commit d0bab0c39e32d39a8c5cddca72e5b4a3059fe050 upstream.
On a system with only one CPU online, when another one CPU panics while
starting-up, smp_send_stop() will fail to send any STOP message to the
other already online core, resulting in a system still responsive and
alive at the end of the panic procedure.
[ 186.700083] CPU3: shutdown
[ 187.075462] CPU2: shutdown
[ 187.162869] CPU1: shutdown
[ 188.689998] ------------[ cut here ]------------
[ 188.691645] kernel BUG at arch/arm64/kernel/cpufeature.c:886!
[ 188.692079] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 188.692444] Modules linked in:
[ 188.693031] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 5.6.0-rc4-00001-g338d25c35a98 #104
[ 188.693175] Hardware name: Foundation-v8A (DT)
[ 188.693492] pstate: 200001c5 (nzCv dAIF -PAN -UAO)
[ 188.694183] pc : has_cpuid_feature+0xf0/0x348
[ 188.694311] lr : verify_local_elf_hwcaps+0x84/0xe8
[ 188.694410] sp : ffff800011b1bf60
[ 188.694536] x29: ffff800011b1bf60 x28: 0000000000000000
[ 188.694707] x27: 0000000000000000 x26: 0000000000000000
[ 188.694801] x25: 0000000000000000 x24: ffff80001189a25c
[ 188.694905] x23: 0000000000000000 x22: 0000000000000000
[ 188.694996] x21: ffff8000114aa018 x20: ffff800011156a38
[ 188.695089] x19: ffff800010c944a0 x18: 0000000000000004
[ 188.695187] x17: 0000000000000000 x16: 0000000000000000
[ 188.695280] x15: 0000249dbde5431e x14: 0262cbe497efa1fa
[ 188.695371] x13: 0000000000000002 x12: 0000000000002592
[ 188.695472] x11: 0000000000000080 x10: 00400032b5503510
[ 188.695572] x9 : 0000000000000000 x8 : ffff800010c80204
[ 188.695659] x7 : 00000000410fd0f0 x6 : 0000000000000001
[ 188.695750] x5 : 00000000410fd0f0 x4 : 0000000000000000
[ 188.695836] x3 : 0000000000000000 x2 : ffff8000100939d8
[ 188.695919] x1 : 0000000000180420 x0 : 0000000000180480
[ 188.696253] Call trace:
[ 188.696410] has_cpuid_feature+0xf0/0x348
[ 188.696504] verify_local_elf_hwcaps+0x84/0xe8
[ 188.696591] check_local_cpu_capabilities+0x44/0x128
[ 188.696666] secondary_start_kernel+0xf4/0x188
[ 188.697150] Code: 52805001 72a00301 6b01001f 54000ec0 (d4210000)
[ 188.698639] ---[ end trace 3f12ca47652f7b72 ]---
[ 188.699160] Kernel panic - not syncing: Attempted to kill the idle task!
[ 188.699546] Kernel Offset: disabled
[ 188.699828] CPU features: 0x00004,20c02008
[ 188.700012] Memory Limit: none
[ 188.700538] ---[ end Kernel panic - not syncing: Attempted to kill the idle task! ]---
[root@arch ~]# echo Helo
Helo
[root@arch ~]# cat /proc/cpuinfo | grep proce
processor : 0
Make smp_send_stop() account also for the online status of the calling CPU
while evaluating how many CPUs are effectively online: this way, the right
number of STOPs is sent, so enforcing a proper freeze of the system at the
end of panic even under the above conditions.
Fixes: 08e875c16a16c ("arm64: SMP support")
Reported-by: Dave Martin <Dave.Martin@arm.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Cristian Marussi <cristian.marussi@arm.com>
Signed-off-by: Will Deacon <will@kernel.org>
[ Upstream commit f357b3a7e17af7736d67d8267edc1ed3d1dd9391 ]
The __cpu_up() routine ignores the errors reported by the firmware
for a CPU bringup operation and looks for the error status set by the
booting CPU. If the CPU never entered the kernel, we could end up
in assuming stale error status, which otherwise would have been
set/cleared appropriately by the booting CPU.
Reported-by: Steve Capper <steve.capper@arm.com>
Signed-off-by: Suzuki K Poulose <suzuki.poulose@arm.com>
[ Upstream commit a96a33b1ca57dbea4285893dedf290aeb8eb090b ]
For cases where there is a mismatch in ARMv8.2-LVA support between CPUs
we have to be careful in allowing secondary CPUs to boot if 52-bit
virtual addresses have already been enabled on the boot CPU.
This patch adds code to the secondary startup path. If the boot CPU has
enabled 52-bit VAs then ID_AA64MMFR2_EL1 is checked to see if the
secondary can also enable 52-bit support. If not, the secondary is
prevented from booting and an error message is displayed indicating why.
Technically this patch could be implemented using the cpufeature code
when considering 52-bit userspace support. However, we employ low level
checks here as the cpufeature code won't be able to run if we have
mismatched 52-bit kernel va support.
Signed-off-by: Steve Capper <steve.capper@arm.com>
[ Upstream commit b154886f7892499d0d3054026e19dfb9a731df61 ]
We can't call function trace hook before setup percpu offset.
When entering secondary_start_kernel(), percpu offset has not
been initialized. So this lead hotplug malfunction.
Here is the flow to reproduce this bug:
echo 0 > /sys/devices/system/cpu/cpu1/online
echo function > /sys/kernel/debug/tracing/current_tracer
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 1 > /sys/devices/system/cpu/cpu1/online
Tested-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Signed-off-by: Zhizhou Zhang <zhizhouzhang@asrmicro.com>
commit 335d2c2d192266358c5dfa64953a4c162f46e464 upstream.
Commit 5c492c3f5255 ("arm64: smp: Add function to determine if cpus are
stuck in the kernel") added a helper function to determine if die() is
supported in cpu_ops. This function assumes a cpu will have a valid
cpu_ops entry, but that may not be the case for cpu0 is spin-table or
parking protocol is used to boot secondary cpus. In that case, there
is a NULL dereference if have_cpu_die() is called by cpu0. So add a
check for a valid cpu_ops before dereferencing it.
