Out-of-the-box the analogue camera adapter fails detecting with the
following error:
[ 6.503046] adv7280 2-0021: adv7280_probe:Analog Device adv7280 not detected -6!
Unfortunately, the camera seems to be held in reset due to the BL_ON pin
not being serviced.
Fix this by hogging the camera_nreset aka BL_ON pin to output high.
Related-to: ELB-2580
The MAC of the i.MX6 SoC is compliant with RGMII v1.3. The KSZ9131 PHY
is like KSZ9031 adhering to RGMII v2.0 specification. This means the
MAC should provide a delay to the TXC line. Because the i.MX6 MAC does
not provide this delay this has to be done in the PHY.
This patch adds by default ~1.4ns delay to the TXC line. This should
be good for all boards that have all RGMII signals routed with the
same length.
The KSZ9131 has relatively high tolerances on skew registers from
MMD 2.4 to MMD 2.8. Therefore the new DLL-based delay of 2ns is used
and then as little as possibly subtracted from that so we get more
accurate delay. This is actually needed because the i.MX6 SoC has
an asyn skew on TXC from -100ps to 900ps.
Related-to: ELB-1299
eMMC, used in Colibri iMX7D eMMC modules, supports
200Mhz mode with vccq=1.8v.
Remove the max-frequency limit, it increases the performance significantly:
== before fix ====
root@colibri-imx7-emmc:~# hdparm -t /dev/mmcblk1
/dev/mmcblk1:
Timing buffered disk reads: `^H252 MB in 3.02 seconds = 83.54 MB/sec
=== after fix ====
root@colibri-imx7-emmc:~# hdparm -t /dev/mmcblk0
/dev/mmcblk0:
Timing buffered disk reads: 408 MB in 3.00 seconds = 135.94 MB/sec
Related-to: ELB-1442
Fixes: f928a4a377e4 ("ARM: dts: imx7: add Toradex Colibri iMX7D
1GB (eMMC) support")
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
The interface of Apalis modules is MXM3, not SODIMM.
Just fix the name of the reset touch pin.
Fixes: 96458caa3562 ("ARM: dts: imx6: Add touchscreens used
on Toradex eval boards")
This fixes the following systemd error during boot:
[ 4.225226] systemd[1]: File /lib/systemd/system/systemd-journald.
service:36 configures an IP firewall (IPAddressDeny=any), but the local
system does not support BPF/cgroup based firewalling.
[ 4.242360] systemd[1]: Proceeding WITHOUT firewalling in effect!
(This warning is only shown for the first loaded unit using IP
firewalling.)
(similar to arm64 commit cfbad309c60a13bb7fb0ad4b1139a52d485db0cd)
toradex_4.14-2.0.x-imx-next
sound/soc/codecs/sgtl5000.c
This is the 4.14.159 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6sx.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/input/keyboard/imx_keypad.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
[ Upstream commit 2398c41d64321e62af54424fd399964f3d48cdc2 ]
With a wl1251 child node of mmc3 in the device tree decoded
in omap_hsmmc.c to handle special wl1251 initialization, we do
no longer need to instantiate the mmc3 through pdata quirks.
We also can remove the wlan regulator and reset/interrupt definitions
and do them through device tree.
Fixes: 81eef6ca9201 ("mmc: omap_hsmmc: Use dma_request_chan() for requesting DMA channel")
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
Cc: <stable@vger.kernel.org> # v4.7+
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 287897f9aaa2ad1c923d9875914f57c4dc9159c8 upstream.
The MMC card detection GPIO polarity is active low on TAO3530, like in many
other similar boards. Now the card is not detected and it is unable to
mount rootfs from an SD card.
Fix this by using the correct polarity.
This incorrect polarity was defined already in the commit 30d95c6d7092
("ARM: dts: omap3: Add Technexion TAO3530 SOM omap3-tao3530.dtsi") in v3.18
kernel and later changed to use defined GPIO constants in v4.4 kernel by
the commit 3a637e008e54 ("ARM: dts: Use defined GPIO constants in flags
cell for OMAP2+ boards").
While the latter commit did not introduce the issue I'm marking it with
Fixes tag due the v4.4 kernels still being maintained.
