Tune Colibri VF SoM defconfig for backports-5.4.
Related-to: ELB-2724
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
This is the 4.4.220 stable release
[ Upstream commit 27f13774654ea6bd0b6fc9b97cce8d19e5735661 ]
'dma-ranges' in a PCI bridge node does correctly set dma masks for PCI
devices not described in the DT. Certain DRA7 platforms (e.g., DRA76)
has RAM above 32-bit boundary (accessible with LPAE config) though the
PCIe bridge will be able to access only 32-bits. Add 'dma-ranges'
property in PCIe RC DT nodes to indicate the host bridge can access
only 32 bits.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
This is the 4.4.217 stable release
commit f87b1c49bc675da30d8e1e8f4b60b800312c7b90 upstream.
When the uaccess .fixup section was renamed to .text.fixup, one case was
missed. Under ld.bfd, the orphaned section was moved close to .text
(since they share the "ax" bits), so things would work normally on
uaccess faults. Under ld.lld, the orphaned section was placed outside
the .text section, making it unreachable.
Link: https://github.com/ClangBuiltLinux/linux/issues/282
Link: https://bugs.chromium.org/p/chromium/issues/detail?id=1020633#c44
Link: https://lore.kernel.org/r/nycvar.YSQ.7.76.1912032147340.17114@knanqh.ubzr
Link: https://lore.kernel.org/lkml/202002071754.F5F073F1D@keescook/
Fixes: c4a84ae39b4a5 ("ARM: 8322/1: keep .text and .fixup regions closer together")
Cc: stable@vger.kernel.org
Reviewed-by: Ard Biesheuvel <ardb@kernel.org>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
commit 45939ce292b4b11159719faaf60aba7d58d5fe33 upstream.
It is possible for a system with an ARMv8 timer to run a 32-bit kernel.
When this happens we will unconditionally have the vDSO code remove the
__vdso_gettimeofday and __vdso_clock_gettime symbols because
cntvct_functional() returns false since it does not match that
compatibility string.
Fixes: ecf99a439105 ("ARM: 8331/1: VDSO initialization, mapping, and synchronization")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
commit 512a928affd51c2dc631401e56ad5ee5d5dd68b6 upstream.
This function is not only needed by the platform suspend code, but is also
reused as the CPU resume function when the ARM cores can be powered down
completely in deep idle, which is the case on i.MX6SX and i.MX6UL(L).
Providing the static inline stub whenever CONFIG_SUSPEND is disabled means
that those platforms will hang on resume from cpuidle if suspend is disabled.
So there are two problems:
- The static inline stub masks the linker error
- The function is not available where needed
Fix both by just building the function unconditionally, when
CONFIG_SOC_IMX6 is enabled. The actual code is three instructions long,
so it's arguably ok to just leave it in for all i.MX6 kernel configurations.
Fixes: 05136f0897b5 ("ARM: imx: support arm power off in cpuidle for i.mx6sx")
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Signed-off-by: Ahmad Fatoum <a.fatoum@pengutronix.de>
Signed-off-by: Rouven Czerwinski <r.czerwinski@pengutronix.de>
[ Upstream commit 76950f7162cad51d2200ebd22c620c14af38f718 ]
To perform the reserve_crashkernel() operation kexec uses SECTION_SIZE to
find a memblock in a range.
SECTION_SIZE is not defined for nommu systems. Trying to compile kexec in
these conditions results in a build error:
linux/arch/arm/kernel/setup.c: In function ‘reserve_crashkernel’:
linux/arch/arm/kernel/setup.c:1016:25: error: ‘SECTION_SIZE’ undeclared
(first use in this function); did you mean ‘SECTIONS_WIDTH’?
crash_size, SECTION_SIZE);
SECTIONS_WIDTH
linux/arch/arm/kernel/setup.c:1016:25: note: each undeclared identifier
is reported only once for each function it appears in
linux/scripts/Makefile.build:265: recipe for target 'arch/arm/kernel/setup.o'
failed
Make KEXEC depend on MMU to fix the compilation issue.
Signed-off-by: Vincenzo Frascino <vincenzo.frascino@arm.com>
[ Upstream commit 8443ffd1bbd5be74e9b12db234746d12e8ea93e2 ]
Add a device node for the global timer, which is part of the Cortex-A9
MPCore.
The global timer can serve as an accurate (4 ns) clock source for
scheduling and delay loops.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Link: https://lore.kernel.org/r/20191211135222.26770-4-geert+renesas@glider.be
This is the 4.4.214 stable release
commit a7e0f3fc01df4b1b7077df777c37feae8c9e8b6d upstream.
