The TNET variant of DaVinci compiles some code that it shares
with other DaVinci variants, however it has a V6 CPU rather than
an ARM926T, thus the hardcoded call to arm926_flush_kern_cache_all()
in sleep.S will obviously fail, and we need to build with the
v6_flush_kern_cache_all() call instead. This was triggered by
manually altering the DaVinci config to build the TNET version.
Cc: Dave Martin <dave.martin@linaro.org>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Cc: stable@kernel.org
MDSTAT.STATE occupies bits 0..5 according to all available documentation, so fix
the #define MDSTAT_STATE_MASK at last. Using the wrong value seems to have been
harmless though...
DA850/OMAP-L138 EMAC driver uses random mac address instead of
a fixed one because the mac address is not stuffed into EMAC
platform data.
This patch provides a function which reads the mac address
stored in SPI flash (registered as MTD device) and populates the
EMAC platform data. The function which reads the mac address is
registered as a callback which gets called upon addition of MTD
device.
NOTE: In case the MAC address stored in SPI flash is erased, follow
the instructions at [1] to restore it.
[1] http://processors.wiki.ti.com/index.php/GSG:_OMAP-L138_DVEVM_Additional_Procedures#Restoring_MAC_address_on_SPI_Flash
Modifications in v2:
Guarded registering the mtd_notifier only when MTD is enabled.
Earlier this was handled using mtd_has_partitions() call, but
this has been removed in Linux v3.0.
Modifications in v3:
a. Guarded da850_evm_m25p80_notify_add() function and
da850evm_spi_notifier structure with CONFIG_MTD macros.
b. Renamed da850_evm_register_mtd_user() function to
da850_evm_setup_mac_addr() and removed the struct mtd_notifier
argument to this function.
c. Passed the da850evm_spi_notifier structure to register_mtd_user()
function.
Modifications in v4:
Moved the da850_evm_setup_mac_addr() function within the first
CONFIG_MTD ifdef construct.
Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com>
Fighting unfixed U-Boots and other beasts that may the cache in
a locked-down state when starting the kernel, we make sure to
disable all cache lock-down when initializing the l2x0 so we
are in a known state.
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Rabin Vincent <rabin.vincent@stericsson.com>
Cc: Adrian Bunk <adrian.bunk@movial.com>
Cc: Rob Herring <robherring2@gmail.com>
Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Reported-by: Jan Rinze <janrinze@gmail.com>
Tested-by: Robert Marklund <robert.marklund@stericsson.com>
I was intrigued by the fact that the clock stood still on
the Integrator, but it wasn't strange at all, because the
timer was set up all wrong and probably has been for a
while. With this patch the clock starts ticking again:
make the timer periodic (reload), |= on the divisor bit
and load the timer before starting it.
The suspend/resume _noirq handlers were #ifdef'd out in the
!CONFIG_SUSPEND case, but were still assigned to the dev_pm_ops
struct. Fix by defining them to NULL in the !CONFIG_SUSPEND case.
Signed-off-by: Kevin Hilman <khilman@ti.com>
'omap4_clock_fixes_3.1rc', 'missing_2430_musb_adds_terminator_fix_3.1rc' and 'pwrdm_clkdm_fixes_3.1rc' into prcm-fixes-a-3.1rc
Add a missing array terminator to omap2430_usbhsotg_addrs[]. Without
this terminator, the omap_hwmod resource building code runs off the
end of the array, resulting in at least this error -- if not worse
behavior:
[ 0.578002] musb-omap2430: failed to claim resource 4
[ 0.583465] omap_device: musb-omap2430: build failed (-16)
[ 0.589294] Could not build omap_device for musb-omap2430 usb_otg_hs
This should have been part of commit
78183f3fdf76f422431a81852468be01b36db325 ("omap_hwmod: use a null
structure record to terminate omap_hwmod_addr_space arrays") but was
evidently missed.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
When ARCH_HAS_HOLES_MEMORYMODEL is selected, pfn_valid calls
memblock_is_memory to test validity of a pfn:
> memblock_is_memory(pfn << PAGE_SHIFT);
On LPAE systems this cuts off the top bits, as the shift occurs before
the value is promoted to a phys_addr_t.