Fixes: 3a637e008e54 ("ARM: dts: Use defined GPIO constants in flags cell for OMAP2+ boards")
Cc: linux-stable <stable@vger.kernel.org> # 4.4+
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
commit 4f9007d692017cef38baf2a9b82b7879d5b2407b upstream.
Since v4.7 the dma initialization requires that there is a
device tree property for "rx" and "tx" channels which is
not provided by the pdata-quirks initialization.
By conversion of the mmc3 setup to device tree this will
finally allows to remove the OpenPandora wlan specific omap3
data-quirks.
[ Upstream commit 5719ac19fc32d892434939c1756c2f9a8322e6ef ]
"arm,cortex-a15-pmu" is not a valid fallback compatible string for an
Cortex-A7 PMU, so drop it.
Cc: Maxime Ripard <maxime.ripard@bootlin.com>
Cc: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Rob Herring <robh@kernel.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Maxime Ripard <maxime.ripard@bootlin.com>
[ Upstream commit f3b2f758ec1e6cdb13c925647cbd8ad4938b78fb ]
There's a bug in dtc in checking for duplicate node names when there's
another section (e.g. "/ { };"). In this case, skeleton.dtsi provides
another section. Upon removal of skeleton.dtsi, the dtb fails to build
due to a duplicate node 'fixedregulator@0'. As both nodes were pretty
much the same 3.3V fixed regulator, it hasn't really mattered. Fix this
by renaming the nodes to something unique. In the process, drop the
unit-address which shouldn't be present wtihout reg property.
[ Upstream commit c40ad24254f1dbd54f2df5f5f524130dc1862122 ]
PXA25xx SoCs don't have a USB controller, so drop the node from the
common pxa2xx.dtsi base file. Both pxa27x and pxa3xx have a dedicated
node already anyway.
While at it, unify the names for the nodes across all pxa platforms.
Signed-off-by: Daniel Mack <daniel@zonque.org>
Reported-by: Sergey Yanovich <ynvich@gmail.com>
Link: https://patchwork.kernel.org/patch/8375421/
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
[ Upstream commit 7f4b001b7f6e0480b5bdab9cd8ce1711e43e5cb5 ]
Cc: Linus Walleij <linus.walleij@linaro.org>
[ Upstream commit 400583983f8a8e95ec02c9c9e2b50188753a87fb ]
gpio-pxa uses two cell to encode the interrupt source: the pin number
and the trigger type. Adjust the device node accordingly.
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Acked-by: Pavel Machek <pavel@ucw.cz>
[ Upstream commit 04a92358b3964988c78dfe370a559ae550383886 ]
Currently we get extra newlines on OMAP1/2 when the SoC name is printed:
[ 0.000000] OMAP1510
[ 0.000000] revision 2 handled as 15xx id: bc058c9b93111a16
[ 0.000000] OMAP2420
[ 0.000000]
Fix by using pr_cont.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
[ Upstream commit f6628486c8489e91c513b62608f89ccdb745600d ]
Cyclone5 and Arria10 doesn't have the same memory map for UART1.
Split the SOCFPGA_UART1 into 2 options to allow debugging on UART1 for Cyclone5.
Signed-off-by: Clément Péron <peron.clem@gmail.com>
Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
[ Upstream commit 438a44ce7e51ce571f942433c6c7cb87c4c0effd ]
All our pinctrl nodes were using a node name convention with a unit-address
to differentiate the different muxing options. However, since those nodes
didn't have a reg property, they were generating warnings in DTC.
In order to accomodate for this, convert the old nodes to the syntax we've
been using for the new SoCs, including removing the letter suffix of the
node labels to the bank of those pins to make things more readable.
Acked-by: Chen-Yu Tsai <wens@csie.org>
[ Upstream commit ed5fc60b909427be6ca93d3e07a0a5f296d7000a ]
Our HDMI output endpoint on the A10s DTSI has a warning under DTC: "graph
node has single child node 'endpoint', #address-cells/#size-cells are not
necessary". Fix this by removing those properties.
[ Upstream commit efc2e0bd9594060915696a418564aefd0270b1d6 ]
It is not correct to assign the 24MHz clock oscillator to the GPIO
ports.
