path: root/arch/avr32
2016-10-07Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge updates from Andrew Morton: - fsnotify updates - ocfs2 updates - all of MM * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (127 commits) console: don't prefer first registered if DT specifies stdout-path cred: simpler, 1D supplementary groups CREDITS: update Pavel's information, add GPG key, remove snail mail address mailmap: add Johan Hovold .gitattributes: set git diff driver for C source code files uprobes: remove function declarations from arch/{mips,s390} spelling.txt: "modeled" is spelt correctly nmi_backtrace: generate one-line reports for idle cpus arch/tile: adopt the new nmi_backtrace framework nmi_backtrace: do a local dump_stack() instead of a self-NMI nmi_backtrace: add more trigger_*_cpu_backtrace() methods min/max: remove sparse warnings when they're nested Documentation/filesystems/proc.txt: add more description for maps/smaps mm, proc: fix region lost in /proc/self/smaps proc: fix timerslack_ns CAP_SYS_NICE check when adjusting self proc: add LSM hook checks to /proc/<tid>/timerslack_ns proc: relax /proc/<tid>/timerslack_ns capability requirements meminfo: break apart a very long seq_printf with #ifdefs seq/proc: modify seq_put_decimal_[u]ll to take a const char *, not char proc: faster /proc/*/status ...
2016-10-07nmi_backtrace: generate one-line reports for idle cpusChris Metcalf
When doing an nmi backtrace of many cores, most of which are idle, the output is a little overwhelming and very uninformative. Suppress messages for cpus that are idling when they are interrupted and just emit one line, "NMI backtrace for N skipped: idling at pc 0xNNN". We do this by grouping all the cpuidle code together into a new .cpuidle.text section, and then checking the address of the interrupted PC to see if it lies within that section. This commit suitably tags x86 and tile idle routines, and only adds in the minimal framework for other architectures. Link: http://lkml.kernel.org/r/1472487169-14923-5-git-send-email-cmetcalf@mellanox.com Signed-off-by: Chris Metcalf <cmetcalf@mellanox.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org> Tested-by: Daniel Thompson <daniel.thompson@linaro.org> [arm] Tested-by: Petr Mladek <pmladek@suse.com> Cc: Aaron Tomlin <atomlin@redhat.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-03avr32: migrate exception table users off module.h and onto extable.hPaul Gortmaker
These files were only including module.h for exception table related functions. We've now separated that content out into its own file "extable.h" so now move over to that and avoid all the extra header content in module.h that we don't really need to compile these files. One uses "print_modules" so that prevents us removing module.h in that case, however. Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
2016-09-18avr32: fix 'undefined reference to `___copy_from_user'Guenter Roeck
avr32 builds fail with: arch/avr32/kernel/built-in.o: In function `arch_ptrace': (.text+0x650): undefined reference to `___copy_from_user' arch/avr32/kernel/built-in.o:(___ksymtab+___copy_from_user+0x0): undefined reference to `___copy_from_user' kernel/built-in.o: In function `proc_doulongvec_ms_jiffies_minmax': (.text+0x5dd8): undefined reference to `___copy_from_user' kernel/built-in.o: In function `proc_dointvec_minmax_sysadmin': sysctl.c:(.text+0x6174): undefined reference to `___copy_from_user' kernel/built-in.o: In function `ptrace_has_cap': ptrace.c:(.text+0x69c0): undefined reference to `___copy_from_user' kernel/built-in.o:ptrace.c:(.text+0x6b90): more undefined references to `___copy_from_user' follow Fixes: 8630c32275ba ("avr32: fix copy_from_user()") Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Havard Skinnemoen <hskinnemoen@gmail.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-13avr32: fix copy_from_user()Al Viro
really ugly, but apparently avr32 compilers turns access_ok() into something so bad that they want it in assembler. Left that way, zeroing added in inline wrapper. Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-08-04dma-mapping: use unsigned long for dma_attrsKrzysztof Kozlowski
The dma-mapping core and the implementations do not change the DMA attributes passed by pointer. Thus the pointer can point to const data. However the attributes do not have to be a bitfield. Instead unsigned long will do fine: 1. This is just simpler. Both in terms of reading the code and setting attributes. Instead of initializing local attributes on the stack and passing pointer to it to dma_set_attr(), just set the bits. 2. It brings safeness and checking for const correctness because the attributes are passed by value. Semantic patches for this change (at least most of them): virtual patch virtual context @r@ identifier f, attrs; @@ f(..., - struct dma_attrs *attrs + unsigned long attrs , ...) { ... } @@ identifier r.f; @@ f(..., - NULL + 0 ) and // Options: --all-includes virtual patch virtual context @r@ identifier f, attrs; type t; @@ t f(..., struct dma_attrs *attrs); @@ identifier r.f; @@ f(..., - NULL + 0 ) Link: http://lkml.kernel.org/r/1468399300-5399-2-git-send-email-k.kozlowski@samsung.com Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Robin Murphy <robin.murphy@arm.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Acked-by: Mark Salter <msalter@redhat.com> [c6x] Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> [cris] Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> [drm] Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Fabien Dessenne <fabien.dessenne@st.com> [bdisp] Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> [vb2-core] Acked-by: David Vrabel <david.vrabel@citrix.com> [xen] Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen swiotlb] Acked-by: Joerg Roedel <jroedel@suse.de> [iommu] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon] Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> [m68k] Acked-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> [s390] Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> [avr32] Acked-by: Vineet Gupta <vgupta@synopsys.com> [arc] Acked-by: Robin Murphy <robin.murphy@arm.com> [arm64 and dma-iommu] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32 Pull AVR32 updates from Hans-Christian Noren Egtvedt. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32: avr32: off by one in at32_init_pio() avr32: fixup code style in unistd.h and syscall_table.S avr32: wire up preadv2 and pwritev2 syscalls
2016-07-29avr32: off by one in at32_init_pio()Dan Carpenter
The pio_dev[] array has MAX_NR_PIO_DEVICES elements so the > should be >=. Fixes: 5f97f7f9400d ('[PATCH] avr32 architecture') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com>
2016-07-29avr32: fixup code style in unistd.h and syscall_table.SHans-Christian Noren Egtvedt
This patch swaps the mix of tabs and space for alignment of comment after code to use spaces only. Also document why recvmmsg was defined twice in the syscall_table.S table, but only once in unistd.h. In short, wired in the table by generic arch patch, but forgotten in unistd.h (review slip).
