path: root/arch/arm
2013-01-09Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King. * 'fixes' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7616/1: cache-l2x0: aurora: Use writel_relaxed instead of writel ARM: 7615/1: cache-l2x0: aurora: Invalidate during clean operation with WT enable ARM: 7614/1: mm: fix wrong branch from Cortex-A9 to PJ4b ARM: 7612/1: imx: Do not select some errata that depends on !ARCH_MULTIPLATFORM ARM: 7611/1: VIC: fix bug in VIC irqdomain code ARM: 7610/1: versatile: bump IRQ numbers ARM: 7609/1: disable errata work-arounds which access secure registers ARM: 7608/1: l2x0: Only set .set_debug on PL310 r3p0 and earlier
2013-01-08Merge tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC fixes from Olof Johansson: "People are back from the holiday breaks, and it shows. Here are a bunch of fixes for a number of platforms: - A couple of small fixes for Nomadik - A larger set of changes for kirkwood/mvebu - uart driver selection, dt clocks, gpio-poweroff fixups, a few __init annotation fixes and some error handling improvement in their xor dma driver. - i.MX had a couple of minor fixes (and a critical one for flexcan2 clock setup) - MXS has a small board fix and a framebuffer bugfix - A set of fixes for Samsung Exynos, fixing default bootargs and some Exynos5440 clock issues - A set of OMAP changes including PM fixes and a few sparse warning fixups All in all a bit more positive code delta than we'd ideally want to see here, mostly from the OMAP PM changes, but nothing overly crazy." * tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (44 commits) ARM: clps711x: Fix bad merge of clockevents setup ARM: highbank: save and restore L2 cache and GIC on suspend ARM: highbank: add a power request clear ARM: highbank: fix secondary boot and hotplug ARM: highbank: fix typos with hignbank in power request functions ARM: dts: fix highbank cpu mpidr values ARM: dts: add device_type prop to cpu nodes on Calxeda platforms ARM: mx5: Fix MX53 flexcan2 clock ARM: OMAP2+: am33xx-hwmod: Fix wrongly terminated am33xx_usbss_mpu_irqs array pinctrl: mvebu: make pdma clock on dove mandatory ARM: Dove: Add pinctrl clock to DT dma: mv_xor: fix error handling for clocks dma: mv_xor: fix error handling of mv_xor_channel_add() arm: mvebu: Add missing ; for cpu node. arm: mvebu: Armada XP MV78230 has only three Ethernet interfaces arm: mvebu: Armada XP MV78230 has two cores, not one clk: mvebu: Remove inappropriate __init tagging ARM: Kirkwood: Use fixed-regulator instead of board gpio call ARM: Kirkwood: Fix missing sdio clock ARM: Kirkwood: Switch TWSI1 of 88f6282 to DT clock providers ...
2013-01-08Merge tag 'omap-for-v3.8-rc2/fixes-signed-v2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes From Tony Lindgren: The biggest change is a fix to deal with different power state on omap2 registers that causes issues trying to use common PM code. Also fix few incorrect registers, and an issue for omap1 USB, and few sparse fixes for issues that sneaked in with all the clean-up. * tag 'omap-for-v3.8-rc2/fixes-signed-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: ARM: OMAP2+: am33xx-hwmod: Fix wrongly terminated am33xx_usbss_mpu_irqs array ARM: OMAP1: fix USB configuration use-after-release ARM: OMAP2/3: PRM: fix bogus OMAP2xxx powerstate return values ARM: OMAP3: clock data: Add missing enable/disable for EMU clock ARM: OMAP4: PRM: Correct wrong instance usage for reading reset sources ARM: OMAP4: PRM: fix RSTTIME and RSTST offsets ARM: OMAP4: PRM: Correct reset source map ARM: OMAP: SRAM: resolve sparse warnings ARM: OMAP AM33xx: hwmod data: resolve sparse warnings ARM: OMAP: 32k counter: resolve sparse warnings Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-08Merge branch 'v3.8-samsung-fixes-2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes From Kukjin Kim: Most of them are EXYNOS5440 fixes which are for changing uart console, cpu id (typo) and silent complaining gpio error in kernel boot. * 'v3.8-samsung-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: EXYNOS: skip the clock initialization for exynos5440 ARM: EXYNOS: enable PINCTRL for EXYNOS5440 ARM: dts: use uart port1 for console on exynos4210-smdkv310 ARM: dts: use uart port0 for console on exynos5440-ssdk5440 ARM: SAMSUNG: fix the cpu id for EXYNOS5440 ARM: EXYNOS: Revise HDMI resource size
2013-01-08Merge tag 'mxs-fixes-3.8' of git://git.linaro.org/people/shawnguo/linux-2.6 ↵Olof Johansson
into fixes From Shawn Guo: I have to send one critical mxsfb fix through arm-soc, as FB maintainer is unresponsive for quite a while. People start complaining the missing of such an important fix. * tag 'mxs-fixes-3.8' of git://git.linaro.org/people/shawnguo/linux-2.6: video: mxsfb: fix crash when unblanking the display ARM: dts: imx23-olinuxino: Fix IOMUX settings
2013-01-08Merge tag 'imx-fixes-3.8' of git://git.linaro.org/people/shawnguo/linux-2.6 ↵Olof Johansson
into fixes From Shawn Guo: It includes one critical fix - wrong flexcan2 clock will hang system when the port gets brought up. The other two are non-critical fixes, which are sent together here, since it's still early -rc stage. * tag 'imx-fixes-3.8' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: mx5: Fix MX53 flexcan2 clock ARM: dts: imx31-bug: Fix manufacturer compatible string clk: imx: Remove 'clock-output-names' from the examples
2013-01-07Merge tag 'mvebu_fixes_for_v3.8' of ↵Olof Johansson
git://git.infradead.org/users/jcooper/linux into fixes From Jason Cooper: fixes for mvebu/kirkwood v3.8 - use correct uart driver for mvebu boards - add a missing DT clocks - gpio-poweroff level vs. edge triggering, use gpio_is_valid() - remove an inappropriate __init, modules need to access function. - various DT fixes - error handling in mv_xor * tag 'mvebu_fixes_for_v3.8' of git://git.infradead.org/users/jcooper/linux: pinctrl: mvebu: make pdma clock on dove mandatory ARM: Dove: Add pinctrl clock to DT dma: mv_xor: fix error handling for clocks dma: mv_xor: fix error handling of mv_xor_channel_add() arm: mvebu: Add missing ; for cpu node. arm: mvebu: Armada XP MV78230 has only three Ethernet interfaces arm: mvebu: Armada XP MV78230 has two cores, not one clk: mvebu: Remove inappropriate __init tagging ARM: Kirkwood: Use fixed-regulator instead of board gpio call ARM: Kirkwood: Fix missing sdio clock ARM: Kirkwood: Switch TWSI1 of 88f6282 to DT clock providers Power: gpio-poweroff: Fix documentation and gpio_is_valid ARM: Kirkwood: Fix missing clk for USB device. arm: mvebu: Use dw-apb-uart instead of ns16650 as UART driver Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-07ARM: clps711x: Fix bad merge of clockevents setupOlof Johansson
I mismerged a previous branch from Alexander, and accidentally left in ARCH_USES_GETTIMEOFFSET. Remove it. Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Alexander Shiyan <shc_work@mail.ru>
2013-01-07Merge tag 'nomadik-fixes-for-arm-soc' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-nomadik into fixes From Linus Walleij: Two fixes to the Nomadik: - Delete a dangling include - Bump IRQ numbers to offset at 32 * tag 'nomadik-fixes-for-arm-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-nomadik: ARM: nomadik: bump the IRQ numbers again ARM: nomadik: delete dangling include
2013-01-07ARM: highbank: save and restore L2 cache and GIC on suspendRob Herring