Fix it by assigning the proper GPIO clocks instead.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Tested-by: Fabio Berton <fabio.berton@ossystems.com.br>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
[ Upstream commit c955b7aec510145129ca7aaea6ecbf6d748f5ebf ]
According to the Rockchip vendor tree the PMU interrupt number is
76, so fix it accordingly.
[ Upstream commit 6035cbcceb069f87296b3cd0bc4736ad5618bf47 ]
DWC2 hardware module integrated in Samsung SoCs requires some quirks to
operate properly, so use Samsung SoC specific compatible to notify driver
to apply respective fixes.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
[ Upstream commit 03d9f8fa2bfdc791865624d3adc29070cf67814e ]
There is no functional change from this, but it is confusing to find two
copies of vcc_sys and no vcc_flash when looking in
/sys/class/regulator/*/name.
Signed-off-by: John Keeping <john@metanate.com>
[ Upstream commit 344eb5539abf3e0b6ce22568c03e86450073e097 ]
getuser() and putuser() (and there underscored variants) use two
strb[t]/ldrb[t] instructions when they are asked to get/put 16-bits.
This means that the read/write is not atomic even when performed to a
16-bit-aligned address.
This leads to problems with vhost: vhost uses __getuser() to read the
vring's 16-bit avail.index field, and if it happens to observe a partial
update of the index, wrong descriptors will be used which will lead to a
breakdown of the virtio communication. A similar problem exists for
__putuser() which is used to write to the vring's used.index field.
The reason these functions use strb[t]/ldrb[t] is because strht/ldrht
instructions did not exist until ARMv6T2/ARMv7. So we should be easily
able to fix this on ARMv7. Also, since all ARMv6 processors also don't
actually use the unprivileged instructions anymore for uaccess (since
CONFIG_CPU_USE_DOMAINS is not used) we can easily fix them too.
Signed-off-by: Vincent Whitchurch <vincent.whitchurch@axis.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
This driver supports Toradex USB WiFi module LP816.
[ Upstream commit 4aa64677330beeeed721b4b122884dabad845d66 ]
WARNING: vmlinux.o(.text+0x13250): Section mismatch in reference from the function acs5k_i2c_init() to the (unknown reference) .init.data:(unknown)
The function acs5k_i2c_init() references
the (unknown reference) __initdata (unknown).
This is often because acs5k_i2c_init lacks a __initdata
annotation or the annotation of (unknown) is wrong.
[ Upstream commit c7b7b5cbd0c859b1546a5a3455d457708bdadf4c ]
Currently we do USB configuration only if the host mode (CONFIG_USB)
is enabled. But it should be done also in the case of device-only setups,
so change the condition to CONFIG_USB_SUPPORT. This allows to use
omap_udc on Palm Tungsten E.
[ Upstream commit 998a84c27a7f3f9133d32af64e19c05cec161a1a ]
imx53-voipac-dmm-668 has two memory nodes, but the correct representation
would be to use a single one with two reg entries - one for each RAM chip
select, so fix it accordingly.
Reported-by: Marco Franchi <marco.franchi@nxp.com>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
[ Upstream commit 7c41ea57beb2aee96fa63091a457b1a2826f3c42 ]
If debugging on i.MX is enabled DEBUG_IMX_UART_PORT defines which UART
is used for the debug output. If however debugging is off don't only
hide the then unused config item but drop it completely by using a
dependency instead of a conditional prompt.
This fixes DEBUG_IMX_UART_PORT being present in the kernel config even
if DEBUG_LL is disabled.
[ Upstream commit d88b11ef91b15d0af9c0676cbf4f441a0dff0c56 ]
This sets the partition information on the SQ201 to be read
out from the RedBoot partition table, removes the static
partition table and sets our boot options to mount root from
/dev/mtdblock2 where the squashfs+JFFS2 resides.
This reverts commit d627db185347ab6f551560bab08526a5e8805ea8.
There is now a mainline variant for a regulator-fixed to be enabled
by a clock. Make use of this newly cherry-picked mainline feature.
Enable building all RPMsg drivers.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
commit 1d31999cf04c21709f72ceb17e65b54a401330da upstream.
adjust_lowmem_bounds() checks every memblocks in order to find the boundary
between lowmem and highmem. However some memblocks could be marked as NOMAP
so they are not used by kernel, which should be skipped while calculating
the boundary.