The clock rate range for the TCB1 clock is missing. define it in the device
tree.
Reported-by: Karl Rudbæk Olsen <karl@micro-technic.com>
Fixes: d2e8190b7916 ("ARM: at91/dt: define sama5d3 clocks")
Link: https://lore.kernel.org/r/20200110172007.1253659-2-alexandre.belloni@bootlin.com
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
commit ee0aa926ddb0bd8ba59e33e3803b3b5804e3f5da upstream.
Currently the maximum rate for peripheral clock is calculated based on a
typical 133MHz MCK. The maximum frequency is defined in the datasheet as a
ratio to MCK. Some sama5d3 platforms are using a 166MHz MCK. Update the
device trees to match the maximum rate based on 166MHz.
Link: https://lore.kernel.org/r/20200110172007.1253659-1-alexandre.belloni@bootlin.com
commit 1a3388d506bf5b45bb283e6a4c4706cfb4897333 upstream.
For a little over a year, U-Boot has configured the flow controller to
perform automatic RAM re-repair on off->on power transitions of the CPU
rail[1]. This is mandatory for correct operation of Tegra124. However,
RAM re-repair relies on certain clocks, which the kernel must enable and
leave running. PLLP is one of those clocks. This clock is shut down
during LP1 in order to save power. Enable bypass (which I believe routes
osc_div_clk, essentially the crystal clock, to the PLL output) so that
this clock signal toggles even though the PLL is not active. This is
required so that LP1 power mode (system suspend) operates correctly.
The bypass configuration must then be undone when resuming from LP1, so
that all peripheral clocks run at the expected rate. Without this, many
peripherals won't work correctly; for example, the UART baud rate would
be incorrect.
NVIDIA's downstream kernel code only does this if not compiled for
Tegra30, so the added code is made conditional upon the chip ID.
NVIDIA's downstream code makes this change conditional upon the active
CPU cluster. The upstream kernel currently doesn't support cluster
switching, so this patch doesn't test the active CPU cluster ID.
[1] 3cc7942a4ae5 ARM: tegra: implement RAM repair
Reported-by: Jonathan Hunter <jonathanh@nvidia.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
[ Upstream commit 63a0666bca9311f35017be454587f3ba903644b8 ]
Fix lack of keyboard interrupts for RiscPC due to incorrect conversion.
Fixes: e8d36d5dbb6a ("ARM: kill off set_irq_flags usage")
[ Upstream commit 9ee8578d953023cc57e7e736ae48502c707c0210 ]
Since commit 1c459de1e645 ("ARM: pxa: ssp: use devm_ functions")
kfree, iounmap, clk_put etc are not needed anymore in remove path.
Fixes: 1c459de1e645 ("ARM: pxa: ssp: use devm_ functions")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
[ commit message spelling fix ]
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
[ Upstream commit 7f0d078667a494466991aa7133f49594f32ff6a2 ]
Commit 747834ab8347 ("ARM: OMAP2+: hwmod: revise hardreset behavior") made
the call to _enable() conditional based on no oh->rst_lines_cnt. This
caused the return value to be potentially uninitialized. Curiously we see
no compiler warnings for this, probably as this gets inlined.
We call _setup_reset() from _setup() and only _setup_postsetup() if the
return value is zero. Currently the return value can be uninitialized for
cases where oh->rst_lines_cnt is set and HWMOD_INIT_NO_RESET is not set.
Fixes: 747834ab8347 ("ARM: OMAP2+: hwmod: revise hardreset behavior")
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Tero Kristo <t-kristo@ti.com>
[ Upstream commit ca70ea43f80c98582f5ffbbd1e6f4da2742da0c4 ]
MCPM does a soft reset of the CPUs and uses common cpu_resume() routine to
perform low-level platform initialization. This results in a try to install
HYP stubs for the second time for each CPU and results in false HYP/SVC
mode mismatch detection. The HYP stubs are already installed at the
beginning of the kernel initialization on the boot CPU (head.S) or in the
secondary_startup() for other CPUs. To fix this issue MCPM code should use
a cpu_resume() routine without HYP stubs installation.
This change fixes HYP/SVC mode mismatch on Samsung Exynos5422-based Odroid
XU3/XU4/HC1 boards.
Fixes: 3721924c8154 ("ARM: 8081/1: MCPM: provide infrastructure to allow for MCPM loopback")
Acked-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Anand Moon <linux.amoon@gmail.com>
[ Upstream commit c6b16761c6908d3dc167a0a566578b4b0b972905 ]
The LCD panel on AM4 GP EVMs and ePOS boards seems to be
osd070t1718-19ts. The current dts files say osd057T0559-34ts. Possibly
the panel has changed since the early EVMs, or there has been a mistake
with the panel type.
