commit dd0b3825495a2e7a8cd6cf0ec077618c008ac7c4 upstream.
Since 193ab2a6070039e7ee2b9b9bebea754a7c52fd1b, various AT91 boards don't
register USBA adapters anymore due to depending on a now non-existing
symbol. Fix the symbol name.
Signed-off-by: Jochen Friedrich <jochen@scram.de>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit 1bf6d2c1bb23533af6930581cc39b74685bc29de upstream.
Apparently U8500 U-Boot versions may leave the l2x0 locked down
before executing the kernel. Make sure we unlock it before we
initialize the l2x0. This fixes a performance problem reported
by Jan Rinze.
The l2x0 core has been modified to unlock the l2x0 by default,
but it will not touch the locking registers if the l2x0 was
already enabled, as on the ux500, so we need this quirk to
make sure it is properly turned off.
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Rabin Vincent <rabin.vincent@stericsson.com>
Cc: Adrian Bunk <adrian.bunk@movial.com>
Reported-by: Jan Rinze <janrinze@gmail.com>
Tested-by: Robert Marklund <robert.marklund@stericsson.com>
commit 1a64200ec5e93be03e27c3b2fc332e04ae443eb2 upstream.
Fix below build warning and properly set bt_reset pin.
CC arch/arm/mach-pxa/cm-x300.o
arch/arm/mach-pxa/cm-x300.c: In function 'cm_x300_init_wi2wi':
arch/arm/mach-pxa/cm-x300.c:779: warning: unused variable 'wlan_en'
arch/arm/mach-pxa/cm-x300.c:795: warning: 'bt_reset' may be used uninitialized in this function
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
commit 6571534b600b8ca1936ff5630b9e0947f21faf16 upstream.
To configure pads during the initialisation a set of special constants
is used, e.g.
#define MX25_PAD_FEC_MDIO__FEC_MDIO IOMUX_PAD(0x3c4, 0x1cc, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_22K_UP)
The problem is that no pull-up/down is getting activated unless both
PAD_CTL_PUE (pull-up enable) and PAD_CTL_PKE (pull/keeper module
enable) set. This is clearly stated in the i.MX25 datasheet and is
confirmed by the measurements on hardware. This leads to some rather
hard to understand bugs such as misdetecting an absent ethernet PHY (a
real bug i had), unstable data transfer etc. This might affect mx25,
mx35, mx50, mx51 and mx53 SoCs.
It's reasonable to expect that if the pullup value is specified, the
intention was to have it actually active, so we implicitly add the
needed bits.
Signed-off-by: Paul Fertser <fercerpav@gmail.com>
commit a06f916b7a9b57447ceb875eb0a89f1a66b31bca upstream.
Rather than clipping the number of CPUs using the compile-time NR_CPUS
constant, use the runtime nr_cpu_ids value instead. This allows the
nr_cpus command line option to work as expected.
Reported-by: Mark Salter <msalter@redhat.com>
v2:
- register_syscore_ops(&s3c24xx_irq_syscore_ops) does not need to be
conditionally compiled out, it is already optimized out on !CONFIG_PM
- fix also s3c2412 and s3c2416 affected by the same build issue
v1:
s3c2440.c fails to build if !CONFIG_PM because in such case
s3c2410_pm_syscore_ops is not defined. Same error should happen also
in s3c2410.c and s3c2442.c
Signed-off-by: Domenico Andreoli <cavokz@gmail.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Offsets of the irq controller registers were calculated
correctly only for first GPIO bank. This patch fixes
calculation of the register offsets for all GPIO banks.
Reported-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'fixes' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm:
ARM: 7128/1: vic: Don't write to the read-only register VIC_IRQ_STATUS
ARM: 7122/1: localtimer: add header linux/errno.h explicitly
ARM: 7117/1: perf: fix HW_CACHE_* events on Cortex-A9
ARM: 7113/1: mm: Align bank start to MAX_ORDER_NR_PAGES
This is unneeded and causes an abort on the SPMP8000 platform.
