do_file_page and do_no_page don't exist anymore, but some comments
still refers them. The patch fixes them by replacing them with
existing ones.
Signed-off-by: Ryota Ozaki <ozaki.ryota@gmail.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Now that the dw_dmac DMA driver supports configurable source and
destination masters we need to specify which ones to use. This was
previously hardcoded to 0 and 1 respectively in the driver.
Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
This patch adds the linux/mm.h header file to the AVR32 arch pgalloc.c
implementation to fix the undefined reference to pgtable_page_ctor() and
pgtable_page_dtor().
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6:
avr32: update default configuration files for Atmel boards
avr32: Convert to clocksource_register_hz
avr32: make architecture sys_clone prototype match asm-generic prototype
avr32: use syscall prototypes from asm-generic instead of arch
avr32: disable kprobes for all default configurations
avr32: boards: setup: use IS_ERR() instead of NULL check
This patch adjusts some values to make the default configuration for Atmel
boards more similar, and adds missing values to enable required functions. Also
remove defined symbols for functions not in use.
This converts the avr32 clocksource to use clocksource_register_hz.
This is untested, so any assistance in testing would be appreciated!
CC: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
CC: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: John Stultz <johnstul@us.ibm.com>
This patch will fix the arguments to the architecture sys_clone() function to
match the asm-generic/syscalls.h prototype. In the same go remove the
architecture specific prototype for the same function.
The sys_clone() function is only called from assembly, hence the argument types
were not having any affect.
This patch removes the redundant syscalls prototypes in the architecture
specific syscalls.h header file. These were identical with the ones in
asm-generic/syscalls.h.
Reported-by: Peter Huewe <PeterHuewe@gmx.de>
Reported-by: Sven Schnelle <svens@stackframe.org>
Cc: stable <stable@kernel.org>
This patch will disable kprobes for all the default AVR32 board configurations.
This works around a regression in kprobes which seems to be related to AVR32 is
now lacking the struct kprobe_ctlblk.
clk_get() returns ERR_PTR() on error, not NULL.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
While at it, fix two checkpatch errors.
Several non-const struct instances constified by this patch were added after
the introduction of platform_suspend_ops in checkpatch.pl's list of "should
be const" structs (79404849e90a41ea2109bd0e2f7c7164b0c4ce73).
Patch against mainline.
Inspired by hunks of the grsecurity patch, updated for newer kernels.
Signed-off-by: Lionel Debroux <lionel_debroux@yahoo.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits)
kbuild: convert `arch/tile' to the kconfig mainmenu upgrade
README: cite nconfig
Revert "kconfig: Temporarily disable dependency warnings"
kconfig: Use PATH_MAX instead of 128 for path buffer sizes.
kconfig: Fix realloc usage()
kconfig: Propagate const
kconfig: Don't go out from read config loop when you read new symbol
kconfig: fix menuconfig on debian lenny
kbuild: migrate all arch to the kconfig mainmenu upgrade
kconfig: expand file names
kconfig: use the file's name of sourced file
kconfig: constify file name
kconfig: don't emit warning upon rootmenu's prompt redefinition
kconfig: replace KERNELVERSION usage by the mainmenu's prompt
kconfig: delay gconf window initialization
kconfig: expand by default the rootmenu's prompt
kconfig: add a symbol string expansion helper
kconfig: regen parser
kconfig: implement the `mainmenu' directive
kconfig: allow PACKAGE to be defined on the compiler's command-line
Fix up trivial conflict in arch/mn10300/Kconfig
use new 'datap' variable type of void pointer in order to remove unnecessary
castings.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Fix up the arguments to arch_ptrace() to take account of the fact that
@addr and @data are now unsigned long rather than long as of a preceding
patch in this series.
Acked-by: Roland McGrath <roland@redhat.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Since we no longer need to provide KM_type, the whole pte_*map_nested()
API is now redundant, remove it.
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (49 commits)
serial8250: ratelimit "too much work" error
serial: bfin_sport_uart: speed up sport RX sample rate to be 3% faster
serial: abstraction for 8250 legacy ports
serial/imx: check that the buffer is non-empty before sending it out
serial: mfd: add more baud rates support
jsm: Remove the uart port on errors
Alchemy: Add UART PM methods.