Signed-off-by: Chester Lin <clin@suse.com>
Reviewed-by: Mike Rapoport <rppt@linux.ibm.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Some pinmuxings are obviously wrong, originating from a copy/paste
error. This patch corrects that with the following strategy:
- Set all reserved bits to zero
- Leave drive strength and slew rate as is
- Add sensible pull and hysteresis depending on the function of the pin
- Not used pins are muxed to their reset-value defined by the SoC
[ Upstream commit a763ecc15d0e37c3a15ff6825183061209832685 ]
OMAP5's Super-Speed USB port has a software mailbox register
that needs to be fed with VBUS and ID events from an external
VBUS/ID comparator.
Without this, Host role will not work correctly.
Fixes: 656c1a65ab55 ("ARM: dts: omap5: enable OTG role for DWC3 controller")
Reported-by: H. Nikolaus Schaller <hns@goldelico.com>
Signed-off-by: Roger Quadros <rogerq@ti.com>
[ Upstream commit f18aef742c8fbd68e280dff0a63ba0ca6ee8ad85 ]
On at least x86 and ARM64, and as documented in the ptrace man page
a skipped system call will still cause a syscall exit ptrace stop.
Previous to this commit 32-bit ARM did not, resulting in strace
being confused when seccomp skips system calls.
This change also impacts programs that use ptrace to skip system calls.
Fixes: ad75b51459ae ("ARM: 7579/1: arch/allow a scno of -1 to not cause a SIGILL")
Signed-off-by: Timothy E Baldwin <T.E.Baldwin99@members.leeds.ac.uk>
Signed-off-by: Eugene Syromyatnikov <evgsyr@gmail.com>
Tested-by: Kees Cook <keescook@chromium.org>
Tested-by: Eugene Syromyatnikov <evgsyr@gmail.com>
[ Upstream commit 6f270d88a0c4a11725afd8fd2001ae408733afbf ]
at91sam9x5cm comes with a 2Gb NAND flash. Fix the rootfs size to
match this limit.
Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com>
Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com>
[ Upstream commit df90fc64367ffdb6f1b5c0f0c4940d44832b0174 ]
sama5d4_xplained comes with a 4Gb NAND flash. Increase the rootfs
size to match this limit.
[ Upstream commit 6c700289a3e84d5d3f2a95cf27732a7f7fce105b ]
The size of the register should be the size of the whole memory block,
not just the registers, that are needed.
Signed-off-by: Philipp Rossak <embed3d@gmail.com>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
[ Upstream commit 656c1a65ab555ee5c7cd0d6aee8ab82ca3c1795f ]
Since SMPS10 and OTG cable detection extcon are described here, and
work to enable OTG power when an OTG cable is plugged in, we can
define OTG mode in the controller (which is disabled by default in
omap5.dtsi).
Tested on OMAP5EVM and Pyra.
Suggested-by: Roger Quadros <rogerq@ti.com>
[ Upstream commit b830526f304764753fcb8b4a563a94080e982a6c ]
Add ti,syscon-unaligned-access property to PCIe RC nodes to set
appropriate bits in CTRL_CORE_SMA_SW_7 register to enable workaround for
errata i870.
Signed-off-by: Vignesh R <vigneshr@ti.com>
[ Upstream commit 11236ef582b8d66290bb3b3710e03ca1d85d8ad8 ]
SPI controller nodes should be named 'spi' rather than 'ssp'. Fixing the
name enables dtc SPI bus checks.
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: Sylvain Lemieux <slemieux.tyco@gmail.com>
[ Upstream commit 016add12977bcc30f77d7e48fc9a3a024cb46645 ]
[ Upstream commit ebea2a43fdafdbce918bd7e200b709d6c33b9f3b ]
The power key is controlled solely by the EC, which only tiggeres this
gpio after wakeup.
Fixes immediately return to suspend after wake from LP1.
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
Tested-by: Nicolas Chauvet <kwizart@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
[ Upstream commit 1c997fe4becdc6fcbc06e23982ceb65621e6572a ]
Fix MMC1 cmd pin pull-up causing issues on carrier boards without
external pull-up.
