[ Upstream commit 8630c32275bac2de6ffb8aea9d9b11663e7ad28e ]
really ugly, but apparently avr32 compilers turns access_ok() into
something so bad that they want it in assembler. Left that way,
zeroing added in inline wrapper.
Cc: stable@vger.kernel.org
Signed-off-by: Richard Weinberger <richard@nod.at>
If an attacker can cause a controlled kernel stack overflow, overwriting
the restart block is a very juicy exploit target. This is because the
restart_block is held in the same memory allocation as the kernel stack.
Moving the restart block to struct task_struct prevents this exploit by
making the restart_block harder to locate.
Note that there are other fields in thread_info that are also easy
targets, at least on some architectures.
It's also a decent simplification, since the restart code is more or less
identical on all architectures.
[james.hogan@imgtec.com: metag: align thread_info::supervisor_stack]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Richard Weinberger <richard@nod.at>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Aurelien Jacquiot <a-jacquiot@ti.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Cc: Chen Liqin <liqin.linux@gmail.com>
Cc: Lennox Wu <lennox.wu@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Signed-off-by: James Hogan <james.hogan@imgtec.com>
This patch adds a bunch of missing syscalls to AVR32:
__NR_pread64
__NR_pwrite64
__NR_timerfd_create
__NR_fallocate
__NR_timerfd_settime
__NR_timerfd_gettime
__NR_signalfd4
__NR_eventfd2
__NR_epoll_create1
__NR_dup3
__NR_pipe2
__NR_inotify_init1
__NR_preadv
__NR_pwritev
__NR_rt_tgsigqueueinfo
__NR_perf_event_open
__NR_recvmmsg
__NR_fanotify_init
__NR_fanotify_mark
__NR_prlimit64
__NR_name_to_handle_at
__NR_open_by_handle_at
__NR_clock_adjtime
__NR_syncfs
__NR_sendmmsg
__NR_process_vm_readv
__NR_process_vm_writev
__NR_kcmp
__NR_finit_module
__NR_sched_setattr
__NR_sched_getattr
__NR_renameat2
__NR_seccomp
__NR_getrandom
__NR_memfd_create
__NR_bpf
__NR_execveat
On AVR32, all parameters beyond the 5th are passed on the stack. System
calls don't use the stack -- they borrow a callee-saved register
instead. This means that syscalls that take 6 parameters must be called
through a stub that pushes the last parameter on the stack.
This relates to syscall fallocate, fanotify_mark, process_vm_readv, and
process_vm_writev.
Signed-off-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Archs have been abusing module_free() to clean up their arch-specific
allocations. Since module_free() is also (ab)used by BPF and trace code,
let's keep it to simple allocations, and provide a hook called before
that.
This means that avr32, ia64, parisc and s390 no longer need to implement
their own module_free() at all. avr32 doesn't need module_finalize()
either.
Cc: linux-ia64@vger.kernel.org
Cc: linux-parisc@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Replace the single use of __get_cpu_var in avr32 with
__this_cpu_write.
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Signed-off-by: Christoph Lameter <cl@linux.com>
Use sigsp() instead of the open coded variant.
Use the more generic functions get_signal() signal_setup_done()
for signal delivery.
simple_strtoul() is marked for obsoletion; use the newer and more
pleasant kstrtoul() in its place.
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com>
This patch proposes to remove the use of the IRQF_DISABLED flag
It's a NOOP since 2.6.35 and it will be removed one day.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
This patch fixes following error (for big kernels):
---8<---
arch/avr32/boot/u-boot/head.o: In function `no_tag_table':
(.init.text+0x44): relocation truncated to fit: R_AVR32_22H_PCREL against symbol `panic' defined in .text.unlikely section in kernel/built-in.o
arch/avr32/kernel/built-in.o: In function `bad_return':
(.ex.text+0x236): relocation truncated to fit: R_AVR32_22H_PCREL against symbol `panic' defined in .text.unlikely section in kernel/built-in.o
--->8---
It comes up when the kernel increases and 'panic()' is too far away to fit in
the +/- 2MiB range. Which in turn issues from the 21-bit displacement in
'br{cond4}' mnemonic which is one of the two ways to do jumps (rjmp has just
10-bit displacement and therefore a way smaller range). This fact was stated
before in 8d29b7b9f81d6b83d869ff054e6c189d6da73f1f.
One solution to solve this is to add a local storage for the symbol address
and just load the $pc with that value.
Signed-off-by: Andreas Bießmann <andreas@biessmann.de>
Before the CRT was (fully) set up in kernel_entry (bss cleared before in
_start, but also not before jump to panic() in no_tag_table case).