This fixes suspend to RAM adding necessary save and restore of L2 and GIC. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-07ARM: highbank: add a power request clearRob Herring
When we fail to power down, we need to clear out the power request. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-07ARM: highbank: fix secondary boot and hotplugRob Herring
With commit 384a290 (ARM: gic: use a private mapping for CPU target interfaces), wake-up IPIs now go to all cores as the gic cpu interface numbering may not follow core numbering. This broke secondary boot on highbank since the boot address was already set for all secondary cores, this caused all cores to boot before the kernel was ready. Fix this by moving the setting of the jump address to highbank_boot_secondary instead of highbank_smp_prepare_cpus and highbank_cpu_die. Also, clear the address when we boot. This prevents cores from booting before they are actually triggered and is also necessary to get suspend/resume to work. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-07ARM: highbank: fix typos with hignbank in power request functionsRob Herring
s/hignbank/highbank/ Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-07ARM: dts: fix highbank cpu mpidr valuesRob Herring
With the addition of commit a0ae0240 (ARM: kernel: add device tree init map function), the cpu reg values must match the cpu mpidr register or we'll get warnings. For some reason, the CLUSTERID on highbank is 9, so the reg value needs to be 0x90n to quiet the warnings. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-07ARM: dts: add device_type prop to cpu nodes on Calxeda platformsRob Herring
While device_type is considered deprecated, it is still needed for tools like lshw to identify cpu nodes. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-08ARM: mx5: Fix MX53 flexcan2 clockMarek Vasut
The second FlexCAN port uses different clock than the first one, configure correct clock to prevent hanging of the system during bringing up of the port. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-01-07ARM: OMAP2+: am33xx-hwmod: Fix wrongly terminated am33xx_usbss_mpu_irqs arrayPantelis Antoniou
The IRQ array must be terminated by -1 and not by -1+OMAP_INTC_START This led to having a resource list of 100s of IRQs. Looks like this was caused by commit a2cfc509 (ARM: OMAP3+: hwmod: Add AM33XX HWMOD data) that probably had some search and replace updates done for the patch for sparse irq support. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com> Acked-by: Paul Walmsley <paul@pwsan.com> [tony@atomide.com: updated wit information about the breaking commit] Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-01-07ARM: Dove: Add pinctrl clock to DTSebastian Hesselbarth
During merge of the mvebu patches a clock gate for pinctrl was lost. This patch just readds the clock gate. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-01-07ARM: 7616/1: cache-l2x0: aurora: Use writel_relaxed instead of writelGregory CLEMENT
The use of writel instead of writel_relaxed lead to deadlock in some situation (SMP on Armada 370 for instance). The use of writel_relaxed as it was done in the rest of this driver fixes this bug. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-01-07ARM: 7615/1: cache-l2x0: aurora: Invalidate during clean operation with WT ↵Gregory CLEMENT
enable This patch fixes a bug for Aurora L2 cache controller when the write-through mode is enable. For the clean operation even if we don't have to flush the lines we still need to invalidate them. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-01-06ARM: 7614/1: mm: fix wrong branch from Cortex-A9 to PJ4bHaojian Zhuang