Update the DT files accordingly.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
[ Upstream commit 2a76352ad2cc6b78e58f737714879cc860903802 ]
Currently we add individual copy of same OPP table for each CPU within
the cluster. This is redundant and doesn't reflect the reality.
We can't use core cpumask to set policy->cpus in ve_spc_cpufreq_init()
anymore as it gets called via cpuhp_cpufreq_online()->cpufreq_online()
->cpufreq_driver->init() and the cpumask gets updated upon CPU hotplug
operations. It also may cause issues when the vexpress_spc_cpufreq
driver is built as a module.
Since ve_spc_clk_init is built-in device initcall, we should be able to
use the same topology_core_cpumask to set the opp sharing cpumask via
dev_pm_opp_set_sharing_cpus and use the same later in the driver via
dev_pm_opp_get_sharing_cpus.
Cc: Liviu Dudau <liviu.dudau@arm.com>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Tested-by: Dietmar Eggemann <dietmar.eggemann@arm.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
[ Upstream commit a8de1304b7df30e3a14f2a8b9709bb4ff31a0385 ]
The DTC v1.5.1 added references to (U)INT32_MAX.
This is no problem for user-space programs since <stdint.h> defines
(U)INT32_MAX along with (u)int32_t.
For the kernel space, libfdt_env.h needs to be adjusted before we
pull in the changes.
In the kernel, we usually use s/u32 instead of (u)int32_t for the
fixed-width types.
Accordingly, we already have S/U32_MAX for their max values.
So, we should not add (U)INT32_MAX to <linux/limits.h> any more.
Instead, add them to the in-kernel libfdt_env.h to compile the
latest libfdt.
Signed-off-by: Rob Herring <robh@kernel.org>
commit d70f7d31a9e2088e8a507194354d41ea10062994 upstream.
There is an unfortunate typo in the code that results in writing to
FLOW_CTLR_HALT instead of FLOW_CTLR_CSR.
Cc: <stable@vger.kernel.org>
Acked-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
commit d60d0cff4ab01255b25375425745c3cff69558ad upstream.
fin_pll is the parent of clock-controller@7e00f000, specify
the dependency to ensure proper initialization order of clock
providers.
without this patch:
[ 0.000000] S3C6410 clocks: apll = 0, mpll = 0
[ 0.000000] epll = 0, arm_clk = 0
with this patch:
[ 0.000000] S3C6410 clocks: apll = 532000000, mpll = 532000000
[ 0.000000] epll = 24000000, arm_clk = 532000000
Fixes: 3f6d439f2022 ("clk: reverse default clk provider initialization order in of_clk_init()")
Signed-off-by: Lihua Yao <ylhuajnu@outlook.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
[ Upstream commit 287897f9aaa2ad1c923d9875914f57c4dc9159c8 ]
The MMC card detection GPIO polarity is active low on TAO3530, like in many
other similar boards. Now the card is not detected and it is unable to
mount rootfs from an SD card.
Fix this by using the correct polarity.
This incorrect polarity was defined already in the commit 30d95c6d7092
("ARM: dts: omap3: Add Technexion TAO3530 SOM omap3-tao3530.dtsi") in v3.18
kernel and later changed to use defined GPIO constants in v4.4 kernel by
the commit 3a637e008e54 ("ARM: dts: Use defined GPIO constants in flags
cell for OMAP2+ boards").
While the latter commit did not introduce the issue I'm marking it with
Fixes tag due the v4.4 kernels still being maintained.
Fixes: 3a637e008e54 ("ARM: dts: Use defined GPIO constants in flags cell for OMAP2+ boards")
Cc: linux-stable <stable@vger.kernel.org> # 4.4+
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
[ Upstream commit 5719ac19fc32d892434939c1756c2f9a8322e6ef ]
"arm,cortex-a15-pmu" is not a valid fallback compatible string for an
Cortex-A7 PMU, so drop it.
Cc: Maxime Ripard <maxime.ripard@bootlin.com>
Cc: Chen-Yu Tsai <wens@csie.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
[ Upstream commit c40ad24254f1dbd54f2df5f5f524130dc1862122 ]
PXA25xx SoCs don't have a USB controller, so drop the node from the
common pxa2xx.dtsi base file. Both pxa27x and pxa3xx have a dedicated
node already anyway.
While at it, unify the names for the nodes across all pxa platforms.