Signed-off-by: Zoltan Devai <zoss@devai.org>
Per the text in Documentation/SubmitChecklist as below, we should
explicitly have header linux/errno.h in localtimer.h for ENXIO
reference.
1: If you use a facility then #include the file that defines/declares
that facility. Don't depend on other header files pulling in ones
that you use.
Otherwise, we may run into some compiling error like the following one,
if any file includes localtimer.h without CONFIG_LOCAL_TIMERS defined.
arch/arm/include/asm/localtimer.h: In function ‘local_timer_setup’:
arch/arm/include/asm/localtimer.h:53:10: error: ‘ENXIO’ undeclared (first use in this function)
Using COHERENT_LINE_{MISS,HIT} for cache misses and references
respectively is completely wrong. Instead, use the L1D events which
are a better and more useful approximation despite ignoring instruction
traffic.
Reported-by: Alasdair Grant <alasdair.grant@arm.com>
Reported-by: Matt Horsnell <matt.horsnell@arm.com>
Reported-by: Michael Williams <michael.williams@arm.com>
Cc: stable@kernel.org
Cc: Jean Pihet <j-pihet@ti.com>
* 'fixes' of git://git.linaro.org/people/arnd/arm-soc:
ARM: mach-ux500: enable fix for ARM errata 754322
ARM: OMAP: musb: Remove a redundant omap4430_phy_init call in usb_musb_init
ARM: OMAP: Fix i2c init for twl4030
ARM: OMAP4: MMC: fix power and audio issue, decouple USBC1 from MMC1
This fixes a compilation error in cpu-tegra.c which was introduced in
dc8d966bccde ("ARM: convert PCI defines to variables") which removed the
now obsolete mach/hardware.h from the mach-tegra subtree.
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
This applies ARM errata fix 754322 for all ux500 platforms.
Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com>
The VM subsystem assumes that there are valid memmap entries from
the bank start aligned to MAX_ORDER_NR_PAGES.
On the Ux500 we have a lot of mem=N arguments on the commandline
triggering this bug several times over and causing kernel
oops messages.
Cc: Michael Bohan <mbohan@codeaurora.org>
Cc: Nicolas Pitre <nico@fluxnic.net>
Signed-off-by: Johan Palsson <johan.palsson@stericsson.com>
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
Current code calls omap4430_phy_init() twice in usb_musb_init().
Calling omap4430_phy_init() once is enough.
This patch removes the first omap4430_phy_init() call, which using an
uninitialized pointer as parameter.
This patch elimates below build warning:
arch/arm/mach-omap2/usb-musb.c: In function 'usb_musb_init':
arch/arm/mach-omap2/usb-musb.c:141: warning: 'dev' may be used uninitialized in this function
Bjarne Steinsbo <bsteinsbo@gmail.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Looks like 2600 kHz rate does not work reliably on 2430,
so just use the 100 kHz rate.
Otherwise the system often fails to boot properly with:
omap_i2c omap_i2c.2: timeout waiting for bus ready
twl: i2c_write failed to transfer all messages
twl: clock init err [-110]
TWL4030 Unable to unlock IDCODE registers --110
Remove OMAP4_USBC1_ICUSB_PWRDNZ_MASK during enable/disable PWRDNZ mode for
MMC1_PBIAS and associated extended-drain MMC1 I/O cell. This is in accordance
with the control module programming guide. This fixes a bug where if trying to
use gpio_98 or gpio_99 and MMC1 at the same time the GPIO signal will be
affected by a changing SDMMC1_VDDS.
Software must keep MMC1_PBIAS cell and MMC1_IO cell PWRDNZ signals low whenever
SDMMC1_VDDS ramps up/down or changes for cell protection purposes.
MMC1 is based on SDMMC1_VDDS whereas USBC1 is based on SIM_VDDS therefore
they can operate independently.