2016-07-29avr32: wire up preadv2 and pwritev2 syscallsHans-Christian Noren Egtvedt
This patch wires up the new preadv2 and pwritev2 syscall on AVR32. On AVR32, all parameters beyond the 5th are passed on the stack. System calls don't use the stack -- they borrow a callee-saved register instead. This means that syscalls that take 6 parameters must be called through a stub that pushes the last parameter on the stack. Signed-off-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
2016-07-26mm: do not pass mm_struct into handle_mm_faultKirill A. Shutemov
We always have vma->vm_mm around. Link: http://lkml.kernel.org/r/1466021202-61880-8-git-send-email-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-07-25Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking updates from Ingo Molnar: "The locking tree was busier in this cycle than the usual pattern - a couple of major projects happened to coincide. The main changes are: - implement the atomic_fetch_{add,sub,and,or,xor}() API natively across all SMP architectures (Peter Zijlstra) - add atomic_fetch_{inc/dec}() as well, using the generic primitives (Davidlohr Bueso) - optimize various aspects of rwsems (Jason Low, Davidlohr Bueso, Waiman Long) - optimize smp_cond_load_acquire() on arm64 and implement LSE based atomic{,64}_fetch_{add,sub,and,andnot,or,xor}{,_relaxed,_acquire,_release}() on arm64 (Will Deacon) - introduce smp_acquire__after_ctrl_dep() and fix various barrier mis-uses and bugs (Peter Zijlstra) - after discovering ancient spin_unlock_wait() barrier bugs in its implementation and usage, strengthen its semantics and update/fix usage sites (Peter Zijlstra) - optimize mutex_trylock() fastpath (Peter Zijlstra) - ... misc fixes and cleanups" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (67 commits) locking/atomic: Introduce inc/dec variants for the atomic_fetch_$op() API locking/barriers, arch/arm64: Implement LDXR+WFE based smp_cond_load_acquire() locking/static_keys: Fix non static symbol Sparse warning locking/qspinlock: Use __this_cpu_dec() instead of full-blown this_cpu_dec() locking/atomic, arch/tile: Fix tilepro build locking/atomic, arch/m68k: Remove comment locking/atomic, arch/arc: Fix build locking/Documentation: Clarify limited control-dependency scope locking/atomic, arch/rwsem: Employ atomic_long_fetch_add() locking/atomic, arch/qrwlock: Employ atomic_fetch_add_acquire() locking/atomic, arch/mips: Convert to _relaxed atomics locking/atomic, arch/alpha: Convert to _relaxed atomics locking/atomic: Remove the deprecated atomic_{set,clear}_mask() functions locking/atomic: Remove linux/atomic.h:atomic_fetch_or() locking/atomic: Implement atomic{,64,_long}_fetch_{add,sub,and,andnot,or,xor}{,_relaxed,_acquire,_release}() locking/atomic: Fix atomic64_relaxed() bits locking/atomic, arch/xtensa: Implement atomic_fetch_{add,sub,and,or,xor}() locking/atomic, arch/x86: Implement atomic{,64}_fetch_{add,sub,and,or,xor}() locking/atomic, arch/tile: Implement atomic{,64}_fetch_{add,sub,and,or,xor}() locking/atomic, arch/sparc: Implement atomic{,64}_fetch_{add,sub,and,or,xor}() ...
2016-06-24tree wide: get rid of __GFP_REPEAT for order-0 allocations part IMichal Hocko
This is the third version of the patchset previously sent [1]. I have basically only rebased it on top of 4.7-rc1 tree and dropped "dm: get rid of superfluous gfp flags" which went through dm tree. I am sending it now because it is tree wide and chances for conflicts are reduced considerably when we want to target rc2. I plan to send the next step and rename the flag and move to a better semantic later during this release cycle so we will have a new semantic ready for 4.8 merge window hopefully. Motivation: While working on something unrelated I've checked the current usage of __GFP_REPEAT in the tree. It seems that a majority of the usage is and always has been bogus because __GFP_REPEAT has always been about costly high order allocations while we are using it for order-0 or very small orders very often. It seems that a big pile of them is just a copy&paste when a code has been adopted from one arch to another. I think it makes some sense to get rid of them because they are just making the semantic more unclear. Please note that GFP_REPEAT is documented as * __GFP_REPEAT: Try hard to allocate the memory, but the allocation attempt * _might_ fail. This depends upon the particular VM implementation. while !costly requests have basically nofail semantic. So one could reasonably expect that order-0 request with __GFP_REPEAT will not loop for ever. This is not implemented right now though. I would like to move on with __GFP_REPEAT and define a better semantic for it. $ git grep __GFP_REPEAT origin/master | wc -l 111 $ git grep __GFP_REPEAT | wc -l 36 So we are down to the third after this patch series. The remaining places really seem to be relying on __GFP_REPEAT due to large allocation requests. This still needs some double checking which I will do later after all the simple ones are sorted out. I am touching a lot of arch specific code here and I hope I got it right but as a matter of fact I even didn't compile test for some archs as I do not have cross compiler for them. Patches should be quite trivial to review for stupid compile mistakes though. The tricky parts are usually hidden by macro definitions and thats where I would appreciate help from arch maintainers. [1] http://lkml.kernel.org/r/1461849846-27209-1-git-send-email-mhocko@kernel.org This patch (of 19): __GFP_REPEAT has a rather weak semantic but since it has been introduced around 2.6.12 it has been ignored for low order allocations. Yet we have the full kernel tree with its usage for apparently order-0 allocations. This is really confusing because __GFP_REPEAT is explicitly documented to allow allocation failures which is a weaker semantic than the current order-0 has (basically nofail). Let's simply drop __GFP_REPEAT from those places. This would allow to identify place which really need allocator to retry harder and formulate a more specific semantic for what the flag is supposed to do actually. Link: http://lkml.kernel.org/r/1464599699-30131-2-git-send-email-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Andy Lutomirski <luto@kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> [for tile] Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jan Kara <jack@suse.cz> Cc: John Crispin <blogic@openwrt.org> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-06-16locking/atomic: Remove linux/atomic.h:atomic_fetch_or()Peter Zijlstra
Since all architectures have this implemented now natively, remove this dead code. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-06-16locking/atomic, arch/avr32: Implement atomic_fetch_{add,sub,and,or,xor}()Peter Zijlstra
Implement FETCH-OP atomic primitives, these are very similar to the existing OP-RETURN primitives we already have, except they return the value of the atomic variable _before_ modification. This is especially useful for irreversible operations -- such as bitops (because it becomes impossible to reconstruct the state prior to modification). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-arch@vger.kernel.org Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-05-20printk/nmi: generic solution for safe printk in NMIPetr Mladek
printk() takes some locks and could not be used a safe way in NMI context. The chance of a deadlock is real especially when printing stacks from all CPUs. This particular problem has been addressed on x86 by the commit a9edc8809328 ("x86/nmi: Perform a safe NMI stack trace on all CPUs"). The patchset brings two big advantages. First, it makes the NMI backtraces safe on all architectures for free. Second, it makes all NMI messages almost safe on all architectures (the temporary buffer is limited. We still should keep the number of messages in NMI context at minimum). Note that there already are several messages printed in NMI context: WARN_ON(in_nmi()), BUG_ON(in_nmi()), anything being printed out from MCE handlers. These are not easy to avoid. This patch reuses most of the code and makes it generic. It is useful for all messages and architectures that support NMI. The alternative printk_func is set when entering and is reseted when leaving NMI context. It queues IRQ work to copy the messages into the main ring buffer in a safe context. __printk_nmi_flush() copies all available messages and reset the buffer. Then we could use a simple cmpxchg operations to get synchronized with writers. There is also used a spinlock to get synchronized with other flushers. We do not longer use seq_buf because it depends on external lock. It would be hard to make all supported operations safe for a lockless use. It would be confusing and error prone to make only some operations safe. The code is put into separate printk/nmi.c as suggested by Steven Rostedt. It needs a per-CPU buffer and is compiled only on architectures that call nmi_enter(). This is achieved by the new HAVE_NMI Kconfig flag. The are MN10300 and Xtensa architectures. We need to clean up NMI handling there first. Let's do it separately. The patch is heavily based on the draft from Peter Zijlstra, see https://lkml.org/lkml/2015/6/10/327 [arnd@arndb.de: printk-nmi: use %zu format string for size_t] [akpm@linux-foundation.org: min_t->min - all types are size_t here] Signed-off-by: Petr Mladek <pmladek@suse.com> Suggested-by: Peter Zijlstra <peterz@infradead.org> Suggested-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jan Kara <jack@suse.cz> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> [arm part] Cc: Daniel Thompson <daniel.thompson@linaro.org> Cc: Jiri Kosina <jkosina@suse.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: David Miller <davem@davemloft.net> Cc: Daniel Thompson <daniel.thompson@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20exit_thread: accept a task parameter to be exitedJiri Slaby