If CONFIG_ARCH_MULTIPLATFORM & CONFIG_ARCH_MVEBU are both enabled, __v7_pj4b_setup is added between __v7_ca9mp_setup and __v7_setup. But there's no jump instruction added. If the chip is Cortex A5/A9, it goes through __v7_pj4b_setup also. It results in system hang. Signed-off-by: Haojian Zhuang <haojian.zhuang@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-01-06ARM: 7612/1: imx: Do not select some errata that depends on !ARCH_MULTIPLATFORMFabio Estevam
Since commit 62e4d357a (ARM: 7609/1: disable errata work-arounds which access secure registers) ARM_ERRATA_743622/751472 depends on !ARCH_MULTIPLATFORM. Since imx has been converted to multiplatform, the following warning happens: $ make imx_v6_v7_defconfig warning: (SOC_IMX6Q && ARCH_TEGRA_2x_SOC && ARCH_TEGRA_3x_SOC) selects ARM_ERRATA_751472 which has unmet direct dependencies (CPU_V7 && !ARCH_MULTIPLATFORM) warning: (SOC_IMX6Q && ARCH_TEGRA_3x_SOC) selects ARM_ERRATA_743622 which has unmet direct dependencies (CPU_V7 && !ARCH_MULTIPLATFORM) warning: (SOC_IMX6Q && ARCH_TEGRA_3x_SOC) selects ARM_ERRATA_743622 which has unmet direct dependencies (CPU_V7 && !ARCH_MULTIPLATFORM) warning: (SOC_IMX6Q && ARCH_TEGRA_2x_SOC && ARCH_TEGRA_3x_SOC) selects ARM_ERRATA_751472 which has unmet direct dependencies (CPU_V7 && !ARCH_MULTIPLATFORM) Recommended approach is to remove ARM_ERRATA_743622/751472 from being selected by SOC_IMX6Q and apply such workarounds into the bootloader. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-01-06arm: mvebu: Add missing ; for cpu node.Andrew Lunn
The Armada XP MV78230 DT include file is missing a ; at the end of the cpu node. Reported-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-01-06arm: mvebu: Armada XP MV78230 has only three Ethernet interfacesThomas Petazzoni
We originally thought that the MV78230 variant of the Armada XP had four Ethernet interfaces, like the other variants MV78260 and MV78460. In fact, this is not true, and the MV78230 has only three Ethernet interfaces. So, the definitions of the Ethernet interfaces is now done as follows: * armada-370-xp.dtsi: definitions of the first two interfaces, that are common to Armada 370 and Armada XP * armada-xp.dtsi: definition of the third interface, common to all Armada XP variants. * armada-xp-mv78260.dtsi and armada-xp-mv78460.dtsi: definition of the fourth interface. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-01-06arm: mvebu: Armada XP MV78230 has two cores, not oneThomas Petazzoni
Contrary to our understanding at the time armada-xp-mv78230.dtsi was written, the MV78230 variant of the Armada XP SoC has two cores and not one. This patch updates the .dtsi file to take into account this reality. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-01-06ARM: Kirkwood: Use fixed-regulator instead of board gpio callAndrew Lunn
With the change to a DT based pinctrl/gpio driver, using gpio API calls in board-*.c files no longer works, a dereferenced NULL pointer exception occurs instead. By converting the GPIO code into a fixed-regulator which gets probed later once pinctrl/gpio is available, we avoid the exception. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Stefan Peter <s.peter@mplch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-01-06ARM: Kirkwood: Fix missing sdio clockAndrew Lunn
We moved to declaring clk gates in DT. However, device which do not yet have a DT binding need to have a clkdev alias. This was missing for SDIO. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Stefan Peter <s.peter@mplch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-01-06ARM: Kirkwood: Switch TWSI1 of 88f6282 to DT clock providersNobuhiro Iwamatsu