This patch fixes this up to have a fully working CRT when branching to panic()
in no_tag_table.
The patch fixes the following compiler warning:
CC arch/avr32/kernel/process.o
arch/avr32/kernel/process.c: In function 'copy_thread':
arch/avr32/kernel/process.c:292: warning: assignment makes integer \
from pointer without a cast
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Since commit 01426478df3a8791ff5c8b6b82d409e699cfaf38
(avr32: Use generic idle loop) the kernel throws the
following warning on avr32:
WARNING: at 900322e4 [verbose debug info unavailable]
Modules linked in:
CPU: 0 PID: 0 Comm: swapper Not tainted 3.12.0-rc2 #117
task: 901c3ecc ti: 901c0000 task.ti: 901c0000
PC is at cpu_idle_poll_ctrl+0x1c/0x38
LR is at comparator_mode+0x3e/0x40
pc : [<900322e4>] lr : [<90014882>] Not tainted
sp : 901c1f74 r12: 00000000 r11: 901c74a0
r10: 901d2510 r9 : 00000001 r8 : 901db4de
r7 : 901c74a0 r6 : 00000001 r5 : 00410020 r4 : 901db574
r3 : 00410024 r2 : 90206fe0 r1 : 00000000 r0 : 007f0000
Flags: qvnzc
Mode bits: hjmde....G
CPU Mode: Supervisor
Call trace:
[<90039ede>] clockevents_set_mode+0x16/0x2e
[<90039f00>] clockevents_shutdown+0xa/0x1e
[<9003a078>] clockevents_exchange_device+0x58/0x70
[<9003a78c>] tick_check_new_device+0x38/0x54
[<9003a1a2>] clockevents_register_device+0x32/0x90
[<900035c4>] time_init+0xa8/0x108
[<90000520>] start_kernel+0x128/0x23c
When the 'avr32_comparator' clockevent device is registered,
the clockevent core sets the mode of that clockevent device
to CLOCK_EVT_MODE_SHUTDOWN. Due to this, the 'comparator_mode'
function calls the 'cpu_idle_poll_ctrl' to disables idle poll.
This results in the aforementioned warning because the polling
is not enabled yet.
Change the code to only disable idle poll if it is enabled by
the same function to avoid the warning.
Normalize global variables exported by vmlinux.lds to conform usage
guidelines from include/asm-generic/sections.h.
Use _text to mark the start of the kernel image including the head text,
and _stext to mark the start of the .text section.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Most of the stuff from kernel/sched.c was moved to kernel/sched/core.c long time
back and the comments/Documentation never got updated.
I figured it out when I was going through sched-domains.txt and so thought of
fixing it globally.
I haven't crossed check if the stuff that is referenced in sched/core.c by all
these files is still present and hasn't changed as that wasn't the motive behind
this patch.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/cdff76a265326ab8d71922a1db5be599f20aad45.1370329560.git.viresh.kumar@linaro.org
Caught by static code analysis by David.
Reported-by: David Binderman <dcb314@hotmail.com>
Cc: stable@kernel.org
show_regs() is inherently arch-dependent but it does make sense to print
generic debug information and some archs already do albeit in slightly
different forms. This patch introduces a generic function to print debug
information from show_regs() so that different archs print out the same
information and it's much easier to modify what's printed.
show_regs_print_info() prints out the same debug info as dump_stack()
does plus task and thread_info pointers.
* Archs which didn't print debug info now do.
alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r,
metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc,
um, xtensa
* Already prints debug info. Replaced with show_regs_print_info().
The printed information is superset of what used to be there.
arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86
* s390 is special in that it used to print arch-specific information
along with generic debug info. Heiko and Martin think that the
arch-specific extra isn't worth keeping s390 specfic implementation.
Converted to use the generic version.
Note that now all archs print the debug info before actual register
dumps.
An example BUG() dump follows.
kernel BUG at /work/os/work/kernel/workqueue.c:4841!
invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7
Hardware name: empty empty/S3992, BIOS 080011 10/26/2007
task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000
RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6
RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246
RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001
RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a
RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0
Stack:
ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650
0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d
ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760
Call Trace:
[<ffffffff81000312>] do_one_initcall+0x122/0x170
[<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8
[<ffffffff81c47760>] ? rest_init+0x140/0x140
[<ffffffff81c4776e>] kernel_init+0xe/0xf0
[<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0
v2: Typo fix in x86-32.
v3: CPU number dropped from show_regs_print_info() as
dump_stack_print_info() has been updated to print it. s390
specific implementation dropped as requested by s390 maintainers.