We need to call exit_thread from copy_process in a fail path. So make it accept task_struct as a parameter. [v2] * s390: exit_thread_runtime_instr doesn't make sense to be called for non-current tasks. * arm: fix the comment in vfp_thread_copy * change 'me' to 'tsk' for task_struct * now we can change only archs that actually have exit_thread [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: "David S. Miller" <davem@davemloft.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Howells <dhowells@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Jonas Bonn <jonas@southpole.se> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Mikael Starvik <starvik@axis.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Russell King <linux@arm.linux.org.uk> Cc: Steven Miao <realmz6@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20exit_thread: remove empty bodiesJiri Slaby
Define HAVE_EXIT_THREAD for archs which want to do something in exit_thread. For others, let's define exit_thread as an empty inline. This is a cleanup before we change the prototype of exit_thread to accept a task parameter. [akpm@linux-foundation.org: fix mips] Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: "David S. Miller" <davem@davemloft.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chen Liqin <liqin.linux@gmail.com> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Chris Zankel <chris@zankel.net> Cc: David Howells <dhowells@redhat.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Jonas Bonn <jonas@southpole.se> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Mikael Starvik <starvik@axis.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Rich Felker <dalias@libc.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Russell King <linux@arm.linux.org.uk> Cc: Steven Miao <realmz6@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-19Merge tag 'dmaengine-4.7-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This time round the update brings in following changes: - new tegra driver for ADMA device - support for Xilinx AXI Direct Memory Access Engine and Xilinx AXI Central Direct Memory Access Engine and few updates to this driver - new cyclic capability to sun6i and few updates - slave-sg support in bcm2835 - updates to many drivers like designware, hsu, mv_xor, pxa, edma, qcom_hidma & bam" * tag 'dmaengine-4.7-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (84 commits) dmaengine: ioatdma: disable relaxed ordering for ioatdma dmaengine: of_dma: approximate an average distribution dmaengine: core: Use IS_ENABLED() instead of checking for built-in or module dmaengine: edma: Re-evaluate errors when ccerr is triggered w/o error event dmaengine: qcom_hidma: add support for object hierarchy dmaengine: qcom_hidma: add debugfs hooks dmaengine: qcom_hidma: implement lower level hardware interface dmaengine: vdma: Add clock support Documentation: DT: vdma: Add clock support for dmas dmaengine: vdma: Add config structure to differentiate dmas MAINTAINERS: Update Tegra DMA maintainers dmaengine: tegra-adma: Add support for Tegra210 ADMA Documentation: DT: Add binding documentation for NVIDIA ADMA dmaengine: vdma: Add Support for Xilinx AXI Central Direct Memory Access Engine Documentation: DT: vdma: update binding doc for AXI CDMA dmaengine: vdma: Add Support for Xilinx AXI Direct Memory Access Engine Documentation: DT: vdma: update binding doc for AXI DMA dmaengine: vdma: Rename xilinx_vdma_ prefix to xilinx_dma dmaengine: slave means at least one of DMA_SLAVE, DMA_CYCLIC dmaengine: mv_xor: Allow selecting mv_xor for mvebu only compatible SoC ...
2016-05-17Merge tag 'gpio-v4.7-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for kernel cycle v4.7: Core infrastructural changes: - Support for natively single-ended GPIO driver stages. This means that if the hardware has registers to configure open drain or open source configuration, we use that rather than (as we did before) try to emulate it by switching the line to an input to get high impedance. This is also documented throughly in Documentation/gpio/driver.txt for those of you who did not understand one word of what I just wrote. - Start to do away with the unnecessarily complex and unitelligible ARCH_REQUIRE_GPIOLIB and ARCH_WANT_OPTIONAL_GPIOLIB, another evolutional artifact from the time when the GPIO subsystem was unmaintained. Archs can now just select GPIOLIB and be done with it, cleanups to arches will trickle in for the next kernel. Some minor archs ACKed the changes immediately so these are included in this pull request. - Advancing the use of the data pointer inside the GPIO device for storing driver data by switching the PowerPC, Super-H Unicore and a few other subarches or subsystem drivers in ALSA SoC, Input, serial, SSB, staging etc to use it. - The initialization now reads the input/output state of the GPIO lines, so that each GPIO descriptor knows - if this callback is implemented - whether the line is input or output. This also reflects nicely in userspace "lsgpio". - It is now possible to name GPIO producer names, line names, from the device tree. (Platform data has been supported for a while). I bet we will get a similar mechanism for ACPI one of those days. This makes is possible to get sensible producer names for e.g. GPIO rails in "lsgpio" in userspace. New drivers: - New driver for the Loongson1. - The XLP driver now supports Broadcom Vulcan ARM64. - The IT87 driver now supports IT8620 and IT8628. - The PCA953X driver now supports Galileo Gen2. Driver improvements: - MCP23S08 was switched to use the gpiolib irqchip helpers and now also suppors level-triggered interrupts. - 74x164 and RCAR now supports the .set_multiple() callback - AMDPT was converted to use generic GPIO. - TC3589x, TPS65218, SX150X, F7188X, MENZ127, VX855, WM831X, WM8994 support the new single ended callback for open drain and in some cases open source. - Implement the .get_direction() callback for a few more drivers like PL061, Xgene. Cleanups: - Paul Gortmaker combed through the drivers and de-modularized those who are not really modules. - Move the GPIO poweroff DT bindings to the power subdir where they belong. - Rename gpio-generic.c to gpio-mmio.c, which is much more to the point. That's what it is handling, nothing more, nothing less" * tag 'gpio-v4.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (126 commits) MIPS: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB gpio: zevio: make it explicitly non-modular gpio: timberdale: make it explicitly non-modular gpio: stmpe: make it explicitly non-modular gpio: sodaville: make it explicitly non-modular pinctrl: sh-pfc: Let gpio_chip.to_irq() return zero on error gpio: dwapb: Add ACPI device ID for DWAPB GPIO controller on X-Gene platforms gpio: dt-bindings: add wd,mbl-gpio bindings gpio: of: make it possible to name GPIO lines gpio: make gpiod_to_irq() return negative for NO_IRQ gpio: xgene: implement .get_direction() gpio: xgene: Enable ACPI support for X-Gene GFC GPIO driver gpio: tegra: Implement gpio_get_direction callback gpio: set up initial state from .get_direction() gpio: rename gpio-generic.c into gpio-mmio.c gpio: generic: fix GPIO_GENERIC_PLATFORM is set to module case gpio: dwapb: add gpio-signaled acpi event support gpio: dwapb: convert device node to fwnode gpio: dwapb: remove name from dwapb_port_property gpio/qoriq: select IRQ_DOMAIN ...