Signed-off-by: Bryan Buckley <bryan.buckley@ti.com>
Acked-by: Kishore Kadiyala <kishore.kadiyala@ti.com>
Tested-by: Balaji T K <balajitk@ti.com>
* 'samsung-fixes-3' of git://github.com/kgene/linux-samsung:
ARM: EXYNOS4: Rename sclk_cam clocks for FIMC driver
ARM: S5PV210: Rename sclk_cam clocks for FIMC media driver
ARM: S5P: fix incorrect loop iterator usage on gpio-interrupt
ARM: S3C2443: Fix bit-reset in setrate of clk_armdiv
The sclk_cam clocks are now controlled by the top level FIMC media
device driver bound to "s5p-fimc-md" platform device.
Rename sclk_cam clocks so they accessible by the corresponding
driver.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
driver.
ARM: 7099/1: futex: preserve oldval in SMP __futex_atomic_op
ARM: dma-mapping: free allocated page if unable to map
ARM: fix vmlinux.lds.S discarding sections
ARM: nommu: fix warning with checksyscalls.sh
ARM: 7091/1: errata: D-cache line maintenance operation by MVA may not succeed
The SMP implementation of __futex_atomic_op clobbers oldval with the
status flag from the exclusive store. This causes it to always read as
zero when performing the FUTEX_OP_CMP_* operation.
This patch updates the ARM __futex_atomic_op implementations to take a
tmp argument, allowing us to store the strex status flag without
overwriting the register containing oldval.
Reported-by: Minho Ban <mhban@samsung.com>
Reviewed-by: Nicolas Pitre <nicolas.pitre@linaro.org>
If the attempt to map a page for DMA fails (eg, because we're out of
mapping space) then we must not hold on to the page we allocated for
DMA - doing so will result in a memory leak.
Cc: <stable@kernel.org>
Reported-by: Bryan Phillippe <bp@darkforest.org>
Tested-by: Bryan Phillippe <bp@darkforest.org>
Loop iterator value after terminating list_for_each_entry()
is not NULL. This patch fixes incorrect iterator usage in
GPIO interrupt code for SAMSUNG S5P platforms.
The changed statement should set the old armdiv bits to 0
and not everything else, before setting the new value.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
We are seeing linker errors caused by sections being discarded, despite
the linker script trying to keep them. The result is (eg):
`.exit.text' referenced in section `.alt.smp.init' of drivers/built-in.o: defined in discarded section `.exit.text' of drivers/built-in.o
`.exit.text' referenced in section `.alt.smp.init' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o
This is the relevent part of the linker script (reformatted to make it
clearer):
| SECTIONS
| * unwind exit sections must be discarded before the rest of the
| * unwind sections get included.
| /DISCARD/ : {
| *(.ARM.exidx.exit.text)
| *(.ARM.extab.exit.text)
| .exit.text : {
| *(.exit.text)
| *(.memexit.text)
| /DISCARD/ : {
| *(.exit.text)
| *(.memexit.text)
| *(.exit.data)
| *(.memexit.data)
| *(.memexit.rodata)
| *(.exitcall.exit)
| *(.discard)
| *(.discard.*)
Now, this is what the linker manual says about discarded output sections:
| The special output section name `/DISCARD/' may be used to discard
| input sections. Any input sections which are assigned to an output
| section named `/DISCARD/' are not included in the output file.
No questions, no exceptions. It doesn't say "unless they are listed
before the /DISCARD/ section." Now, this is what asn-generic/vmlinux.lds.S
says:
| * Default discarded sections.
| * Some archs want to discard exit text/data at runtime rather than
| * link time due to cross-section references such as alt instructions,
| * bug table, eh_frame, etc. DISCARDS must be the last of output
| * section definitions so that such archs put those in earlier section
| * definitions.
And guess what - the list _always_ includes .exit.text etc.