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits]
Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits]
Both dump_stack() and show_stack() are currently implemented by each
architecture. show_stack(NULL, NULL) dumps the backtrace for the
current task as does dump_stack(). On some archs, dump_stack() prints
extra information - pid, utsname and so on - in addition to the
backtrace while the two are identical on other archs.
The usages in arch-independent code of the two functions indicate
show_stack(NULL, NULL) should print out bare backtrace while
dump_stack() is used for debugging purposes when something went wrong,
so it does make sense to print additional information on the task which
triggered dump_stack().
There's no reason to require archs to implement two separate but mostly
identical functions. It leads to unnecessary subtle information.
This patch expands the dummy fallback dump_stack() implementation in
lib/dump_stack.c such that it prints out debug information (taken from
x86) and invokes show_stack(NULL, NULL) and drops arch-specific
dump_stack() implementations in all archs except blackfin. Blackfin's
dump_stack() does something wonky that I don't understand.
Debug information can be printed separately by calling
dump_stack_print_info() so that arch-specific dump_stack()
implementation can still emit the same debug information. This is used
in blackfin.
This patch brings the following behavior changes.
* On some archs, an extra level in backtrace for show_stack() could be
printed. This is because the top frame was determined in
dump_stack() on those archs while generic dump_stack() can't do that
reliably. It can be compensated by inlining dump_stack() but not
sure whether that'd be necessary.
* Most archs didn't use to print debug info on dump_stack(). They do
now.
An example WARN dump follows.
WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505()
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9
0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48
ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c
0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58
Call Trace:
[<ffffffff81c614dc>] dump_stack+0x19/0x1b
[<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20
[<ffffffff8234a071>] init_workqueues+0x35/0x505
v2: CPU number added to the generic debug info as requested by s390
folks and dropped the s390 specific dump_stack(). This loses %ksp
from the debug message which the maintainers think isn't important
enough to keep the s390-specific dump_stack() implementation.
dump_stack_print_info() is moved to kernel/printk.c from
lib/dump_stack.c. Because linkage is per objecct file,
dump_stack_print_info() living in the same lib file as generic
dump_stack() means that archs which implement custom dump_stack()
- at this point, only blackfin - can't use dump_stack_print_info()
as that will bring in the generic version of dump_stack() too. v1
The v1 patch broke build on blackfin due to this issue. The build
breakage was reported by Fengguang Wu.
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits]
Also replace the idle poll enforcement by the generic functionality.
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Link: http://lkml.kernel.org/r/20130321215233.950290809@linutronix.de
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module update from Rusty Russell:
"The sweeping change is to make add_taint() explicitly indicate whether
to disable lockdep, but it's a mechanical change."
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
MODSIGN: Add option to not sign modules during modules_install
MODSIGN: Add -s <signature> option to sign-file
MODSIGN: Specify the hash algorithm on sign-file command line
MODSIGN: Simplify Makefile with a Kconfig helper
module: clean up load_module a little more.
modpost: Ignore ARC specific non-alloc sections
module: constify within_module_*
taint: add explicit flag to show whether lock dep is still OK.
module: printk message when module signature fail taints kernel.
Fix up all callers as they were before, with make one change: an
unsigned module taints the kernel, but doesn't turn off lockdep.
getname() is intended to copy pathname strings from userspace into a
kernel buffer. The result is just a string in kernel space. It would
however be quite helpful to be able to attach some ancillary info to
the string.
For instance, we could attach some audit-related info to reduce the
amount of audit-related processing needed. When auditing is enabled,
we could also call getname() on the string more than once and not
need to recopy it from userspace.
This patchset converts the getname()/putname() interfaces to return
a struct instead of a string. For now, the struct just tracks the
string in kernel space and the original userland pointer for it.
Later, we'll add other information to the struct as it becomes
convenient.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
This include is no longer needed.
(seems to be a leftover from try_to_freeze())
Obvious brainos spotted by Geert.
Does block_sigmask() + tracehook_signal_handler(); called when
sigframe has been successfully built. All architectures converted
to it; block_sigmask() itself is gone now (merged into this one).
I'm still not too happy with the signature, but that's a separate
story (IMO we need a structure that would contain signal number +
siginfo + k_sigaction, so that get_signal_to_deliver() would fill one,
signal_delivered(), handle_signal() and probably setup...frame() -
take one).
Only 3 out of 63 do not. Renamed the current variant to __set_current_blocked(),
added set_current_blocked() that will exclude unblockable signals, switched
open-coded instances to it.
replace boilerplate "should we use ->saved_sigmask or ->blocked?"
with calls of obvious inlined helper...
first fruits of ..._restore_sigmask() helpers: now we can take
boilerplate "signal didn't have a handler, clear RESTORE_SIGMASK
and restore the blocked mask from ->saved_mask" into a common
helper. Open-coded instances switched...
we need that not just on syscall returns but on irq ones as well...