Clock Management of kirkwood has moved to DT clock providers. However, TWSI1 has not yet been done. This switches TWSI1 of 88f6282 to DT clock providers. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-01-06ARM: Kirkwood: Fix missing clk for USB device.Andrew Lunn
Without the clock being held by a driver, it gets turned off at a bad time causing the SoC to lockup. This is often during reboot. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Stefan Peter <s.peter@mpl.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-01-06arm: mvebu: Use dw-apb-uart instead of ns16650 as UART driverGregory CLEMENT
The UART controller used in the Armada 370 and Armada XP SoCs is the Synopsys DesignWare 8250 (aka Synopsys DesignWare ABP UART). The improper use of the ns16550 can lead to a kernel oops during boot if a character is sent to the UART before the initialization of the driver. The DW APB has an extra interrupt that gets raised when writing to the LCR when busy. This explains why we need to use dw-apb-uart driver to handle this. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-01-05ARM: EXYNOS: skip the clock initialization for exynos5440Kukjin Kim
Since exynos5440 can support only common clk stuff, so this patch skips legacy exynos5 clock initialization. Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2013-01-04ARM: dts: imx31-bug: Fix manufacturer compatible stringFabio Estevam
In the compatible field we should point the manufacturer of the board, which in this case is Buglabs. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-01-03Merge tag 'driver-core-3.8-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core __dev* removal patches - take 3 - from Greg Kroah-Hartman: "Here are the remaining __dev* removal patches against the 3.8-rc2 tree. All of these patches were previously sent to the subsystem maintainers, most of them were picked up and pushed to you, but there were a number that fell through the cracks, and new drivers were added during the merge window, so this series cleans up the rest of the instances of these markings. Third time's the charm... Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflict with the pinctrl pull in pinctrl-sirf.c. * tag 'driver-core-3.8-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (54 commits) misc: remove __dev* attributes. include: remove __dev* attributes. Documentation: remove __dev* attributes. Drivers: misc: remove __dev* attributes. Drivers: block: remove __dev* attributes. Drivers: bcma: remove __dev* attributes. Drivers: char: remove __dev* attributes. Drivers: clocksource: remove __dev* attributes. Drivers: ssb: remove __dev* attributes. Drivers: dma: remove __dev* attributes. Drivers: gpu: remove __dev* attributes. Drivers: infinband: remove __dev* attributes. Drivers: memory: remove __dev* attributes. Drivers: mmc: remove __dev* attributes. Drivers: iommu: remove __dev* attributes. Drivers: power: remove __dev* attributes. Drivers: message: remove __dev* attributes. Drivers: macintosh: remove __dev* attributes. Drivers: mfd: remove __dev* attributes. pstore: remove __dev* attributes. ...
2013-01-03ARM: drivers: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03ARM: nomadik: bump the IRQ numbers againLinus Walleij
Bump the IRQ numbers from offset at 1 (right above NO_IRQ) to 32. This is the painful way to learn that if you're using SPARSE_IRQ and avoid to define .nr_irqs in your machine, the first 16 IRQs will be pre-allocated, and the IRQdomain code (as the VIC core code before it) will then assume that all IRQ descriptors are pre-allocated, and 16 of them are - by somebody else. So mapping the IRQs will fail in irq_create_mapping(). Moving the offset upward rids us of this problem. Cc: Rob Herring <rob.herring@calxeda.com> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-03ARM: nomadik: delete dangling includeLinus Walleij