8250: allow platforms to override PM hook.
altera_uart: Don't use plain integer as NULL pointer
altera_uart: Fix missing prototype for registering an early console
altera_uart: Fixup type usage of port flags
altera_uart: Make it possible to use Altera UART and 8250 ports together
altera_uart: Add support for different address strides
altera_uart: Add support for getting mapbase and IRQ from resources
altera_uart: Add support for polling mode (IRQ-less)
serial: Factor out uart_poll_timeout() from 8250 driver
serial: mark the 8250 driver as maintained
serial: 8250: Don't delay after transmitter is ready.
tty: MAINTAINERS: add drivers/serial/jsm/ as maintained driver
vcs: invoke the vt update callback when /dev/vcs* is written to
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
This patch converts avr32 to use asm-generic/ioctls.h instead of its
own version.
The differences between the arch-specific version and the generic
version are as follows:
- The generic version adds support for termiox
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (278 commits)
arm: remove machine_desc.io_pg_offst and .phys_io
arm: use addruart macro to establish debug mappings
arm: return both physical and virtual addresses from addruart
arm/debug: consolidate addruart macros for CONFIG_DEBUG_ICEDCC
ARM: make struct machine_desc definition coherent with its comment
eukrea_mbimxsd-baseboard: Pass the correct GPIO to gpio_free
cpuimx27: fix compile when ULPI is selected
mach-pcm037_eet: fix compile errors
Fixing ethernet driver compilation error for i.MX31 ADS board
cpuimx51: update board support
mx5: add cpuimx51sd module and its baseboard
iomux-mx51: fix GPIO_1_xx 's IOMUX configuration
imx-esdhc: update devices registration
mx51: add resources for SD/MMC on i.MX51
iomux-mx51: fix SD1 and SD2's iomux configuration
clock-mx51: rename CLOCK1 to CLOCK_CCGR for better readability
clock-mx51: factorize clk_set_parent and clk_get_rate
eukrea_mbimxsd: add support for DVI displays
cpuimx25 & cpuimx35: fix OTG port registration in host mode
i.MX31 and i.MX35 : fix errate TLSbo65953 and ENGcm09472
The patch below updates broken web addresses in the arch directory.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
We need to revert the temporary hack in 71ebc01, hence the merge.
Many Atmel SOC are embedding a MACB controller. This patch removes the long
dependency line for this Atmel MACB ethernet driver configuration entry.
The HAVE_NET_MACB configuration option is located in the net Kconfig file
as it may be setup by ARM/AT91 and AVR32 chips.
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Andrew Victor <linux@maxim.org.za>
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration,
it maps:
local_irq_enable() -> raw_local_irq_enable()
local_irq_disable() -> raw_local_irq_disable()
local_irq_save() -> raw_local_irq_save()
and under the other configuration, it maps:
raw_local_irq_enable() -> local_irq_enable()
raw_local_irq_disable() -> local_irq_disable()
raw_local_irq_save() -> local_irq_save()
This is quite confusing. There should be one set of names expected of the
arch, and this should be wrapped to give another set of names that are expected
by users of this facility.
Change this to have the arch provide:
flags = arch_local_save_flags()
flags = arch_local_irq_save()
arch_local_irq_restore(flags)
arch_local_irq_disable()
arch_local_irq_enable()
arch_irqs_disabled_flags(flags)
arch_irqs_disabled()
arch_safe_halt()
Then linux/irqflags.h wraps these to provide:
raw_local_save_flags(flags)
raw_local_irq_save(flags)
raw_local_irq_restore(flags)
raw_irqs_disabled_flags(flags)
raw_irqs_disabled()
raw_safe_halt()
with type checking on the flags 'arguments', and then wraps those to provide:
local_irq_disable()
local_irq_enable()
irqs_disabled()
safe_halt()
with tracing included if enabled.
The arch functions can now all be inline functions rather than some of them
having to be macros.
Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300]
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile]
Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze]
Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM]
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR]
Acked-by: Tony Luck <tony.luck@intel.com> [IA-64]
Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R]
Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU]
Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS]
Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC]
Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC]
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390]
Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score]
Acked-by: Matt Fleming <matt@console-pimps.org> [SH]
Acked-by: David S. Miller <davem@davemloft.net> [Sparc]
Acked-by: Chris Zankel <chris@zankel.net> [Xtensa]
Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha]
Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300]
Cc: starvik@axis.com [CRIS]
Cc: jesper.nilsson@axis.com [CRIS]
Cc: linux-cris-kernel@axis.com
With all the recent module loading cleanups, we've minimized the code
that sits under module_mutex, fixing various deadlocks and making it
possible to do most of the module loading in parallel.
