path: root/arch/avr32
2011-05-28Merge branch 'setns'Linus Torvalds
* setns: ns: Wire up the setns system call Done as a merge to make it easier to fix up conflicts in arm due to addition of sendmmsg system call
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-27Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (45 commits) ARM: 6945/1: Add unwinding support for division functions ARM: kill pmd_off() ARM: 6944/1: mm: allow ASID 0 to be allocated to tasks ARM: 6943/1: mm: use TTBR1 instead of reserved context ID ARM: 6942/1: mm: make TTBR1 always point to swapper_pg_dir on ARMv6/7 ARM: 6941/1: cache: ensure MVA is cacheline aligned in flush_kern_dcache_area ARM: add sendmmsg syscall ARM: 6863/1: allow hotplug on msm ARM: 6832/1: mmci: support for ST-Ericsson db8500v2 ARM: 6830/1: mach-ux500: force PrimeCell revisions ARM: 6829/1: amba: make hardcoded periphid override hardware ARM: 6828/1: mach-ux500: delete SSP PrimeCell ID ARM: 6827/1: mach-netx: delete hardcoded periphid ARM: 6940/1: fiq: Briefly document driver responsibilities for suspend/resume ARM: 6938/1: fiq: Refactor {get,set}_fiq_regs() for Thumb-2 ARM: 6914/1: sparsemem: fix highmem detection when using SPARSEMEM ARM: 6913/1: sparsemem: allow pfn_valid to be overridden when using SPARSEMEM at91: drop at572d940hf support at91rm9200: introduce at91rm9200_set_type to specficy cpu package at91: drop boot_params and PLAT_PHYS_OFFSET ...
2011-05-27Merge branches 'devel', 'devel-stable' and 'fixes' into for-linusRussell King
2011-05-26arch: add #define for each of optimized find bitopsAkinobu Mita
The style that we normally use in asm-generic is to test the macro itself for existence, so in asm-generic, do: #ifndef find_next_zero_bit_le extern unsigned long find_next_zero_bit_le(const void *addr, unsigned long size, unsigned long offset); #endif and in the architectures, write static inline unsigned long find_next_zero_bit_le(const void *addr, unsigned long size, unsigned long offset) #define find_next_zero_bit_le find_next_zero_bit_le This adds the #define for each of the optimized find bitops in the architectures. Suggested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25atmel_serial: keep the platform_device unchangedJean-Christophe PLAGNIOL-VILLARD
specify the port num via platform_data this will allow to match the clock with the plaform_dev staticaly Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Alan Cox <alan@linux.intel.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-11PM / AVR32: Use struct syscore_ops instead of sysdevs for PMRafael J. Wysocki
Convert some AVR32 architecture's code to using struct syscore_ops objects for power management instead of sysdev classes and sysdevs. This simplifies the code and reduces the kernel's memory footprint. It also is necessary for removing sysdevs from the kernel entirely in the future. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-04-13avr32: add ATAG_BOARDINFOAndreas Bießmann
The ATAG_BOARDINFO is intended to hand over the information bd->bi_board_number from u-boot to the kernel. This piece of information can be used to implement some kind of board identification while booting the kernel. Therefore it is placed in .initdata section and can be accessed via the new symbol board_number only while initializing the kernel. Signed-off-by: Andreas Bießmann <biessmann@corscience.de> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-04-13don't check platform_get_irq's return value against zeroUwe Kleine-König
platform_get_irq returns -ENXIO on failure, so !int_irq was probably always true. Better use (int)int_irq <= 0. Note that a return value of zero is still handled as error even though this could mean irq0. This is a followup to 305b3228f9ff4d59f49e6d34a7034d44ee8ce2f0 that changed the return value of platform_get_irq from 0 to -ENXIO on error. Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-04-13avr32: init cannot ignore signals sent by force_sig_info()Matt Fleming
We can delete the code that checks to see if we're sending an ignored signal to init because force_sig_info() already handles this case. force_sig_info() will kill init even if the signal handler is SIG_DFL and the scenario described in the comment where init might "generate the same exception over and over again" cannot occur (force_sig_info() clears SIGNAL_UNKILLABLE to ensure that init will die). Also, the use of is_global_init() is not correct in the multhreaded case, as Oleg Nesterov explains, "is_global_init() is not right in theory, /sbin/init can be multithreaded. And, this doesn't cover the sub-namespace inits... I'd suggest to check SIGNAL_UNKILLABLE, but looking closer I think you can simply remove this code." It seems this code was copied from arch/powerpc in March 2007 in commit 623b0355d5b1 "[AVR32] Clean up exception handling code" but the code was deleted from arch/powerpc in November 2009 in commit a0592d42fe3e "powerpc: kill the obsolete code under is_global_init()" So catch up with powerpc and delete the bogus code. Signed-off-by: Matt Fleming <matt.fleming@linux.intel.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-04-13avr32: fix deadlock when reading clock list in debugfsOle Henrik Jahren