This patch replaces the shift with a call to __pfn_to_phys (which casts
pfn to phys_addr_t before shifting), preventing the loss of significant
bits.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm:
ARM: pm: avoid writing the auxillary control register for ARMv7
ARM: pm: some ARMv7 requires a dsb in resume to ensure correctness
ARM: pm: arm920/926: fix number of registers saved
ARM: pm: CPU specific code should not overwrite r1 (v:p offset)
ARM: 7066/1: proc-v7: disable SCTLR.TE when disabling MMU
ARM: 7065/1: kexec: ensure new kernel is entered in ARM state
ARM: 7003/1: vexpress: Add clock definition for the SP805.
ARM: 7051/1: cpuimx* boards: fix mach-types errors
ARM: 7019/1: Footbridge: select CLKEVT_I8253 for ARCH_NETWINDER
ARM: 7015/1: ARM errata: Possible cache data corruption with hit-under-miss enabled
ARM: 7014/1: cache-l2x0: Fix L2 Cache size calculation.
ARM: 6967/1: ep93xx: ts72xx: fix board model detection
ARM: 6965/1: ep93xx: add model detection for ts-7300 and ts-7400 boards
ARM: cache: detect VIPT aliasing I-cache on ARMv6
ARM: twd: register clockevents device before enabling PPI
ARM: realview: ensure visibility of writes during reset
ARM: perf: make name of arm_pmu_type consistent
ARM: perf: fix prototype of release_pmu
ARM: fix perf build with uclibc toolchains
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
ARM: mach-footbridge: add missing header file <video/vga.h>
ARM: mach-orion5x: add missing header file <linux/vga.h>
arm: fix compile failure in orion5x/dns323-setup.c
at91: at91sam9261.c: fix typo in t2_clk alias for atmel_tcb.0
ARM: S5P: fix bug in spdif_clk_get_rate
ARM: EXYNOS4: Add restart hook for proper reboot
ARM: EXYNOS4: Increase reset delay for USB HOST PHY
ARM: S5P: add required chained_irq_enter/exit to gpio-int code
ARM: EXYNOS4: add required chained_irq_enter/exit to eint code
ARM: SAMSUNG: Add chained enrty/exit call to timer interrupt handler
ARM: S3C64XX: Fix build break in PM debug
ARM: S5PV210: Fix build warning
ARM: EXYNOS4: Fix the IRQ definitions for MIPI CSIS device
ARM: EXYNOS4: remove duplicated inclusion
ARM: EXYNOS4: Fix wrong devname to support clkdev
ARM: EXYNOS4: Use the correct regulator names on universal_c210
ARM: SAMSUNG: Fix Section mismatch in samsung_bl_set()
ARM: S5P64X0: Replace irq_gc_ack() with irq_gc_ack_set_bit()
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x
* 'rmobile-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-3.x:
ARM: mach-shmobile: sh7372 CMT3 and CMT4 clock support
ARM: mach-shmobile: sh7372 MSIOF clock support
ARM: mach-shmobile: clock-sh7372: fixup USB-DMAC1 settings
ARM: mach-shmobile: clock-sh73a0: tidyup CKSCR main clock selecter
ARM: mach-shmobile: Remove 3DG/SGX from sh7372 INTCS
ARM: mach-shmobile: mackerel: Add USB-DMA ID
mmc: sdhi, mmcif: zboot: Correct clock disable logic
ARM: mach-shmobile: ag5evm: SDHI requires waiting for idle
ARM: static should be at beginning of declaration
ARM: mach-shmobile: Use CMT2 for timer on sh7372
ARM: mach-shmobile: sh7372: Add USB-DMAC support
Add clock control support for sh7372 CMT hardware blocks.