This reference to the old include header for the FSMC NAND MTD driver was somehow left in place, get rid of it. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-03Merge tag 'pinctrl-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pinctrl fixes from Linus Walleij: "A first round of pinctrl fixes for v3.8: - i.MX5 register configuration - Swap a kfree to devm_kfree() to avoid memory corruption in the at91 driver - Add the missing device tree binding doc for the SIRF pin controller - Enable the SIRF GPIO pull up/down configuration from the device tree, it was previously retired from the hard-coded approach. - NULL check for the prcm_base in the Nomadik pin controller. - Provide the prcm_base from the device tree in the DT boot path for the Nomadik pin controller." * tag 'pinctrl-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: ARM: ux500: add pinctrl address resources pinctrl: nomadik: return if prcm_base is NULL pinctrl: sirf: enable GPIO pullup/down configuration from dts pinctrl: sirf: add missing DT-binding document pinctrl: fix comment mistake drivers/pinctrl/pinctrl-at91.c: convert kfree to devm_kfree pinctrl: imx5: fix GPIO_8 pad CAN1_RXCAN configuration
2013-01-03ARM: OMAP1: fix USB configuration use-after-releaseAaro Koskinen
All boards, except Amstrad E3, mark USB config with __initdata. As a result, when you compile USB into modules, they will try to refer already released platform data and the behaviour is undefined. For example on Nokia 770, I get the following kernel panic when modprobing ohci-hcd: [ 3.462158] Unable to handle kernel paging request at virtual address e7fddef0 [ 3.477050] pgd = c3434000 [ 3.487365] [e7fddef0] *pgd=00000000 [ 3.498535] Internal error: Oops: 80000005 [#1] ARM [ 3.510955] Modules linked in: ohci_hcd(+) [ 3.522705] CPU: 0 Not tainted (3.7.0-770_tiny+ #5) [ 3.535552] PC is at 0xe7fddef0 [ 3.546508] LR is at ohci_omap_init+0x5c/0x144 [ohci_hcd] [ 3.560272] pc : [<e7fddef0>] lr : [<bf003140>] psr: a0000013 [ 3.560272] sp : c344bdb0 ip : c344bce0 fp : c344bdcc [ 3.589782] r10: 00000001 r9 : 00000000 r8 : 00000000 [ 3.604553] r7 : 00000026 r6 : 000000de r5 : c0227300 r4 : c342d620 [ 3.621032] r3 : e7fddef0 r2 : c048b880 r1 : 00000000 r0 : 0000000a [ 3.637786] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user [ 3.655822] Control: 0005317f Table: 13434000 DAC: 00000015 [ 3.672790] Process modprobe (pid: 425, stack limit = 0xc344a1b8) [ 3.690643] Stack: (0xc344bdb0 to 0xc344c000) [ 3.707031] bda0: bf0030e4 c342d620 00000000 c049e62c [ 3.727905] bdc0: c344be04 c344bdd0 c0150ff0 bf0030f4 bf001b88 00000000 c048a4ac c345b020 [ 3.748870] bde0: c342d620 00000000 c048a468 bf003968 00000001 bf006000 c344be34 c344be08 [ 3.769836] be00: bf001bf0 c0150e48 00000000 c344be18 c00b9bfc c048a478 c048a4ac bf0037f8 [ 3.790985] be20: c012ca04 c000e024 c344be44 c344be38 c012d968 bf001a84 c344be64 c344be48 [ 3.812164] be40: c012c8ac c012d95c 00000000 c048a478 c048a4ac bf0037f8 c344be84 c344be68 [ 3.833740] be60: c012ca74 c012c80c 20000013 00000000 c344be88 bf0037f8 c344beac c344be88 [ 3.855468] be80: c012b038 c012ca14 c38093cc c383ee10 bf0037f8 c35be5a0 c049d5e8 00000000 [ 3.877166] bea0: c344bebc c344beb0 c012c40c c012aff4 c344beec c344bec0 c012bfc0 c012c3fc [ 3.898834] bec0: bf00378c 00000000 c344beec bf0037f8 00067f39 00000000 00005c44 c000e024 [ 3.920837] bee0: c344bf14 c344bef0 c012cd54 c012befc c04ce080 