Fixes: 5c492c3f5255 ("arm64: smp: Add function to determine if cpus are stuck in the kernel")
Signed-off-by: Mark Salter <msalter@redhat.com>
Commit 7ba5f605f3a0 ("arm64/numa: remove the limitation that cpu0 must
bind to node0") removed the numa cpu<->node mapping restriction whereby
logical cpu 0 always corresponds to numa node 0; removing the
restriction was correct, in that it does not really exist in practice
but the commit only updated the early mapping of logical cpu 0 to its
real numa node for the DT boot path, missing the ACPI one, leading to
boot failures on ACPI systems owing to missing node<->cpu map for
logical cpu 0.
Fix the issue by updating the ACPI boot path with code that carries out
the early cpu<->node mapping also for the boot cpu (ie cpu 0), mirroring
what is currently done in the DT boot path.
Fixes: 7ba5f605f3a0 ("arm64/numa: remove the limitation that cpu0 must bind to node0")
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Tested-by: Laszlo Ersek <lersek@redhat.com>
Reported-by: Laszlo Ersek <lersek@redhat.com>
Cc: Laszlo Ersek <lersek@redhat.com>
Cc: Hanjun Guo <hanjun.guo@linaro.org>
Cc: Andrew Jones <drjones@redhat.com>
Cc: Zhen Lei <thunder.leizhen@huawei.com>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
"It's a bit all over the place this time with no "killer feature" to
speak of. Support for mismatched cache line sizes should help people
seeing whacky JIT failures on some SoCs, and the big.LITTLE perf
updates have been a long time coming, but a lot of the changes here
are cleanups.
We stray outside arch/arm64 in a few areas: the arch/arm/ arch_timer
workaround is acked by Russell, the DT/OF bits are acked by Rob, the
arch_timer clocksource changes acked by Marc, CPU hotplug by tglx and
jump_label by Peter (all CC'd).
Summary:
- Support for execute-only page permissions
- Support for hibernate and DEBUG_PAGEALLOC
- Support for heterogeneous systems with mismatches cache line sizes
- Errata workarounds (A53 843419 update and QorIQ A-008585 timer bug)
- arm64 PMU perf updates, including cpumasks for heterogeneous systems
- Set UTS_MACHINE for building rpm packages
- Yet another head.S tidy-up
- Some cleanups and refactoring, particularly in the NUMA code
- Lots of random, non-critical fixes across the board"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (100 commits)
arm64: tlbflush.h: add __tlbi() macro
arm64: Kconfig: remove SMP dependence for NUMA
arm64: Kconfig: select OF/ACPI_NUMA under NUMA config
arm64: fix dump_backtrace/unwind_frame with NULL tsk
arm/arm64: arch_timer: Use archdata to indicate vdso suitability
arm64: arch_timer: Work around QorIQ Erratum A-008585
arm64: arch_timer: Add device tree binding for A-008585 erratum
arm64: Correctly bounds check virt_addr_valid
arm64: migrate exception table users off module.h and onto extable.h
arm64: pmu: Hoist pmu platform device name
arm64: pmu: Probe default hw/cache counters
arm64: pmu: add fallback probe table
MAINTAINERS: Update ARM PMU PROFILING AND DEBUGGING entry
arm64: Improve kprobes test for atomic sequence
arm64/kvm: use alternative auto-nop
arm64: use alternative auto-nop
arm64: alternative: add auto-nop infrastructure
arm64: lse: convert lse alternatives NOP padding to use __nops
arm64: barriers: introduce nops and __nops macros for NOP sequences
arm64: sysreg: replace open-coded mrs_s/msr_s with {read,write}_sysreg_s
The wq_numa_init() function makes a private CPU to node map by calling
cpu_to_node() early in the boot process, before the non-boot CPUs are
brought online. Since the default implementation of cpu_to_node()
returns zero for CPUs that have never been brought online, the
workqueue system's view is that *all* CPUs are on node zero.
When the unbound workqueue for a non-zero node is created, the
tsk_cpus_allowed() for the worker threads is the empty set because
there are, in the view of the workqueue system, no CPUs on non-zero
nodes. The code in try_to_wake_up() using this empty cpumask ends up
using the cpumask empty set value of NR_CPUS as an index into the
per-CPU area pointer array, and gets garbage as it is one past the end
of the array. This results in:
[ 0.881970] Unable to handle kernel paging request at virtual address fffffb1008b926a4
[ 1.970095] pgd = fffffc00094b0000
[ 1.973530] [fffffb1008b926a4] *pgd=0000000000000000, *pud=0000000000000000, *pmd=0000000000000000
[ 1.982610] Internal error: Oops: 96000004 [#1] SMP
[ 1.987541] Modules linked in:
[ 1.990631] CPU: 48 PID: 295 Comm: cpuhp/48 Tainted: G W 4.8.0-rc6-preempt-vol+ #9
[ 1.999435] Hardware name: Cavium ThunderX CN88XX board (DT)
[ 2.005159] task: fffffe0fe89cc300 task.stack: fffffe0fe8b8c000
[ 2.011158] PC is at try_to_wake_up+0x194/0x34c
[ 2.015737] LR is at try_to_wake_up+0x150/0x34c
[ 2.020318] pc : [<fffffc00080e7468>] lr : [<fffffc00080e7424>] pstate: 600000c5
[ 2.027803] sp : fffffe0fe8b8fb10
[ 2.031149] x29: fffffe0fe8b8fb10 x28: 0000000000000000
[ 2.036522] x27: fffffc0008c63bc8 x26: 0000000000001000
[ 2.041896] x25: fffffc0008c63c80 x24: fffffc0008bfb200
[ 2.047270] x23: 00000000000000c0 x22: 0000000000000004
[ 2.052642] x21: fffffe0fe89d25bc x20: 0000000000001000
[ 2.058014] x19: fffffe0fe89d1d00 x18: 0000000000000000