Signed-off-by: Daniel Mack <daniel@zonque.org>
Reported-by: Sergey Yanovich <ynvich@gmail.com>
Link: https://patchwork.kernel.org/patch/8375421/
[ Upstream commit 400583983f8a8e95ec02c9c9e2b50188753a87fb ]
gpio-pxa uses two cell to encode the interrupt source: the pin number
and the trigger type. Adjust the device node accordingly.
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Acked-by: Pavel Machek <pavel@ucw.cz>
[ Upstream commit 04a92358b3964988c78dfe370a559ae550383886 ]
Currently we get extra newlines on OMAP1/2 when the SoC name is printed:
[ 0.000000] OMAP1510
[ 0.000000] revision 2 handled as 15xx id: bc058c9b93111a16
[ 0.000000] OMAP2420
[ 0.000000]
Fix by using pr_cont.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
[ Upstream commit 6035cbcceb069f87296b3cd0bc4736ad5618bf47 ]
DWC2 hardware module integrated in Samsung SoCs requires some quirks to
operate properly, so use Samsung SoC specific compatible to notify driver
to apply respective fixes.
[ Upstream commit 344eb5539abf3e0b6ce22568c03e86450073e097 ]
getuser() and putuser() (and there underscored variants) use two
strb[t]/ldrb[t] instructions when they are asked to get/put 16-bits.
This means that the read/write is not atomic even when performed to a
16-bit-aligned address.
This leads to problems with vhost: vhost uses __getuser() to read the
vring's 16-bit avail.index field, and if it happens to observe a partial
update of the index, wrong descriptors will be used which will lead to a
breakdown of the virtio communication. A similar problem exists for
__putuser() which is used to write to the vring's used.index field.
The reason these functions use strb[t]/ldrb[t] is because strht/ldrht
instructions did not exist until ARMv6T2/ARMv7. So we should be easily
able to fix this on ARMv7. Also, since all ARMv6 processors also don't
actually use the unprivileged instructions anymore for uaccess (since
CONFIG_CPU_USE_DOMAINS is not used) we can easily fix them too.
Signed-off-by: Vincent Whitchurch <vincent.whitchurch@axis.com>
[ Upstream commit 4aa64677330beeeed721b4b122884dabad845d66 ]
WARNING: vmlinux.o(.text+0x13250): Section mismatch in reference from the function acs5k_i2c_init() to the (unknown reference) .init.data:(unknown)
The function acs5k_i2c_init() references
the (unknown reference) __initdata (unknown).
This is often because acs5k_i2c_init lacks a __initdata
annotation or the annotation of (unknown) is wrong.
[ Upstream commit 998a84c27a7f3f9133d32af64e19c05cec161a1a ]
imx53-voipac-dmm-668 has two memory nodes, but the correct representation
would be to use a single one with two reg entries - one for each RAM chip
select, so fix it accordingly.
Reported-by: Marco Franchi <marco.franchi@nxp.com>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
[ Upstream commit 7c41ea57beb2aee96fa63091a457b1a2826f3c42 ]
If debugging on i.MX is enabled DEBUG_IMX_UART_PORT defines which UART
is used for the debug output. If however debugging is off don't only
hide the then unused config item but drop it completely by using a
dependency instead of a conditional prompt.
This fixes DEBUG_IMX_UART_PORT being present in the kernel config even
if DEBUG_LL is disabled.
[ Upstream commit f18aef742c8fbd68e280dff0a63ba0ca6ee8ad85 ]
On at least x86 and ARM64, and as documented in the ptrace man page
a skipped system call will still cause a syscall exit ptrace stop.
Previous to this commit 32-bit ARM did not, resulting in strace
being confused when seccomp skips system calls.
This change also impacts programs that use ptrace to skip system calls.
Fixes: ad75b51459ae ("ARM: 7579/1: arch/allow a scno of -1 to not cause a SIGILL")
Signed-off-by: Timothy E Baldwin <T.E.Baldwin99@members.leeds.ac.uk>
Signed-off-by: Eugene Syromyatnikov <evgsyr@gmail.com>
Tested-by: Kees Cook <keescook@chromium.org>
Tested-by: Eugene Syromyatnikov <evgsyr@gmail.com>
[ Upstream commit 1c997fe4becdc6fcbc06e23982ceb65621e6572a ]
Fix MMC1 cmd pin pull-up causing issues on carrier boards without
external pull-up.
[ Upstream commit 564706f65cda3de52b09e51feb423a43940fe661 ]
There was a dot instead of a comma. Fix this.
[ Upstream commit 2f967f9e9fa076affb711da1a8389b5d33814fc6 ]
SPI controller nodes should be named 'spi' rather than 'ssp'. Fixing the
name enables dtc SPI bus checks.