No upstream sh7372 boards are making use of CMT3 + CMT4,
but the sh7372 hardware happens to come out of reset with
all CMT MSTP clocks _enabled_, so to save power we need
to implement a fix in software to shut down unused clocks.
This patch relies on the recently merged
794d78f drivers: sh: late disabling of clocks V2
to make sure the unused clocks get disabled as expected.
Signed-off-by: Magnus Damm <damm@opensource.se>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Add clock control support for sh7372 MSIOF hardware blocks.
No upstream sh7372 boards are making use of MSIOF0->2,
all MSIOF MSTP clocks _enabled_, so to save power we need
USB-DMAC1 needs SMSTPCR4/MSTP407 controls, not MSTP214
this patch tested on mackerel board
Reported-by: Magnus Damm <damm@opensource.se>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
MAINCKSEL is [29:28], not [27:24]
This patch removes support for the SGX interrupt source in
the sh7372 INTCS controller.
The SGX hardware block included in sh7372 is already hooked
up to the ARM Cortex-A8 core using the INTCA controller,
so SGX users are encouraged to make use of that interrupt
source instead.
Removing support for the SGX interrupt source in INTCS
simplifies the sh7372 power management code by allowing
us to assume that only INTCA needs to be powered on to
operate the SGX hardware.
If the INTCS interrupt source would be kept then the kernel
would be forced to deal with additional dependencies that does
not follow the regular power domain hiearachy. With this
patch in place we can safely power down INTCS while the
SGX is operating.
* 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ARM: mach-shmobile: sh7372 LCDC1 suspend fix V2 (incremental)
OMAP: omap_device: only override _noirq methods, not normal suspend/resume
PM / Runtime: Correct documentation of pm_runtime_irq_safe()
sh-sci / PM: Use power.irq_safe
PM: Use spinlock instead of mutex in clock management functions
For ARMv7 kernels running in the non-secure world, writing to the
auxillary control register causes an abort, so we must avoid directly
writing the auxillary control register. If the ACR has already been
reinitialized by SoC code, don't try to restore it.
Add a dsb after the isb to ensure that the previous writes to the
CP15 registers take effect before we enable the MMU.
ARM920 and ARM926 save four registers, not three. Fix the size of
the suspend region required.
r1 stores the v:p offset from the CPU invariant resume code, and is
expected to be preserved by the CPU specific code. Overwriting it is
not a good idea.
We've managed to get away with it on sa1100 platforms because most
happen to have PHYS_OFFSET == PAGE_OFFSET, but that may not be the
case depending on kernel configuration. So fix this latent bug.
This fixes xsc3 as well which was saving and restoring this register
independently.
cpu_v7_reset disables the MMU and then branches to the provided address.
On Thumb-2 kernels, we should take care to clear the Thumb Exception
enable bit in the System Control Register, otherwise this may wreak
havok in the code to which we are branching (for example, an ARM kernel
image via kexec).
Reviewed-by: Dave Martin <dave.martin@linaro.org>
Commit 540b5738 ("ARM: 6999/1: head, zImage: Always Enter the kernel in
ARM state") mandates that the kernel should be entered in ARM state.
If a Thumb-2 kernel kexecs a new kernel image, we need to ensure that
we change state when branching to the new code. This patch replaces a
mov pc, lr with a bx lr on Thumb-2 kernels so that we transition to ARM
state if need be.
This patch updates the recently submitted
"Associate the HDMI clock together with LCDC1 on sh7372"
to V2 with the following change:
- Use lcdc1_device on AP4EVB to build properly.