[ 2.063386] x17: 0000000000000000 x16: 0000000000000000
[ 2.068760] x15: 0000000000000018 x14: 0000000000000000
[ 2.074133] x13: 0000000000000000 x12: 0000000000000000
[ 2.079505] x11: 0000000000000000 x10: 0000000000000000
[ 2.084879] x9 : 0000000000000000 x8 : 0000000000000000
[ 2.090251] x7 : 0000000000000040 x6 : 0000000000000000
[ 2.095621] x5 : ffffffffffffffff x4 : 0000000000000000
[ 2.100991] x3 : 0000000000000000 x2 : 0000000000000000
[ 2.106364] x1 : fffffc0008be4c24 x0 : ffffff0ffffada80
[ 2.111737]
[ 2.113236] Process cpuhp/48 (pid: 295, stack limit = 0xfffffe0fe8b8c020)
[ 2.120102] Stack: (0xfffffe0fe8b8fb10 to 0xfffffe0fe8b90000)
[ 2.125914] fb00: fffffe0fe8b8fb80 fffffc00080e7648
[ 2.442859] Call trace:
[ 2.445327] Exception stack(0xfffffe0fe8b8f940 to 0xfffffe0fe8b8fa70)
[ 2.451843] f940: fffffe0fe89d1d00 0000040000000000 fffffe0fe8b8fb10 fffffc00080e7468
[ 2.459767] f960: fffffe0fe8b8f980 fffffc00080e4958 ffffff0ff91ab200 fffffc00080e4b64
[ 2.467690] f980: fffffe0fe8b8f9d0 fffffc00080e515c fffffe0fe8b8fa80 0000000000000000
[ 2.475614] f9a0: fffffe0fe8b8f9d0 fffffc00080e58e4 fffffe0fe8b8fa80 0000000000000000
[ 2.483540] f9c0: fffffe0fe8d10000 0000000000000040 fffffe0fe8b8fa50 fffffc00080e5ac4
[ 2.491465] f9e0: ffffff0ffffada80 fffffc0008be4c24 0000000000000000 0000000000000000
[ 2.499387] fa00: 0000000000000000 ffffffffffffffff 0000000000000000 0000000000000040
[ 2.507309] fa20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 2.515233] fa40: 0000000000000000 0000000000000000 0000000000000000 0000000000000018
[ 2.523156] fa60: 0000000000000000 0000000000000000
[ 2.528089] [<fffffc00080e7468>] try_to_wake_up+0x194/0x34c
[ 2.533723] [<fffffc00080e7648>] wake_up_process+0x28/0x34
[ 2.539275] [<fffffc00080d3764>] create_worker+0x110/0x19c
[ 2.544824] [<fffffc00080d69dc>] alloc_unbound_pwq+0x3cc/0x4b0
[ 2.550724] [<fffffc00080d6bcc>] wq_update_unbound_numa+0x10c/0x1e4
[ 2.557066] [<fffffc00080d7d78>] workqueue_online_cpu+0x220/0x28c
[ 2.563234] [<fffffc00080bd288>] cpuhp_invoke_callback+0x6c/0x168
[ 2.569398] [<fffffc00080bdf74>] cpuhp_up_callbacks+0x44/0xe4
[ 2.575210] [<fffffc00080be194>] cpuhp_thread_fun+0x13c/0x148
[ 2.581027] [<fffffc00080dfbac>] smpboot_thread_fn+0x19c/0x1a8
[ 2.586929] [<fffffc00080dbd64>] kthread+0xdc/0xf0
[ 2.591776] [<fffffc0008083380>] ret_from_fork+0x10/0x50
[ 2.597147] Code: b00057e1 91304021 91005021 b8626822 (b8606821)
[ 2.603464] ---[ end trace 58c0cd36b88802bc ]---
[ 2.608138] Kernel panic - not syncing: Fatal exception
Fix by moving call to numa_store_cpu_info() for all CPUs into
smp_prepare_cpus(), which happens before wq_numa_init(). Since
smp_store_cpu_info() now contains only a single function call,
simplify by removing the function and out-lining its contents.
Suggested-by: Robert Richter <rric@kernel.org>
Fixes: 1a2db300348b ("arm64, numa: Add NUMA support for arm64 platforms.")
Cc: <stable@vger.kernel.org> # 4.7.x-
Signed-off-by: David Daney <david.daney@cavium.com>
Reviewed-by: Robert Richter <rrichter@cavium.com>
Tested-by: Yisheng Xie <xieyisheng1@huawei.com>
Right now we run through the work around checks on a CPU
from __cpuinfo_store_cpu. There are some problems with that:
1) We initialise the system wide CPU feature registers only after the
Boot CPU updates its cpuinfo. Now, if a work around depends on the
variance of a CPU ID feature (e.g, check for Cache Line size mismatch),
we have no way of performing it cleanly for the boot CPU.
2) It is out of place, invoked from __cpuinfo_store_cpu() in cpuinfo.c. It
is not an obvious place for that.
This patch rearranges the CPU specific capability(aka work around) checks.
1) At the moment we use verify_local_cpu_capabilities() to check if a new
CPU has all the system advertised features. Use this for the secondary CPUs
to perform the work around check. For that we rename
verify_local_cpu_capabilities() => check_local_cpu_capabilities()
which:
If the system wide capabilities haven't been initialised (i.e, the CPU
is activated at the boot), update the system wide detected work arounds.
Otherwise (i.e a CPU hotplugged in later) verify that this CPU conforms to the
system wide capabilities.
2) Boot CPU updates the work arounds from smp_prepare_boot_cpu() after we have
initialised the system wide CPU feature values.
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Andre Przywara <andre.przywara@arm.com>
1. Remove the old binding code.
2. Read the nid of cpu0 from dts.
3. Fallback the nid of cpu0 to 0 when numa=off is set in bootargs.
Signed-off-by: Zhen Lei <thunder.leizhen@huawei.com>
This patch adds static keys transparently for all the cpu_hwcaps
features by implementing an array of default-false static keys and
enabling them when detected. The cpus_have_cap() check uses the static
keys if the feature being checked is a constant, otherwise the compiler
generates the bitmap test.
Because of the early call to static_branch_enable() via
check_local_cpu_errata() -> update_cpu_capabilities(), the jump labels
are initialised in cpuinfo_store_boot_cpu().
Cc: Suzuki K. Poulose <Suzuki.Poulose@arm.com>
Enable the hard limit of cpu count by set boot options nr_cpus=x
on arm64, and make a minor change about message when total number
of cpu exceeds the limit.