However, that whole conversion totally missed the rather obscure code
that adds a new module to the list for BUG() handling. That code was
doubly obscure because (a) the code itself lives in lib/bugs.c (for
dubious reasons) and (b) it gets called from the architecture-specific
"module_finalize()" rather than from generic code.
Calling it from arch-specific code makes no sense what-so-ever to begin
with, and is now actively wrong since that code isn't protected by the
module loading lock any more.
So this commit moves the "module_bug_{finalize,cleanup}()" calls away
from the arch-specific code, and into the generic code - and in the
process protects it with the module_mutex so that the list operations
are now safe.
Future fixups:
- move the module list handling code into kernel/module.c where it
belongs.
- get rid of 'module_bug_list' and just use the regular list of modules
(called 'modules' - imagine that) that we already create and maintain
for other reasons.
Reported-and-tested-by: Thomas Gleixner <tglx@linutronix.de>
Cc: Adrian Bunk <bunk@kernel.org>
Cc: stable@kernel.org
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
Reviewed-by: Michal Marek <mmarek@suse.cz>
Make do_execve() take a const filename pointer so that kernel_execve() compiles
correctly on ARM:
arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type
This also requires the argv and envp arguments to be consted twice, once for
the pointer array and once for the strings the array points to. This is
because do_execve() passes a pointer to the filename (now const) to
copy_strings_kernel(). A simpler alternative would be to cast the filename
pointer in do_execve() when it's passed to copy_strings_kernel().
do_execve() may not change any of the strings it is passed as part of the argv
or envp lists as they are some of them in .rodata, so marking these strings as
const should be fine.
Further kernel_execve() and sys_execve() need to be changed to match.
This has been test built on x86_64, frv, arm and mips.
Tested-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Use the defconfig files generated by "make savedefconfig" for
remaining defconfig files.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Mark arguments to certain system calls as being const where they should be but
aren't. The list includes:
(*) The filename arguments of various stat syscalls, execve(), various utimes
syscalls and some mount syscalls.
(*) The filename arguments of some syscall helpers relating to the above.
(*) The buffer argument of various write syscalls.
Architectures implement dma_is_consistent() in different ways (some
misinterpret the definition of API in DMA-API.txt). So it hasn't been so
useful for drivers. We have only one user of the API in tree. Unlikely
out-of-tree drivers use the API.
Even if we fix dma_is_consistent() in some architectures, it doesn't look
useful at all. It was invented long ago for some old systems that can't
allocate coherent memory at all. It's better to export only APIs that are
definitely necessary for drivers.
Let's remove this API.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
dma_get_cache_alignment returns the minimum DMA alignment. Architectures
defines it as ARCH_DMA_MINALIGN (formally ARCH_KMALLOC_MINALIGN). So we
can unify dma_get_cache_alignment implementations.
Note that some architectures implement dma_get_cache_alignment wrongly.
dma_get_cache_alignment() should return the minimum DMA alignment. So
fully-coherent architectures should return 1. This patch also fixes this
issue.
Now each architecture has the own dma_get_cache_alignment implementation.
define it as ARCH_KMALLOC_MINALIGN (it's used to make sure that malloc'ed
buffer is DMA-safe; the buffer doesn't share a cache with the others). So
we can unify dma_get_cache_alignment implementations.
This patch:
dma_get_cache_alignment() needs to know if an architecture defines
ARCH_KMALLOC_MINALIGN or not (needs to know if architecture has DMA
alignment restriction). However, slab.h define ARCH_KMALLOC_MINALIGN if
architectures doesn't define it.
Let's rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGN.
ARCH_KMALLOC_MINALIGN is used only in the internals of slab/slob/slub
(except for crypto).