2016-04-26avr32: do away with ARCH_REQUIRE_GPIOLIBLinus Walleij
Replace "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can now be selected directly. Cc: Michael Büsch <m@bues.ch> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Acked-by: Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-18avr32: Fix misspelling of 'definitions' in comment.Adam Buchbinder
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2016-04-13dmaengine: dw: rename masters to reflect actual topologyAndy Shevchenko
The source and destination masters are reflecting buses or their layers to where the different devices can be connected. The patch changes the master names to reflect which one is related to which independently on the transfer direction. The outcome of the change is that the memory data width is now always limited by a data width of the master which is dedicated to communicate to memory. The patch will not break anything since all current users have the same data width for all masters. Though it would be nice to revisit avr32 platforms to check what is the actual hardware topology in use there. It seems that it has one bus and two masters on it as stated by Table 8-2, that's why everything works independently on the master in use. The purpose of the sequential patch is to fix the driver for configuration of more than one bus. The change is done in the assumption that src_master and dst_master are reflecting a connection to the memory and peripheral correspondently on avr32 and otherwise on the rest. Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Mark Brown <broonie@kernel.org> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2016-03-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Support more Realtek wireless chips, from Jes Sorenson. 2) New BPF types for per-cpu hash and arrap maps, from Alexei Starovoitov. 3) Make several TCP sysctls per-namespace, from Nikolay Borisov. 4) Allow the use of SO_REUSEPORT in order to do per-thread processing of incoming TCP/UDP connections. The muxing can be done using a BPF program which hashes the incoming packet. From Craig Gallek. 5) Add a multiplexer for TCP streams, to provide a messaged based interface. BPF programs can be used to determine the message boundaries. From Tom Herbert. 6) Add 802.1AE MACSEC support, from Sabrina Dubroca. 7) Avoid factorial complexity when taking down an inetdev interface with lots of configured addresses. We were doing things like traversing the entire address less for each address removed, and flushing the entire netfilter conntrack table for every address as well. 8) Add and use SKB bulk free infrastructure, from Jesper Brouer. 9) Allow offloading u32 classifiers to hardware, and implement for ixgbe, from John Fastabend. 10) Allow configuring IRQ coalescing parameters on a per-queue basis, from Kan Liang. 11) Extend ethtool so that larger link mode masks can be supported. From David Decotigny. 12) Introduce devlink, which can be used to configure port link types (ethernet vs Infiniband, etc.), port splitting, and switch device level attributes as a whole. From Jiri Pirko. 13) Hardware offload support for flower classifiers, from Amir Vadai. 14) Add "Local Checksum Offload". Basically, for a tunneled packet the checksum of the outer header is 'constant' (because with the checksum field filled into the inner protocol header, the payload of the outer frame checksums to 'zero'), and we can take advantage of that in various ways. From Edward Cree" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits) bonding: fix bond_get_stats() net: bcmgenet: fix dma api length mismatch net/mlx4_core: Fix backward compatibility on VFs phy: mdio-thunder: Fix some Kconfig typos lan78xx: add ndo_get_stats64 lan78xx: handle statistics counter rollover RDS: TCP: Remove unused constant RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket net: smc911x: convert pxa dma to dmaengine team: remove duplicate set of flag IFF_MULTICAST bonding: remove duplicate set of flag IFF_MULTICAST net: fix a comment typo ethernet: micrel: fix some error codes ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it bpf, dst: add and use dst_tclassid helper bpf: make skb->tc_classid also readable net: mvneta: bm: clarify dependencies cls_bpf: reset class and reuse major in da ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c ldmvsw: Add ldmvsw.c driver code ...
2016-03-17Merge tag 'gpio-v4.6-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for kernel v4.6. There is quite a lot of interesting stuff going on. The patches to other subsystems and arch-wide are ACKed as far as possible, though I consider things like per-arch <asm/gpio.h> as essentially a part of the GPIO subsystem so it should not be needed. Core changes: - The gpio_chip is now a *real device*. Until now the gpio chips were just piggybacking the parent device or (gasp) floating in space outside of the device model. We now finally make GPIO chips devices. The gpio_chip will create a gpio_device which contains a struct device, and this gpio_device struct is kept private. Anything that needs to be kept private from the rest of the kernel will gradually be moved over to the gpio_device. - As a result of making the gpio_device a real device, we have added resource management, so devm_gpiochip_add_data() will cut down on overhead and reduce code lines. A huge slew of patches convert almost all drivers in the subsystem to use this. - Building on making the GPIO a real device, we add the first step of a new userspace ABI: the GPIO character device. We take small steps here, so we first add a pure *information* ABI and the tool "lsgpio" that will list all GPIO devices on the system and all lines on these devices. We can now discover GPIOs properly from userspace. We still have not come up with a way to actually *use* GPIOs from userspace. - To encourage people to use the character device for the future, we have it always-enabled when using GPIO. The old sysfs ABI is still opt-in (and can be used in parallel), but is marked as deprecated. We will keep it around for the foreseeable future, but it will not be extended to cover ever more use cases. Cleanup: - Bjorn Helgaas removed a whole slew of per-architecture <asm/gpio.h> includes. This dates back to when GPIO was an opt-in feature and no shared library even existed: just a header file with proper prototypes was provided and all semantics were up to the arch to implement. These patches make the GPIO chip even more a proper device and cleans out leftovers of the old in-kernel API here and there. Still some cruft is left but it's very little now. - There is still some clamping of return values for .get() going on, but we now return sane values in the vast majority of drivers and the errorpath is sanitized. Some patches for powerpc, blackfin and unicore still drop in. - We continue to switch the ARM, MIPS, blackfin, m68k local GPIO implementations to use gpiochip_add_data() and cut down on code lines. - MPC8xxx is converted to use the generic GPIO helpers. - ATH79 is converted to use the generic GPIO helpers. New drivers: - WinSystems WS16C48 - Acces 104-DIO-48E - F81866 (a F7188x variant) - Qoric (a MPC8xxx variant) - TS-4800 - SPI serializers (pisosr): simple 74xx shift registers connected to SPI to obtain a dirt-cheap output-only GPIO expander. - Texas Instruments TPIC2810 - Texas Instruments TPS65218 - Texas Instruments TPS65912 - X-Gene (ARM64) standby GPIO controller" * tag 'gpio-v4.6-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (194 commits) Revert "Share upstreaming patches" gpio: mcp23s08: Fix clearing of interrupt. gpiolib: Fix comment referring to gpio_*() in gpiod_*() gpio: pca953x: Fix pca953x_gpio_set_multiple() on 64-bit gpio: xgene: Fix kconfig for standby GIPO contoller gpio: Add generic serializer DT binding gpio: uapi: use 0xB4 as ioctl() major gpio: tps65912: fix bad merge Revert "gpio: lp3943: Drop pin_used and lp3943_gpio_request/lp3943_gpio_free" gpio: omap: drop dev field from gpio_bank structure gpio: mpc8xxx: Slightly update the code for better readability gpio: mpc8xxx: Remove *read_reg and *write_reg from struct mpc8xxx_gpio_chip gpio: mpc8xxx: Fixup setting gpio direction output gpio: mcp23s08: Add support for mcp23s18 dt-bindings: gpio: altera: Fix altr,interrupt-type property gpio: add driver for MEN 16Z127 GPIO controller gpio: lp3943: Drop pin_used and lp3943_gpio_request/lp3943_gpio_free gpio: timberdale: Switch to devm_ioremap_resource() gpio: ts4800: Add IMX51 dependency gpiolib: rewrite gpiodev_add_to_list ...