Use the new helper function introduced in commit 5e6292c0f28f ("signal:
add block_sigmask() for adding sigmask to current->blocked") which
centralises the code for updating current->blocked after successfully
delivering a signal and reduces the amount of duplicate code across
architectures.
In the past some architectures got this code wrong, so using this helper
function should stop that from happening again.
Acked-by: Oleg Nesterov <oleg@redhat.com>
Cc: Havard Skinnemoen <hskinnemoen@gmail.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
It is wrong to change ->blocked directly, see e6fa16ab. Change
handle_signal() and sys_rt_sigreturn() to use the right helper,
set_current_blocked().
Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com>
Reviewed-by: Matt Fleming <matt.fleming@intel.com>
The current handle_signal() implementation is broken - it will mask
signals if we fail to setup the signal stack frame, which isn't the
desired behaviour, we should only be masking signals if we succeed in
setting up the stack frame. It looks like this code was copied from the
old (broken) arm implementation but wasn't updated when the arm code was
fixed in commit a6c61e9dfdd0 ("[ARM] 3168/1: Update ARM signal delivery
and masking").
Same code. Use the generic version.
Link: http://lkml.kernel.org/r/20120503085034.281527118@linutronix.de
Coccinelle based conversion.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org
It's a very old and now unused prototype marking so just delete it.
Neaten panic pointer argument style to keep checkpatch quiet.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Cc: Chris Metcalf <cmetcalf@tilera.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
* 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (73 commits)
arm: fix up some samsung merge sysdev conversion problems
firmware: Fix an oops on reading fw_priv->fw in sysfs loading file
Drivers:hv: Fix a bug in vmbus_driver_unregister()
driver core: remove __must_check from device_create_file
debugfs: add missing #ifdef HAS_IOMEM
arm: time.h: remove device.h #include
driver-core: remove sysdev.h usage.
clockevents: remove sysdev.h
arm: convert sysdev_class to a regular subsystem
arm: leds: convert sysdev_class to a regular subsystem
kobject: remove kset_find_obj_hinted()
m86k: gpio - convert sysdev_class to a regular subsystem
mips: txx9_sram - convert sysdev_class to a regular subsystem
mips: 7segled - convert sysdev_class to a regular subsystem
sh: dma - convert sysdev_class to a regular subsystem
sh: intc - convert sysdev_class to a regular subsystem
power: suspend - convert sysdev_class to a regular subsystem
power: qe_ic - convert sysdev_class to a regular subsystem
power: cmm - convert sysdev_class to a regular subsystem
s390: time - convert sysdev_class to a regular subsystem
Fix up conflicts with 'struct sysdev' removal from various platform
drivers that got changed:
- arch/arm/mach-exynos/cpu.c
- arch/arm/mach-exynos/irq-eint.c
- arch/arm/mach-s3c64xx/common.c
- arch/arm/mach-s3c64xx/cpu.c
- arch/arm/mach-s5p64x0/cpu.c
- arch/arm/mach-s5pv210/common.c
- arch/arm/plat-samsung/include/plat/cpu.h
- arch/powerpc/kernel/sysfs.c
and fix up cpu_is_hotpluggable() as per Greg in include/linux/cpu.h
The sysdev.h file should not be needed by any in-kernel code, so remove
the .h file from these random files that seem to still want to include
it.
The sysdev code will be going away soon, so this include needs to be
removed no matter what.
Cc: Jiandong Zheng <jdzheng@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: David Brown <davidb@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: "Venkatesh Pallipadi
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Matthew Garrett <mjg@redhat.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
This moves the 'cpu sysdev_class' over to a regular 'cpu' subsystem
and converts the devices to regular devices. The sysdev drivers are
implemented as subsystem interfaces now.
After all sysdev classes are ported to regular driver core entities, the
sysdev implementation will be entirely removed from the kernel.
Userspace relies on events and generic sysfs subsystem infrastructure
from sysdev devices, which are made available with this conversion.
Cc: Borislav Petkov <bp@amd64.org>
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
Cc: Len Brown <lenb@kernel.org>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
Those two APIs were provided to optimize the calls of
tick_nohz_idle_enter() and rcu_idle_enter() into a single
irq disabled section. This way no interrupt happening in-between would
needlessly process any RCU job.
Now we are talking about an optimization for which benefits
have yet to be measured. Let's start simple and completely decouple
idle rcu and dyntick idle logics to simplify.
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