Reviewed-by: Suzuki K Poulose <suzuki.poulose@arm.com>
Reported-by: Shiyuan Hu <hushiyuan@huawei.com>
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Pull arm64 updates from Catalin Marinas:
- Kexec support for arm64
- Kprobes support
- Expose MIDR_EL1 and REVIDR_EL1 CPU identification registers to sysfs
- Trapping of user space cache maintenance operations and emulation in
the kernel (CPU errata workaround)
- Clean-up of the early page tables creation (kernel linear mapping,
EFI run-time maps) to avoid splitting larger blocks (e.g. pmds) into
smaller ones (e.g. ptes)
- VDSO support for CLOCK_MONOTONIC_RAW in clock_gettime()
- ARCH_HAS_KCOV enabled for arm64
- Optimise IP checksum helpers
- SWIOTLB optimisation to only allocate/initialise the buffer if the
available RAM is beyond the 32-bit mask
- Properly handle the "nosmp" command line argument
- Fix for the initialisation of the CPU debug state during early boot
- vdso-offsets.h build dependency workaround
- Build fix when RANDOMIZE_BASE is enabled with MODULES off
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (64 commits)
arm64: arm: Fix-up the removal of the arm64 regs_query_register_name() prototype
arm64: Only select ARM64_MODULE_PLTS if MODULES=y
arm64: mm: run pgtable_page_ctor() on non-swapper translation table pages
arm64: mm: make create_mapping_late() non-allocating
arm64: Honor nosmp kernel command line option
arm64: Fix incorrect per-cpu usage for boot CPU
arm64: kprobes: Add KASAN instrumentation around stack accesses
arm64: kprobes: Cleanup jprobe_return
arm64: kprobes: Fix overflow when saving stack
arm64: kprobes: WARN if attempting to step with PSTATE.D=1
arm64: debug: remove unused local_dbg_{enable, disable} macros
arm64: debug: remove redundant spsr manipulation
arm64: debug: unmask PSTATE.D earlier
arm64: localise Image objcopy flags
arm64: ptrace: remove extra define for CPSR's E bit
kprobes: Add arm64 case in kprobe example module
arm64: Add kernel return probes support (kretprobes)
arm64: Add trampoline code for kretprobes
arm64: kprobes instruction simulation support
arm64: Treat all entry code as non-kprobe-able
* acpi-numa:
ACPI / NUMA: Enable ACPI based NUMA on ARM64
arm64, ACPI, NUMA: NUMA support based on SRAT and SLIT
ACPI / processor: Add acpi_map_madt_entry()
ACPI / NUMA: Improve SRAT error detection and add messages
ACPI / NUMA: Move acpi_numa_memory_affinity_init() to drivers/acpi/numa.c
ACPI / NUMA: remove unneeded acpi_numa=1
ACPI / NUMA: move bad_srat() and srat_disabled() to drivers/acpi/numa.c
x86 / ACPI / NUMA: cleanup acpi_numa_processor_affinity_init()
arm64, NUMA: Cleanup NUMA disabled messages
arm64, NUMA: rework numa_add_memblk()
ACPI / NUMA: move acpi_numa_slit_init() to drivers/acpi/numa.c
ACPI / NUMA: Move acpi_numa_arch_fixup() to ia64 only
ACPI / NUMA: remove duplicate NULL check
ACPI / NUMA: Replace ACPI_DEBUG_PRINT() with pr_debug()
ACPI / NUMA: Use pr_fmt() instead of printk
Passing "nosmp" should boot the kernel with a single processor, without
provision to enable secondary CPUs even if they are present. "nosmp" is
implemented by setting maxcpus=0. At the moment we still mark the secondary
CPUs present even with nosmp, which allows the userspace to bring them
up. This patch corrects the smp_prepare_cpus() to honor the maxcpus == 0.
Commit 44dbcc93ab67145 ("arm64: Fix behavior of maxcpus=N") fixed the
behavior for maxcpus >= 1, but broke maxcpus = 0.
Fixes: 44dbcc93ab67 ("arm64: Fix behavior of maxcpus=N")
Cc: <stable@vger.kernel.org> # 4.7+
Cc: James Morse <james.morse@arm.com>
[catalin.marinas@arm.com: updated code comment]
In smp_prepare_boot_cpu(), we invoke cpuinfo_store_boot_cpu to store
the cpuinfo in a per-cpu ptr, before initialising the per-cpu offset for
the boot CPU. This patch reorders the sequence to make sure we initialise
the per-cpu offset before accessing the per-cpu area.
Commit 4b998ff1885eec ("arm64: Delay cpuinfo_store_boot_cpu") fixed the
issue where we modified the per-cpu area even before the kernel initialises
the per-cpu areas, but failed to wait until the boot cpu updated it's
offset.
Fixes: 4b998ff1885e ("arm64: Delay cpuinfo_store_boot_cpu")
Cc: <stable@vger.kernel.org> # 4.4+
Clearing PSTATE.D is one of the requirements for generating a debug
exception. The arm64 booting protocol requires that PSTATE.D is set,
since many of the debug registers (for example, the hw_breakpoint
registers) are UNKNOWN out of reset and could potentially generate
spurious, fatal debug exceptions in early boot code if PSTATE.D was
clear. Once the debug registers have been safely initialised, PSTATE.D
is cleared, however this is currently broken for two reasons:
(1) The boot CPU clears PSTATE.D in a postcore_initcall and secondary
CPUs clear PSTATE.D in secondary_start_kernel. Since the initcall
runs after SMP (and the scheduler) have been initialised, there is
no guarantee that it is actually running on the boot CPU. In this
case, the boot CPU is left with PSTATE.D set and is not capable of
generating debug exceptions.
(2) In a preemptible kernel, we may explicitly schedule on the IRQ
return path to EL1. If an IRQ occurs with PSTATE.D set in the idle
thread, then we may schedule the kthread_init thread, run the
postcore_initcall to clear PSTATE.D and then context switch back
to the idle thread before returning from the IRQ. The exception
return path will then restore PSTATE.D from the stack, and set it
again.
This patch fixes the problem by moving the clearing of PSTATE.D earlier
to proc.S. This has the desirable effect of clearing it in one place for
all CPUs, long before we have to worry about the scheduler or any
exception handling. We ensure that the previous reset of MDSCR_EL1 has
completed before unmasking the exception, so that any spurious
exceptions resulting from UNKNOWN debug registers are not generated.
Without this patch applied, the kprobes selftests have been seen to fail
under KVM, where we end up attempting to step the OOL instruction buffer
with PSTATE.D set and therefore fail to complete the step.