Now, what's actually happening is that the linker is reading the script,
and it finds the first /DISCARD/ output section at the beginning of the
script. It continues reading the script, and finds the 'DISCARD' macro
at the end, which having been postprocessed results in another
/DISCARD/ output section. As the linker already contains the earlier
/DISCARD/ output section, it adds it to that existing section, so it
effectively is placed at the start. This can be seen by using the -M
option to ld:
| Linker script and memory map
| 0xc037c080 jiffies = jiffies_64
| /DISCARD/
| *(.exit.text)
| *(.memexit.text)
| *(.exit.data)
| *(.memexit.data)
| *(.memexit.rodata)
| *(.exitcall.exit)
| *(.discard)
| *(.discard.*)
| 0xc0008000 . = 0xc0008000
| .head.text 0xc0008000 0x1d0
| 0xc0008000 _text = .
| *(.head.text)
| .head.text 0xc0008000 0x1d0 arch/arm/kernel/head.o
| 0xc0008000 stext
| .text 0xc0008200 0x2d78d0
| 0xc0008200 _stext = .
| 0xc0008200 __exception_text_start = .
| *(.exception.text)
| .exception.text
As you can see, all the discarded sections are grouped together - and
as a result of it being the first output section, they all appear before
any other section.
The result is that not only is the unwind information discarded (as
intended), but also the .exit.text, despite us wanting to have the
.exit.text preserved.
We can't move the unwind information elsewhere, because it'll then be
included even when we do actually discard the .exit.text (and similar)
sections.
So, work around this by avoiding the generic DISCARDS macro, and instead
conditionalize the sections to be discarded ourselves. This avoids the
ambiguity in how the linker assigns input sections to output sections,
making our script less dependent on undocumented linker behaviour.
Reported-by: Rob Herring <robherring2@gmail.com>
Tested-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
The changes introduced in commit
cc22b4c18540e5e8bf55c7d124044f9317527d3c
"ARM: set vga memory base at run-time"
Makes the Integrator/AP freeze completely. I appears that
this is due to the VGA base address being assigned at PCI
init time, while this base is needed earlier than that.
Moving the initialization of the base address to the
.map_io function solves this problem.
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Rob Herring <rob.herring@calxeda.com>
The bindings were recently updated to have separate properties for each
type of GPIO. Update the Device Tree source to match that.
Acked-by: Olof Johansson <olof@lixom.net>
CALL scripts/checksyscalls.sh
<stdin>:46:1: warning: "__IGNORE_migrate_pages" redefined
In file included from <stdin>:2:
arch/arm/include/asm/unistd.h:482:1: warning: this is the location of the previous definition
This is caused because we define __IGNORE_migrate_pages to be 1, but
in the case of nommu, it's defined to be empty. Fix this by just
defining the __IGNORE_ symbols to be empty.
This patch implements a workaround for erratum 764369 affecting
Cortex-A9 MPCore with two or more processors (all current revisions).
Under certain timing circumstances, a data cache line maintenance
operation by MVA targeting an Inner Shareable memory region may fail to
proceed up to either the Point of Coherency or to the Point of
Unification of the system. This workaround adds a DSB instruction before
the relevant cache maintenance functions and sets a specific bit in the
diagnostic control register of the SCU.
Tested-by: Mark Rutland <mark.rutland@arm.com>
The keypad controller requires a external pull-up for all the keypad
row lines. Fix the incorrect pad configuration for keypad controller
row lines by enabling the pad pull-up for the all row lines of the
keypad controller.
Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org>
The plat/clock.h revised to prevent declaring duplicated.
clkdev framework uses global mutex to protect clock tree, so it is not
possible to call clk_get() in interrupt context. This patch fixes this
issue and makes system reset by watchdog call working again.
According to commit 96d78686d4("ARM: S3C64XX: Add PWM backlight
support on SMDK6410") and commit f00207b255("ARM: SAMSUNG: Create
a common infrastructure for PWM backlight support"), this should
not be used anymore.
And this patch fixes follwing warning:
arch/arm/mach-s3c64xx/mach-smdk6410.c:296: warning: 'smdk6410_backlight_device' defined but not used
Signed-off-by: Banajit Goswami <banajit.g@samsung.com>
[kgene.kim@samsung.com: modified commit message]
System resume can't be completed because mct-frc isn't restarted
after system suspends. This patch restarts mct-frc during system
resume.
