path: root/arch/arm
2008-10-14i2c/isp1301_omap: Convert to a new-style i2c driver, part 2Jean Delvare
Based on David Brownell's patch for tps65010 and previous work by Felipe Balbi, this patch finishes converting isp1301_omap to a new-style i2c driver. There's definitely room for further drivers cleanups, but these are out of the scope of this patch. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Tony Lindgren <tony@atomide.com>
2008-10-13Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (313 commits) V4L/DVB (9186): Added support for Prof 7300 DVB-S/S2 cards V4L/DVB (9185): S2API: Ensure we have a reasonable ROLLOFF default V4L/DVB (9184): cx24116: Change the default SNR units back to percentage by default. V4L/DVB (9183): S2API: Return error of the caller provides 0 commands. V4L/DVB (9182): S2API: Added support for DTV_HIERARCHY V4L/DVB (9181): S2API: Add support fot DTV_GUARD_INTERVAL and DTV_TRANSMISSION_MODE V4L/DVB (9180): S2API: Added support for DTV_CODE_RATE_HP/LP V4L/DVB (9179): S2API: frontend.h cleanup V4L/DVB (9178): cx24116: Add module parameter to return SNR as ESNO. V4L/DVB (9177): S2API: Change _8PSK / _16APSK to PSK_8 and APSK_16 V4L/DVB (9176): Add support for DvbWorld USB cards with STV0288 demodulator. V4L/DVB (9175): Remove NULL pointer in stb6000 driver. V4L/DVB (9174): Allow custom inittab for ST STV0288 demodulator. V4L/DVB (9173): S2API: Remove the hardcoded command limit during validation V4L/DVB (9172): S2API: Bugfix related to DVB-S / DVB-S2 tuning for the legacy API. V4L/DVB (9171): S2API: Stop an OOPS if illegal commands are dumped in S2API. V4L/DVB (9170): cx24116: Sanity checking to data input via S2API to the cx24116 demod. V4L/DVB (9169): uvcvideo: Support two new Bison Electronics webcams. V4L/DVB (9168): Add support for MSI TV@nywhere Plus remote V4L/DVB: v4l2-dev: remove duplicated #include ...
2008-10-13Merge branch 'proc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc * 'proc' of git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc: proc: remove kernel.maps_protect proc: remove now unneeded ADDBUF macro [PATCH] proc: show personality via /proc/pid/personality [PATCH] signal, procfs: some lock_task_sighand() users do not need rcu_read_lock() proc: move PROC_PAGE_MONITOR to fs/proc/Kconfig proc: make grab_header() static proc: remove unused get_dma_list() proc: remove dummy vmcore_open() proc: proc_sys_root tweak proc: fix return value of proc_reg_open() in "too late" case Fixed up trivial conflict in removed file arch/sparc/include/asm/dma_32.h
2008-10-13Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: include/asm-x86/statfs.h
2008-10-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] orion5x_wdt.c: add spinlocking [WATCHDOG] Orion: add hardware watchdog support [WATCHDOG] omap_wdt.c: cleanup a bit omap_wdt.c [WATCHDOG] omap_wdt.c: another ioremap() fix [WATCHDOG] omap_wdt.c: sync linux-omap changes [WATCHDOG] Add AT91SAM9X watchdog [WATCHDOG] Add driver for winbond w83697ug/uf watchdog feature [WATCHDOG] add watchdog driver IT8716 IT8726 IT8712J/K
2008-10-12V4L/DVB (8687): soc-camera: Move .power and .reset from soc_camera host to ↵Stefan Herbrechtsmeier