Reported-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Catalin Marinas <catalin.marinas@arm.com>
kernel/smp.c has a fancy counter that keeps track of the number of CPUs
it marked as not-present and left in cpu_park_loop(). If there are any
CPUs spinning in here, features like kexec or hibernate may release them
by overwriting this memory.
This problem also occurs on machines using spin-tables to release
secondary cores.
After commit 44dbcc93ab67 ("arm64: Fix behavior of maxcpus=N")
we bring all known cpus into the secondary holding pen, meaning this
memory can't be re-used by kexec or hibernate.
Add a function cpus_are_stuck_in_kernel() to determine if either of these
cases have occurred.
Signed-off-by: James Morse <james.morse@arm.com>
[catalin.marinas@arm.com: cherry-picked from mainline for kexec dependency]
secondary cores.
Introduce a new file to hold ACPI based NUMA information parsing from
SRAT and SLIT.
SRAT includes the CPU ACPI ID to Proximity Domain mappings and memory
ranges to Proximity Domain mapping. SLIT has the information of inter
node distances(relative number for access latency).
Signed-off-by: Hanjun Guo <hanjun.guo@linaro.org>
Signed-off-by: Ganapatrao Kulkarni <gkulkarni@caviumnetworks.com>
[rrichter@cavium.com Reworked for numa v10 series ]
Signed-off-by: Robert Richter <rrichter@cavium.com>
[david.daney@cavium.com reorderd and combinded with other patches in
Hanjun Guo's original set, removed get_mpidr_in_madt() and use
acpi_map_madt_entry() instead.]
Tested-by: Dennis Chen <dennis.chen@arm.com>
Remove the unnecessary smp_wmb(), which was added to make sure
that the update_cpu_boot_status() completes before we mark the
CPU online. But update_cpu_boot_status() already has dsb() (required
for the failing CPUs) to ensure the correct behavior.
Reported-by: Dennis Chen <dennis.chen@arm.com>
maxcpu=n sets the number of CPUs activated at boot time to a max of n,
but allowing the remaining CPUs to be brought up later if the user
decides to do so. However, on arm64 due to various reasons, we disallowed
hotplugging CPUs beyond n, by marking them not present. Now that
we have checks in place to make sure the hotplugged CPUs have compatible
features with system and requires no new errata, relax the restriction.
When CPUs are stopped during an abnormal operation like panic
for each CPU a line is printed and the stack trace is dumped.
This information is only interesting for the aborting CPU
and on systems with many CPUs it only makes it harder to
debug if after the aborting CPU the log is flooded with data
about all other CPUs too.
Therefore remove the stack dump and printk of other CPUs
and only print a single line that the other CPUs are going to be
stopped and, in case any CPUs remain online list them.
Signed-off-by: Jan Glauber <jglauber@cavium.com>
Attempt to get the memory and CPU NUMA node via of_numa. If that
fails, default the dummy NUMA node and map all memory and CPUs to node
0.
Tested-by: Shannon Zhao <shannon.zhao@linaro.org>
With a VHE capable CPU, kernel can run at EL2 and is a decided at early
boot. If some of the CPUs didn't start it EL2 or doesn't have VHE, we
could have CPUs running at different exception levels, all in the same
kernel! This patch adds an early check for the secondary CPUs to detect
such situations.
For each non-boot CPU add a sanity check to make sure we don't have
different run levels w.r.t the boot CPU. We save the information on
whether the boot CPU is running in hyp mode or not and ensure the
remaining CPUs match it.
Cc: Marc Zyngier <marc.zyngier@arm.com>
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
[will: made boot_cpu_hyp_mode static]
"Here are the main arm64 updates for 4.6. There are some relatively
intrusive changes to support KASLR, the reworking of the kernel
virtual memory layout and initial page table creation.
Summary:
- Initial page table creation reworked to avoid breaking large block
mappings (huge pages) into smaller ones. The ARM architecture
requires break-before-make in such cases to avoid TLB conflicts but
that's not always possible on live page tables
- Kernel virtual memory layout: the kernel image is no longer linked
to the bottom of the linear mapping (PAGE_OFFSET) but at the bottom
of the vmalloc space, allowing the kernel to be loaded (nearly)
anywhere in physical RAM
- Kernel ASLR: position independent kernel Image and modules being
randomly mapped in the vmalloc space with the randomness is
provided by UEFI (efi_get_random_bytes() patches merged via the
arm64 tree, acked by Matt Fleming)
- Implement relative exception tables for arm64, required by KASLR
(initial code for ARCH_HAS_RELATIVE_EXTABLE added to lib/extable.c
but actual x86 conversion to deferred to 4.7 because of the merge
dependencies)
- Support for the User Access Override feature of ARMv8.2: this
allows uaccess functions (get_user etc.) to be implemented using
LDTR/STTR instructions. Such instructions, when run by the kernel,
perform unprivileged accesses adding an extra level of protection.
The set_fs() macro is used to "upgrade" such instruction to
privileged accesses via the UAO bit
- Half-precision floating point support (part of ARMv8.2)
- Optimisations for CPUs with or without a hardware prefetcher (using
run-time code patching)
- copy_page performance improvement to deal with 128 bytes at a time
- Sanity checks on the CPU capabilities (via CPUID) to prevent
incompatible secondary CPUs from being brought up (e.g. weird
big.LITTLE configurations)
- valid_user_regs() reworked for better sanity check of the
sigcontext information (restored pstate information)
- ACPI parking protocol implementation
- CONFIG_DEBUG_RODATA enabled by default
- VDSO code marked as read-only
- DEBUG_PAGEALLOC support
- ARCH_HAS_UBSAN_SANITIZE_ALL enabled
- Erratum workaround Cavium ThunderX SoC
- set_pte_at() fix for PROT_NONE mappings
- Code clean-ups"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (99 commits)
arm64: kasan: Fix zero shadow mapping overriding kernel image shadow
arm64: kasan: Use actual memory node when populating the kernel image shadow
arm64: Update PTE_RDONLY in set_pte_at() for PROT_NONE permission
arm64: Fix misspellings in comments.