When writing out /sys/kernel/debug/at32ap_clk, clock list lock is being held while clk_get() is called. clk_get() attempts to take the same lock, which results in deadlock. Introduce and call lock free version, __clk_get(), instead. Signed-off-by: Ole Henrik Jahren <olehenja@alumni.ntnu.no> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-04-13avr32: Fix .size directive for cpu_enter_idleBen Hutchings
gas used to accept (and ignore?) .size directives which referred to undefined symbols, as this does. In binutils 2.21 these are treated as errors. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-04-13avr32: At32ap: pio fix typo "))" on gpio_irq_unmask prototypeJean-Christophe PLAGNIOL-VILLARD
introduce in commit d75f1bfdbccb Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-04-13fix the wrong argument of the functions definitionWanlong Gao
The functions of eic_chip's memebers use the wrong argument . Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-03-30avr32: Fix missing irq namespace conversionThomas Gleixner
2011-03-30genirq: Remove the now obsolete config options and select statementsThomas Gleixner
2011-03-25Merge branch 'irq-cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (23 commits) genirq: Expand generic show_interrupts() gpio: Fold irq_set_chip/irq_set_handler to irq_set_chip_and_handler gpio: Cleanup genirq namespace arm: ep93xx: Add basic interrupt info arm/gpio: Remove three copies of broken and racy debug code xtensa: Use generic show_interrupts() xtensa: Convert genirq namespace xtensa: Use generic IRQ Kconfig and set GENERIC_HARDIRQS_NO_DEPRECATED xtensa: Convert s6000 gpio irq_chip to new functions xtensa: Convert main irq_chip to new functions um: Use generic show_interrupts() um: Convert genirq namespace m32r: Use generic show_interrupts() m32r: Convert genirq namespace h8300: Use generic show_interrupts() h8300: Convert genirq namespace avr32: Cleanup eic_set_irq_type() avr32: Use generic show_interrupts() avr: Cleanup genirq namespace avr32: Use generic IRQ config, enable GENERIC_HARDIRQS_NO_DEPRECATED ... Fix up trivial conflict in drivers/gpio/timbgpio.c
2011-03-24avr32: Cleanup eic_set_irq_type()Thomas Gleixner
No need to fiddle in irq_desc. The trigger mask can be written back into irq_data. Return IRQ_SET_MASK_OK_NOCOPY, so the generic code wont overwrite it again. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-03-24avr32: Use generic show_interrupts()Thomas Gleixner
2011-03-24avr: Cleanup genirq namespaceThomas Gleixner
Scripted conversion to new function names with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-03-24avr32: Use generic IRQ config, enable GENERIC_HARDIRQS_NO_DEPRECATEDThomas Gleixner
Use the generic Kconfig for interrupts and enable GENERIC_HARDIRQS_NO_DEPRECATED. All conversions done. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> LKML-Reference: <20110206163009.289833604@linutronix.de>
2011-03-24avr32: At32ap: Convert pop irq_chip to new functionsThomas Gleixner
Also replace the open coded handler call with the proper wrapper. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> LKML-Reference: <20110206163009.190112353@linutronix.de>
2011-03-24avr32: At32ap: Convert intc irq_chip to new functionsThomas Gleixner
Also replace the open coded handler call with the proper wrapper. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> LKML-Reference: <20110206163009.096308633@linutronix.de>
2011-03-24avr32: At32ap: Convert extint irq_chip to new functionsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> LKML-Reference: <20110206163008.996220791@linutronix.de>
2011-03-23bitops: remove minix bitops from asm/bitops.hAkinobu Mita
minix bit operations are only used by minix filesystem and useless by other modules. Because byte order of inode and block bitmaps is different on each architecture like below: m68k: big-endian 16bit indexed bitmaps h8300, microblaze, s390, sparc, m68knommu: big-endian 32 or 64bit indexed bitmaps m32r, mips, sh, xtensa: big-endian 32 or 64bit indexed bitmaps for big-endian mode little-endian bitmaps for little-endian mode Others: little-endian bitmaps In order to move minix bit operations from asm/bitops.h to architecture independent code in minix filesystem, this provides two config options. CONFIG_MINIX_FS_BIG_ENDIAN_16BIT_INDEXED is only selected by m68k. CONFIG_MINIX_FS_NATIVE_ENDIAN is selected by the architectures which use native byte order bitmaps (h8300, microblaze, s390, sparc, m68knommu, m32r, mips, sh, xtensa). The architectures which always use little-endian bitmaps do not select these options. Finally, we can remove minix bit operations from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Michal Simek <monstr@monstr.eu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove ext2 non-atomic bitops from asm/bitops.hAkinobu Mita