The nfsservctl system call is now gone, so we should remove all
linkage for it.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc into fixes
This patch fixes following building error:
arch/arm/mach-footbridge/dc21285.c: In function 'dc21285_preinit':
arch/arm/mach-footbridge/dc21285.c:299:2: error: 'vga_base' undeclared (first use in this function)
arch/arm/mach-footbridge/dc21285.c:299:2: note: each undeclared identifier is reported only once for each function it appears in
make[1]: *** [arch/arm/mach-footbridge/dc21285.o] Error 1
Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
Acked-by: Rob Herring <rob.herring@calxeda.com>
This patch fixed following building error:
arch/arm/mach-orion5x/pci.c: In function 'orion5x_pci_sys_setup':
arch/arm/mach-orion5x/pci.c:563:2: error: 'vga_base' undeclared (first use in this function)
arch/arm/mach-orion5x/pci.c:563:2: note: each undeclared identifier is reported only once for each function it appears in
make[1]: *** [arch/arm/mach-orion5x/pci.o] Error 1
make[1]: *** Waiting for unfinished jobs....
Upstream commit d5341942d784134f2997b3ff82cd63cf71d1f932 "PCI: Make the
struct pci_dev * argument of pci_fixup_irqs const." leaked an extra
"const" into an actual call site (vs a proto/decl) which causes this:
arch/arm/mach-orion5x/dns323-setup.c: In function 'dns323_pci_map_irq':
arch/arm/mach-orion5x/dns323-setup.c:80: error: expected expression before 'const'
arch/arm/mach-orion5x/dns323-setup.c:80: error: too few arguments to function 'orion5x_pci_map_irq'
make[3]: *** [arch/arm/mach-orion5x/dns323-setup.o] Error 1
Acked-by: Nicolas Pitre <nico@fluxnic.net>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Commit c03f007a8bf0e092caeb6856a5c8a850df10b974 (OMAP: PM:
omap_device: add system PM methods for PM domain handling) mistakenly
used SET_SYSTEM_SLEEP_PM_OPS() when trying to configure custom methods
for the PM domains noirq methods. Fix that by setting only the
suspend_noirq and resume_noirq methods with custom versions.
Note that all other PM domain methods (including the "normal"
suspend/resume methods) are populated using USE_PLATFORM_PM_SLEEP_OPS,
which configures them all to the default subsystem (platform_bus)
methods.
Reported-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Associate the HDMI clock together with LCDC1 on sh7372.
Without this patch Suspend-to-RAM hangs on the boards
AP4EVB and Mackerel. The code hangs in the LCDC driver
where the software is waiting forever for the hardware to
power down. By explicitly associating the HDMI clock with
LCDC1 we can make sure the HDMI clock is enabled using
Runtime PM whenever the driver is accessing the hardware.
This HDMI and LCDC1 dependency is documented in the sh7372
data sheet. Older kernels did work as expected but the
recently merged (3.1-rc)
introduced code to turn off clocks lacking software reference
which happens to include the HDMI clock that is needed by
LCDC1 to operate as expected.
This was a typo in clockdev declaration for at91sam9261 SoC.
Fix the kernel hanging when switching clocksource to TC (tcb_clksrc).
Acked-by: Remy Bohmer <linux@bohmer.net>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
It seems that an entry for the SP805 watchdog in the table of clocks was
missing. This results in the sp805_wdt driver rejecting the device with
the following errors:
sp805-wdt mb:wdt: Clock not found
sp805-wdt mb:wdt: Probe Failed!!!
sp805-wdt: probe of mb:wdt failed with error -2
While not obviously stated in the hardware docs, the onboard SP810's
"REFCLK" is connected to a 32.768KHz crystal, and this drives the
watchdog. Add a struct clk and corresponding lookup entry for it.
Signed-off-by: Nick Bowler <nbowler@elliptictech.com>
The oscillator that supplies GPT12_FCLK and WDT1_FCLK exists in the
WKUP powerdomain[1]. This resolves at least one boot-time warning:
omap_hwmod: gpt12_fck: missing clockdomain for gpt12_fck.
1. _OMAP34xx Multimedia High Security (HS) Device Silicon Revision 3.1.x
Security Addendum Version K (SWPU119K)_ Figure 3-29. August 2010.