arm64: efi: add missing frame pointer assignment
arm64: make mrs_s prefixing implicit in read_cpuid
arm64: enable CONFIG_DEBUG_RODATA by default
arm64: Rework valid_user_regs
arm64: mm: check at build time that PAGE_OFFSET divides the VA space evenly
arm64: KVM: Move kvm_call_hyp back to its original localtion
arm64: mm: treat memstart_addr as a signed quantity
arm64: mm: list kernel sections in order
arm64: lse: deal with clobbered IP registers after branch via PLT
arm64: mm: dump: Use VA_START directly instead of private LOWEST_ADDR
arm64: kconfig: add submenu for 8.2 architectural features
arm64: kernel: acpi: fix ioremap in ACPI parking protocol cpu_postboot
arm64: Add support for Half precision floating point
arm64: Remove fixmap include fragility
arm64: Add workaround for Cavium erratum 27456
arm64: mm: Mark .rodata as RO
Let the non boot cpus call into idle with the corresponding hotplug state, so
the hotplug core can handle the further bringup. That's a first step to
convert the boot side of the hotplugged cpus to do all the synchronization
with the other side through the state machine. For now it'll only start the
hotplug thread and kick the full bringup of the cpu.
Cc: Rafael Wysocki <rafael.j.wysocki@intel.com>
Cc: "Srivatsa S. Bhat" <srivatsa@mit.edu>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Tejun Heo <tj@kernel.org>
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/20160226182341.614102639@linutronix.de
A secondary CPU could fail to come online due to insufficient
capabilities and could simply die or loop in the kernel.
e.g, a CPU with no support for the selected kernel PAGE_SIZE
loops in kernel with MMU turned off.
or a hotplugged CPU which doesn't have one of the advertised
system capability will die during the activation.
There is no way to synchronise the status of the failing CPU
back to the master. This patch solves the issue by adding a
field to the secondary_data which can be updated by the failing
CPU. If the secondary CPU fails even before turning the MMU on,
it updates the status in a special variable reserved in the head.txt
section to make sure that the update can be cache invalidated safely
without possible sharing of cache write back granule.
Here are the possible states :
-1. CPU_MMU_OFF - Initial value set by the master CPU, this value
indicates that the CPU could not turn the MMU on, hence the status
could not be reliably updated in the secondary_data. Instead, the
CPU has updated the status @ __early_cpu_boot_status.
0. CPU_BOOT_SUCCESS - CPU has booted successfully.
1. CPU_KILL_ME - CPU has invoked cpu_ops->die, indicating the
master CPU to synchronise by issuing a cpu_ops->cpu_kill.
2. CPU_STUCK_IN_KERNEL - CPU couldn't invoke die(), instead is
looping in the kernel. This information could be used by say,
kexec to check if it is really safe to do a kexec reboot.
3. CPU_PANIC_KERNEL - CPU detected some serious issues which
requires kernel to crash immediately. The secondary CPU cannot
call panic() until it has initialised the GIC. This flag can
be used to instruct the master to do so.
Acked-by: Will Deacon <will.deacon@arm.com>
[catalin.marinas@arm.com: conflict resolution]
[catalin.marinas@arm.com: converted "status" from int to long]
[catalin.marinas@arm.com: updated update_early_cpu_boot_status to use str_l]
This patch moves cpu_die_early to smp.c, where it fits better.
No functional changes, except for adding the necessary checks
for CONFIG_HOTPLUG_CPU.
The SBBR and ACPI specifications allow ACPI based systems that do not
implement PSCI (eg systems with no EL3) to boot through the ACPI parking
protocol specification[1].
This patch implements the ACPI parking protocol CPU operations, and adds
code that eases parsing the parking protocol data structures to the
ARM64 SMP initializion carried out at the same time as cpus enumeration.
To wake-up the CPUs from the parked state, this patch implements a
wakeup IPI for ARM64 (ie arch_send_wakeup_ipi_mask()) that mirrors the
ARM one, so that a specific IPI is sent for wake-up purpose in order
to distinguish it from other IPI sources.
Given the current ACPI MADT parsing API, the patch implements a glue
layer that helps passing MADT GICC data structure from SMP initialization
code to the parking protocol implementation somewhat overriding the CPU
operations interfaces. This to avoid creating a completely trasparent
DT/ACPI CPU operations layer that would require creating opaque
structure handling for CPUs data (DT represents CPU through DT nodes, ACPI
through static MADT table entries), which seems overkill given that ACPI
on ARM64 mandates only two booting protocols (PSCI and parking protocol),
so there is no need for further protocol additions.
Based on the original work by Mark Salter <msalter@redhat.com>
[1] https://acpica.org/sites/acpica/files/MP%20Startup%20for%20ARM%20platforms.docx
Tested-by: Loc Ho <lho@apm.com>
Cc: Sudeep Holla <sudeep.holla@arm.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Al Stone <ahs3@redhat.com>
[catalin.marinas@arm.com: Added WARN_ONCE(!acpi_parking_protocol_valid() on the IPI]
We currently open-code the removal of the idmap and restoration of the
current task's MMU state in a few places.
Before introducing yet more copies of this sequence, unify these to call
a new helper, cpu_uninstall_idmap.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Tested-by: Jeremy Linton <jeremy.linton@arm.com>
Cc: Laura Abbott <labbott@fedoraproject.org>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
of_parse_and_init_cpus is only called from within smp.c, so it can be
declared static.
Signed-off-by: Jisheng Zhang <jszhang@marvell.com>
At the moment we run through the arm64_features capability list for
each CPU and set the capability if one of the CPU supports it. This
could be problematic in a heterogeneous system with differing capabilities.
Delay the CPU feature checks until all the enabled CPUs are up(i.e,
smp_cpus_done(), so that we can make better decisions based on the
overall system capability. Once we decide and advertise the capabilities
the alternatives can be applied. From this state, we cannot roll back
a feature to disabled based on the values from a new hotplugged CPU,
due to the runtime patching and other reasons. So, for all new CPUs,
we need to make sure that they have the established system capabilities.
Failing which, we bring the CPU down, preventing it from turning online.
Once the capabilities are decided, any new CPU booting up goes through
verification to ensure that it has all the enabled capabilities and also
invokes the respective enable() method on the CPU.
The CPU errata checks are not delayed and is still executed per-CPU
to detect the respective capabilities. If we ever come across a non-errata
capability that needs to be checked on each-CPU, we could introduce them via
a new capability table(or introduce a flag), which can be processed per CPU.