As the result of conversions, there are no users of ext2 non-atomic bit operations except for ext2 filesystem itself. Now we can put them into architecture independent code in ext2 filesystem, and remove from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: introduce little-endian bitops for most architecturesAkinobu Mita
Introduce little-endian bit operations to the big-endian architectures which do not have native little-endian bit operations and the little-endian architectures. (alpha, avr32, blackfin, cris, frv, h8300, ia64, m32r, mips, mn10300, parisc, sh, sparc, tile, x86, xtensa) These architectures can just include generic implementation (asm-generic/bitops/le.h). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23asm-generic: rename generic little-endian bitops functionsAkinobu Mita
As a preparation for providing little-endian bitops for all architectures, This renames generic implementation of little-endian bitops. (remove "generic_" prefix and postfix "_le") s/generic_find_next_le_bit/find_next_bit_le/ s/generic_find_next_zero_le_bit/find_next_zero_bit_le/ s/generic_find_first_zero_le_bit/find_first_zero_bit_le/ s/generic___test_and_set_le_bit/__test_and_set_bit_le/ s/generic___test_and_clear_le_bit/__test_and_clear_bit_le/ s/generic_test_le_bit/test_bit_le/ s/generic___set_le_bit/__set_bit_le/ s/generic___clear_le_bit/__clear_bit_le/ s/generic_test_and_set_le_bit/test_and_set_bit_le/ s/generic_test_and_clear_le_bit/test_and_clear_bit_le/ Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (66 commits) avr32: at32ap700x: fix typo in DMA master configuration dmaengine/dmatest: Pass timeout via module params dma: let IMX_DMA depend on IMX_HAVE_DMA_V1 instead of an explicit list of SoCs fsldma: make halt behave nicely on all supported controllers fsldma: reduce locking during descriptor cleanup fsldma: support async_tx dependencies and automatic unmapping fsldma: fix controller lockups fsldma: minor codingstyle and consistency fixes fsldma: improve link descriptor debugging fsldma: use channel name in printk output fsldma: move related helper functions near each other dmatest: fix automatic buffer unmap type drivers, pch_dma: Fix warning when CONFIG_PM=n. dmaengine/dw_dmac fix: use readl & writel instead of __raw_readl & __raw_writel avr32: at32ap700x: Specify DMA Flow Controller, Src and Dst msize dw_dmac: Setting Default Burst length for transfers as 16. dw_dmac: Allow src/dst msize & flow controller to be configured at runtime dw_dmac: Changing type of src_master and dest_master to u8. dw_dmac: Pass Channel Priority from platform_data dw_dmac: Pass Channel Allocation Order from platform_data ...
2011-03-22add the common dma_addr_t typedef to include/linux/types.hFUJITA Tomonori
All architectures can use the common dma_addr_t typedef now. We can remove the arch specific dma_addr_t. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Matt Turner <mattst88@gmail.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22avr32: at32ap700x: fix typo in DMA master configurationJamie Iles
Commit 4aa5f366431fe (avr32: at32ap700x: specify DMA src and dst masters) specified the masters for the ac97c playback device but incorrectly set them in the capture slave information rather than playback. Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reported-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Vinod Koul <vinod.koul@intel.com> [rebased on dmaengine for 2.6.39 (d42efe6b)] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-03-07avr32: at32ap700x: Specify DMA Flow Controller, Src and Dst msizeViresh Kumar
Now that the dw_dmac DMA driver supports configurable Flow Controller, source and destination burst or msize, we need to specify which ones to use. Msize or burst size was previously hardcoded to 1, Flow controller was DMA for both M2P & P2M transfers. Signed-off-by: Viresh Kumar <viresh.kumar@st.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2011-02-17mm: Fix out-of-date comments which refers non-existent functionsRyota Ozaki
do_file_page and do_no_page don't exist anymore, but some comments still refers them. The patch fixes them by replacing them with existing ones. Signed-off-by: Ryota Ozaki <ozaki.ryota@gmail.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-14Merge branch 'dw_dmac' into dmaengineDan Williams
2011-01-29avr32: at32ap700x: specify DMA src and dst mastersJamie Iles
Now that the dw_dmac DMA driver supports configurable source and destination masters we need to specify which ones to use. This was previously hardcoded to 0 and 1 respectively in the driver. Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2011-01-26avr32: add missing include causing undefined pgtable_page_* referencesHans-Christian Egtvedt