2016-03-16Merge tag 'pci-v4.6-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "PCI changes for v4.6: Enumeration: - Disable IO/MEM decoding for devices with non-compliant BARs (Bjorn Helgaas) - Mark Broadwell-EP Home Agent & PCU as having non-compliant BARs (Bjorn Helgaas Resource management: - Mark shadow copy of VGA ROM as IORESOURCE_PCI_FIXED (Bjorn Helgaas) - Don't assign or reassign immutable resources (Bjorn Helgaas) - Don't enable/disable ROM BAR if we're using a RAM shadow copy (Bjorn Helgaas) - Set ROM shadow location in arch code, not in PCI core (Bjorn Helgaas) - Remove arch-specific IORESOURCE_ROM_SHADOW size from sysfs (Bjorn Helgaas) - ia64: Use ioremap() instead of open-coded equivalent (Bjorn Helgaas) - ia64: Keep CPU physical (not virtual) addresses in shadow ROM resource (Bjorn Helgaas) - MIPS: Keep CPU physical (not virtual) addresses in shadow ROM resource (Bjorn Helgaas) - Remove unused IORESOURCE_ROM_COPY and IORESOURCE_ROM_BIOS_COPY (Bjorn Helgaas) - Don't leak memory if sysfs_create_bin_file() fails (Bjorn Helgaas) - rcar: Remove PCI_PROBE_ONLY handling (Lorenzo Pieralisi) - designware: Remove PCI_PROBE_ONLY handling (Lorenzo Pieralisi) Virtualization: - Wait for up to 1000ms after FLR reset (Alex Williamson) - Support SR-IOV on any function type (Kelly Zytaruk) - Add ACS quirk for all Cavium devices (Manish Jaggi) AER: - Rename pci_ops_aer to aer_inj_pci_ops (Bjorn Helgaas) - Restore pci_ops pointer while calling original pci_ops (David Daney) - Fix aer_inject error codes (Jean Delvare) - Use dev_warn() in aer_inject (Jean Delvare) - Log actual error causes in aer_inject (Jean Delvare) - Log aer_inject error injections (Jean Delvare) VPD: - Prevent VPD access for buggy devices (Babu Moger) - Move pci_read_vpd() and pci_write_vpd() close to other VPD code (Bjorn Helgaas) - Move pci_vpd_release() from header file to pci/access.c (Bjorn Helgaas) - Remove struct pci_vpd_ops.release function pointer (Bjorn Helgaas) - Rename VPD symbols to remove unnecessary "pci22" (Bjorn Helgaas) - Fold struct pci_vpd_pci22 into struct pci_vpd (Bjorn Helgaas) - Sleep rather than busy-wait for VPD access completion (Bjorn Helgaas) - Update VPD definitions (Hannes Reinecke) - Allow access to VPD attributes with size 0 (Hannes Reinecke) - Determine actual VPD size on first access (Hannes Reinecke) Generic host bridge driver: - Move structure definitions to separate header file (David Daney) - Add pci_host_common_probe(), based on gen_pci_probe() (David Daney) - Expose pci_host_common_probe() for use by other drivers (David Daney) Altera host bridge driver: - Fix altera_pcie_link_is_up() (Ley Foon Tan) Cavium ThunderX host bridge driver: - Add PCIe host driver for ThunderX processors (David Daney) - Add driver for ThunderX-pass{1,2} on-chip devices (David Daney) Freescale i.MX6 host bridge driver: - Add DT bindings to configure PHY Tx driver settings (Justin Waters) - Move imx6_pcie_reset_phy() near other PHY handling functions (Lucas Stach) - Move PHY reset into imx6_pcie_establish_link() (Lucas Stach) - Remove broken Gen2 workaround (Lucas Stach) - Move link up check into imx6_pcie_wait_for_link() (Lucas Stach) Freescale Layerscape host bridge driver: - Add "fsl,ls2085a-pcie" compatible ID (Yang Shi) Intel VMD host bridge driver: - Attach VMD resources to parent domain's resource tree (Jon Derrick) - Set bus resource start to 0 (Keith Busch) Microsoft Hyper-V host bridge driver: - Add fwnode_handle to x86 pci_sysdata (Jake Oshins) - Look up IRQ domain by fwnode_handle (Jake Oshins) - Add paravirtual PCI front-end for Microsoft Hyper-V VMs (Jake Oshins) NVIDIA Tegra host bridge driver: - Add pci_ops.{add,remove}_bus() callbacks (Thierry Reding) - Implement ->{add,remove}_bus() callbacks (Thierry Reding) - Remove unused struct tegra_pcie.num_ports field (Thierry Reding) - Track bus -> CPU mapping (Thierry Reding) - Remove misleading PHYS_OFFSET (Thierry Reding) Renesas R-Car host bridge driver: - Depend on ARCH_RENESAS, not ARCH_SHMOBILE (Simon Horman) Synopsys DesignWare host bridge driver: - ARC: Add PCI support (Joao Pinto) - Add generic dw_pcie_wait_for_link() (Joao Pinto) - Add default link up check if sub-driver doesn't override (Joao Pinto) - Add driver for prototyping kits based on ARC SDP (Joao Pinto) TI Keystone host bridge driver: - Defer probing if devm_phy_get() returns -EPROBE_DEFER (Shawn Lin) Xilinx AXI host bridge driver: - Use of_pci_get_host_bridge_resources() to parse DT (Bharat Kumar Gogada) - Remove dependency on ARM-specific struct hw_pci (Bharat Kumar Gogada) - Don't call pci_fixup_irqs() on Microblaze (Bharat Kumar Gogada) - Update Zynq binding with Microblaze node (Bharat Kumar Gogada) - microblaze: Support generic Xilinx AXI PCIe Host Bridge IP driver (Bharat Kumar Gogada) Xilinx NWL host bridge driver: - Add support for Xilinx NWL PCIe Host Controller (Bharat Kumar Gogada) Miscellaneous: - Check device_attach() return value always (Bjorn Helgaas) - Move pci_set_flags() from asm-generic/pci-bridge.h to linux/pci.h (Bjorn Helgaas) - Remove includes of empty asm-generic/pci-bridge.h (Bjorn Helgaas) - ARM64: Remove generated include of asm-generic/pci-bridge.h (Bjorn Helgaas) - Remove empty asm-generic/pci-bridge.h (Bjorn Helgaas) - Remove includes of asm/pci-bridge.h (Bjorn Helgaas) - Consolidate PCI DMA constants and interfaces in linux/pci-dma-compat.h (Bjorn Helgaas) - unicore32: Remove unused HAVE_ARCH_PCI_SET_DMA_MASK definition (Bjorn Helgaas) - Cleanup pci/pcie/Kconfig whitespace (Andreas Ziegler) - Include pci/hotplug Kconfig directly from pci/Kconfig (Bjorn Helgaas) - Include pci/pcie/Kconfig directly from pci/Kconfig (Bogicevic Sasa) - frv: Remove stray pci_{alloc,free}_consistent() declaration (Christoph Hellwig) - Move pci_dma_* helpers to common code (Christoph Hellwig) - Add PCI_CLASS_SERIAL_USB_DEVICE definition (Heikki Krogerus) - Add QEMU top-level IDs for (sub)vendor & device (Robin H. Johnson) - Fix broken URL for Dell biosdevname (Naga Venkata Sai Indubhaskar Jupudi)" * tag 'pci-v4.6-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (94 commits) PCI: Add PCI_CLASS_SERIAL_USB_DEVICE definition PCI: designware: Add driver for prototyping kits based on ARC SDP PCI: designware: Add default link up check if sub-driver doesn't override PCI: designware: Add generic dw_pcie_wait_for_link() PCI: Cleanup pci/pcie/Kconfig whitespace PCI: Simplify pci_create_attr() control flow PCI: Don't leak memory if sysfs_create_bin_file() fails PCI: Simplify sysfs ROM cleanup PCI: Remove unused IORESOURCE_ROM_COPY and IORESOURCE_ROM_BIOS_COPY MIPS: Loongson 3: Keep CPU physical (not virtual) addresses in shadow ROM resource MIPS: Loongson 3: Use temporary struct resource * to avoid repetition ia64/PCI: Keep CPU physical (not virtual) addresses in shadow ROM resource ia64/PCI: Use ioremap() instead of open-coded equivalent ia64/PCI: Use temporary struct resource * to avoid repetition PCI: Clean up pci_map_rom() whitespace PCI: Remove arch-specific IORESOURCE_ROM_SHADOW size from sysfs PCI: thunder: Add driver for ThunderX-pass{1,2} on-chip devices PCI: thunder: Add PCIe host driver for ThunderX processors PCI: generic: Expose pci_host_common_probe() for use by other drivers PCI: generic: Add pci_host_common_probe(), based on gen_pci_probe() ...