sensor driver Make .power and .reset callbacks per camera instead of per host, also move their invocation to camera drivers. .arch/arm/mach-pxa/include/mach/camera.h | 2 - Signed-off-by: Stefan Herbrechtsmeier <hbmeier@hni.uni-paderborn.de> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-11Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (236 commits) [ARM] 5300/1: fixup spitz reset during boot [ARM] 5295/1: make ZONE_DMA optional [ARM] 5239/1: Palm Zire 72 power management support [ARM] 5298/1: Drop desc_handle_irq() [ARM] 5297/1: [KS8695] Fix two compile-time warnings [ARM] 5296/1: [KS8695] Replace macro's with trailing underscores. [ARM] pxa: allow multi-machine PCMCIA builds [ARM] pxa: add preliminary CPUFREQ support for PXA3xx [ARM] pxa: add missing ACCR bit definitions to pxa3xx-regs.h [ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.c [ARM] pxa/zylonite: add support for USB OHCI [ARM] ohci-pxa27x: use ioremap() and offset for register access [ARM] ohci-pxa27x: introduce pxa27x_clear_otgph() [ARM] ohci-pxa27x: use platform_get_{irq,resource} for the resource [ARM] ohci-pxa27x: move OHCI controller specific registers into the driver [ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registers [ARM] pxa: move I2S register and bit definitions into pxa2xx-i2s.c [ARM] pxa: simplify DMA register definitions [ARM] pxa: make additional DCSR bits valid for PXA3xx [ARM] pxa: move i2c register and bit definitions into i2c-pxa.c ... Fixed up conflicts in arch/arm/mach-versatile/core.c sound/soc/pxa/pxa2xx-ac97.c sound/soc/pxa/pxa2xx-i2s.c manually.
2008-10-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1075 commits) myri10ge: update driver version number to 1.4.3-1.369 r8169: add shutdown handler r8169: preliminary 8168d support r8169: support additional 8168cp chipset r8169: change default behavior for mildly identified 8168c chipsets r8169: add a new 8168cp flavor r8169: add a new 8168c flavor (bis) r8169: add a new 8168c flavor r8169: sync existing 8168 device hardware start sequences with vendor driver r8169: 8168b Tx performance tweak r8169: make room for more specific 8168 hardware start procedure r8169: shuffle some registers handling around (8168 operation only) r8169: new phy init parameters for the 8168b r8169: update phy init parameters r8169: wake up the PHY of the 8168 af_key: fix SADB_X_SPDDELETE response ath9k: Fix return code when ath9k_hw_setpower() fails on reset ath9k: remove nasty FAIL macro from ath9k_hw_reset() gre: minor cleanups in netlink interface gre: fix copy and paste error ...
2008-10-11Merge branch 'for-linus' of git://git.alsa-project.org/alsa-kernelLinus Torvalds
* 'for-linus' of git://git.alsa-project.org/alsa-kernel: (258 commits) ALSA: hda: VREF powerdown for headphones ALSA: hda: STAC_HP_M4 ALSA: ASoC: Check for machine type in GTA01 machine driver ALSA: mtpav - Fix race in probe ALSA: usb-audio: dynamic detection of MIDI interfaces in uaxx-quirk ALSA: Add a note on dependency of RTC stuff ALSA: ASoC: add new param mux to dapm_mux_update_power ALSA: Increase components array size ALSA: ASoC: Correct inverted Mic PGA Switch control in wm8510 driver ALSA: hda: comment typo fix ALSA: hda: comment typo fix ALSA: hda - Fix PCI SSID for ASROCK K18N78FullHD-hSLI ALSA: snd-usb-audio: support for Edirol UA-4FX device ALSA: usb - Fix possible Oops at USB-MIDI disconnection ALSA: hda - Fix another ALC889A (rev 0x100101) ALSA: hda: add more board-specific information for Realtek ALC662 rev1 ALSA: Correct Vladimir Barinov's e-mail address ALSA: cs46xx: Add PCI IDs for TerraTec and Hercules cards ALSA: hda: SPDIF stream muting support ALSA: hda: appletv support ...