This patch adds the linux/mm.h header file to the AVR32 arch pgalloc.c implementation to fix the undefined reference to pgtable_page_ctor() and pgtable_page_dtor(). Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/egtvedt/avr32-2.6: avr32: update default configuration files for Atmel boards avr32: Convert to clocksource_register_hz avr32: make architecture sys_clone prototype match asm-generic prototype avr32: use syscall prototypes from asm-generic instead of arch avr32: disable kprobes for all default configurations avr32: boards: setup: use IS_ERR() instead of NULL check
2011-01-13avr32: update default configuration files for Atmel boardsHans-Christian Egtvedt
This patch adjusts some values to make the default configuration for Atmel boards more similar, and adds missing values to enable required functions. Also remove defined symbols for functions not in use. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-01-13avr32: Convert to clocksource_register_hzJohn Stultz
This converts the avr32 clocksource to use clocksource_register_hz. This is untested, so any assistance in testing would be appreciated! CC: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> CC: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <johnstul@us.ibm.com>
2011-01-13avr32: make architecture sys_clone prototype match asm-generic prototypeHans-Christian Egtvedt
This patch will fix the arguments to the architecture sys_clone() function to match the asm-generic/syscalls.h prototype. In the same go remove the architecture specific prototype for the same function. The sys_clone() function is only called from assembly, hence the argument types were not having any affect. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-01-13avr32: use syscall prototypes from asm-generic instead of archHans-Christian Egtvedt
This patch removes the redundant syscalls prototypes in the architecture specific syscalls.h header file. These were identical with the ones in asm-generic/syscalls.h. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reported-by: Peter Huewe <PeterHuewe@gmx.de> Reported-by: Sven Schnelle <svens@stackframe.org> Cc: stable <stable@kernel.org>
2011-01-13avr32: disable kprobes for all default configurationsHans-Christian Egtvedt
This patch will disable kprobes for all the default AVR32 board configurations. This works around a regression in kprobes which seems to be related to AVR32 is now lacking the struct kprobe_ctlblk. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2011-01-13avr32: boards: setup: use IS_ERR() instead of NULL checkVasiliy Kulikov
clk_get() returns ERR_PTR() on error, not NULL. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
2010-11-16suspend: constify platform_suspend_opsLionel Debroux
While at it, fix two checkpatch errors. Several non-const struct instances constified by this patch were added after the introduction of platform_suspend_ops in checkpatch.pl's list of "should be const" structs (79404849e90a41ea2109bd0e2f7c7164b0c4ce73). Patch against mainline. Inspired by hunks of the grsecurity patch, updated for newer kernels. Signed-off-by: Lionel Debroux <lionel_debroux@yahoo.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-28Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (38 commits) kbuild: convert `arch/tile' to the kconfig mainmenu upgrade README: cite nconfig Revert "kconfig: Temporarily disable dependency warnings" kconfig: Use PATH_MAX instead of 128 for path buffer sizes. kconfig: Fix realloc usage() kconfig: Propagate const kconfig: Don't go out from read config loop when you read new symbol kconfig: fix menuconfig on debian lenny kbuild: migrate all arch to the kconfig mainmenu upgrade kconfig: expand file names kconfig: use the file's name of sourced file kconfig: constify file name kconfig: don't emit warning upon rootmenu's prompt redefinition kconfig: replace KERNELVERSION usage by the mainmenu's prompt kconfig: delay gconf window initialization kconfig: expand by default the rootmenu's prompt kconfig: add a symbol string expansion helper kconfig: regen parser kconfig: implement the `mainmenu' directive kconfig: allow PACKAGE to be defined on the compiler's command-line ... Fix up trivial conflict in arch/mn10300/Kconfig
2010-10-27ptrace: cleanup arch_ptrace() on avr32Namhyung Kim
use new 'datap' variable type of void pointer in order to remove unnecessary castings. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27ptrace: change signature of arch_ptrace()Namhyung Kim
Fix up the arguments to arch_ptrace() to take account of the fact that @addr and @data are now unsigned long rather than long as of a preceding patch in this series. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: <linux-arch@vger.kernel.org> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: remove pte_*map_nested()Peter Zijlstra
Since we no longer need to provide KM_type, the whole pte_*map_nested() API is now redundant, remove it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