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits)
block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n
xen-blkfront: fix missing out label
blkdev: fix blkdev_issue_zeroout return value
block: update request stacking methods to support discards
block: fix missing export of blk_types.h
writeback: fix bad _bh spinlock nesting
drbd: revert "delay probes", feature is being re-implemented differently
drbd: Initialize all members of sync_conf to their defaults [Bugz 315]
drbd: Disable delay probes for the upcomming release
writeback: cleanup bdi_register
writeback: add new tracepoints
writeback: remove unnecessary init_timer call
writeback: optimize periodic bdi thread wakeups
writeback: prevent unnecessary bdi threads wakeups
writeback: move bdi threads exiting logic to the forker thread
writeback: restructure bdi forker loop a little
writeback: move last_active to bdi
writeback: do not remove bdi from bdi_list
writeback: simplify bdi code a little
writeback: do not lose wake-ups in bdi threads
Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and
drivers/scsi/scsi_error.c as per Jens.
This patch is against the 2.6.34 source.
Paraphrased from the 1989 BSD patch by David Borman @ cray.com:
These are the changes needed for the kernel to support
LINEMODE in the server.
There is a new bit in the termios local flag word, EXTPROC.
When this bit is set, several aspects of the terminal driver
are disabled. Input line editing, character echo, and mapping
of signals are all disabled. This allows the telnetd to turn
off these functions when in linemode, but still keep track of
what state the user wants the terminal to be in.
New ioctl:
TIOCSIG Generate a signal to processes in the
current process group of the pty.
There is a new mode for packet driver, the TIOCPKT_IOCTL bit.
When packet mode is turned on in the pty, and the EXTPROC bit
is set, then whenever the state of the pty is changed, the
next read on the master side of the pty will have the TIOCPKT_IOCTL
bit set. This allows the process on the server side of the pty
to know when the state of the terminal has changed; it can then
issue the appropriate ioctl to retrieve the new state.
Since the original BSD patches accompanied the source code for telnet
I've left that reference here, but obviously the feature is useful for
any remote terminal protocol, including ssh.
The corresponding feature has existed in the BSD tty driver since 1989.
For historical reference, a good copy of the relevant files can be found
here:
http://anonsvn.mit.edu/viewvc/krb5/trunk/src/appl/telnet/?pathrev=17741
Signed-off-by: Howard Chu <hyc@symas.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
As Jeff Dike pointed out, the Hayes ESP driver was removed in commit
f53a2ade0bb9f2a81f473e6469155172a96b7c38, so these ioctl definitions
should also be removed. This cleans up the remaining arch-specific
locations of this ioctl value.
Thanks to Arnd for pointing these out.
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Alan Cox <alan@linux.intel.com>
As explained in commit 1c0fe6e3bd ("mm: invoke oom-killer from page
fault") , we want to call the architecture independent oom killer when
getting an unexplained OOM from handle_mm_fault, rather than simply
killing current.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Acked-by: David Rientjes <rientjes@google.com>
Architectures don't need to define ISA_DMA_THRESHOLD anymore.
Acked-by: James Bottomley <James.Bottomley@suse.de>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
* 'timers-timekeeping-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
um: Fix read_persistent_clock fallout
kgdb: Do not access xtime directly
powerpc: Clean up obsolete code relating to decrementer and timebase
powerpc: Rework VDSO gettimeofday to prevent time going backwards
clocksource: Add __clocksource_updatefreq_hz/khz methods
x86: Convert common clocksources to use clocksource_register_hz/khz
timekeeping: Make xtime and wall_to_monotonic static
hrtimer: Cleanup direct access to wall_to_monotonic
um: Convert to use read_persistent_clock
timkeeping: Fix update_vsyscall to provide wall_to_monotonic offset
powerpc: Cleanup xtime usage
powerpc: Simplify update_vsyscall
time: Kill off CONFIG_GENERIC_TIME
time: Implement timespec_add
x86: Fix vtime/file timestamp inconsistencies
Trivial conflicts in Documentation/feature-removal-schedule.txt
Much less trivial conflicts in arch/powerpc/kernel/time.c resolved as
per Thomas' earlier merge commit 47916be4e28c ("Merge branch
'powerpc.cherry-picks' into timers/clocksource")
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits)
tracing/kprobes: unregister_trace_probe needs to be called under mutex
perf: expose event__process function
perf events: Fix mmap offset determination
perf, powerpc: fsl_emb: Restore setting perf_sample_data.period
perf, powerpc: Convert the FSL driver to use local64_t
perf tools: Don't keep unreferenced maps when unmaps are detected
perf session: Invalidate last_match when removing threads from rb_tree
perf session: Free the ref_reloc_sym memory at the right place
x86,mmiotrace: Add support for tracing STOS instruction
perf, sched migration: Librarize task states and event headers helpers
perf, sched migration: Librarize the GUI class
perf, sched migration: Make the GUI class client agnostic
perf, sched migration: Make it vertically scrollable
perf, sched migration: Parameterize cpu height and spacing
perf, sched migration: Fix key bindings
perf, sched migration: Ignore unhandled task states
perf, sched migration: Handle ignored migrate out events
perf: New migration tool overview
tracing: Drop cpparg() macro
perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call
Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
arch/powerpc/Makefile
It is now possible to assign options to AS, CC and LD
on the command line - which is only used when building modules.