2016-03-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32 Pull AVR32 updates from Hans-Christian Egtvedt. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32: avr32: fix asm operand constraint in cmpxchg() avr32: wire up copy_file_range syscall
2016-03-14avr32: fix asm operand constraint in cmpxchg()Mans Rullgard
If the 'old' operand to cmpxchg() is a constant wider than 21 bits, linking fails with a "relocation truncated to fit: R_AVR32_21S" error. Fix this by replacing the "i" constraint with "Ks21" which makes the compiler use a temporary register for out of range constants. Signed-off-by: Mans Rullgard <mans@mansr.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Tested-by: Andy Shevchenko <andy.shevchenko@gmail.com> Tested-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
2016-03-14avr32: wire up copy_file_range syscallHans-Christian Egtvedt
This patch wires up the new copy_file_range syscall on AVR32. On AVR32, all parameters beyond the 5th are passed on the stack. System calls don't use the stack -- they borrow a callee-saved register instead. This means that syscalls that take 6 parameters must be called through a stub that pushes the last parameter on the stack. Signed-off-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
2016-03-13ipv4: Update parameters for csum_tcpudp_magic to their original typesAlexander Duyck
This patch updates all instances of csum_tcpudp_magic and csum_tcpudp_nofold to reflect the types that are usually used as the source inputs. For example the protocol field is populated based on nexthdr which is actually an unsigned 8 bit value. The length is usually populated based on skb->len which is an unsigned integer. This addresses an issue in which the IPv6 function csum_ipv6_magic was generating a checksum using the full 32b of skb->len while csum_tcpudp_magic was only using the lower 16 bits. As a result we could run into issues when attempting to adjust the checksum as there was no protocol agnostic way to update it. With this change the value is still truncated as many architectures use "(len + proto) << 8", however this truncation only occurs for values greater than 16776960 in length and as such is unlikely to occur as we stop the inner headers at ~64K in size. I did have to make a few minor changes in the arm, mn10300, nios2, and score versions of the function in order to support these changes as they were either using things such as an OR to combine the protocol and length, or were using ntohs to convert the length which would have truncated the value. I also updated a few spots in terms of whitespace and type differences for the addresses. Most of this was just to make sure all of the definitions were in sync going forward. Signed-off-by: Alexander Duyck <aduyck@mirantis.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-03-07PCI: Move pci_dma_* helpers to common codeChristoph Hellwig
For a long time all architectures implement the pci_dma_* functions using the generic DMA API, and they all use the same header to do so. Move this header, pci-dma-compat.h, to include/linux and include it from the generic pci.h instead of having each arch duplicate this include. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2016-02-25net: Facility to report route quality of connected socketsTom Herbert
This patch add the SO_CNX_ADVICE socket option (setsockopt only). The purpose is to allow an application to give feedback to the kernel about the quality of the network path for a connected socket. The value argument indicates the type of quality report. For this initial patch the only supported advice is a value of 1 which indicates "bad path, please reroute"-- the action taken by the kernel is to call dst_negative_advice which will attempt to choose a different ECMP route, reset the TX hash for flow label and UDP source port in encapsulation, etc. This facility should be useful for connected UDP sockets where only the application can provide any feedback about path quality. It could also be useful for TCP applications that have additional knowledge about the path outside of the normal TCP control loop. Signed-off-by: Tom Herbert <tom@herbertland.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-02-16gpio: Include linux/gpio.h instead of asm/gpio.hBjorn Helgaas
Most arches have an asm/gpio.h that merely includes linux/gpio.h. The others select ARCH_HAVE_CUSTOM_GPIO_H, and when that's selected, linux/gpio.h includes asm/gpio.h. Therefore, code should include linux/gpio.h instead of including asm/gpio.h directly. Remove includes of asm/gpio.h, adding an include of linux/gpio.h when necessary. This is a follow-on to 7563bbf89d06 ("gpiolib/arches: Centralise bolierplate asm/gpio.h"). Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-01-30arch: Set IORESOURCE_SYSTEM_RAM flag for System RAMToshi Kani
Set IORESOURCE_SYSTEM_RAM in flags of resource ranges with "System RAM", "Kernel code", "Kernel data", and "Kernel bss". Note that: - IORESOURCE_SYSRAM (i.e. modifier bit) is set in flags when IORESOURCE_MEM is already set. IORESOURCE_SYSTEM_RAM is defined as (IORESOURCE_MEM|IORESOURCE_SYSRAM). - Some archs do not set 'flags' for children nodes, such as "Kernel code". This patch does not change 'flags' in this case. Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luis R. Rodriguez <mcgrof@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Toshi Kani <toshi.kani@hp.com> Cc: linux-arch@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-mips@linux-mips.org Cc: linux-mm <linux-mm@kvack.org> Cc: linux-parisc@vger.kernel.org Cc: linux-s390@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Cc: sparclinux@vger.kernel.org Link: http://lkml.kernel.org/r/1453841853-11383-7-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-01-20dma-mapping: always provide the dma_map_ops based implementationChristoph Hellwig
