreport Stage 2 translation faults
when a Stage 1 permission fault or device alignment fault should
have been reported.
This patch implements the workaround (which is to validate that the
Stage-1 translation actually succeeds) by using code patching.
Cc: stable@vger.kernel.org
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
- "genirq: Introduce generic irq migration for cpu hotunplugged" patch
merged from tip/irq/for-arm to allow the arm64-specific part to be
upstreamed via the arm64 tree
- CPU feature detection reworked to cope with heterogeneous systems
where CPUs may not have exactly the same features. The features
reported by the kernel via internal data structures or ELF_HWCAP are
delayed until all the CPUs are up (and before user space starts)
- Support for 16KB pages, with the additional bonus of a 36-bit VA
space, though the latter only depending on EXPERT
- Implement native {relaxed, acquire, release} atomics for arm64
- New ASID allocation algorithm which avoids IPI on roll-over, together
with TLB invalidation optimisations (using local vs global where
feasible)
- KASan support for arm64
- EFI_STUB clean-up and isolation for the kernel proper (required by
KASan)
- copy_{to,from,in}_user optimisations (sharing the memcpy template)
- perf: moving arm64 to the arm32/64 shared PMU framework
- L1_CACHE_BYTES increased to 128 to accommodate Cavium hardware
- Support for the contiguous PTE hint on kernel mapping (16 consecutive
entries may be able to use a single TLB entry)
- Generic CONFIG_HZ now used on arm64
- defconfig updates
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (91 commits)
arm64/efi: fix libstub build under CONFIG_MODVERSIONS
ARM64: Enable multi-core scheduler support by default
arm64/efi: move arm64 specific stub C code to libstub
arm64: page-align sections for DEBUG_RODATA
arm64: Fix build with CONFIG_ZONE_DMA=n
arm64: Fix compat register mappings
arm64: Increase the max granular size
arm64: remove bogus TASK_SIZE_64 check
arm64: make Timer Interrupt Frequency selectable
arm64/mm: use PAGE_ALIGNED instead of IS_ALIGNED
arm64: cachetype: fix definitions of ICACHEF_* flags
arm64: cpufeature: declare enable_cpu_capabilities as static
genirq: Make the cpuhotplug migration code less noisy
arm64: Constify hwcap name string arrays
arm64/kvm: Make use of the system wide safe values
arm64/debug: Make use of the system wide safe value
arm64: Move FP/ASIMD hwcap handling to common code
arm64/HWCAP: Use system wide safe values
arm64/capabilities: Make use of system wide safe value
arm64: Delay cpu feature capability checks
check_cpu_capabilities runs through a given list of caps and
checks if the system has the cap, updates the system capability
bitmap and also runs any enable() methods associated with them.
All of this is not quite obvious from the name 'check'. This
patch splits the check_cpu_capabilities into two parts :
1) update_cpu_capabilities
=> Runs through the given list and updates the system
wide capability map.
2) enable_cpu_capabilities
=> Runs through the given list and invokes enable() (if any)
for the caps enabled on the system.
Suggested-by: Catalin Marinas <catalin.marinsa@arm.com>
Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com>
Tested-by: Dave Martin <Dave.Martin@arm.com>
This patch implements Cavium ThunderX erratum 23154.
The gicv3 of ThunderX requires a modified version for reading the IAR
status to ensure data synchronization. Since this is in the fast-path
and called with each interrupt, runtime patching is used using jump
label patching for smallest overhead (no-op). This is the same
technique as used for tracepoints.
Signed-off-by: Robert Richter <rrichter@cavium.com>
Reviewed-by: Marc Zygnier <marc.zyngier@arm.com>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Cc: Tirumalesh Chalamarla <tchalamarla@cavium.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Link: http://lkml.kernel.org/r/1442869119-1814-3-git-send-email-rric@kernel.org
Register MIDR_EL1 is masked to get variant and revision fields, then
compared against midr_range_min and midr_range_max when checking
whether CPU is affected by any particular erratum. However, variant
and revision fields in MIDR_EL1 are separated by 16 bits, so the min
and max of midr range should be constructed accordingly, otherwise
the patch will not be applied when variant field is non-0.
Cc: stable@vger.kernel.org # 3.19+
Reviewed-by: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Bo Yan <byan@nvidia.com>
[will: use MIDR_VARIANT_SHIFT to construct upper bound]
When running a compat (AArch32) userspace on Cortex-A53, a load at EL0
from a virtual address that matches the bottom 32 bits of the virtual
address used by a recent load at (AArch64) EL1 might return incorrect
data.
This patch works around the issue by writing to the contextidr_el1
register on the exception return path when returning to a 32-bit task.
This workaround is patched in at runtime based on the MIDR value of the
processor.
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
As we detect more architectural features at runtime, it makes
sense to reuse the existing framework whilst avoiding to call
a feature an erratum...
This patch extract the core capability parsing, moves it into
a new file (cpufeature.c), and let the CPU errata detection code
use it.
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Consistently use the plural form for alternatives pr_fmt strings.
Not all of the errata we have workarounds for apply necessarily to all
SoCs, so people compiling a kernel for one very specific SoC may not
need to patch the kernel.
Introduce a new submenu in the "Platform selection" menu to allow
people to turn off certain bugs if they are not affected. By default
all of them are enabled.
Normal users or distribution kernels shouldn't bother to deselect any
bugs here, since the alternatives framework will take care of
patching them in only if needed.
[will: moved kconfig menu under `Kernel Features']
The ARM erratum 832075 applies to certain revisions of Cortex-A57,
one of the workarounds is to change device loads into using
load-aquire semantics.
This is achieved using the alternatives framework.
The ARM errata 819472, 826319, 827319 and 824069 define the same
workaround for these hardware issues in certain Cortex-A53 parts.
Use the new alternatives framework and the CPU MIDR detection to
patch "cache clean" into "cache clean and invalidate" instructions if
an affected CPU is detected at runtime.
[will: add __maybe_unused to squash gcc warning]
After each CPU has been started, we iterate through a list of
CPU features or bugs to detect CPUs which need (or could benefit
from) kernel code patches.
For each feature/bug there is a function which checks if that
particular CPU is affected. We will later provide some more generic
functions for common things like testing for certain MIDR ranges.
We do this for every CPU to cover big.LITTLE systems properly as
well.
If a certain feature/bug has been detected, the capability bit will
be set, so that later the call to apply_alternatives() will trigger
the actual code patching.
