path: root/arch/arm64/kernel/psci.c
2014-07-18arm64: kernel: add __init marker to PSCI init functionsLorenzo Pieralisi
PSCI init functions must be marked as __init so that they are freed by the kernel upon boot. This patch marks the PSCI init functions as such since they need not be persistent in the kernel address space after the kernel has booted. Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2014-07-18arm64: kernel: enable PSCI cpu operations on UP systemsLorenzo Pieralisi
PSCI CPU operations have to be enabled on UP kernels so that calls like eg cpu_suspend can be made functional on UP too. This patch reworks the PSCI CPU operations so that they can be enabled on UP systems. Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2014-05-15ARM: Check if a CPU has gone offlineAshwin Chaugule
PSCIv0.2 adds a new function called AFFINITY_INFO, which can be used to query if a specified CPU has actually gone offline. Calling this function via cpu_kill ensures that a CPU has quiesced after a call to cpu_die. This helps prevent the CPU from doing arbitrary bad things when data or instructions are clobbered (as happens with kexec) in the window between a CPU announcing that it is dead and said CPU leaving the kernel. Signed-off-by: Ashwin Chaugule <ashwin.chaugule@linaro.org> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Rob Herring <robh@kernel.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com>
2014-05-15PSCI: Add initial support for PSCIv0.2 functionsAshwin Chaugule
The PSCIv0.2 spec defines standard values of function IDs and introduces a few new functions. Detect version of PSCI and appropriately select the right PSCI functions. Signed-off-by: Ashwin Chaugule <ashwin.chaugule@linaro.org> Reviewed-by: Rob Herring <robh@kernel.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com>
2014-02-28arm64: remove return value form psci_init()Vladimir Murzin
psci_init() is written to return err code if something goes wrong. However, the single user, setup_arch(), doesn't care about it. Moreover, every error path is supplied with a clear message which is enough for pleasant debugging. Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2014-02-28arm64: remove redundant "psci:" prefixesVladimir Murzin
Since 652af899799354049b273af897b798b8f03fdd88 "arm64: factor out spin-table boot method" psci prefix's been introduced. We have a common pr_fmt, so clean them up. Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com> Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-10-25arm64: add PSCI CPU_OFF-based hotplug supportMark Rutland
This patch adds support for using PSCI CPU_OFF calls for CPU hotplug. With this code it is possible to hot unplug CPUs with "psci" as their boot-method, as long as there's an appropriate cpu_off function id specified in the psci node. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-10-25arm64: factor out spin-table boot methodMark Rutland
The arm64 kernel has an internal holding pen, which is necessary for some systems where we can't bring CPUs online individually and must hold multiple CPUs in a safe area until the kernel is able to handle them. The current SMP infrastructure for arm64 is closely coupled to this holding pen, and alternative boot methods must launch CPUs into the pen, where they sit before they are launched into the kernel proper. With PSCI (and possibly other future boot methods), we can bring CPUs online individually, and need not perform the secondary_holding_pen dance. Instead, this patch factors the holding pen management code out to the spin-table boot method code, as it is the only boot method requiring the pen. A new entry point for secondaries, secondary_entry is added for other boot methods to use, which bypasses the holding pen and its associated overhead when bringing CPUs online. The smp.pen.text section is also removed, as the pen can live in head.text without problem. The cpu_operations structure is extended with two new functions, cpu_boot and cpu_postboot, for bringing a cpu into the kernel and performing any post-boot cleanup required by a bootmethod (e.g. resetting the secondary_holding_pen_release to INVALID_HWID). Documentation is added for cpu_operations. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-10-25arm64: reorganise smp_enable_opsMark Rutland
For hotplug support, we're going to want a place to store operations that do more than bring CPUs online, and it makes sense to group these with our current smp_enable_ops. For cpuidle support, we'll want to group additional functions, and we may want them even for UP kernels. This patch renames smp_enable_ops to the more general cpu_operations, and pulls the definitions out of smp code such that they can be used in UP kernels. While we're at it, fix up instances of the cpu parameter to be an unsigned int, drop the init markings and rename the *_cpu functions to cpu_* to reduce future churn when cpu_operations is extended. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-10-25arm64: unify smp_psci.c and psci.cMark Rutland
The functions in psci.c are only used from smp_psci.c, and smp_psci cannot function without psci.c. Additionally psci.c is built when !SMP, where it's expected that cpu_suspend may be useful. This patch unifies the two files, removing pointless duplication and paving the way for PSCI support in UP systems. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2013-01-29arm64: psci: add support for PSCI invocations from the kernelWill Deacon
This patch adds support for the Power State Coordination Interface defined by ARM, allowing Linux to request CPU-centric power-management operations from firmware implementing the PSCI protocol. Signed-off-by: Will Deacon <will.deacon@arm.com> [Marc: s/u32/u64/ in the relevant spots, and switch from an initcall to an simpler init function] Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