00067f39 00000000 00005c44 [ 3.943023] bf00: c000e024 bf006000 c344bf24 c344bf18 c012db14 c012ccc0 c344bf3c c344bf28 [ 3.965423] bf20: bf00604c c012dad8 c344a000 bf003834 c344bf7c c344bf40 c00087ac bf006010 [ 3.987976] bf40: 0000000f bf003834 00067f39 00000000 00005c44 bf003834 00067f39 00000000 [ 4.010711] bf60: 00005c44 c000e024 c344a000 00000000 c344bfa4 c344bf80 c004c35c c0008720 [ 4.033569] bf80: c344bfac c344bf90 01422192 01427ea0 00000000 00000080 00000000 c344bfa8 [ 4.056518] bfa0: c000dec0 c004c2f0 01422192 01427ea0 01427ea0 00005c44 00067f39 00000000 [ 4.079406] bfc0: 01422192 01427ea0 00000000 00000080 b6e11008 014221aa be941fcc b6e1e008 [ 4.102569] bfe0: b6ef6300 be941758 0000e93c b6ef6310 60000010 01427ea0 00000000 00000000 [ 4.125946] Backtrace: [ 4.143463] [<bf0030e4>] (ohci_omap_init+0x0/0x144 [ohci_hcd]) from [<c0150ff0>] (usb_add_hcd+0x1b8/0x61c) [ 4.183898] r6:c049e62c r5:00000000 r4:c342d620 r3:bf0030e4 [ 4.205596] [<c0150e38>] (usb_add_hcd+0x0/0x61c) from [<bf001bf0>] (ohci_hcd_omap_drv_probe+0x17c/0x224 [ohci_hcd]) [ 4.248138] [<bf001a74>] (ohci_hcd_omap_drv_probe+0x0/0x224 [ohci_hcd]) from [<c012d968>] (platform_drv_probe+0x1c/0x20) [ 4.292144] r8:c000e024 r7:c012ca04 r6:bf0037f8 r5:c048a4ac r4:c048a478 [ 4.316192] [<c012d94c>] (platform_drv_probe+0x0/0x20) from [<c012c8ac>] (driver_probe_device+0xb0/0x208) [ 4.360168] [<c012c7fc>] (driver_probe_device+0x0/0x208) from [<c012ca74>] (__driver_attach+0x70/0x94) [ 4.405548] r6:bf0037f8 r5:c048a4ac r4:c048a478 r3:00000000 [ 4.429809] [<c012ca04>] (__driver_attach+0x0/0x94) from [<c012b038>] (bus_for_each_dev+0x54/0x90) [ 4.475708] r6:bf0037f8 r5:c344be88 r4:00000000 r3:20000013 [ 4.500366] [<c012afe4>] (bus_for_each_dev+0x0/0x90) from [<c012c40c>] (driver_attach+0x20/0x28) [ 4.528442] r7:00000000 r6:c049d5e8 r5:c35be5a0 r4:bf0037f8 [ 4.553466] [<c012c3ec>] (driver_attach+0x0/0x28) from [<c012bfc0>] (bus_add_driver+0xd4/0x228) [ 4.581878] [<c012beec>] (bus_add_driver+0x0/0x228) from [<c012cd54>] (driver_register+0xa4/0x134) [ 4.629730] r8:c000e024 r7:00005c44 r6:00000000 r5:00067f39 r4:bf0037f8 [ 4.656738] [<c012ccb0>] (driver_register+0x0/0x134) from [<c012db14>] (platform_driver_register+0x4c/0x60) [ 4.706542] [<c012dac8>] (platform_driver_register+0x0/0x60) from [<bf00604c>] (ohci_hcd_mod_init+0x4c/0x8c [ohci_hcd]) [ 4.757843] [<bf006000>] (ohci_hcd_mod_init+0x0/0x8c [ohci_hcd]) from [<c00087ac>] (do_one_initcall+0x9c/0x174) [ 4.808990] r4:bf003834 r3:c344a000 [ 4.832641] [<c0008710>] (do_one_initcall+0x0/0x174) from [<c004c35c>] (sys_init_module+0x7c/0x194) [ 4.881530] [<c004c2e0>] (sys_init_module+0x0/0x194) from [<c000dec0>] (ret_fast_syscall+0x0/0x2c) [ 4.930664] r7:00000080 r6:00000000 r5:01427ea0 r4:01422192 [ 4.956481] Code: bad PC value [ 4.978729] ---[ end trace 58280240f08342c4 ]--- [ 5.002258] Kernel panic - not syncing: Fatal exception Fix this by taking a copy of the data. Also mark Amstrad E3's data with __initdata to save some memory with multi-board kernels. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Tony Lindgren <tony@atomide.com>
2013-01-03Merge tag 'omap-fixes-a2-for-v3.8-rc' of ↵Tony Lindgren
git://git.kernel.org/pub/scm/linux/kernel/git/pjw/omap-pending into omap-for-v3.8-rc2/fixes Some OMAP PRCM and sparse fixes against v3.8-rc1. A basic set of test logs are available here: http://www.pwsan.com/omap/testlogs/prcm_fixes_b_3.8-rc/20130102120724/ The 3730 Beagle XM here has an intermittent failure mounting SD root, but the suspicion right now is that this is due to a failing SD card, rather than any change introduced by these patches. This second version includes a few changes requested by Tony Lindgren.
