path: root/arch/avr32/configs/atstk1004_defconfig
2011-06-14avr32: set CONFIG_CC_OPTIMIZE_FOR_SIZE=y for all defconfigsHans-Christian Egtvedt
This patch makes sure the kconfig option CC_OPTIMIZE_FOR_SIZE is set to yes for all default configuration files. This ensures the kernel is optimized for size, and avoids potential relocation truncated to fit problems. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-01-13avr32: update default configuration files for Atmel boardsHans-Christian Egtvedt
This patch adjusts some values to make the default configuration for Atmel boards more similar, and adds missing values to enable required functions. Also remove defined symbols for functions not in use. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2010-08-14defconfig reductionSam Ravnborg
Use the defconfig files generated by "make savedefconfig" for remaining defconfig files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-01-26eeprom: More consistent symbol namesJean Delvare
Now that all EEPROM drivers live in the same place, let's harmonize their symbol names. Also fix eeprom's dependencies, it definitely needs sysfs, and is no longer experimental after many years in the kernel tree. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Cc: David Brownell <dbrownell@users.sourceforge.net>
2008-08-08avr32: Update defconfigsHaavard Skinnemoen
Enable power management, DMA and MMC on all boards except ATSTK1004, and add defconfig for the new ATSTK1006 board with NAND flash, UBI and UBIFS enabled as well. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-05-26avr32: Update defconfigsHaavard Skinnemoen
Just provide reasonable defaults for the new stuff. Tickless and hrtimers are turned on for all boards except ATSTK1004. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-01-25[AVR32] Add support for ATSTK1003 and ATSTK1004Haavard Skinnemoen
ATSTK1003 and ATSTK1004 are CPU daughterboards for ATSTK1000 featuring the AT32AP7001 and AT32AP7002 CPUs, respectively. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