I made some changes to the entry in the ARM Machine Registry after
submission which was the wrong thing to do.
This patch should help to fix this error.
Signed-off-by: Eric Bénard <eric@eukrea.com>
Fix the following compile warning:
arch/arm/mach-omap2/clock44xx_data.c: In function 'omap4xxx_clk_init':
arch/arm/mach-omap2/clock44xx_data.c:3371:6: warning: 'cpu_clkflg' may be used uninitialized in this function
The approach taken here is intended to work if omap4xxx_clk_init() is
converted into an initcall.
Thanks to Bjarne Steinsbo <bsteinsbo@gmail.com> for proposing another
approach.
Cc: Bjarne Steinsbo <bsteinsbo@gmail.com>
After commit 665d001338b494d6d62810aa99b4c0fa1a0884b9 ("OMAP2+: hwmod:
Follow the recommended PRCM module enable sequence"), device drivers
for OMAP IP blocks that do not use runtime PM can cause oopses or
kernel instability[1][2].
This is because those non-runtime PM drivers do not use the hwmod
code, which implements the correct IP block enable and disable
sequence.
Several options for dealing with this problem have been proposed:
1. Add a new field to the OMAP struct clk to mark clocks that are
currently used by non-runtime PM drivers. Modify the clock code to
use the old clockdomain sequence for these marked clocks. As
drivers are converted to use runtime PM, remove the annotation from
the clocks.
2. Similar to #1, but associate the flag with the struct omap_clk
instead.
3. Add IDLEST wait support to the OMAP4 clock code, similar to the way
it is implemented for OMAP2/3, and enable it in each struct clk
currently used by non-runtime PM drivers. As drivers are converted
to use runtime PM, remove the annotation from the clocks.
4. Do nothing; leave the problem to those responsible for the
unconverted drivers.
5. Re-enable clock-based clockdomain control in the OMAP4 clock code.
This would revert back to the behavior of Linux 3.0, simply with a
slightly longer module enable/disable latency.
Unfortunately, no approach seemed particularly good. Options 1
through 3 seemed unwise due to the following reasons:
A. The OMAP struct clks are intended primarily to describe hardware
clock nodes, and the intention is that no driver-specific data
should be stored there (applies to #1)
B. The resulting patch would have been quite large for the -rc series
(applies to #1, #2, #3)
C. The patch would have been a new, yet temporary hack; and similar fixes
have drawn negative comments in the recent past (see for example [3])
Option 4 is undesirable because commit
665d001338b494d6d62810aa99b4c0fa1a0884b9 ("OMAP2+: hwmod: Follow the
recommended PRCM module enable sequence") has resulted in a less
stable kernel; and kernel stability is more important than OMAP4 power
management.
Option 5 is the approach taken in this patch. This seemed to be the
least intrusive approach for 3.1-rc.
The approach in this patch was originally proposed by Ohad Ben-Cohen
<ohad@wizery.com>. I'm simply writing the commit message and passing
it along.
Thanks to Luciano Coelho <coelho@ti.com> for reporting the problem.
Thanks to Ohad Ben-Cohen <ohad@wizery.com> for tracking the problem
down, generating a temporary workaround, and proposing a patch to deal
with the problem. Thanks to Rajendra Nayak <rnayak@ti.com> for
proposing another patch to deal with the problem. Thanks to Felipe
Balbi <balbi@ti.com> for comments.
1. Coelho, Luciano <coelho@ti.com>. _Re: Oops on ehci_hcd when
booting 3.0.0-rc2 on panda_. Tue, 09 Aug 2011 14:26:08 +0300.