Move the generic implementation to <linux/dma-mapping.h> now that all architectures support it and remove the HAVE_DMA_ATTR Kconfig symbol now that everyone supports them. [valentinrothberg@gmail.com: remove leftovers in Kconfig] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Helge Deller <deller@gmx.de> Cc: James Hogan <james.hogan@imgtec.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Steven Miao <realmz6@gmail.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Valentin Rothberg <valentinrothberg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-20avr32: convert to dma_map_opsChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Joerg Roedel <jroedel@suse.de> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32 Pull AVR32 updates from Hans-Christian Noren Egtvedt. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/linux-avr32: mmc: atmel: get rid of struct mci_dma_data mmc: atmel-mci: restore dma on AVR32 avr32: wire up missing syscalls avr32: wire up accept4 syscall
2016-01-17Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - more MM stuff: - Kirill's page-flags rework - Kirill's now-allegedly-fixed THP rework - MADV_FREE implementation - DAX feature work (msync/fsync). This isn't quite complete but DAX is new and it's good enough and the guys have a handle on what needs to be done - I expect this to be wrapped in the next week or two. - some vsprintf maintenance work - various other misc bits * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (145 commits) printk: change recursion_bug type to bool lib/vsprintf: factor out %pN[F] handler as netdev_bits() lib/vsprintf: refactor duplicate code to special_hex_number() printk-formats.txt: remove unimplemented %pT printk: help pr_debug and pr_devel to optimize out arguments lib/test_printf.c: test dentry printing lib/test_printf.c: add test for large bitmaps lib/test_printf.c: account for kvasprintf tests lib/test_printf.c: add a few number() tests lib/test_printf.c: test precision quirks lib/test_printf.c: check for out-of-bound writes lib/test_printf.c: don't BUG lib/kasprintf.c: add sanity check to kvasprintf lib/vsprintf.c: warn about too large precisions and field widths lib/vsprintf.c: help gcc make number() smaller lib/vsprintf.c: expand field_width to 24 bits lib/vsprintf.c: eliminate potential race in string() lib/vsprintf.c: move string() below widen_string() lib/vsprintf.c: pull out padding code from dentry_name() printk: do cond_resched() between lines while outputting to consoles ...
2016-01-17Merge tag 'gpio-v4.5-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "Here is the bulk of GPIO changes for v4.5. Notably there are big refactorings mostly by myself, aimed at getting the gpio_chip into a shape that makes me believe I can proceed to preserve state for a proper userspace ABI (character device) that has already been proposed once, but resulted in the feedback that I need to go back and restructure stuff. So I've been restructuring stuff. On the way I ran into brokenness (return code from the get_value() callback) and had to fix it. Also, refactored generic GPIO to be simpler. Some of that is still waiting to trickle down from the subsystems all over the kernel that provide random gpio_chips, I've touched every single GPIO driver in the kernel now, oh man I didn't know I was responsible for so much... Apart from that we're churning along as usual. I took some effort to test and retest so it should merge nicely and we shook out a couple of bugs in -next. Infrastructural changes: - In struct gpio_chip, rename the .dev node to .parent to better reflect the fact that this is not the GPIO struct device abstraction. We will add that soon so this would be totallt confusing. - It was noted that the driver .get_value() callbacks was sometimes reporting negative -ERR values to the gpiolib core, expecting them to be propagated to consumer gpiod_get_value() and gpio_get_value() calls. This was not happening, so as there was a mess of drivers returning negative errors and some returning "anything else than zero" to indicate that a line was active. As some would have bit 31 set to indicate "line active" it clashed with negative error codes. This is fixed by the largeish series clamping values in all drivers with !!value to [0,1] and then augmenting the code to propagate error codes to consumers. (Includes some ACKed patches in other subsystems.) - Add a void *data pointer to struct gpio_chip. The container_of() design pattern is indeed very nice, but we want to reform the struct gpio_chip to be a non-volative, stateless business, and keep states internal to the gpiolib to be able to hold on to the state when adding a proper userspace ABI (character device) further down the road. To achieve this, drivers need a handle at the internal state that is not dependent on their struct gpio_chip() so we add gpiochip_add_data() and gpiochip_get_data() following the pattern of many other subsystems. All the "use gpiochip data pointer" patches transforms drivers to this scheme. - The Generic GPIO chip header has been merged into the general <linux/gpio/driver.h> header, and the custom header for that removed. Instead of having a separate mm_gpio_chip struct for these generic drivers, merge that into struct gpio_chip, simplifying the code and removing the need for separate and confusing includes. Misc improvements: - Stabilize the way GPIOs are looked up from the ACPI legacy specification. - Incremental driver features for PXA, PCA953X, Lantiq (patches from the OpenWRT community), RCAR, Zynq, PL061, 104-idi-48 New drivers: - Add a GPIO chip to the ALSA SoC AC97 driver. - Add a new Broadcom NSP SoC driver (this lands in the pinctrl dir, but the branch is merged here too to account for infrastructural changes). - The sx150x driver now supports the sx1502" * tag 'gpio-v4.5-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (220 commits) gpio: generic: make bgpio_pdata always visible gpiolib: fix chip order in gpio list gpio: mpc8xxx: Do not use gpiochip_get_data() in mpc8xxx_gpio_save_regs() gpio: mm-lantiq: Do not use gpiochip_get_data() in ltq_mm_save_regs() gpio: brcmstb: Allow building driver for BMIPS_GENERIC gpio: brcmstb: Set endian flags for big-endian MIPS gpio: moxart: fix build regression gpio: xilinx: Do not use gpiochip_get_data() in xgpio_save_regs() leds: pca9532: use gpiochip data pointer leds: tca6507: use gpiochip data pointer hid: cp2112: use gpiochip data pointer bcma: gpio: use gpiochip data pointer avr32: gpio: use gpiochip data pointer video: fbdev: via: use gpiochip data pointer gpio: pch: Optimize pch_gpio_get() Revert "pinctrl: lantiq: Implement gpio_chip.to_irq" pinctrl: nsp-gpio: use gpiochip data pointer pinctrl: vt8500-wmt: use gpiochip data pointer pinctrl: exynos5440: use gpiochip data pointer pinctrl: at91-pio4: use gpiochip data pointer ...