2013-01-02ARM: OMAP2/3: PRM: fix bogus OMAP2xxx powerstate return valuesPaul Walmsley
On OMAP2xxx chips, the register bitfields for the PM_PWSTCTRL_*.POWERSTATE and PM_PWSTST_*.LASTSTATEENTERED are different than those used on OMAP3/4. The order is reversed. So, for example, on OMAP2xxx, 0x0 indicates 'ON'; but on OMAP3/4, 0x0 indicates 'OFF'. Similarly, on OMAP2xxx, 0x3 indicates 'OFF', but on OMAP3/4, 0x3 indicates 'ON'. To fix this, we treat the OMAP3/4 values as the powerdomain API values, and create new low-level powerdomain functions for the OMAP2xxx chips which translate between the OMAP2xxx values and the OMAP3/4 values. Without this patch, the conversion of the OMAP2xxx PM code to the functional powerstate code results in a non-booting kernel. Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-01-02ARM: OMAP3: clock data: Add missing enable/disable for EMU clockJon Hunter
The ETM/ETB drivers for OMAP3, enable the emu_src_ck clock in order to access the ETM/ETB hardware. The emu_src_ck should enable the EMU clock domain so that the ETM/ETB hardware is accessible. However, currently when enabling the emu_src_ck the EMU clock domain is not being enabled and so the ETM/ETB drivers are failing. Add enable/disable clock functions to enable the EMU clock domain when enabling the emu_src_ck. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-01-02ARM: OMAP4: PRM: Correct wrong instance usage for reading reset sourcesIvan Khoronzhuk
To read reset sources registers we have to use PRM_DEVICE_INST Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-01-02ARM: OMAP4: PRM: fix RSTTIME and RSTST offsetsNishanth Menon
RSTTIME is offset 0x8 and RSTST is offset 0x04 for OMAP4430 and OMAP4460. Signed-off-by: Nishanth Menon <nm@ti.com> [ivan.khoronzhuk@ti.com: ported from k3.4] Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-01-02ARM: OMAP4: PRM: Correct reset source mapIvan Khoronzhuk
In the map for reset sources register we use defines intended for using with PRM_RSTCTRL register. So fix it. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com>
2013-01-02watchdog: twl4030_wdt: add DT supportAaro Koskinen
Add DT support for twl4030_wdt. This is needed to get twl4030_wdt to probe when booting with DT. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-01-02ARM: 7611/1: VIC: fix bug in VIC irqdomain codeLinus Walleij
The VIC irqdomain code added in commit 07c9249f1fa90cc8189bed44c0bcece664596a72 "ARM: 7554/1: VIC: use irq_domain_add_simple()" Had two bugs: 1) It didn't call irq_create_mapping() once on each valid irq source in the slowpath when registering the controller. 2) It passed a -1 as IRQ offset for the DT case, whereas 0 should be passed as invalid IRQ instead. Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-01-02ARM: 7610/1: versatile: bump IRQ numbersLinus Walleij
The Versatile starts to register Linux IRQ numbers from offset 0 which is illegal, since this is NO_IRQ. Bump all hard-coded IRQs by 32 to get rid of the problem. Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-01-02ARM: 7609/1: disable errata work-arounds which access secure registersRob Herring
In order to support secure and non-secure platforms in multi-platform kernels, errata work-arounds that access secure only registers need to be disabled. Make all the errata options that fit in this category depend on !CONFIG_ARCH_MULTIPLATFORM. This will effectively remove the errata options as platforms are converted over to multi-platform. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-01-02ARM: 7608/1: l2x0: Only set .set_debug on PL310 r3p0 and earlierRob Herring
PL310 errata work-arounds using .set_debug function are only needed on r3p0 and earlier, so check the rev and only set .set_debug on older revs. Avoiding debug register accesses fixes aborts on non-secure platforms like highbank. It is assumed that non-secure platforms needing these work-arounds have already implemented .set_debug with secure monitor calls. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-01-01ARM: OMAP: SRAM: resolve sparse warningsPaul Walmsley
Commit bb77209432873214a796a70a4539e4ebdf3feb54 ("ARM: OMAP: Move omap2+ specific parts of sram.c to mach-omap2") adds some new sparse warnings: arch/arm/plat-omap/sram.c:43:6: warning: symbol 'omap_sram_push_address' was not declared. Should it be static? arch/arm/plat-omap/sram.c:65:6: warning: symbol 'omap_sram_reset' was not declared. Should it be static? arch/arm/plat-omap/sram.c:73:13: warning: symbol 'omap_map_sram' was not declared. Should it be static? This second version fixes the warnings by including <plat/sram.h>, at Tony's request. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Tony Lindgren <tony@atomide.com>