[ Upstream commit ecde29569e3484e1d0a032bf4074449bce4d4a03 ]
The "lcdaclk_b_1" group is muxed with the function "lcd"
but needs a separate entry to be muxed in with "lcda"
rather than "lcd".
[ Upstream commit 2f217d24ecaec2012e628d21e244eef0608656a4 ]
The unit address of the Cortex-A9 SCU device node contains one zero too
many. Remove it.
[ Upstream commit dcbf6b18d81bcdc51390ca1b258c17e2e13b7d0c ]
am335x-evm has only one CPSW external port physically wired, but DT defines
2 ext. ports. As result, PHY connection failure reported for the second
ext. port.
Update DT to reflect am335x-evm board HW configuration, and, while here,
switch to use phy-handle instead of phy_id.
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
[ Upstream commit 53dd9dce6979bc54d64a3a09a2fb20187a025be7 ]
The next update of libfdt has a new dependency on INT_MAX. Update the
instances of libfdt_env.h in the kernel to either include the necessary
header with the definition or define it locally.
Cc: Russell King <linux@armlinux.org.uk>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: linuxppc-dev@lists.ozlabs.org
[ Upstream commit cbbc488ed85061a765cf370c3e41f383c1e0add6 ]
dtc has new checks for I2C buses. Fix the warnings in unit-addresses.
arch/arm/boot/dts/socfpga_cyclone5_de0_sockit.dtb: Warning (i2c_bus_reg): /soc/i2c@ffc04000/adxl345@0: I2C bus unit address format error, expected "53"
Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
[ Upstream commit 8148d2136002da2e2887caf6a07bbd9c033f14f3 ]
One of the Freescale recommended sequences for power off with external
PMIC is the following:
3. SoC is programming PMIC for power off when standby is asserted.
4. In CCM STOP mode, Standby is asserted, PMIC gates SoC supplies.
See:
http://www.nxp.com/assets/documents/data/en/reference-manuals/IMX6DQRM.pdf
page 5083
This patch implements step 4. of this sequence.
Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de>
[ Upstream commit 1ae00833e30c9b4af5cbfda65d75b1de12f74013 ]
This is needed to make the display and venc work properly.
Compare to omap3-beagle.dts.
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
[ Upstream commit fa99c21ecb3cd4021a60d0e8bf880e78b5bd0729 ]
Vendor defined U-Boot has changed the partition scheme a while ago:
* kernel partition 6MB
* file system partition uses the remainder up to end of the NAND
* increased size of the environment partition (to get an OneNAND compatible base address)
* shrink the U-Boot partition
Let's be compatible (e.g. Debian kernel built from upstream).
[ Upstream commit 8905592b6e50cec905e6c6035bbd36201a3bfac1 ]
The omap dss susbystem takes the display aliases to find
out which displays exist. To enable tv-out we must define
an alias.
other DTS files
[ Upstream commit fa0d7dc355c890725b6178dab0cc11b194203afa ]
needed for device variants based on GTA04 board but with
different display panel (driver).
[ Upstream commit 8a1ecc01a473b75ab97be9b36f623e4551a6e9ae ]
There is one too many zeroes in the Power I2C base address. Fix this.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
[ Upstream commit 64858773d78e820003a94e5a7179d368213655d6 ]
This patch adds missing properties to the CODEC and sound nodes, so the
audio will work also on Snow rev5 Chromebook. This patch is an extension
to the commit e9eefc3f8ce0 ("ARM: dts: exynos: Add missing clock and
DAI properties to the max98095 node in Snow Chromebook")
and commit 6ab569936d60 ("ARM: dts: exynos: Enable HDMI audio on Snow
Chromebook"). It has been reported that such changes work fine on the
rev5 board too.
[krzk: Fixed typo in phandle to &max98090]
[ Upstream commit 10af10db8c76fa5b9bf1f52a895c1cb2c0ac24da ]
Fix a typo. No functional change made by this patch.
Signed-off-by: Jay Foster <jayfoster@ieee.org>
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Commit d6951f582cc50ba0ad22ef46b599740966599b14 upstream.
The intention in the previous patch was to only place the processor
tables in the .rodata section if big.Little was being built and we
wanted the branch target hardening, but instead (due to the way it
was tested) it ended up always placing the tables into the .rodata
section.
Although harmless, let's correct this anyway.
Fixes: 3a4d0c2172bc ("ARM: ensure that processor vtables is not lost after boot")
Signed-off-by: David A. Long <dave.long@linaro.org>
Reviewed-by: Julien Thierry <julien.thierry@arm.com>
Signed-off-by: Ard Biesheuvel <ardb@kernel.org>