2008-10-11[ARM] 5300/1: fixup spitz reset during bootDmitry Baryshkov
Some machines don't have the pullup/down on their reset pin, so configuring the reset generating pin as input makes them reset immediately. Fix that by making reset pin direction configurable. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-10[WATCHDOG] Orion: add hardware watchdog supportSylver Bruneau
This patch allows the use of the hardware watchdog in the Marvell Orion series of ARM SoCs. Signed-off-by: Sylver Bruneau <sylver.bruneau@googlemail.com> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-10-10[WATCHDOG] omap_wdt.c: sync linux-omap changesFelipe Balbi
These are changes that have been sitting in linux-omap and were never sent upstream. Hopefully, it'll never happen again at least for this driver. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-10-10ALSA: Correct Vladimir Barinov's e-mail addressVladimir Barinov
Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-10-10proc: remove unused get_dma_list()Alexey Dobriyan
2008-10-09Merge branch 'for-rmk' of git://git.marvell.com/orionRussell King
Merge branch 'orion-devel' into devel
2008-10-09Merge branch 'for-rmk' of git://source.mvista.com/git/linux-davinci-2.6.gitRussell King
Merge branch 'davinci' into devel
2008-10-09Merge branch 'for-rmk' of ↵Russell King
git://pasiphae.extern.pengutronix.de/git/imx/linux-2.6.git Merge branch 'imx-devel' into devel
2008-10-09Merge branch 'pxa-all' into develRussell King
Conflicts: arch/arm/mach-pxa/Kconfig arch/arm/mach-pxa/corgi.c arch/arm/mach-pxa/include/mach/hardware.h arch/arm/mach-pxa/spitz.c
2008-10-09Merge branch 'at91' into develRussell King
2008-10-09Merge branch 'ptebits' into develRussell King
Conflicts: arch/arm/Kconfig
2008-10-09Merge branches 'machtypes', 'core', 'ep93xx', 'ks8695', 'netdev' and ↵Russell King
'sa1100' into devel
2008-10-09[ARM] 5295/1: make ZONE_DMA optionalNicolas Pitre
Most ARM machines don't need a special "DMA" memory zone, and when configured out, the kernel becomes a bit smaller: | text data bss dec hex filename |3826182 102384 111700 4040266 3da64a vmlinux |3823593 101616 111700 4036909 3d992d vmlinux.nodmazone This is because the system now has only one zone total which effect is to optimize away many conditionals in page allocation paths. So let's configure this zone only on machines that need split zones. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09[ARM] 5239/1: Palm Zire 72 power management supportSergey Lapin
This patch contains Palm Zire 72 power management support. Depends on #5238/1 Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09[ARM] 5298/1: Drop desc_handle_irq()Dmitry Baryshkov
desc_handle_irq() was declared as obsolete since long ago. Replace it with generic_handle_irq() Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09[ARM] 5297/1: [KS8695] Fix two compile-time warningsAndrew Victor
Fix two warnings when compiling for the KS8695 processor. arch/arm/include/asm/dma-mapping.h: In function 'dma_to_virt': arch/arm/include/asm/dma-mapping.h:40: warning: return makes pointer from integer without a cast Section mismatch in reference from the function pcibios_fixup_bus() to the (unknown reference) .devinit.text:(unknown) The function pcibios_fixup_bus() references the (unknown reference) __devinit (unknown). This is often because pcibios_fixup_bus lacks a __devinit annotation or the annotation of (unknown) is wrong. Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09[ARM] 5296/1: [KS8695] Replace macro's with trailing underscores.Andrew Victor
Replace Macro names that have trailing underscores. Also use the IOPD() macro instead of a hard-coded bit-shift (for better readability). Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-08Merge branches 'sched/devel', 'sched/cpu-hotplug', 'sched/cpusets' and ↵Ingo Molnar
