commit 3ac0f4526dfb80625f5c2365bccd85be68db93ef upstream.
In an effort to clarify and simplify the annotation of assembly functions
in the kernel new macros have been introduced. These replace ENTRY and
ENDPROC and also add a new annotation for static functions which previously
had no ENTRY equivalent. Update the annotations in the library code to the
new macros.
Signed-off-by: Mark Brown <broonie@kernel.org>
[will: Use SYM_FUNC_START_WEAK_PI]
Signed-off-by: Will Deacon <will@kernel.org>
Cc: Jian Cai <jiancai@google.com>
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation this program is
distributed in the hope that it will be useful but without any
warranty without even the implied warranty of merchantability or
fitness for a particular purpose see the gnu general public license
for more details you should have received a copy of the gnu general
public license along with this program if not see http www gnu org
licenses
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 503 file(s).
Reviewed-by: Alexios Zavras <alexios.zavras@intel.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Reviewed-by: Enrico Weigelt <info@metux.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190602204653.811534538@linutronix.de
For a while now it's been possible to use EXPORT_SYMBOL() in assembly
files, which allows us to place exports immediately after assembly
functions, as we do for C functions.
As a step towards removing arm64ksyms.c, let's move the string routine
exports to the assembly files the functions are defined in. Routines
which should only be exported for !KASAN builds are exported using the
EXPORT_SYMBOL_NOKASAN() helper.
There should be no functional change as a result of this patch.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
ARM64 has asm implementation of memchr(), memcmp(), str[r]chr(),
str[n]cmp(), str[n]len(). KASAN don't see memory accesses in asm code,
thus it can potentially miss many bugs.
Ifdef out __HAVE_ARCH_* defines of these functions when KASAN is enabled,
so the generic implementations from lib/string.c will be used.
We can't just remove the asm functions because efistub uses them. And we
can't have two non-weak functions either, so declare the asm functions as
weak.
Link: http://lkml.kernel.org/r/20180920135631.23833-2-aryabinin@virtuozzo.com
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Reported-by: Kyeongdon Kim <kyeongdon.kim@lge.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Changes introduced in the upstream version of libfdt pulled in by commit
91feabc2e224 ("scripts/dtc: Update to upstream commit b06e55c88b9b") use
the strnlen() function, which isn't currently available to the EFI name-
space. Add it to the EFI namespace to avoid a linker error.
Cc: Rob Herring <robh@kernel.org>
Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Thierry Reding <treding@nvidia.com>
This patch, based on Linaro's Cortex Strings library, adds
an assembly optimized strlen() and strnlen() functions.
Signed-off-by: Zhichang Yuan <zhichang.yuan@linaro.org>
Signed-off-by: Deepak Saxena <dsaxena@linaro.org>