Posted to the <linux-omap@vger.kernel.org> mailing list. Available
from (among others)
http://www.spinics.net/linux/lists/linux-omap/msg55213.html
2. Munegowda, Keshava <keshava_mgowda@ti.com>. _Re: Oops on ehci_hcd
when booting 3.0.0-rc2 on panda_. Thu, 11 Aug 2011 13:51:05 +0530.
from (among others)
http://www.spinics.net/linux/lists/linux-omap/msg55371.html
3. King, Russell <linux@arm.linux.org.uk>. _Re: [PATCH 5/8] OMAP4:
PM: TEMP: Prevent l3init from idling/force sleep_. Thu, 23 Jun
2011 16:22:49 +0100. Posted to the <linux-omap@vger.kernel.org>
mailing list. Available from (among others)
http://www.mail-archive.com/linux-omap@vger.kernel.org/msg51392.html
Cc: Luciano Coelho <coelho@ti.com>
Cc: Ohad Ben-Cohen <ohad@wizery.com>
Cc: Rajendra Nayak <rnayak@ti.com>
Cc: Benoît Cousson <b-cousson@ti.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
force wakeup
While using clockdomain force wakeup method, not waiting for powerdomain
to be effectively ON may end up locking the clockdomain FSM until a
next wakeup event occurs.
One such issue was seen on OMAP4430, where L4_PER was periodically
getting stuck in in-transition state when transitioning from from OSWR to ON.
This issue was reported and investigated by Patrick Titiano <p-titiano@ti.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Rajendra Nayak <rnayak@ti.com>
Reported-by: Patrick Titiano <p-titiano@ti.com>
Cc: Kevin Hilman <khilman@ti.com>
Cc: Benoit Cousson <b-cousson@ti.com>
Cc: Paul Walmsley <paul@pwsan.com>
[paul@pwsan.com: updated to apply; added transition wait on clkdm_deny_idle();
remove two superfluous pwrdm_wait_transition() calls]
Program all powerdomain target state as ON; this is to prevent domains
from hitting low power states (if bootloader has target states set to
something other than ON) and potentially even losing context while PM
is not fully initialized, which can cause the system to crash. The PM
late init code can then program the desired target state for all the
power domains.
[paul@pwsan.com: dropped comment typo hunk; fixed comment indent and moved
to kerneldoc; moved code to pwrdm_init(); changed pwrdm_init() argument name
to prevent clash; cleaned up patch description]
Should be passing the parent clk object when
calling for parent rate.
Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This is required to use SWRESET.
This patch increases reset delay from 50 usec to 80 usec for
USB HOST PHY. In order to reset USB HOST PHY controller properly,
a little extra time is required during its reset cycle.
Signed-off-by: Yulgon Kim <yulgon.kim@samsung.com>
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
This patch adds chained IRQ enter/exit functions to gpio interrupt
handler in order to function correctly on primary controllers with
different methods of flow control.
This patch adds chained IRQ enter/exit functions to external interrupt
This patch adds chained IRQ enter/exit functions to timer
interrupt handler in order to function correctly on primary
controllers with different methods of flow control.
When S3C_PM_DEBUG_LED_SMDK is enabled for suspend/resume debugging, the following
compilation error occurs:
arch/arm/mach-s3c64xx/pm.c: In function 's3c_pm_debug_smdkled':
arch/arm/mach-s3c64xx/pm.c:41: error: implicit declaration of function 'gpio_set_value'
arch/arm/mach-s3c64xx/pm.c:41: error: implicit declaration of function 'S3C64XX_GPN'
arch/arm/mach-s3c64xx/pm.c: In function 's3c64xx_pm_init':
arch/arm/mach-s3c64xx/pm.c:184: error: implicit declaration of function 'gpio_request'
arch/arm/mach-s3c64xx/pm.c:188: error: implicit declaration of function 'gpio_direction_output'
Fix the error by including linux/gpio.h
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Fixed the following warning for S5PV210.
arch/arm/mach-s5pv210/pm.c: In function 's5pv210_pm_add':
arch/arm/mach-s5pv210/pm.c:139: warning: assignment from
incompatible pointer type
Also, staticized the function.
