The architecture specifies that when the processor wakes up from a WFE
or WFI instruction, the instruction is considered complete, however we
currrently return to EL1 (or EL0) at the WFI/WFE instruction itself.
While most guests may not be affected by this because their local
exception handler performs an exception returning setting the event bit
or with an interrupt pending, some guests like UEFI will get wedged due
this little mishap.
Simply skip the instruction when we have completed the emulation.
Cc: <stable@vger.kernel.org>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
As we're about to trap a bunch of CP14 registers, let's rework
the CP15 handling so it can be generalized and work with multiple
tables.
Reviewed-by: Anup Patel <anup.patel@linaro.org>
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
Currently, the kvm_psci_call() returns 'true' or 'false' based on whether
the PSCI function call was handled successfully or not. This does not help
us emulate system-level PSCI functions where the actual emulation work will
be done by user space (QEMU or KVMTOOL). Examples of such system-level PSCI
functions are: PSCI v0.2 SYSTEM_OFF and SYSTEM_RESET.
This patch updates kvm_psci_call() to return three types of values:
1) > 0 (success)
2) = 0 (success but exit to user space)
3) < 0 (errors)
Signed-off-by: Anup Patel <anup.patel@linaro.org>
Signed-off-by: Pranavkumar Sawargaonkar <pranavkumar@linaro.org>
Pull KVM updates from Paolo Bonzini:
"First round of KVM updates for 3.14; PPC parts will come next week.
Nothing major here, just bugfixes all over the place. The most
interesting part is the ARM guys' virtualized interrupt controller
overhaul, which lets userspace get/set the state and thus enables
migration of ARM VMs"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (67 commits)
kvm: make KVM_MMU_AUDIT help text more readable
KVM: s390: Fix memory access error detection
KVM: nVMX: Update guest activity state field on L2 exits
KVM: nVMX: Fix nested_run_pending on activity state HLT
KVM: nVMX: Clean up handling of VMX-related MSRs
KVM: nVMX: Add tracepoints for nested_vmexit and nested_vmexit_inject
KVM: nVMX: Pass vmexit parameters to nested_vmx_vmexit
KVM: nVMX: Leave VMX mode on clearing of feature control MSR
KVM: VMX: Fix DR6 update on #DB exception
KVM: SVM: Fix reading of DR6
KVM: x86: Sync DR7 on KVM_SET_DEBUGREGS
add support for Hyper-V reference time counter
KVM: remove useless write to vcpu->hv_clock.tsc_timestamp
KVM: x86: fix tsc catchup issue with tsc scaling
KVM: x86: limit PIT timer frequency
KVM: x86: handle invalid root_hpa everywhere
kvm: Provide kvm_vcpu_eligible_for_directed_yield() stub
kvm: vfio: silence GCC warning
KVM: ARM: Remove duplicate include
arm/arm64: KVM: relax the requirements of VMA alignment for THP
The SMC-based PSCI emulation for Guest is going to be very different
from the in-kernel HVC-based PSCI emulation hence for now just inject
undefined exception when Guest executes SMC instruction.
Signed-off-by: marc Zyngier <marc.zyngier@arm.com>
Correct spelling typo in various part of kernel
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
On an (even slightly) oversubscribed system, spinlocks are quickly
becoming a bottleneck, as some vcpus are spinning, waiting for a
lock to be released, while the vcpu holding the lock may not be
running at all.
The solution is to trap blocking WFEs and tell KVM that we're
now spinning. This ensures that other vpus will get a scheduling
boost, allowing the lock to be released more quickly. Also, using
CONFIG_HAVE_KVM_CPU_RELAX_INTERCEPT slightly improves the performance
when the VM is severely overcommited.
Acked-by: Christoffer Dall <christoffer.dall@linaro.org>
Provide the necessary infrastructure to trap coprocessor accesses that
occur when running 32bit guests.
Also wire SMC and HVC trapped in 32bit mode while were at it.
Reviewed-by: Christopher Covington <cov@codeaurora.org>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Wire the PSCI backend into the exit handling code.
Handle the exit of a VM, decoding the exit reason from HYP mode
and calling the corresponding handler.
