The software breakpoint handlers are hooked in directly from ptrace,
which makes it difficult to add additional handlers for things like
kprobes and kgdb.
This patch moves the handling code into debug-monitors.c, where we can
dispatch to different debug subsystems more easily.
Rather than completely killing the kernel if we receive an esr value we
can't deal with in the el0 handlers, send the process a SIGILL and log
the esr value in the hope that we can debug it. If we receive a bad esr
from el1, we'll die() as before.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: stable@vger.kernel.org
Currently user faults (page, undefined instruction) are always reported
even though the user may have a signal handler for them. This patch adds
unhandled_signal() check together with printk_ratelimit() for these
cases.
Both dump_stack() and show_stack() are currently implemented by each
architecture. show_stack(NULL, NULL) dumps the backtrace for the
current task as does dump_stack(). On some archs, dump_stack() prints
extra information - pid, utsname and so on - in addition to the
backtrace while the two are identical on other archs.
The usages in arch-independent code of the two functions indicate
show_stack(NULL, NULL) should print out bare backtrace while
dump_stack() is used for debugging purposes when something went wrong,
so it does make sense to print additional information on the task which
triggered dump_stack().
There's no reason to require archs to implement two separate but mostly
identical functions. It leads to unnecessary subtle information.
This patch expands the dummy fallback dump_stack() implementation in
lib/dump_stack.c such that it prints out debug information (taken from
x86) and invokes show_stack(NULL, NULL) and drops arch-specific
dump_stack() implementations in all archs except blackfin. Blackfin's
dump_stack() does something wonky that I don't understand.
Debug information can be printed separately by calling
dump_stack_print_info() so that arch-specific dump_stack()
implementation can still emit the same debug information. This is used
in blackfin.
This patch brings the following behavior changes.
* On some archs, an extra level in backtrace for show_stack() could be
printed. This is because the top frame was determined in
dump_stack() on those archs while generic dump_stack() can't do that
reliably. It can be compensated by inlining dump_stack() but not
sure whether that'd be necessary.
* Most archs didn't use to print debug info on dump_stack(). They do
now.
An example WARN dump follows.
WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505()
Hardware name: empty
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9
0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48
ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c
0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58
Call Trace:
[<ffffffff81c614dc>] dump_stack+0x19/0x1b
[<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8234a071>] init_workqueues+0x35/0x505
v2: CPU number added to the generic debug info as requested by s390
folks and dropped the s390 specific dump_stack(). This loses %ksp
from the debug message which the maintainers think isn't important
enough to keep the s390-specific dump_stack() implementation.
dump_stack_print_info() is moved to kernel/printk.c from
lib/dump_stack.c. Because linkage is per objecct file,
dump_stack_print_info() living in the same lib file as generic
dump_stack() means that archs which implement custom dump_stack()
- at this point, only blackfin - can't use dump_stack_print_info()
as that will bring in the generic version of dump_stack() too. v1
The v1 patch broke build on blackfin due to this issue. The build
breakage was reported by Fengguang Wu.
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits]
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits]
Fix up all callers as they were before, with make one change: an
unsigned module taints the kernel, but doesn't turn off lockdep.
The patch contains the exception entry code (kernel/entry.S), pt_regs
structure and related accessors, undefined instruction trapping and
stack tracing.
AArch64 Linux kernel (including kernel threads) runs in EL1 mode using
the SP1 stack. The vectors don't have a fixed address, only alignment
(2^11) requirements.
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Olof Johansson <olof@lixom.net>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
