Looks like from the very beginning we were missing a proper pinmuxing
for the active state of the HSIC data pin!
Settings taken from discussion on NXP's public community forum:
https://community.nxp.com/t5/i-MX-Processors/i-MX-8QuadMax-USB-HSIC-Functionality/m-p/1228662/highlight/true#M169217
Fixes: 321682bbb785 ("apalis-imx8qm: add USB HSIC support")
Related-to: ELB-3228
(cherry picked from commit a43e07cd3980304b3665fff7b816dee6dad2bf5e)
Put settings into different file, as the filename changed in 5.4.
Sai2 and Sai3 definitions for DMA were missing in the device tree of
kernel 4.14.
Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
Our GPIO list starts with gpio5-01 while it really should start with
gpio5-00. So the whole list is shifted by one.
Related-to: ELB-3032
(cherry picked from commit a4fae6e282a3b68f6d6c7dd5b7deca3b33099abb)
Correct ldo1/ldo2 voltage as below:
ldo1 --NVCC_SNVS_1V8
ldo2 --VDD_SNVS_0V8
Analogous to commit 96c179b63e7b ("MLK-23275-1: ARM64: dts: freescale: fsl-imx8mm-evk: correct ldo1/ldo2 voltage")
from NXP's downstream BSP.
The pins which can be used for an external ethernet PHY are powered by
a sepearte LDO. Currently in the device tree this rail is set to 1.8V,
the default apalis functionality of these pins requires 3.3V so change
to that.
If used with an external PHY in addition to add the PHY to the device also
the rail's voltage needs to be adapted.
Related-to: ELB-2899
This commit adds the Cortex-M4- and RPMsg-related nodes to the base Verdin iMX8M Mini device tree.
Enable GPIO and serial-port (CD-signal) sources for
the PPS (pulse-per-second) module.
Related-to: ELB-2837
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Related-to: ELB-2606, ELB-2730
Apalis carrier boards do not have the Write-Protect signal connected
Temporarily add device trees for the e-con Systems e-CAM50_CUIMX8. Once
we have working device tree overlays for this we may drop those again.
These are the albeit heavily modified device tree parts from the following patch we got from Yogaesh
<yogaesh@e-consystems.com> on May 8, 2020:
Related-to: ELB-2793
Enable driver for the e-con Systems e-CAM50_CUIMX8.
This is needed for the new KSZ9131 phy
NXP fixes a lot of issues in PCIe subsystem, in particular, add new
clocks. Synchronize the set of clocks for Apalis-iMX8QM SoM.
Related-to: ELB-1306
Fix conflicts after merging changes from the latest NXP branch.
arch/arm64/boot/dts/freescale/fsl-imx8qm-device.dtsi
drivers/pci/dwc/pci-imx6.c
Change model string of iMX8QM/QP V1.1 to differentiate from the model
string used in the device tree for the earlier iMX8QM/QP module (this
has been causing problems with the dtconf tool).
Related-to: ELB-2829
Signed-off-by: Sergio Prado <sergio.prado@toradex.com>
It’s a limitation that one cannot use native SPI CS & DMA and have a
continuous CS for the whole transfer. The CS is deasserted after each
word sent.
One can either use DMA and GPIO CS or one can use PIO mode.
With this commit we change from using PIO mode to DMA mode and
change the CS used from the IP provided one to GPIO CS on the same pin.
This sync's the SPI configuration with the i.MX 8X based modules which
already uses DMA with GPIO CS.
Related-to: ELB-1278
Add GPIO line names on module level. Those are all GPIOs which a user
might use on his custom carrier board. If more meaningful names are
available on the carrier board, the user can overwrite the line names
in the carrier board level device tree.
Related-to: ELB-2528
Related-to: ELB-2527
Related-to: ELB-2526
Add bluetooth drivers useful for the Gumstix AutoBSP as kernel modules.
Related-to: TOR-1068
Add iio/hwmon sensor drivers useful for the Gumstix AutoBSP as kernel
modules.
Add sound drivers useful for the Gumstix AutoBSP as kernel modules.
Integrate RESET_MOCI#_DRV handling with work-around for PCIe switch as
found on the Apalis Evaluation Board similar to what we upstreamed.
Related-to: ELB-1929
This pulls the reset_moci signal by default low and insures reset is
applied when pin is being muxed. It needs then actively set high
for getting out of reset.
RESET and CONNECT come out of reset with pull downs enabled. Keep
that in the pin muxing.
These pins are switched to output during the hub configuration and then
controlled as needed. The datasheet specifically states that CONNECT
must not be driven when RESET is low, so keeping the pull downs is
less likely to violate the spec.
The INT pin has an external pull up, so keeping the pull down makes
the system draw more power.
Related-to: ELB-2702
Related-to: ELB-2529
Related-to: ELB-2324
This unifies node names and adds a reference to the sound node.
The write protect switch is not connected. Specify that to get rid of:
mmc1: host does not support reading read-only switch, assuming write-enable
- Refine the PCIe clocks for iMX8DX and iMX8QXP.
- Correct the HSIO power domain name on iMX8QXP, otherwise, the
peripheral clocks wouldn't be enabled.
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
Reviewed-by: Fugang Duan <fugang.duan@nxp.com>
(cherry picked from commit a2c09691aeafc818c287f25d69e53b6411d4ef26)
The 2nd CAN controller is not assembled in the standard SKUs.
Thus disable it and prevent unneeded probing and kernel output.
The DSI to other display technologies bridges are modules. Currently two
bridges are enabled in the device tree, HDMI and LVDS. However using the
module with the LVDS bridge requires further changes to the device tree.
With out this, the suspend sequence will stop and the system resumes
immediately.
The iomuxc pinctrl-0 property is set with pinctrl nodes muxed for
potential user space use in the module specific device tree.
In order to keep them copy the full list here and amend the additional
pinctrl_uart24_forceoff.
voltage
ldo2 --VDD_SNVS_0V8
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
Reviewed-by: Jacky Bai <ping.bai@nxp.com>
(cherry picked from commit d11796134f55d88b49d79bf25d6c42b677ff47bc)
(cherry picked from commit 1c923bdd27021b011358f9422a6a18cbf30de491)
ldo2 --VDD_SNVS_0V8
(cherry picked from commit 6e1db954c1261c9a8a40f7c4e33f03173c4d05b6)
(cherry picked from commit 8574922dd583141a332be58fe1656ee05c9e5dd4)
I understood this property as I could reset something that is on this
USB controller. This was a wrong understanding and the property
reset-gpio is meant to reset the IP inside the SoC.
Remove this for fixing the USB issue.
Related-to: ELB-2592
Enable WIRELESS_EXT and WEXT_PRIV options as needed for the backported
rtl81288eu driver.
Related-to: ELB-2388
Disabling all wireless drivers and cfg80211 module makes able
to completely avoid interferences with backported drivers.
There are some unstable drivers in the kernel.
The stable versions of these drivers present in backported-5.4 package.
Remove duplicated mwifiex_sdio and mwifiex_usb.
Related-to: ELB-2684
Further clean-up modularising it some more.
BTW: Changing BT_MRVL, BT_MRVL_SDIO, CFG80211 and MAC80211 to modules
will make it co-exist with our latest backports efforts.
The driver mwifiex_sdio stucks after the wifi firmware crash.
Enabling asynchronous interrupts processing in sdio driver
fixes this issue and allows the mwifiex_sdio driver to be reloaded
and continue operates successfully.
Related-to: ELB-2596