'sched/urgent' into sched/core
2008-10-07[ARM] pxa: add preliminary CPUFREQ support for PXA3xxEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] pxa: add missing ACCR bit definitions to pxa3xx-regs.hEric Miao
2008-10-07[ARM] pxa: rename cpu-pxa.c to cpufreq-pxa2xx.cEric Miao
2008-10-07[ARM] pxa/zylonite: add support for USB OHCIEric Miao
2008-10-07[ARM] ohci-pxa27x: use ioremap() and offset for register accessEric Miao
This avoid the pre-mapping of OHCI controller register space, and the mapping is made only when necessary (OHCI is probed). Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] ohci-pxa27x: introduce pxa27x_clear_otgph()Eric Miao
Direct access to pxa27x specific register PSSR in a generic ohci driver is no good, introduce pxa27x_clear_otgph() and move the implementation into processor specific code. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] ohci-pxa27x: move OHCI controller specific registers into the driverEric Miao
2008-10-07[ARM] ohci-pxa27x: introduce flags to avoid direct access to OHCI registersEric Miao
Direct access to USB host controller registers is considered to be not portable, and is usually a bad sign for poorly abstracted interface. Introduce .flags and .power_on_delay to "struct pxaohci_platform_data" so that most platforms don't bother to write their own .init/.exit() sequences. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] pxa: move I2S register and bit definitions into pxa2xx-i2s.cEric Miao
Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] pxa: simplify DMA register definitionsEric Miao
1. DRCMRxx is no longer recommended, use DRCMR(xx) instead, and pass DRCMR index by "struct resource" if possible 2. DCSRxx, DDADRxx, DSADRxx, DTADRxx, DCMDxx is never used, use DCSR(), DDADR(), DSADR(), DTADR(), DCMD() instead Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] pxa: make additional DCSR bits valid for PXA3xxEric Miao
2008-10-07[ARM] pxa: move i2c register and bit definitions into i2c-pxa.cEric Miao
2008-10-07[ARM] pxa: fix incorrect initialization of mfp sysdev when not pxa2xxEric Miao
The initialization of mfp sysdev in pxa2xx_mfp_init() shall really be avoided when !cpu_is_pxa2xx(). Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07Merge branches 'pxa-core' and 'pxa-machines' into pxa-allRussell King
Conflicts: arch/arm/mach-pxa/Kconfig arch/arm/mach-pxa/pxa25x.c arch/arm/mach-pxa/pxa27x.c
2008-10-07Merge branch 'for_rmk' of git://git.mnementh.co.uk/linux-2.6-imRussell King
Merge branch 'pxa-eseries' into pxa-machines Conflicts: arch/arm/mach-pxa/Makefile
2008-10-07Merge branch 'viper-for-rmk' of git://www.misterjones.org/linux-2.6-armRussell King
Merge branch 'pxa-viper' into pxa-machines Conflicts: arch/arm/mach-pxa/Makefile drivers/pcmcia/Kconfig drivers/pcmcia/Makefile
2008-10-07Merge branch 'pxa-palm' into pxa-machinesRussell King
Conflicts: drivers/mfd/Kconfig drivers/pcmcia/Makefile
2008-10-07Merge branch 'pxa-trizeps' into pxa-machinesRussell King
Conflicts: drivers/pcmcia/Makefile
2008-10-07Merge branches 'metronomefb', 'pxa-cm2xx', 'pxa-gumstix', 'pxa-misc', ↵Russell King
'pxa-mitac', 'pxa-mp900', 'pxa-zylonite' and 'pxa-zaurus' into pxa-machines Conflicts: arch/arm/mach-pxa/poodle.c
2008-10-07[ARM] 5285/1: pxa: update xm_x2xx_defconfigMike Rapoport
Signed-off-by: Russ Dill <russ.dill@gmail.com> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] 5284/1: pxa: cm-x255: add NOR and NAND flash supportMike Rapoport
This patch adds support for NOR and NAND flashes on CM-X255. The NAND flash support uses not yet merged GPIO NAND driver. Signed-off-by: Russ Dill <russ.dill@gmail.com> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-07[ARM] 5282/1: pxa: add CM-X255 supportMike Rapoport
2008-10-07[ARM] 5281/1: pxa: split cm-x2xx.c to cm-x2xx.c and cm-x270.cMike Rapoport