The next patch will make the feature checks use the system wide
safe value of a feature register.
NOTE: The enable() methods associated with the capability is scheduled
on all the CPUs (which is the only use case at the moment). If we need
a different type of 'enable()' which only needs to be run once on any CPU,
we should be able to handle that when needed.
Signed-off-by: Suzuki K. Poulose <suzuki.poulose@arm.com>
Tested-by: Dave Martin <Dave.Martin@arm.com>
[catalin.marinas@arm.com: static variable and coding style fixes]
At the moment the boot CPU stores the cpuinfo long before the
PERCPU areas are initialised by the kernel. This could be problematic
as the non-boot CPU data structures might get copied with the data
from the boot CPU, giving us no chance to detect if a particular CPU
updated its cpuinfo. This patch delays the boot cpu store to
smp_prepare_boot_cpu().
Also kills the setup_processor() which no longer does meaningful
work.
Delay the ELF HWCAP initialisation until all the (enabled) CPUs are
up, i.e, smp_cpus_done(). This is in preparation for detecting the
common features across the CPUS and creating a consistent ELF HWCAP
for the system.
At early boot, we print the CPU version/revision. On a heterogeneous
system, we could have different types of CPUs. Print the CPU info for
all active cpus. Also, the secondary CPUs prints the message only when
they turn online.
Also, remove the redundant 'revision' information which doesn't
make any sense without the 'variant' field.
When cpu is disabled, all irqs will be migratged to another cpu.
In some cases, a new affinity is different, the old affinity need
to be updated and if irq_set_affinity's return value is IRQ_SET_MASK_OK_DONE,
the old affinity can not be updated. Fix it by using irq_do_set_affinity.
And migrating interrupts is a core code matter, so use the generic
function irq_migrate_all_off_this_cpu() to migrate interrupts in
kernel/irq/migration.c.
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Russell King - ARM Linux <linux@arm.linux.org.uk>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Yang Yingliang <yangyingliang@huawei.com>
mm_cpumask isn't actually used for anything on arm64, so remove all the
code trying to keep it up-to-date.
There are a number of places where a single CPU is running with a
private page-table and we need to perform maintenance on the TLB and
I-cache in order to ensure correctness, but do not require the operation
to be broadcast to other CPUs.
This patch adds local variants of tlb_flush_all and __flush_icache_all
to support these use-cases and updates the callers respectively.
__local_flush_icache_all also implies an isb, since it is intended to be
used synchronously.
Acked-by: David Daney <david.daney@cavium.com>
Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Commit 4b3dc9679cf7 ("arm64: force CONFIG_SMP=y and remove redundant
and therfore can not be selected anymore.
Remove dead #ifdef-block depending on UP_LATE_INIT in
arch/arm64/kernel/setup.c
Signed-off-by: Jonas Rabenstein <jonas.rabenstein@studium.uni-erlangen.de>
[will: kill do_post_cpus_up_work altogether]
For those parts of the arm64 ACPI code that need to check GICC subtables
in the MADT, use the new BAD_MADT_GICC_ENTRY macro instead of the previous
BAD_MADT_ENTRY. The new macro takes into account differences in the size
of the GICC subtable that the old macro did not; this caused failures even
though the subtable entries are valid.
Fixes: aeb823bbacc2 ("ACPICA: ACPI 6.0: Add changes for FADT table.")
Signed-off-by: Al Stone <al.stone@linaro.org>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net>
It is normal that firmware presents GICC entry or entries (processors)
with disabled flag in ACPI MADT, taking a system of 16 cpus for example,
ACPI firmware may present 8 ebabled first with another 8 cpus disabled
in MADT, the disabled cpus can be hot-added later.
Firmware may also present more cpus than the hardware actually has, but
disabled the unused ones, and easily enable it when the hardware has such
cpus to make the firmware code scalable.
So that's not an error for disabled cpus in MADT, we can switch pr_err()
to pr_debug() to make the boot a little quieter by default.
Since hwid for disabled cpus often are invalid, and we check invalid hwid
first in the code, for use case that hot add cpus later will be filtered
out and will not be counted in possible cups, so move this check before
the hwid one to prepare the code to count for disabeld cpus when cpu
hot-plug is introduced.
Reviewed-by: Al Stone <ahs3@redhat.com>
John Stultz reported an RCU splat on ARM with ipi trace events
enabled. It looks like the same problem exists on ARM64.
At this point in the IPI handling path we haven't called
irq_enter() yet, so RCU doesn't know that we're about to exit
idle and properly warns that we're using RCU from an idle CPU.
Use trace_ipi_entry_rcuidle() instead of trace_ipi_entry() so
that RCU is informed about our exit from idle.
Cc: John Stultz <john.stultz@linaro.org>
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: <stable@vger.kernel.org> # 3.17+
Fixes: 45ed695ac10a ("ARM64: add IPI tracepoints")
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mark/linux
* 'arm64/psci-rework' of git://git.kernel.org/pub/scm/linux/kernel/git/mark/linux:
arm64: psci: remove ACPI coupling
arm64: psci: kill psci_power_state
arm64: psci: account for Trusted OS instances
arm64: psci: support unsigned return values
arm64: psci: remove unnecessary id indirection
arm64: smp: consistently use error codes
arm64: smp_plat: add get_logical_index
arm/arm64: kvm: add missing PSCI include
arch/arm64/kernel/smp.c
cpu_kill currently returns one for success and zero for failure, which
is unlike all the other cpu_operations, which return zero for success
and an error code upon failure. This difference is unnecessarily
confusing.
Make cpu_kill consistent with the other cpu_operations.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Tested-by: Hanjun Guo <hanjun.guo@linaro.org>
This commit removes the open-coded CPU-offline notification with new
common code. In particular, this change avoids calling scheduler code
using RCU from an offline CPU that RCU is ignoring. This is a minimal
change. A more intrusive change might invoke the cpu_check_up_prepare()
and cpu_set_state_online() functions at CPU-online time, which would
allow onlining throw an error if the CPU did not go offline properly.
The code that initializes cpus on arm64 is currently split in two
different code paths that carry out DT and ACPI cpus initialization.
Most of the code executing SMP initialization is common and should
be merged to reduce discrepancies between ACPI and DT initialization
and to have code initializing cpus in a single common place in the
kernel.