2016-01-15avr32: convert to asm-generic/memory_model.hDan Williams
Switch avr32/include/asm/page.h to use the common defintions for pfn_to_page(), page_to_pfn(), and ARCH_PFN_OFFSET. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching Pull livepatching updates from Jiri Kosina: - RO/NX attribute fixes for patch module relocations from Josh Poimboeuf. As part of this effort, module.c has been cleaned up as well and livepatching is piggy-backing on this cleanup. Rusty is OK with this whole lot going through livepatching tree. - symbol disambiguation support from Chris J Arges. That series is also Reviewed-by: Miroslav Benes <mbenes@suse.cz> but this came in only after I've alredy pushed out. Didn't want to rebase because of that, hence I am mentioning it here. - symbol lookup fix from Miroslav Benes * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching: livepatch: Cleanup module page permission changes module: keep percpu symbols in module's symtab module: clean up RO/NX handling. module: use a structure to encapsulate layout. gcov: use within_module() helper. module: Use the same logic for setting and unsetting RO/NX livepatch: function,sympos scheme in livepatch sysfs directory livepatch: add sympos as disambiguator field to klp_reloc livepatch: add old_sympos as disambiguator field to klp_func
2016-01-14mmc: atmel: get rid of struct mci_dma_dataMans Rullgard
As struct mci_dma_data is now only used by AVR32, it is nothing but pointless indirection. Replace it with struct dw_dma_slave in the AVR32 platform code and with a void pointer elsewhere. Signed-off-by: Mans Rullgard <mans@mansr.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com> Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
2016-01-14mmc: atmel-mci: restore dma on AVR32Mans Rullgard
Commit ecb89f2f5f3e7 ("mmc: atmel-mci: remove compat for non DT board when requesting dma chan") broke dma on AVR32 and any other boards not using DT. This restores a fallback mechanism for such cases. Signed-off-by: Mans Rullgard <mans@mansr.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com> Acked-by: Ulf Hansson <ulf.hansson@linaro.org>
2016-01-11avr32: wire up missing syscallsHans-Christian Egtvedt
This patch adds three missing syscalls to AVR32: __NR_userfaultfd __NR_membarrier __NR_mlock2 Signed-off-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2016-01-11avr32: wire up accept4 syscallMans Rullgard
The accept4 syscall is missing on AVR32. Fix this. Signed-off-by: Mans Rullgard <mans@mansr.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no>
2016-01-07avr32: gpio: use gpiochip data pointerLinus Walleij
This makes the driver use the data pointer added to the gpio_chip to store a pointer to the state container instead of relying on container_of(). Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Acked-by: Hans-Christian Noren Egtvedt <egtvedt@samfundet.no> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-01-04soreuseport: setsockopt SO_ATTACH_REUSEPORT_[CE]BPFCraig Gallek
Expose socket options for setting a classic or extended BPF program for use when selecting sockets in an SO_REUSEPORT group. These options can be used on the first socket to belong to a group before bind or on any socket in the group after bind. This change includes refactoring of the existing sk_filter code to allow reuse of the existing BPF filter validation checks. Signed-off-by: Craig Gallek <kraig@google.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-04module: use a structure to encapsulate layout.Rusty Russell
Makes it easier to handle init vs core cleanly, though the change is fairly invasive across random architectures. It simplifies the rbtree code immediately, however, while keeping the core data together in the same cachline (now iff the rbtree code is enabled). Acked-by: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2015-11-19gpio: change member .dev to .parentLinus Walleij
The name .dev in a struct is normally reserved for a struct device that is let us say a superclass to the thing described by the struct. struct gpio_chip stands out by confusingly using a struct device *dev to point to the parent device (such as a platform_device) that represents the hardware. As we want to give gpio_chip:s real devices, this is not working. We need to rename this member to parent. This was done by two coccinelle scripts, I guess it is possible to combine them into one, but I don't know such stuff. They look like this: @@ struct gpio_chip *var; @@ -var->dev +var->parent and: @@ struct gpio_chip var; @@ -var.dev +var.parent and: @@ struct bgpio_chip *var; @@ -var->gc.dev +var->gc.parent Plus a few instances of bgpio that I couldn't figure out how to teach Coccinelle to rewrite. This patch hits all over the place, but I *strongly* prefer this solution to any piecemal approaches that just exercise patch mechanics all over the place. It mainly hits drivers/gpio and drivers/pinctrl which is my own backyard anyway. Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Rafał Miłecki <zajec5@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Cc: Alek Du <alek.du@intel.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Jacek Anaszewski <j.anaszewski@samsung.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-11-10Merge tag 'dmaengine-4.4-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This time we have a very typical update which is mostly fixes and updates to drivers and no new drivers. - the biggest change is coming from Peter for edma cleanup which even caused some last minute regression, things seem settled now - idma64 and dw updates - iotdma updates - module autoload fixes for various drivers - scatter gather support for hdmac" * tag 'dmaengine-4.4-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (77 commits) dmaengine: edma: Add dummy driver skeleton for edma3-tptc Revert "ARM: DTS: am33xx: Use the new DT bindings for the eDMA3" Revert "ARM: DTS: am437x: Use the new DT bindings for the eDMA3" dmaengine: dw: some Intel devices has no memcpy support dmaengine: dw: platform: provide platform data for Intel dmaengine: dw: don't override platform data with autocfg dmaengine: hdmac: Add scatter-gathered memset support dmaengine: hdmac: factorise memset descriptor allocation dmaengine: virt-dma: Fix kernel-doc annotations ARM: DTS: am437x: Use the new DT bindings for the eDMA3 ARM: DTS: am33xx: Use the new DT bindings for the eDMA3 dmaengine: edma: New device tree binding dmaengine: Kconfig: edma: Select TI_DMA_CROSSBAR in case of ARCH_OMAP dmaengine: ti-dma-crossbar: Add support for crossbar on AM33xx/AM43xx dmaengine: edma: Merge the of parsing functions dmaengine: edma: Do not allocate memory for edma_rsv_info in case of DT boot dmaengine: edma: Refactor the dma device and channel struct initialization dmaengine: edma: Get qDMA channel information from HW also dmaengine: edma: Merge map_dmach_to_queue into assign_channel_eventq dmaengine: edma: Correct PaRAM access function names (_parm_ to _param_) ...