Reported-by: Jongpill Lee <boyko.lee@samsung.com>
Signed-off-by: Changhwan Youn <chaos.youn@samsung.com>
The commit 5dfc54e087c15f823ee9b6541d2f0f314e69cbed
("ARM: GIC: avoid routing interrupts to offline CPUs")
prevents routing interrupts to offline CPUs. But in
case of timer on EXYNOS4, the irq_set_affinity() method
is called in percpu_timer_setup() before CPU1 becomes
online. So this patch fixes routing timer interrupt to
offline CPU.
Reported-by: Changhwan Youn <chaos.youn@samsung.com>
According to commmit af90f10d ("ARM: 6759/1: smp: Select
local timers vs broadcast timer support"), the return type
of local_timer_setup() should be int instead of void.
The PLL4650C is used for VPLL on EXYNOS4 so should be fixed.
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
[kgene.kim@samsung.com: added message]
Commit 980f9f601a "ARM: orion: Consolidate SPI initialization."
broke it by overwriting the SPI0 registration.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
ARM: CSR: add missing sentinels to of_device_id tables
ARM: cns3xxx: Fix newly introduced warnings in the PCIe code
ARM: cns3xxx: Fix compile error caused by hardware.h removed
ARM: davinci: fix cache flush build error
ARM: davinci: correct MDSTAT_STATE_MASK
ARM: davinci: da850 EVM: read mac address from SPI flash
OMAP: omap_device: fix !CONFIG_SUSPEND case in _noirq handlers
OMAP2430: hwmod: musb: add missing terminator to omap2430_usbhsotg_addrs[]
OMAP3: clock: indicate that gpt12_fck and wdt1_fck are in the WKUP clockdomain
OMAP4: clock: fix compile warning
OMAP4: clock: re-enable previous clockdomain enable/disable sequence
OMAP: clockdomain: Wait for powerdomain to be ON when using clockdomain force wakeup
OMAP: powerdomains: Make all powerdomain target states as ON at init
git://gitorious.org/khilman/linux-omap-pm into fixes
The of_device_id tables used for matching should be terminated with
empty sentinel values.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Signed-off-by: Barry Song <baohua.song@csr.com>
Commit be020f8618ca, "ARM: entry: abort-macro: specify registers to be
used for macros", while replacing register numbers with macro parameter
names, mismatched the name used for r1. For me, this resulted in user
space built for EABI with -march=armv4t -mtune=arm920t -mthumb-interwork
-mthumb broken on my OMAP1510 based Amstrad Delta (old ABI and no thumb
still worked for me though).
Fix this by using correct parameter name fsr instead of mismatched psr,
used by callers for another purpose.
Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl>
commit d5341942d784134f2997b3ff82cd63cf71d1f932 ("PCI: Make the struct
pci_dev * argument of pci_fixup_irqs const") did not change argument
of pdev_to_cnspci(), and thus introduced the following warnings:
CHECK arch/arm/mach-cns3xxx/pcie.c
pcie.c:177:60: warning: incorrect type in argument 1 (different modifiers)
pcie.c:177:60: expected struct pci_dev *dev
pcie.c:177:60: got struct pci_dev const *dev
CC arch/arm/mach-cns3xxx/pcie.o
pcie.c: In function 'cns3xxx_pcie_map_irq':
pcie.c:177: warning: passing argument 1 of 'pdev_to_cnspci' discards qualifiers from pointer target type
pcie.c:52: note: expected 'struct pci_dev *' but argument is of type 'const struct pci_dev *'
This patch fixes the issue.
Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
Commit c9d95fbe59e426eed7f16e7cac812e46ac4772d0 "ARM: convert PCI defines
to variables" deleted cns3xxx' hardware.h, but didn't remove references
for it, so do it now.
This patch removes lines that refer to hardware.h.
Signed-off-by: Tommy Lin <tommy.lin.1101@gmail.com>
Signed-off-by: Imre Kaloz <kaloz@openwrt.org>