This patch refactors arm64 SMP cpus initialization code to merge
ACPI and DT boot paths in a common file and to create sanity
checks that can be reused by both boot methods.
Current code assumes PSCI is the only available boot method
when arm64 boots with ACPI; this can be easily extended if/when
the ACPI parking protocol is merged into the kernel.
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Acked-by: Hanjun Guo <hanjun.guo@linaro.org>
Tested-by: Mark Rutland <mark.rutland@arm.com> [DT]
ARM64 CPU operations such as cpu_init and cpu_init_idle take
a struct device_node pointer as a parameter, which corresponds to
the device tree node of the logical cpu on which the operation
has to be applied.
With the advent of ACPI on arm64, where MADT static table entries
are used to initialize cpus, the device tree node parameter
in cpu_ops hooks become useless when booting with ACPI, since
in that case cpu device tree nodes are not present and can not be
used for cpu initialization.
The current cpu_init hook requires a struct device_node pointer
parameter because it is called while parsing the device tree to
initialize CPUs, when the cpu_logical_map (that is used to match
a cpu node reg property to a device tree node) for a given logical
cpu id is not set up yet. This means that the cpu_init hook cannot
rely on the of_get_cpu_node function to retrieve the device tree
node corresponding to the logical cpu id passed in as parameter,
so the cpu device tree node must be passed in as a parameter to fix
this catch-22 dependency cycle.
This patch reshuffles the cpu_logical_map initialization code so
that the cpu_init cpu_ops hook can safely use the of_get_cpu_node
function to retrieve the cpu device tree node, removing the need for
the device tree node pointer parameter.
In the process, the patch removes device tree node parameters
from all cpu_ops hooks, in preparation for SMP DT/ACPI cpus
initialization consolidation.
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
Pull initial ACPI support for arm64 from Will Deacon:
"This series introduces preliminary ACPI 5.1 support to the arm64
kernel using the "hardware reduced" profile. We don't support any
peripherals yet, so it's fairly limited in scope:
- MEMORY init (UEFI)
- ACPI discovery (RSDP via UEFI)
- CPU init (FADT)
- GIC init (MADT)
- SMP boot (MADT + PSCI)
- ACPI Kconfig options (dependent on EXPERT)
ACPI for arm64 has been in development for a while now and hardware
has been available that can boot with either FDT or ACPI tables. This
has been made possible by both changes to the ACPI spec to cater for
ARM-based machines (known as "hardware-reduced" in ACPI parlance) but
also a Linaro-driven effort to get this supported on top of the Linux
kernel. This pull request is the result of that work.
These changes allow us to initialise the CPUs, interrupt controller,
and timers via ACPI tables, with memory information and cmdline coming
from EFI. We don't support a hybrid ACPI/FDT scheme. Of course,
there is still plenty of work to do (a serial console would be nice!)
but I expect that to happen on a per-driver basis after this core
series has been merged.
Anyway, the diff stat here is fairly horrible, but splitting this up
and merging it via all the different subsystems would have been
extremely painful. Instead, we've got all the relevant Acks in place
and I've not seen anything other than trivial (Kconfig) conflicts in
-next (for completeness, I've included my resolution below). Nearly
half of the insertions fall under Documentation/.
So, we'll see how this goes. Right now, it all depends on EXPERT and
I fully expect people to use FDT by default for the immediate future"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (31 commits)
ARM64 / ACPI: make acpi_map_gic_cpu_interface() as void function
ARM64 / ACPI: Ignore the return error value of acpi_map_gic_cpu_interface()
ARM64 / ACPI: fix usage of acpi_map_gic_cpu_interface
ARM64: kernel: acpi: honour acpi=force command line parameter
ARM64: kernel: acpi: refactor ACPI tables init and checks
ARM64: kernel: psci: let ACPI probe PSCI version
ARM64: kernel: psci: factor out probe function
ACPI: move arm64 GSI IRQ model to generic GSI IRQ layer
ARM64 / ACPI: Don't unflatten device tree if acpi=force is passed
ARM64 / ACPI: additions of ACPI documentation for arm64
Documentation: ACPI for ARM64
ARM64 / ACPI: Enable ARM64 in Kconfig
XEN / ACPI: Make XEN ACPI depend on X86
ARM64 / ACPI: Select ACPI_REDUCED_HARDWARE_ONLY if ACPI is enabled on ARM64
clocksource / arch_timer: Parse GTDT to initialize arch timer
irqchip: Add GICv2 specific ACPI boot support
ARM64 / ACPI: Introduce ACPI_IRQ_MODEL_GIC and register device's gsi
ACPI / processor: Make it possible to get CPU hardware ID via GICC
ACPI / processor: Introduce phys_cpuid_t for CPU hardware ID
ARM64 / ACPI: Parse MADT for SMP initialization
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull final removal of deprecated cpus_* cpumask functions from Rusty Russell:
"This is the final removal (after several years!) of the obsolete
cpus_* functions, prompted by their mis-use in staging.
With these function removed, all cpu functions should only iterate to
nr_cpu_ids, so we finally only allocate that many bits when cpumasks
are allocated offstack"
* tag 'cpumask-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits)
cpumask: remove __first_cpu / __next_cpu
cpumask: resurrect CPU_MASK_CPU0
linux/cpumask.h: add typechecking to cpumask_test_cpu
cpumask: only allocate nr_cpumask_bits.
Fix weird uses of num_online_cpus().
cpumask: remove deprecated functions.
mips: fix obsolete cpumask_of_cpu usage.
x86: fix more deprecated cpu function usage.
ia64: remove deprecated cpus_ usage.
powerpc: fix deprecated CPU_MASK_CPU0 usage.
CPU_MASK_ALL/CPU_MASK_NONE: remove from deprecated region.
staging/lustre/o2iblnd: Don't use cpus_weight
staging/lustre/libcfs: replace deprecated cpus_ calls with cpumask_
staging/lustre/ptlrpc: Do not use deprecated cpus_* functions
blackfin: fix up obsolete cpu function usage.
parisc: fix up obsolete cpu function usage.
tile: fix up obsolete cpu function usage.
arm64: fix up obsolete cpu function usage.
mips: fix up obsolete cpu function usage.
x86: fix up obsolete cpu function usage.
