path: root/arch/avr32/configs/atngw100_defconfig
2011-06-14avr32: set CONFIG_CC_OPTIMIZE_FOR_SIZE=y for all defconfigsHans-Christian Egtvedt
This patch makes sure the kconfig option CC_OPTIMIZE_FOR_SIZE is set to yes for all default configuration files. This ensures the kernel is optimized for size, and avoids potential relocation truncated to fit problems. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-01-13avr32: update default configuration files for Atmel boardsHans-Christian Egtvedt
This patch adjusts some values to make the default configuration for Atmel boards more similar, and adds missing values to enable required functions. Also remove defined symbols for functions not in use. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-01-13avr32: disable kprobes for all default configurationsHans-Christian Egtvedt
This patch will disable kprobes for all the default AVR32 board configurations. This works around a regression in kprobes which seems to be related to AVR32 is now lacking the struct kprobe_ctlblk. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2010-08-14defconfig reductionSam Ravnborg
Use the defconfig files generated by "make savedefconfig" for remaining defconfig files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-12-14avr32: update default configurations for ATNGW100, ATSTK1002 and ATSTK1006Hans-Christian Egtvedt
This patch updates the default configuration for ATNGW100 (also for the EVKLCD10X configs), ATSTK1002 and ATSTK1006. By default all kernels will now have support for EXT2/3/4 out of the box, this is handy if the user wants to boot from SD-Card. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2009-01-06avr32: Remove DMATEST from defconfigsBen Nizette
In the defconfigs for ATNGW100 and ATSTK100[236] the DMA Test driver is compiled as a module. This means systems built with *_defconfig + CONFIG_MODULES=n are unusable as the 3 dma test channels monopolise the CPU. I 'spose Haavard uses this module a lot but IMO it isn't really something needed on all eval boards by default. Signed-off-by: Ben Nizette <bn@niasdigital.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-08-08avr32: Update defconfigsHaavard Skinnemoen
Enable power management, DMA and MMC on all boards except ATSTK1004, and add defconfig for the new ATSTK1006 board with NAND flash, UBI and UBIFS enabled as well. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-26avr32: Update defconfigsHaavard Skinnemoen
Just provide reasonable defaults for the new stuff. Tickless and hrtimers are turned on for all boards except ATSTK1004. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-01-25[AVR32] ATNGW100: Update defconfigHaavard Skinnemoen
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-25[AVR32] Add support for AT32AP7001 and AT32AP7002Haavard Skinnemoen
These are derivatives of the AT32AP7000 chip, which means that most of the code stays the same. Rename a few files, functions, definitions and config symbols to reflect that they apply to all AP700x chips, and exclude some platform devices from chips where they aren't present. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-07-16leds: leds-gpio for ngw100David Brownell
Add GPIO leds to the NGW100 platform and its defconfig. Access through /sys/class/leds/{a,b,sys}/* files; one defaults to a heartbeat. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-06-23[AVR32] Update defconfigsHaavard Skinnemoen
Update defconfigs for ATNGW100 and ATSTK1002. This will enable the SLUB allocator by default on both, and will enable NFS root on ATSTK1002 (ATNGW100 had it enabled before.) Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2007-04-27[AVR32] Board code for ATNGW100Haavard Skinnemoen
Add board code and defconfig for the ATNGW100 Network Gateway kit. For more information about this board, see http://www.atmel.com/dyn/products/tools_card.asp?tool_id=4102 Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