{A,C,LD}FLAGS_MODULE was all used both in the top-level Makefile
in the arch makefiles, thus users had no way to specify
additional options to AS, CC, LD when building modules
without overriding the original value.
Introduce a new set of variables KBUILD_{A,C,LD}FLAGS_MODULE
that is used by arch specific files and free up
{A,C,LD}FLAGS_MODULE so they can be assigned on
the command line.
All arch Makefiles that used the old variables has been updated.
Note: Previously we had a MODFLAGS variable for both
AS and CC. But in favour of consistency this was dropped.
So in some cases arch Makefile has one assignmnet replaced by
two assignmnets.
Note2: MODFLAGS was not documented and is dropped
without any notice. I do not expect much/any breakage
from this.
Cc: Denys Vlasenko <vda.linux@googlemail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Chen Liqin <liqin.chen@sunplusct.com>
Acked-by: Mike Frysinger <vapier@gentoo.org> [blackfin]
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [avr32]
tools/perf/Makefile
tools/perf/util/hist.c
Merge reason: Resolve the conflicts and update to latest upstream.
Now that all arches have been converted over to use generic time via
clocksources or arch_gettimeoffset(), we can remove the GENERIC_TIME
config option and simplify the generic code.
LKML-Reference: <1279068988-21864-4-git-send-email-johnstul@us.ibm.com>
This patch fixes a build failure [1-4] in the atmel_serial code introduced by
patch the patch ARM: 6092/1: atmel_serial: support for RS485
communications (e8faff7330a3501eafc9bfe5f4f15af444be29f5)
The build failure was caused by missing struct field and missing defines
for the avr32 board - the patch fixes this.
[1] http://kisskb.ellerman.id.au/kisskb/buildresult/2575242/ - first failure in linux-next, may 11th
[2] http://kisskb.ellerman.id.au/kisskb/buildresult/2816418/ - still exists as of today
[3] http://kisskb.ellerman.id.au/kisskb/buildresult/2617511/ - first failure in Linus' tree - May 20th - did really no one notice this?!
[4] http://kisskb.ellerman.id.au/kisskb/buildresult/2813956/ - still exists in Linus' tree as of today
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
On 64bit, local_t is of size long, and thus we make local64_t an alias.
On 32bit, we fall back to atomic64_t. (architecture can provide optimized
32-bit version)
(This new facility is to be used by perf events optimizations.)
LKML-Reference: <new-submission>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits)
vlynq: make whole Kconfig-menu dependant on architecture
add descriptive comment for TIF_MEMDIE task flag declaration.
EEPROM: max6875: Header file cleanup
EEPROM: 93cx6: Header file cleanup
EEPROM: Header file cleanup
agp: use NULL instead of 0 when pointer is needed
rtc-v3020: make bitfield unsigned
PCI: make bitfield unsigned
jbd2: use NULL instead of 0 when pointer is needed
cciss: fix shadows sparse warning
doc: inode uses a mutex instead of a semaphore.
uml: i386: Avoid redefinition of NR_syscalls
fix "seperate" typos in comments
cocbalt_lcdfb: correct sections
doc: Change urls for sparse
Powerpc: wii: Fix typo in comment
i2o: cleanup some exit paths
Documentation/: it's -> its where appropriate
UML: Fix compiler warning due to missing task_struct declaration
UML: add kernel.h include to signal.c
